for an srtm file. More...
#include <ossimGeneralRasterElevHandler.h>
Classes | |
| class | GeneralRasterInfo |
| ossimGeneralRasterElevHandler (const ossimFilename &file="") | |
| ossimGeneralRasterElevHandler (const ossimGeneralRasterElevHandler::GeneralRasterInfo &generalRasterInfo) | |
| ossimGeneralRasterElevHandler (const ossimGeneralRasterElevHandler &rhs) | |
| virtual | ~ossimGeneralRasterElevHandler () |
| destructor More... | |
| virtual double | getHeightAboveMSL (const ossimGpt &) |
| METHOD: getHeightAboveMSL Height access methods. More... | |
| virtual ossimIpt | getSizeOfElevCell () const |
| METHOD: getSizeOfElevCell Returns the number of post in the cell. More... | |
| virtual double | getPostValue (const ossimIpt &gridPt) const |
| METHOD: getPostValue Returns the value at a given grid point as a double. More... | |
| bool | open (const ossimFilename &file, bool memoryMapFlag=false) |
| Opens a stream to the srtm cell. More... | |
| virtual void | close () |
| Closes the stream to the file. More... | |
| ossimDrect | getBoundingRect () const |
| This method does not really fit the handler since this handle a directory not a cell that could have holes in it. More... | |
| virtual bool | pointHasCoverage (const ossimGpt &gpt) const |
| Loops through ossimGeneralRasterElevHandler::BoundingRectListType and checks for coverage. More... | |
| const ossimGeneralRasterElevHandler::GeneralRasterInfo & | generalRasterInfo () const |
Public Member Functions inherited from ossimElevCellHandler | |
| ossimElevCellHandler (const char *elev_filename) | |
| Constructors: More... | |
| ossimElevCellHandler (const ossimElevCellHandler &src) | |
| virtual double | getMeanSpacingMeters () const |
| METHOD: meanSpacingMeters() Implements pure virtual for. More... | |
| virtual bool | getAccuracyInfo (ossimElevationAccuracyInfo &info, const ossimGpt &gpt) const |
| METHODS: accuracyLE90(), accuracyCE90() Returns the vertical and horizontal accuracy (90% confidence): More... | |
Public Member Functions inherited from ossimElevSource | |
| virtual double | getHeightAboveEllipsoid (const ossimGpt &) |
| bool | intersectRay (const ossimEcefRay &ray, ossimGpt &gpt, double defaultElevValue=0.0) |
| METHOD: intersectRay() More... | |
| virtual double | getMinHeightAboveMSL () const |
| Access methods for the bounding elevations: More... | |
| virtual double | getMaxHeightAboveMSL () const |
| double | getNullHeightValue () const |
| Special numeric quantities as defined by this source: More... | |
| double | getSeaLevelValue () const |
| virtual const ossimGrect & | getBoundingGndRect () const |
| METHODS: accuracyLE90(), accuracyCE90() Returns the vertical and horizontal accuracy (90% confidence) in the region of gpt: More... | |
| Implement ossimSource base-class pure virtuals: More... | |
| virtual bool | getComputeStatisticsFlag () const |
| Opens a stream to an elevation cell. More... | |
| virtual void | setComputeStatisticsFlag (bool flag) |
| Sets the flag which controls whether or not statistics will be computed upon opening a cell and not finding a corresponding statistics file. More... | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
Private Member Functions | |
| template<class T > | |
| double | getHeightAboveMSLFileTemplate (T dummy, const ossimGeneralRasterElevHandler::GeneralRasterInfo &info, const ossimGpt &gpt) |
| double | getHeightAboveMSLMemoryTemplate (T dummy, const ossimGeneralRasterElevHandler::GeneralRasterInfo &info, const ossimGpt &gpt) |
| virtual bool | setFilename (const ossimFilename &file) |
Private Attributes | |
| ossimGeneralRasterElevHandler::GeneralRasterInfo | theGeneralRasterInfo |
| std::mutex | m_inputStreamMutex |
| std::ifstream | m_inputStream |
| bool | m_streamOpen |
| true if stream is open. More... | |
| std::vector< char > | m_memoryMap |
for an srtm file.
Definition at line 37 of file ossimGeneralRasterElevHandler.h.
| ossimGeneralRasterElevHandler::ossimGeneralRasterElevHandler | ( | const ossimFilename & | file = "" | ) |
Definition at line 18 of file ossimGeneralRasterElevHandler.cpp.
References open(), and ossimErrorStatusInterface::setErrorStatus().
| ossimGeneralRasterElevHandler::ossimGeneralRasterElevHandler | ( | const ossimGeneralRasterElevHandler::GeneralRasterInfo & | generalRasterInfo | ) |
Definition at line 36 of file ossimGeneralRasterElevHandler.cpp.
References close(), generalRasterInfo(), open(), ossimErrorCodes::OSSIM_ERROR, ossimErrorStatusInterface::theErrorStatus, ossimGeneralRasterElevHandler::GeneralRasterInfo::theFilename, and theGeneralRasterInfo.
| ossimGeneralRasterElevHandler::ossimGeneralRasterElevHandler | ( | const ossimGeneralRasterElevHandler & | rhs | ) |
Definition at line 28 of file ossimGeneralRasterElevHandler.cpp.
Reimplemented from ossimElevCellHandler.
Definition at line 245 of file ossimGeneralRasterElevHandler.cpp.
References m_inputStream, m_memoryMap, and m_streamOpen.
Referenced by open(), and ossimGeneralRasterElevHandler().
inlinevirtual |
Implements ossimElevSource.
Definition at line 90 of file ossimGeneralRasterElevHandler.h.
| const ossimGeneralRasterElevHandler::GeneralRasterInfo & ossimGeneralRasterElevHandler::generalRasterInfo | ( | ) | const |
Definition at line 721 of file ossimGeneralRasterElevHandler.cpp.
References theGeneralRasterInfo.
Referenced by ossimGeneralRasterElevHandler(), and ossimGeneralRasterElevFactory::setDirectory().
| ossimDrect ossimGeneralRasterElevHandler::getBoundingRect | ( | ) | const |
So users looking for valid coverage should call "pointHasCoverage".
Definition at line 700 of file ossimGeneralRasterElevHandler.cpp.
References theGeneralRasterInfo, and ossimGeneralRasterElevHandler::GeneralRasterInfo::theWgs84GroundRect.
Definition at line 52 of file ossimGeneralRasterElevHandler.cpp.
References getHeightAboveMSLFileTemplate(), getHeightAboveMSLMemoryTemplate(), m_memoryMap, OSSIM_FLOAT32, OSSIM_FLOAT64, OSSIM_SINT16, OSSIM_SINT32, OSSIM_SINT8, OSSIM_UINT16, OSSIM_UINT32, OSSIM_UINT8, theGeneralRasterInfo, ossimGeneralRasterElevHandler::GeneralRasterInfo::theNullHeightValue, and ossimGeneralRasterElevHandler::GeneralRasterInfo::theScalarType.
private |
Definition at line 427 of file ossimGeneralRasterElevHandler.cpp.
References ossimGpt::changeDatum(), ossimEndian::getSystemEndianType(), m_inputStream, m_inputStreamMutex, ossim::nan(), ossimDrect::pointWithin(), ossimEndian::swap(), ossimGeneralRasterElevHandler::GeneralRasterInfo::theByteOrder, ossimGeneralRasterElevHandler::GeneralRasterInfo::theBytesPerRawLine, ossimGeneralRasterElevHandler::GeneralRasterInfo::theDatum, ossimGeneralRasterElevHandler::GeneralRasterInfo::theGeometry, ossimGeneralRasterElevHandler::GeneralRasterInfo::theHeight, ossimGeneralRasterElevHandler::GeneralRasterInfo::theNullHeightValue, ossimGeneralRasterElevHandler::GeneralRasterInfo::theUl, ossimGeneralRasterElevHandler::GeneralRasterInfo::theWgs84GroundRect, ossimGeneralRasterElevHandler::GeneralRasterInfo::theWidth, ossimImageGeometry::worldToLocal(), ossimIpt::x, ossimDpt::x, ossimIpt::y, and ossimDpt::y.
Referenced by getHeightAboveMSL().
private |
Definition at line 558 of file ossimGeneralRasterElevHandler.cpp.
References ossimGpt::changeDatum(), ossimEndian::getSystemEndianType(), m_memoryMap, ossim::nan(), ossimDrect::pointWithin(), ossimEndian::swap(), ossimGeneralRasterElevHandler::GeneralRasterInfo::theByteOrder, ossimGeneralRasterElevHandler::GeneralRasterInfo::theBytesPerRawLine, ossimGeneralRasterElevHandler::GeneralRasterInfo::theDatum, ossimGeneralRasterElevHandler::GeneralRasterInfo::theGeometry, ossimGeneralRasterElevHandler::GeneralRasterInfo::theHeight, ossimGeneralRasterElevHandler::GeneralRasterInfo::theNullHeightValue, ossimGeneralRasterElevHandler::GeneralRasterInfo::theUl, ossimGeneralRasterElevHandler::GeneralRasterInfo::theWgs84GroundRect, ossimGeneralRasterElevHandler::GeneralRasterInfo::theWidth, ossimImageGeometry::worldToLocal(), ossimIpt::x, ossimDpt::x, ossimIpt::y, and ossimDpt::y.
Satisfies pure virtual.
Implements ossimElevCellHandler.
Definition at line 198 of file ossimGeneralRasterElevHandler.cpp.
References ossim::nan(), ossimNotify(), and ossimNotifyLevel_WARN.
Satisfies pure virtual. Note: x = longitude, y = latitude
Definition at line 193 of file ossimGeneralRasterElevHandler.cpp.
References theGeneralRasterInfo, ossimGeneralRasterElevHandler::GeneralRasterInfo::theHeight, and ossimGeneralRasterElevHandler::GeneralRasterInfo::theWidth.
Definition at line 205 of file ossimGeneralRasterElevHandler.cpp.
References m_inputStreamMutex, m_memoryMap, and m_streamOpen.
Definition at line 216 of file ossimGeneralRasterElevHandler.cpp.
References ossimString::c_str(), close(), ossimFilename::fileSize(), m_inputStream, m_memoryMap, m_streamOpen, setFilename(), ossimGeneralRasterElevHandler::GeneralRasterInfo::theFilename, and theGeneralRasterInfo.
Referenced by ossimGeneralRasterElevationDatabase::openGeneralRasterDirectory(), ossimGeneralRasterElevHandler(), and ossimGeneralRasterElevFactory::setDirectory().
| gpt | Point to look for. |
Definition at line 705 of file ossimGeneralRasterElevHandler.cpp.
References ossimDrect::pointWithin(), theGeneralRasterInfo, and ossimGeneralRasterElevHandler::GeneralRasterInfo::theWgs84GroundRect.
Referenced by ossimGeneralRasterElevationDatabase::pointHasCoverage().
privatevirtual |
Definition at line 252 of file ossimGeneralRasterElevHandler.cpp.
References ossimKeywordlist::add(), ossimKeywordlist::addFile(), ossimGeneralRasterInfo::bytesPerRawLine(), ossimString::c_str(), ossimGpt::changeDatum(), ossimKeywordlist::clear(), ossimGpt::datum(), ossimFilename::exists(), ossimKeywordNames::FILENAME_KW, ossimKeywordlist::find(), ossimErrorStatusInterface::getErrorStatus(), ossimGeneralRasterInfo::getImageDataByteOrder(), ossimGeneralRasterInfo::getImageMetaData(), ossimImageGeometry::getMetersPerPixel(), ossimImageMetaData::getNullPix(), ossimImageMetaData::getScalarType(), ossimIrect::height(), ossimGeneralRasterInfo::imageRect(), ossimIrect::ll(), ossimGeneralRasterInfo::loadState(), ossimImageGeometry::loadState(), ossimImageGeometry::localToWorld(), ossimIrect::lr(), ossim::nan(), ossimGeneralRasterInfo::numberOfBands(), ossimErrorCodes::OSSIM_ERROR, OSSIM_RIGHT_HANDED, ossimNotify(), ossimNotifyLevel_WARN, ossimFilename::setExtension(), ossimGeneralRasterElevHandler::GeneralRasterInfo::theByteOrder, ossimGeneralRasterElevHandler::GeneralRasterInfo::theBytesPerRawLine, ossimGeneralRasterElevHandler::GeneralRasterInfo::theDatum, ossimGeneralRasterElevHandler::GeneralRasterInfo::theFilename, ossimElevCellHandler::theFilename, theGeneralRasterInfo, ossimGeneralRasterElevHandler::GeneralRasterInfo::theGeometry, ossimElevSource::theGroundRect, ossimGeneralRasterElevHandler::GeneralRasterInfo::theHeight, ossimGeneralRasterElevHandler::GeneralRasterInfo::theImageRect, ossimGeneralRasterElevHandler::GeneralRasterInfo::theLr, ossimElevCellHandler::theMeanSpacing, ossimGeneralRasterElevHandler::GeneralRasterInfo::theNullHeightValue, ossimElevSource::theNullHeightValue, ossimGeneralRasterElevHandler::GeneralRasterInfo::theScalarType, ossimGeneralRasterElevHandler::GeneralRasterInfo::theUl, ossimGeneralRasterElevHandler::GeneralRasterInfo::theWgs84GroundRect, ossimGeneralRasterElevHandler::GeneralRasterInfo::theWidth, ossimString::trim(), ossimIrect::ul(), ossimIrect::ur(), ossimRefPtr< T >::valid(), ossimIrect::width(), and ossimDpt::y.
Referenced by open().
private |
Definition at line 160 of file ossimGeneralRasterElevHandler.h.
Referenced by close(), getHeightAboveMSLFileTemplate(), and open().
mutableprivate |
Definition at line 159 of file ossimGeneralRasterElevHandler.h.
Referenced by getHeightAboveMSLFileTemplate(), and isOpen().
private |
Definition at line 165 of file ossimGeneralRasterElevHandler.h.
Referenced by close(), getHeightAboveMSL(), getHeightAboveMSLMemoryTemplate(), isOpen(), and open().
private |
Definition at line 163 of file ossimGeneralRasterElevHandler.h.
private |
Definition at line 158 of file ossimGeneralRasterElevHandler.h.
Referenced by generalRasterInfo(), getBoundingRect(), getHeightAboveMSL(), getSizeOfElevCell(), open(), ossimGeneralRasterElevHandler(), pointHasCoverage(), and setFilename().
