the DTED handler is an elevation source that allows for handling of a single cell of data. More...
#include <ossimDtedHandler.h>
Classes | |
| class | DtedHeight |
| DtedHeight is a class for storing DTED information. More... | |
| class | DtedPost |
| DtedPost, this class contains the height, weighting factor and status. More... | |
Public Types | |
| enum | { DATA_RECORD_OFFSET_TO_POST = 8, DATA_RECORD_CHECKSUM_SIZE = 4, POST_SIZE = 2, NULL_POST = -32767 } |
| ossimDtedHandler () | |
| Constructor. More... | |
| ossimDtedHandler (const ossimFilename &dted_file, bool memoryMapFlag=false) | |
| virtual bool | open (const ossimFilename &file, bool memoryMapFlag=false) |
| opens a cell More... | |
| virtual bool | open (std::shared_ptr< ossim::istream > &fileStr, const std::string &connectionString, bool memoryMapFlag=false) |
| opens a cell given a stream More... | |
| virtual void | close () |
| virtual double | getHeightAboveMSL (const ossimGpt &gpt) |
| virtual ossimIpt | getSizeOfElevCell () const |
| virtual double | getPostValue (const ossimIpt &gridPt) const |
| ossimString | edition () const |
| ossimString | productLevel () const |
| ossimString | compilationDate () const |
| virtual bool | getAccuracyInfo (ossimElevationAccuracyInfo &info, const ossimGpt &gpt) const |
| const ossimDtedVol & | vol () const |
| const ossimDtedHdr & | hdr () const |
| const ossimDtedUhl & | uhl () const |
| const ossimDtedDsi & | dsi () const |
| const ossimDtedAcc & | acc () const |
| virtual | ~ossimDtedHandler () |
Public Member Functions inherited from ossimElevCellHandler | |
| ossimElevCellHandler (const char *elev_filename) | |
| Constructors: More... | |
| ossimElevCellHandler (const ossimElevCellHandler &src) | |
| virtual double | getMeanSpacingMeters () const |
| METHOD: meanSpacingMeters() Implements pure virtual for. More... | |
| virtual bool | pointHasCoverage (const ossimGpt &) const |
| METHOD: pointIsInsideRect() Method to check if the ground point elevation is defined: More... | |
| METHODS: accuracyLE90(), accuracyCE90() Returns the vertical and horizontal accuracy (90% confidence): More... | |
Public Member Functions inherited from ossimElevSource | |
| virtual double | getHeightAboveEllipsoid (const ossimGpt &) |
| bool | intersectRay (const ossimEcefRay &ray, ossimGpt &gpt, double defaultElevValue=0.0) |
| METHOD: intersectRay() More... | |
| virtual double | getMinHeightAboveMSL () const |
| Access methods for the bounding elevations: More... | |
| virtual double | getMaxHeightAboveMSL () const |
| double | getNullHeightValue () const |
| Special numeric quantities as defined by this source: More... | |
| double | getSeaLevelValue () const |
| virtual const ossimGrect & | getBoundingGndRect () const |
| METHODS: accuracyLE90(), accuracyCE90() Returns the vertical and horizontal accuracy (90% confidence) in the region of gpt: More... | |
| Implement ossimSource base-class pure virtuals: More... | |
| virtual bool | getComputeStatisticsFlag () const |
| Opens a stream to an elevation cell. More... | |
| virtual void | setComputeStatisticsFlag (bool flag) |
| Sets the flag which controls whether or not statistics will be computed upon opening a cell and not finding a corresponding statistics file. More... | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
Static Public Attributes | |
| static const int | TOTAL_POSTS = 4 |
| static const int | NUM_POSTS_PER_BLOCK = 2 |
| const ossimDtedHandler & | operator= (const ossimDtedHandler &rhs) |
| ossimDtedHandler (const ossimDtedHandler &) | |
| void | gatherStatistics () |
| ossim_sint16 | convertSignedMagnitude (ossim_uint16 &s) const |
| virtual double | getHeightAboveMSL (const ossimGpt &, bool readFromFile) |
| void | readPostsFromFile (DtedHeight &postData, int offset) |
| read the height posts from the File More... | |
Protected Member Functions inherited from ossimElevCellHandler | |
| ossimElevCellHandler () | |
| virtual | ~ossimElevCellHandler () |
Protected Member Functions inherited from ossimElevSource | |
| virtual | ~ossimElevSource () |
| ossimElevSource () | |
| Constructors/Destructors: More... | |
| ossimElevSource (const ossimElevSource &src) | |
DTED is typically a 1x1 degree cell.
This can open from an ossim::istream or from a filename. It allows one to query the cell by overriding the getHeightAboveMSL.
For reference
When a height is calculated it will use a weighted average of 4 neighboring posts.
Definition at line 57 of file ossimDtedHandler.h.
| anonymous enum |
| Enumerator | |
| DATA_RECORD_OFFSET_TO_POST | |
| DATA_RECORD_CHECKSUM_SIZE | |
| POST_SIZE | |
| NULL_POST | |
Definition at line 84 of file ossimDtedHandler.h.
inline |
| ossimDtedHandler::ossimDtedHandler | ( | const ossimFilename & | dted_file, |
| bool | memoryMapFlag = false |
Constructor.
| dted_file | is a file path to the dted cell we wish to open |
| memoryMapFlag | If this is set we will pull the entire cell into memory and treat that memory location as an inputstream. |
Definition at line 36 of file ossimDtedHandler.cpp.
Definition at line 97 of file ossimDtedHandler.cpp.
References close().
protected |
Definition at line 548 of file ossimDtedHandler.cpp.
inline |
Definition at line 162 of file ossimDtedHandler.h.
inlinevirtual |
Reimplemented from ossimElevCellHandler.
Definition at line 293 of file ossimDtedHandler.h.
References m_fileStr, and m_memoryMap.
Referenced by open(), and ~ossimDtedHandler().
| ossimString ossimDtedHandler::compilationDate | ( | ) | const |
inlineprotected |
Definition at line 267 of file ossimDtedHandler.h.
References m_swapBytesFlag.
Referenced by getHeightAboveMSL(), and readPostsFromFile().
inline |
Definition at line 158 of file ossimDtedHandler.h.
inlinevirtual |
Implements ossimElevSource.
Definition at line 167 of file ossimDtedHandler.h.
References ossimElevCellHandler::getFilename().
| ossimString ossimDtedHandler::edition | ( | ) | const |
protected |
If statistics file exist, stats will be initialized from that; else, this scans the dted cell and gets stats, then, writes new stats file. The statistics file will be named accordingly: If dted cell = n27.dt1 then the stats file = n27.statistics. Currently method only grabs the min and max posts value.
Definition at line 424 of file ossimDtedHandler.cpp.
References ossimFilename::setExtension(), and ossimElevCellHandler::theFilename.
Definition at line 102 of file ossimDtedHandler.cpp.
References ossimElevationAccuracyInfo::hasValidAbsoluteError(), ossimElevationAccuracyInfo::m_absoluteCE, ossimElevationAccuracyInfo::m_absoluteLE, m_acc, ossimElevationAccuracyInfo::m_confidenceLevel, m_dsi, ossimElevationAccuracyInfo::m_relativeCE, ossimElevationAccuracyInfo::m_relativeLE, and ossimElevationAccuracyInfo::m_surfaceName.
| gpt | is a ground point <lat, lon> that is used to lookup the elevation pos value. |
Definition at line 116 of file ossimDtedHandler.cpp.
References m_fileStr, m_memoryMap, and ossim::nan().
protectedvirtual |
read the posts from the DTED file.
Definition at line 266 of file ossimDtedHandler.cpp.
References ossimDtedHandler::DtedHeight::calcHeight(), convertSignedMagnitude(), DATA_RECORD_OFFSET_TO_POST, ossimDtedHandler::DtedHeight::debug(), ossimDpt::lat, ossimGpt::lat, ossimDpt::lon, ossimGpt::lon, m_dtedRecordSizeInBytes, ossimDtedHandler::DtedPost::m_height, m_latSpacing, m_lonSpacing, m_memoryMap, m_numLatPoints, m_numLonLines, m_offsetToFirstDataRecord, ossimDtedHandler::DtedHeight::m_posts, ossimDtedHandler::DtedPost::m_status, m_swCornerPost, ossimDtedHandler::DtedPost::m_weight, ossim::nan(), POST_SIZE, and readPostsFromFile().
METHOD: getPostValue Returns the value at a given grid point as a double. Satisfies pure virtual.
Implements ossimElevCellHandler.
Definition at line 387 of file ossimDtedHandler.cpp.
References m_numLatPoints, m_numLonLines, ossimIpt::x, and ossimIpt::y.
METHOD: getSizeOfElevCell Returns the number of post in the cell. Satisfies pure virtual. Note: x = longitude, y = latitude
Definition at line 522 of file ossimDtedHandler.cpp.
References m_numLatPoints, and m_numLonLines.
inline |
Definition at line 150 of file ossimDtedHandler.h.
inlinevirtual |
Definition at line 284 of file ossimDtedHandler.h.
References m_fileStr, m_fileStrMutex, and m_memoryMap.
opens a cell
Definition at line 130 of file ossimDtedHandler.cpp.
References ossimString::c_str(), and ossim::StreamFactoryRegistry::instance().
Referenced by ossimDtedElevationDatabase::inititializeExtension().
| fileStr | is a stream that was opened and has access to a cell. |
| connectionString | is the connection string used to open the input stream. |
Definition at line 139 of file ossimDtedHandler.cpp.
References close(), m_acc, m_connectionString, m_dsi, m_dtedRecordSizeInBytes, m_fileStr, m_hdr, m_numLatPoints, m_numLonLines, m_uhl, m_vol, and ossimErrorCodes::OSSIM_ERROR.
protected |
Definition at line 542 of file ossimDtedHandler.cpp.
| ossimString ossimDtedHandler::productLevel | ( | ) | const |
protected |
| postData | - post heights, status & weight |
| offset | - file contents offset to start reading from |
Definition at line 351 of file ossimDtedHandler.cpp.
References convertSignedMagnitude(), m_dtedRecordSizeInBytes, m_fileStr, m_fileStrMutex, ossimDtedHandler::DtedPost::m_height, ossimDtedHandler::DtedHeight::m_posts, ossimDtedHandler::DtedPost::m_status, NUM_POSTS_PER_BLOCK, and POST_SIZE.
Referenced by getHeightAboveMSL().
inline |
Definition at line 154 of file ossimDtedHandler.h.
inline |
Definition at line 146 of file ossimDtedHandler.h.
protected |
Definition at line 262 of file ossimDtedHandler.h.
Referenced by getAccuracyInfo(), and open().
protected |
Definition at line 246 of file ossimDtedHandler.h.
Referenced by compilationDate().
mutableprotected |
Definition at line 239 of file ossimDtedHandler.h.
Referenced by open().
protected |
Definition at line 261 of file ossimDtedHandler.h.
protected |
Definition at line 243 of file ossimDtedHandler.h.
Referenced by getHeightAboveMSL(), open(), and readPostsFromFile().
protected |
Definition at line 244 of file ossimDtedHandler.h.
Referenced by edition().
mutableprotected |
Definition at line 238 of file ossimDtedHandler.h.
Referenced by close(), getHeightAboveMSL(), isOpen(), open(), and readPostsFromFile().
mutableprotected |
Definition at line 236 of file ossimDtedHandler.h.
Referenced by isOpen(), and readPostsFromFile().
protected |
Definition at line 259 of file ossimDtedHandler.h.
protected |
Definition at line 248 of file ossimDtedHandler.h.
protected |
Definition at line 249 of file ossimDtedHandler.h.
mutableprotected |
Definition at line 256 of file ossimDtedHandler.h.
Referenced by close(), getHeightAboveMSL(), and isOpen().
mutableprotected |
Definition at line 255 of file ossimDtedHandler.h.
protected |
Definition at line 242 of file ossimDtedHandler.h.
Referenced by getHeightAboveMSL(), getPostValue(), getSizeOfElevCell(), and open().
protected |
Definition at line 241 of file ossimDtedHandler.h.
protected |
Definition at line 247 of file ossimDtedHandler.h.
protected |
Definition at line 245 of file ossimDtedHandler.h.
Referenced by productLevel().
protected |
Definition at line 253 of file ossimDtedHandler.h.
Referenced by convertSignedMagnitude().
protected |
Definition at line 250 of file ossimDtedHandler.h.
protected |
Definition at line 260 of file ossimDtedHandler.h.
protected |
Definition at line 258 of file ossimDtedHandler.h.
static |
Definition at line 64 of file ossimDtedHandler.h.
Referenced by readPostsFromFile().
static |
Definition at line 62 of file ossimDtedHandler.h.
Referenced by ossimDtedHandler::DtedHeight::calcHeight().
