Elevation source used for working with generic images opened by an ossimImageHandler. More...
#include <ossimTiledElevationDatabase.h>
Classes | |
| struct | ossimTiledElevationEntry |
| ossimTiledElevationDatabase () | |
| virtual bool | open (const ossimString &connectionString) |
| Open a connection to a database. More... | |
| virtual void | close () |
| close method. More... | |
| void | mapRegion (const ossimGrect ®ion) |
| Maps elevation data for region to a grid. More... | |
| virtual double | getHeightAboveMSL (const ossimGpt &gpt) |
| Get height above MSL for point. More... | |
| virtual double | getHeightAboveEllipsoid (const ossimGpt &) |
| Get height above ellipsoid for point. More... | |
| virtual bool | pointHasCoverage (const ossimGpt &gpt) const |
| Satisfies pure virtual ossimElevSource::pointHasCoverage. More... | |
| Initialize from keyword list. More... | |
| Save the state to a keyword list. More... | |
| bool | getAccuracyInfo (ossimElevationAccuracyInfo &info, const ossimGpt &) const |
| virtual void | processFile (const ossimFilename &file) |
| ProcessFile method. More... | |
Public Member Functions inherited from ossimElevationDatabase | |
| ossimElevationDatabase () | |
| ossimElevationDatabase (const ossimElevationDatabase &src) | |
| virtual double | getMeanSpacingMeters () const |
| METHOD: meanSpacingMeters() This method returns the post spacing in the region of gpt: More... | |
| virtual void | setGeoid (ossimGeoid *geoid) |
| ossimGeoid * | getGeoid () |
| const ossimGeoid * | getGeoid () const |
| const ossimString & | getConnectionString () const |
Public Member Functions inherited from ossimElevSource | |
| bool | intersectRay (const ossimEcefRay &ray, ossimGpt &gpt, double defaultElevValue=0.0) |
| METHOD: intersectRay() More... | |
| virtual double | getMinHeightAboveMSL () const |
| Access methods for the bounding elevations: More... | |
| virtual double | getMaxHeightAboveMSL () const |
| double | getNullHeightValue () const |
| Special numeric quantities as defined by this source: More... | |
| double | getSeaLevelValue () const |
| virtual const ossimGrect & | getBoundingGndRect () const |
| METHODS: accuracyLE90(), accuracyCE90() Returns the vertical and horizontal accuracy (90% confidence) in the region of gpt: More... | |
| virtual bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
| Implement ossimSource base-class pure virtuals: More... | |
| virtual bool | getComputeStatisticsFlag () const |
| Opens a stream to an elevation cell. More... | |
| virtual void | setComputeStatisticsFlag (bool flag) |
| Sets the flag which controls whether or not statistics will be computed upon opening a cell and not finding a corresponding statistics file. More... | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
Public Member Functions inherited from ossimFileProcessorInterface | |
| ossimFileProcessorInterface () | |
| virtual | ~ossimFileProcessorInterface () |
| virtual destructor. More... | |
| virtual | ~ossimTiledElevationDatabase () |
| Protected destructor as this is derived from ossimRefenced. More... | |
Protected Member Functions inherited from ossimElevationDatabase | |
| virtual | ~ossimElevationDatabase () |
| virtual double | getOffsetFromEllipsoid (const ossimGpt &gpt) |
Protected Member Functions inherited from ossimElevSource | |
| virtual | ~ossimElevSource () |
| ossimElevSource () | |
| Constructors/Destructors: More... | |
| ossimElevSource (const ossimElevSource &src) | |
Private Member Functions | |
| void | addEntry (const ossimTiledElevationEntry &entry) |
| adds entry to the list checking for duplicates. More... | |
| void | initializeReferenceProjection () |
| Initializes m_referenceProj from the first entry. More... | |
| bool | isDirectoryBasedImage (ossimRefPtr< ossimImageHandler > ih) |
| bool | isCompatible (ossimImageHandler *ih, ossimImageGeometry *geom, ossimProjection *proj) const |
| Check for match of the following against the first entry of: bands, projection, scalar type and scale. More... | |
| void | getBoundingRect (ossimRefPtr< ossimImageGeometry > geom, ossimGrect &boundingRect) const |
| Initialize bounding rectangle from image handler. More... | |
| void | mapRegion () |
| Loads m_requestedRect into m_grid from m_entries. More... | |
| template<class T > | |
| void | fillGrid (T dummyTemplate, ossimRefPtr< ossimImageData > data) |
| Templated fill grid method. More... | |
| ossimTiledElevationDatabase (const ossimTiledElevationDatabase ©_this) | |
| Hidden from use copy constructor. More... | |
Private Attributes | |
| std::vector< ossimTiledElevationEntry > | m_entries |
| ossimDblGrid * | m_grid |
| Hold region of elevation. More... | |
| ossimRefPtr< ossimProjection > | m_referenceProj |
| Projection of the first entry. More... | |
| ossimGrect | m_requestedRect |
| ossimGrect | m_entryListRect |
| ossimGrect | m_mappedRect |
| ossimFileWalker * | m_fileWalker |
This class is typically utilized through the ossimElevManager.
This class supplies a mapRegion method used to map a region of elevation to a grid. The grid in turn is used for the getHeightAboveMSL. This class is for applications that know their region of interest up front and want to bypass the ossimElevManager and grid the elevation prior to processing for speed. Can work on a file or a directory of files.
Definition at line 47 of file ossimTiledElevationDatabase.h.
| ossimTiledElevationDatabase::ossimTiledElevationDatabase | ( | ) |
default constructor
Definition at line 38 of file ossimTiledElevationDatabase.cpp.
References m_entryListRect, m_requestedRect, ossimGrect::makeNan(), and ossimElevSource::theGroundRect.
protectedvirtual |
Definition at line 60 of file ossimTiledElevationDatabase.cpp.
References m_entries, m_fileWalker, m_grid, and m_referenceProj.
private |
Definition at line 634 of file ossimTiledElevationDatabase.cpp.
private |
Definition at line 297 of file ossimTiledElevationDatabase.cpp.
References ossimSingleImageChain::getFilename(), m_entries, and ossimTiledElevationDatabase::ossimTiledElevationEntry::m_sic.
close method.
Unreferences all data.
Definition at line 106 of file ossimTiledElevationDatabase.cpp.
References ossimString::clear(), ossimElevationDatabase::m_connectionString, m_entries, m_entryListRect, ossimElevationDatabase::m_geoid, m_grid, ossimElevationDatabase::m_meanSpacing, m_referenceProj, m_requestedRect, ossimGrect::makeNan(), and ossimElevSource::theGroundRect.
inlinevirtual |
Implements ossimElevSource.
Definition at line 131 of file ossimTiledElevationDatabase.h.
References open().
private |
Definition at line 606 of file ossimTiledElevationDatabase.cpp.
References ossimImageData::getBuf(), ossimImageData::getHeight(), ossimImageData::getNullPix(), ossimImageData::getWidth(), m_grid, ossim::nan(), ossimDblGrid::setNode(), ossimRefPtr< T >::valid(), x, and y.
inlinevirtual |
Reimplemented from ossimElevationDatabase.
Definition at line 108 of file ossimTiledElevationDatabase.h.
References ossimElevationAccuracyInfo::makeNan().
private |
Sets boundingRect to nan if ossimImageGeometry::getCornerGpts returns false.
| ih | Image handler. |
| boundingRect | Initialized by method. |
Definition at line 466 of file ossimTiledElevationDatabase.cpp.
References ossimImageGeometry::getCornerGpts(), ossimGpt::lat, ossimGpt::lon, ossimGrect::makeNan(), and ossimRefPtr< T >::valid().
Satisfies pure virtual ossimElevSource::getHeightAboveMSL().
Reimplemented from ossimElevSource.
Definition at line 342 of file ossimTiledElevationDatabase.cpp.
References getHeightAboveMSL(), ossimElevationDatabase::getOffsetFromEllipsoid(), and ossim::nan().
Definition at line 333 of file ossimTiledElevationDatabase.cpp.
References ossimGpt::lat, ossimGpt::lon, m_grid, and ossim::nan().
Referenced by getHeightAboveEllipsoid().
private |
Definition at line 316 of file ossimTiledElevationDatabase.cpp.
References ossimImageHandler::getImageGeometry(), ossimImageGeometry::getProjection(), m_entries, m_referenceProj, and ossimRefPtr< T >::valid().
private |
Definition at line 410 of file ossimTiledElevationDatabase.cpp.
References ossimRefPtr< T >::get(), ossimMapProjection::getDecimalDegreesPerPixel(), ossimProjection::getMetersPerPixel(), ossimMapProjection::getMetersPerPixel(), ossimImageSource::getNumberOfOutputBands(), ossimImageSource::getOutputScalarType(), ossimMapProjection::isGeographic(), m_entries, m_referenceProj, and ossimRefPtr< T >::valid().
private |
Definition at line 394 of file ossimTiledElevationDatabase.cpp.
References ossimObject::getClassName(), and ossimRefPtr< T >::valid().
Definition at line 361 of file ossimTiledElevationDatabase.cpp.
| void ossimTiledElevationDatabase::mapRegion | ( | const ossimGrect & | region | ) |
This uses connectionString passed to open method as starting point.
Definition at line 123 of file ossimTiledElevationDatabase.cpp.
private |
Definition at line 491 of file ossimTiledElevationDatabase.cpp.
References ossimConnectableObject::connectMyInputTo(), ossimImageData::getHeight(), ossimOrthoImageMosaic::getImageGeometry(), ossimImageMosaic::getTile(), ossimImageData::getWidth(), ossimDblGrid::initialize(), ossimGrect::isLonLatNan(), ossimGpt::lat, ossimImageGeometry::localToWorld(), ossimGpt::lon, ossimGrect::lr(), m_entries, m_grid, m_requestedRect, ossim::nan(), ossimElevSource::theGroundRect, ossimGrect::ul(), ossimRefPtr< T >::valid(), ossimImageGeometry::worldToLocal(), ossimDpt::x, and ossimDpt::y.
| connectionString | File or directory to open. In most cases this will point to a directory containing DEMs. Satisfies pure virtual ossimElevationDatabase::open(). |
Implements ossimElevationDatabase.
Definition at line 76 of file ossimTiledElevationDatabase.cpp.
Referenced by dup().
Definition at line 352 of file ossimTiledElevationDatabase.cpp.
References ossimGrect::isLonLatNan(), ossimGrect::pointWithin(), and ossimElevSource::theGroundRect.
Definition at line 651 of file ossimTiledElevationDatabase.cpp.
References saveState().
ProcessFile method.
Satisfies pure virtual ossimFileProcessorInterface::processFile.
This method is linked to the ossimFileWalker::walk method via a callback mechanism. It is called by the ossimFileWalk (caller). This class (callee) sets recurse and return flags accordingly to control the ossimFileWalker, e.g. don't recurse, stop altogether.
| file | to process. |
Implements ossimFileProcessorInterface.
Definition at line 189 of file ossimTiledElevationDatabase.cpp.
Definition at line 388 of file ossimTiledElevationDatabase.cpp.
References ossimElevationDatabase::saveState().
Referenced by print().
private |
Definition at line 205 of file ossimTiledElevationDatabase.h.
Referenced by addEntry(), close(), initializeReferenceProjection(), isCompatible(), mapRegion(), and ~ossimTiledElevationDatabase().
private |
Definition at line 214 of file ossimTiledElevationDatabase.h.
Referenced by close(), and ossimTiledElevationDatabase().
private |
Definition at line 217 of file ossimTiledElevationDatabase.h.
Referenced by ~ossimTiledElevationDatabase().
private |
Definition at line 208 of file ossimTiledElevationDatabase.h.
Referenced by close(), fillGrid(), getHeightAboveMSL(), mapRegion(), and ~ossimTiledElevationDatabase().
private |
Definition at line 215 of file ossimTiledElevationDatabase.h.
private |
Stored for convenience.
Definition at line 211 of file ossimTiledElevationDatabase.h.
Referenced by close(), initializeReferenceProjection(), isCompatible(), and ~ossimTiledElevationDatabase().
private |
Definition at line 213 of file ossimTiledElevationDatabase.h.
Referenced by close(), mapRegion(), and ossimTiledElevationDatabase().
