#include <ossimElevationDatabase.h>
| ossimElevationDatabase () | |
| ossimElevationDatabase (const ossimElevationDatabase &src) | |
| virtual bool | getAccuracyInfo (ossimElevationAccuracyInfo &, const ossimGpt &) const |
| virtual double | getMeanSpacingMeters () const |
| METHOD: meanSpacingMeters() This method returns the post spacing in the region of gpt: More... | |
| virtual void | setGeoid (ossimGeoid *geoid) |
| ossimGeoid * | getGeoid () |
| const ossimGeoid * | getGeoid () const |
| virtual bool | open (const ossimString &connectionString)=0 |
| Open a connection to a database. More... | |
| const ossimString & | getConnectionString () const |
Public Member Functions inherited from ossimElevSource | |
| virtual double | getHeightAboveMSL (const ossimGpt &)=0 |
| Height access methods: More... | |
| virtual double | getHeightAboveEllipsoid (const ossimGpt &) |
| virtual ossimObject * | dup () const =0 |
| bool | intersectRay (const ossimEcefRay &ray, ossimGpt &gpt, double defaultElevValue=0.0) |
| METHOD: intersectRay() More... | |
| virtual double | getMinHeightAboveMSL () const |
| Access methods for the bounding elevations: More... | |
| virtual double | getMaxHeightAboveMSL () const |
| double | getNullHeightValue () const |
| Special numeric quantities as defined by this source: More... | |
| double | getSeaLevelValue () const |
| virtual bool | pointHasCoverage (const ossimGpt &) const =0 |
| METHOD: pointHasCoverage(gpt) Returns TRUE if coverage exists over gpt: More... | |
| virtual const ossimGrect & | getBoundingGndRect () const |
| METHODS: accuracyLE90(), accuracyCE90() Returns the vertical and horizontal accuracy (90% confidence) in the region of gpt: More... | |
| virtual bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
| Implement ossimSource base-class pure virtuals: More... | |
| virtual bool | getComputeStatisticsFlag () const |
| Opens a stream to an elevation cell. More... | |
| virtual void | setComputeStatisticsFlag (bool flag) |
| Sets the flag which controls whether or not statistics will be computed upon opening a cell and not finding a corresponding statistics file. More... | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| virtual | ~ossimElevationDatabase () |
| virtual double | getOffsetFromEllipsoid (const ossimGpt &gpt) |
Protected Member Functions inherited from ossimElevSource | |
| virtual | ~ossimElevSource () |
| ossimElevSource () | |
| Constructors/Destructors: More... | |
| ossimElevSource (const ossimElevSource &src) | |
Definition at line 18 of file ossimElevationDatabase.h.
inline |
Definition at line 22 of file ossimElevationDatabase.h.
inline |
Definition at line 28 of file ossimElevationDatabase.h.
inlineprotectedvirtual |
Definition at line 76 of file ossimElevationDatabase.h.
inlinevirtual |
Implements ossimElevSource.
Reimplemented in ossimTiledElevationDatabase, ossimImageElevationDatabase, ossimDtedElevationDatabase, ossimGeneralRasterElevationDatabase, and ossimSrtmElevationDatabase.
Definition at line 36 of file ossimElevationDatabase.h.
inline |
Definition at line 64 of file ossimElevationDatabase.h.
Referenced by ossimElevManager::ConnectionStringVisitor::visit().
inline |
Definition at line 48 of file ossimElevationDatabase.h.
inline |
Definition at line 52 of file ossimElevationDatabase.h.
inlinevirtual |
Definition at line 40 of file ossimElevationDatabase.h.
Referenced by dbSort().
protectedvirtual |
Definition at line 5 of file ossimElevationDatabase.cpp.
References ossimGeoidManager::instance(), ossim::isnan(), m_geoid, ossimGeoid::offsetFromEllipsoid(), ossimGeoidManager::offsetFromEllipsoid(), and ossimRefPtr< T >::valid().
Referenced by ossimSrtmElevationDatabase::getHeightAboveEllipsoid(), ossimDtedElevationDatabase::getHeightAboveEllipsoid(), ossimGeneralRasterElevationDatabase::getHeightAboveEllipsoid(), ossimImageElevationDatabase::getHeightAboveEllipsoid(), and ossimTiledElevationDatabase::getHeightAboveEllipsoid().
Reimplemented in ossimImageElevationDatabase, ossimTiledElevationDatabase, ossimElevationCellDatabase, ossimDtedElevationDatabase, ossimGeneralRasterElevationDatabase, and ossimSrtmElevationDatabase.
Definition at line 25 of file ossimElevationDatabase.cpp.
References ossimString::empty(), ossimKeywordNames::FILENAME_KW, ossimKeywordlist::find(), ossimGeoidManager::findGeoidByShortName(), ossimGeoidManager::instance(), ossimSource::loadState(), m_connectionString, m_geoid, m_meanSpacing, ossimString::size(), and ossimString::toFloat64().
Referenced by ossimElevationDatabaseFactory::createDatabase(), and ossimElevationCellDatabase::loadState().
pure virtual |
In most cases this will be a pointer to a directory like in a Dted directory reader.
Implemented in ossimTiledElevationDatabase, ossimImageElevationDatabase, ossimGeneralRasterElevationDatabase, ossimDtedElevationDatabase, and ossimSrtmElevationDatabase.
Referenced by ossimElevationDatabaseFactory::open().
Reimplemented from ossimElevSource.
Reimplemented in ossimImageElevationDatabase, ossimTiledElevationDatabase, ossimElevationCellDatabase, ossimGeneralRasterElevationDatabase, and ossimDtedElevationDatabase.
Definition at line 64 of file ossimElevationDatabase.cpp.
References saveState().
Method to save the state of the object to a keyword list. Return true if ok or false on error.
Definition at line 52 of file ossimElevationDatabase.cpp.
References ossimKeywordlist::add(), ossimObject::getShortName(), m_connectionString, m_geoid, ossimSource::saveState(), and ossimRefPtr< T >::valid().
Referenced by print(), ossimElevationCellDatabase::saveState(), and ossimTiledElevationDatabase::saveState().
inlinevirtual |
Definition at line 44 of file ossimElevationDatabase.h.
protected |
Definition at line 82 of file ossimElevationDatabase.h.
Referenced by ossimImageElevationDatabase::close(), ossimTiledElevationDatabase::close(), ossimImageElevationDatabase::loadFileMap(), ossimSrtmElevationDatabase::loadState(), ossimGeneralRasterElevationDatabase::loadState(), ossimDtedElevationDatabase::loadState(), loadState(), ossimSrtmElevationDatabase::open(), ossimGeneralRasterElevationDatabase::open(), and saveState().
protected |
Definition at line 83 of file ossimElevationDatabase.h.
Referenced by ossimImageElevationDatabase::close(), ossimTiledElevationDatabase::close(), getOffsetFromEllipsoid(), loadState(), saveState(), and ossimElevationCellDatabase::saveState().
protected |
Definition at line 84 of file ossimElevationDatabase.h.
Referenced by ossimImageElevationDatabase::close(), ossimTiledElevationDatabase::close(), ossimSrtmElevationDatabase::getAccuracyInfo(), ossimImageElevationDatabase::getHeightAboveMSL(), loadState(), and ossimGeneralRasterElevationDatabase::openGeneralRasterDirectory().
