Elevation source for a generic image opened via ossimImageHandler. More...
#include <ossimImageElevationHandler.h>
Classes | |
| class | TileCacheEntry |
| ossimImageElevationHandler () | |
| ossimImageElevationHandler (const ossimFilename &file) | |
| virtual double | getHeightAboveMSL (const ossimGpt &) |
| METHOD: getHeightAboveMSL Height access methods. More... | |
| virtual ossimIpt | getSizeOfElevCell () const |
| METHOD: getSizeOfElevCell Returns the number of post in the cell. More... | |
| virtual double | getPostValue (const ossimIpt &gridPt) const |
| METHOD: getPostValue Returns the value at a given grid point as a double. More... | |
| virtual bool | open (const ossimFilename &file) |
| Opens a stream to the srtm cell. More... | |
| virtual void | close () |
| Closes the stream to the file. More... | |
| virtual bool | pointHasCoverage (const ossimGpt &) const |
| pointHasCoverage(gpt) More... | |
Public Member Functions inherited from ossimElevCellHandler | |
| ossimElevCellHandler (const char *elev_filename) | |
| Constructors: More... | |
| ossimElevCellHandler (const ossimElevCellHandler &src) | |
| virtual double | getMeanSpacingMeters () const |
| METHOD: meanSpacingMeters() Implements pure virtual for. More... | |
| virtual bool | getAccuracyInfo (ossimElevationAccuracyInfo &info, const ossimGpt &gpt) const |
| METHODS: accuracyLE90(), accuracyCE90() Returns the vertical and horizontal accuracy (90% confidence): More... | |
| virtual bool | open (const ossimFilename &, bool=false) |
Public Member Functions inherited from ossimElevSource | |
| virtual double | getHeightAboveEllipsoid (const ossimGpt &) |
| bool | intersectRay (const ossimEcefRay &ray, ossimGpt &gpt, double defaultElevValue=0.0) |
| METHOD: intersectRay() More... | |
| virtual double | getMinHeightAboveMSL () const |
| Access methods for the bounding elevations: More... | |
| virtual double | getMaxHeightAboveMSL () const |
| double | getNullHeightValue () const |
| Special numeric quantities as defined by this source: More... | |
| double | getSeaLevelValue () const |
| virtual const ossimGrect & | getBoundingGndRect () const |
| METHODS: accuracyLE90(), accuracyCE90() Returns the vertical and horizontal accuracy (90% confidence) in the region of gpt: More... | |
| Implement ossimSource base-class pure virtuals: More... | |
| virtual bool | getComputeStatisticsFlag () const |
| Opens a stream to an elevation cell. More... | |
| virtual void | setComputeStatisticsFlag (bool flag) |
| Sets the flag which controls whether or not statistics will be computed upon opening a cell and not finding a corresponding statistics file. More... | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| virtual | ~ossimImageElevationHandler () |
| Protected destructor. More... | |
Protected Member Functions inherited from ossimElevCellHandler | |
| ossimElevCellHandler () | |
| virtual | ~ossimElevCellHandler () |
Protected Member Functions inherited from ossimElevSource | |
| virtual | ~ossimElevSource () |
| ossimElevSource () | |
| Constructors/Destructors: More... | |
| ossimElevSource (const ossimElevSource &src) | |
Private Member Functions | |
| ossimImageElevationHandler (const ossimImageElevationHandler &) | |
| Hidden from use copy constructor. More... | |
| const ossimImageElevationHandler & | operator= (const ossimImageElevationHandler &rhs) |
| Hidden from use assignment operator. More... | |
| ossimImageData * | getTile (ossim_uint32 x, ossim_uint32 y) const |
| Looks for an elevation tile in the cache first before reading the tile from the input handler. More... | |
Private Attributes | |
| ossimRefPtr< ossimImageHandler > | m_ih |
| Pointers to links in chain. More... | |
| ossimRefPtr< ossimImageGeometry > | m_geom |
| std::vector< TileCacheEntry > | m_tileCache |
| ossimDrect | m_rect |
| Image space rect stored as drect for inlined pointHasCoverage method. More... | |
| ossimIpt | m_tileSize |
| ossim_uint32 | m_numTilesPerRow |
| std::mutex | m_mutex |
Definition at line 32 of file ossimImageElevationHandler.h.
| ossimImageElevationHandler::ossimImageElevationHandler | ( | ) |
default constructor
Definition at line 36 of file ossimImageElevationHandler.cpp.
References ossim::defaultTileSize(), and m_tileSize.
| ossimImageElevationHandler::ossimImageElevationHandler | ( | const ossimFilename & | file | ) |
Definition at line 47 of file ossimImageElevationHandler.cpp.
References ossim::defaultTileSize(), m_tileSize, and open().
protectedvirtual |
This class is derived from ossimReferenced so users should always use ossimRefPtr<ossimImageElevationHandler> to hold instance.
Definition at line 131 of file ossimImageElevationHandler.cpp.
References close().
private |
Definition at line 282 of file ossimImageElevationHandler.cpp.
inlinevirtual |
Reimplemented from ossimElevCellHandler.
Definition at line 137 of file ossimImageElevationHandler.h.
Referenced by open(), and ~ossimImageElevationHandler().
inlinevirtual |
Implements ossimElevSource.
Definition at line 81 of file ossimImageElevationHandler.h.
References ossimElevCellHandler::getFilename().
Definition at line 136 of file ossimImageElevationHandler.cpp.
References ossimImageData::getImageRectangle(), ossimImageData::getNullPix(), ossimImageData::getPix(), getTile(), ossimIrect::lr(), m_geom, m_rect, ossim::nan(), ossimDrect::pointWithin(), ossimImageGeometry::worldToLocal(), ossimIpt::x, ossimDpt::x, ossimIpt::y, and ossimDpt::y.
Satisfies pure virtual.
Implements ossimElevCellHandler.
Definition at line 266 of file ossimImageElevationHandler.cpp.
References ossimImageData::getNullPix(), ossimImageData::getPix(), getTile(), m_rect, ossim::nan(), ossimDrect::pointWithin(), ossimRefPtr< T >::valid(), ossimIpt::x, and ossimIpt::y.
Satisfies pure virtual. Note: x = longitude, y = latitude
Definition at line 255 of file ossimImageElevationHandler.cpp.
References ossimImageHandler::getNumberOfLines(), ossimImageHandler::getNumberOfSamples(), m_ih, ossimRefPtr< T >::valid(), ossimIpt::x, and ossimIpt::y.
private |
Definition at line 206 of file ossimImageElevationHandler.cpp.
References ossimImageData::assign(), ossimImageData::dup(), ossimRefPtr< T >::get(), ossimImageSource::getTile(), m_ih, m_mutex, m_numTilesPerRow, m_tileCache, m_tileSize, ossimRefPtr< T >::valid(), ossimIpt::x, x, ossimIpt::y, and y.
Referenced by getHeightAboveMSL(), and getPostValue().
inlinevirtual |
Definition at line 132 of file ossimImageElevationHandler.h.
References m_ih, and ossimRefPtr< T >::valid().
Referenced by ossimImageElevationDatabase::createCell(), and open().
Definition at line 59 of file ossimImageElevationHandler.cpp.
References close(), ossimImageGeometry::getCornerGpts(), ossimImageHandler::getImageGeometry(), ossimImageGeometry::getMetersPerPixel(), ossimImageHandler::getNumberOfLines(), ossimImageHandler::getNumberOfSamples(), ossimImageHandlerRegistry::instance(), isOpen(), ossimGpt::lat, ossimGpt::lon, m_geom, m_ih, m_numTilesPerRow, m_rect, m_tileSize, ossimGrect::makeNan(), ossimImageHandlerRegistry::open(), ossimString::size(), ossimElevCellHandler::theFilename, ossimElevSource::theGroundRect, ossimElevCellHandler::theMeanSpacing, ossimRefPtr< T >::valid(), ossimDrect::width(), ossimIpt::x, ossimDpt::x, and ossimDpt::y.
Referenced by ossimImageElevationDatabase::createCell(), ossimImageElevationDatabase::getBoundingRect(), operator=(), and ossimImageElevationHandler().
private |
Definition at line 288 of file ossimImageElevationHandler.cpp.
References open(), and ossimElevCellHandler::theFilename.
inlinevirtual |
Overrides ossimElevCellHandler::pointHasCoverage
Definition at line 143 of file ossimImageElevationHandler.h.
References m_geom, m_rect, ossimDrect::pointWithin(), ossimRefPtr< T >::valid(), and ossimImageGeometry::worldToLocal().
Referenced by ossimImageElevationDatabase::createCell().
private |
Definition at line 119 of file ossimImageElevationHandler.h.
Referenced by close(), getHeightAboveMSL(), open(), and pointHasCoverage().
mutableprivate |
Definition at line 118 of file ossimImageElevationHandler.h.
Referenced by close(), getSizeOfElevCell(), getTile(), isOpen(), and open().
mutableprivate |
Definition at line 127 of file ossimImageElevationHandler.h.
Referenced by getTile().
private |
Definition at line 125 of file ossimImageElevationHandler.h.
private |
Definition at line 123 of file ossimImageElevationHandler.h.
Referenced by getHeightAboveMSL(), getPostValue(), open(), and pointHasCoverage().
mutableprivate |
Definition at line 120 of file ossimImageElevationHandler.h.
private |
Definition at line 124 of file ossimImageElevationHandler.h.
Referenced by getTile(), open(), and ossimImageElevationHandler().
