ossimEllipsoid.cpp
Go to the documentation of this file.
1 //
3 // License: See top level LICENSE.txt file.
4 //
5 // DESCRIPTION:
6 // Contains implementation of class ossimEllipsoid. The implementation is
7 // actually for an OBLATE SPHEROID (x.radius = y.radius) as Earth is
8 // considered.
9 //
10 // SOFTWARE HISTORY:
11 //>
12 // 06Aug2001 Garrett Potts, Oscar Kramer
13 // Initial coding.
14 //<
15 //*****************************************************************************
16 // $Id: ossimEllipsoid.cpp 22858 2014-08-05 17:24:50Z dburken $
17
19 #include <ossim/base/ossimDpt.h>
20 #include <ossim/base/ossimGpt.h>
28
29 //***
30 // Define Trace flags for use within this file:
31 //***
32 #include <ossim/base/ossimTrace.h>
33 #include <cmath>
34 static ossimTrace traceExec ("ossimEllipsoid:exec");
35 static ossimTrace traceDebug ("ossimEllipsoid:debug");
36
37
38 //*****************************************************************************
39 // CONSTRUCTOR: ossimEllipsoid #1 (COPY)
40 //
41 //*****************************************************************************
43  :
44  theName(ellipsoid.theName),
45  theCode(ellipsoid.theCode),
46  theEpsgCode(ellipsoid.theEpsgCode),
47  theA(ellipsoid.theA),
48  theB(ellipsoid.theB),
49  theFlattening(ellipsoid.theFlattening),
50  theA_squared(ellipsoid.theA_squared),
51  theB_squared(ellipsoid.theB_squared),
52  theEccentricitySquared(ellipsoid.theEccentricitySquared)
53 {
54  if ( theEpsgCode == 0 )
55  {
57  }
58 }
59
60 //*****************************************************************************
61 // CONSTRUCTOR: ossimEllipsoid #2
62 //
63 //*****************************************************************************
65  const ossimString &code,
66  const double &a,
67  const double &b,
68  ossim_uint32 epsg_code)
69  :
70  theName(name),
71  theCode(code),
72  theEpsgCode(epsg_code),
73  theA(a),
74  theB(b),
75  theA_squared(a*a),
76  theB_squared(b*b)
77 {
78  if (theEpsgCode == 0)
79  {
81  }
82
85 }
86
88 {
90
91  *this = *ellipse;
92 }
93
94 //*****************************************************************************
95 // CONSTRUCTOR: ossimEllipsoid #3
96 //
97 //*****************************************************************************
99  const double &b)
100  :
101  theName(""), // initialize to empty
102  theCode(""),
103  theEpsgCode(0),
104  theA(a),
105  theB(b),
106  theA_squared(a*a),
107  theB_squared(b*b)
108 {
109  // First check if this is just WGS84:
111  if ((theA == wgs84->theA) && (theB == wgs84->theB))
112  {
113  *this = *wgs84;
114  }
115  else
116  {
119  }
120 }
121
122 //*****************************************************************************
123 // METHOD: ossimEllipsoid::nearestIntersection
124 //
125 //*****************************************************************************
127  ossimEcefPoint& rtnPt) const
128 {
129  return nearestIntersection(ray, 0.0, rtnPt);
130 }
131
132 //*****************************************************************************
133 // METHOD: ossimEllipsoid::nearestIntersection
134 //
135 // geographic objects that are derive this class will assume that
136 // the reference datum is wgs84 and that the ray origin is a
137 // geocentric coordinate relative to the wgs84 datum. Will return
138 // true if the object was intersected and false otherwise.
139 //
140 // The nearest intersection will use the ray sphere intersection
141 // found in most ray tracers. We will take a Ray defined by the
142 // parametric equation:
143 //
144 // x = x0 + dxt
145 // y = y0 + dyt
146 // z = z0 + dzt
147 //
148 // and intersect this with the equation of a spheroid:
149 //
150 // x^2/theXRadius^2 + y^2/theYRadius^2 + z^2/theZRadius^2 = 1
151 //
152 // the intersection is achieved by substituting the parametric line
153 // into the equation of the spheroid. By doing this you should
154 // get a quadratic in t and the equation should look like this:
155 //
156 // a*t^2 + b*t + c = 0
157 //
158 // let a = dx^2/theXRadius^2 + dy^2/theYRadius^2 + dz^2/theZRadius^2
159 // let b = 2*(x0*dx/theXRadius^2 +y0*dy/theYRadius^2 + z0*dz/theZRadius^2
160 // let c = x0^2/theXRadius^2 + y0^2/theYRadius^2 + z0^2/theZRadius^2 - 1
161 //
162 // Now solve the quadratic (-b +- sqrt(b^2 - 4ac) ) / 2a
163 //
164 // After solving for t, the parameter is applied to the ray to determine
165 // the 3D point position in X,Y,Z, passed back in rtnPt. The boolean
166 // "true" is returned if an intersection was found.
167 //
168 // ESH 1/14/2016: I noticed that the radii used for the spheroid are dependent
169 // on latitude and this was not taken into account, leading to small errors in
170 // the results. The current point on the ray is now used to estimate latitude and
171 // update the radii. Iterations stop when the intersection point has an elevation
172 // value close to the ellipsoid 'offset'. This approach appears to converge very
173 // fast (<=3 iterations). Before this fix, it was noticed that the rtnPt can be
174 // off as the absolute value of 'offset' gets large. For example, at 10000 meters,
175 // rtnPt can be off by almost 2 centimeters.
176 //
177 //*****************************************************************************
179  const double& offset,
180  ossimEcefPoint& rtnPt ) const
181 {
182  static const char MODULE[] = "ossimEllipsoid::nearestIntersection";
183  if (traceExec())
184  {
185  ossimNotify(ossimNotifyLevel_DEBUG) << "DEBUG: " << MODULE << ", entering...\n";
186  }
187
188  bool success = false;
189
190  const double eccSqComp = 1.0 - theEccentricitySquared;
191  const double CONVERGENCE_THRESHOLD = 0.0001;
192  const int MAX_NUM_ITERATIONS = 10;
193
194  //***
195  // get the origin and direction of ray:
196  //***
197  ossimEcefPoint start = ray.origin();
198  ossimEcefVector direction = ray.direction();
199
200  double start_x = start.x();
201  double start_y = start.y();
202  double start_z = start.z();
203
204  double direction_x = direction.x();
205  double direction_y = direction.y();
206  double direction_z = direction.z();
207
208  ossimGpt rayGpt( start );
209
210  int iterations = 0;
211  bool done = false;
212  do
213  {
214  double rayLat = rayGpt.latd();
215  double raySinLat = ossim::sind( rayLat );
216  double rayScale = 1.0 / sqrt( 1.0 - theEccentricitySquared * raySinLat * raySinLat );
217  double rayN = theA * rayScale;
218
219  double A_offset = rayN + offset;
220  double B_offset = rayN * eccSqComp + offset;
221
222  double A_offset_inv = 1.0 / A_offset;
223  double B_offset_inv = 1.0 / B_offset;
224
225  double scaled_x = start_x * A_offset_inv;
226  double scaled_y = start_y * A_offset_inv;
227  double scaled_z = start_z * B_offset_inv;
228
229  double A_over_B = A_offset * B_offset_inv;
230
231  //***
232  // Solve the coefficients of the quadratic formula
233  //***
234
235  double a = (direction_x*direction_x + direction_y*direction_y) * A_offset_inv;
236  a += (direction_z*direction_z * B_offset_inv * A_over_B);
237
238  double b = 2.0 * ( scaled_x*direction_x + scaled_y*direction_y +
239  scaled_z*direction_z*A_over_B );
240
241  double c = scaled_x*start_x + scaled_y*start_y;
242  c += (scaled_z*start_z * A_over_B);
243  c -= A_offset;
244
245  //***
246  // solve the quadratic
247  //***
248  double root = b*b - 4.0*a*c;
249  if ( root < 0.0 )
250  {
251  return false;
252  }
253
254  double squareRoot = sqrt(root);
255  double oneOver2a = 1.0 / (2.0*a);
256
257  double t1 = (-b + squareRoot) * oneOver2a;
258  double t2 = (-b - squareRoot) * oneOver2a;
259
260  //***
261  // sort t1 and t2 and take the nearest intersection if they
262  // are in front of the ray.
263  //***
264 // if ( t2 < t1 )
265 // {
266 // double temp = t1;
267 // t1 = t2;
268 // t2 = temp;
269 // }
270 //
271 // double tEstimate = ( t1 > 0.0 ) ? t1 : t2;
272
273  // OLK: Alternate means to find closest intersection, not necessarily "in front of" origin:
274  double tEstimate = t1;
275  if (fabs(t2) < fabs(t1))
276  tEstimate = t2;
277
278  // Get estimated intersection point.
279  ossimEcefPoint rayEcef = ray.extend( tEstimate );
280
281  rayGpt = ossimGpt( rayEcef );
282  double offsetError = fabs( rayGpt.height() - offset );
283  if ( offsetError < CONVERGENCE_THRESHOLD )
284  {
285  done = true;
286  success = true;
287  rtnPt = rayEcef;
288  }
289
290  } while ( (!done) && (iterations++ < MAX_NUM_ITERATIONS) );
291
292  if (iterations >= MAX_NUM_ITERATIONS)
293  {
294  if(traceDebug())
295  {
297  << "WARNING ossimEllipsoid::nearestIntersection: Max number of iterations reached"
298  << " solving for intersection point. Result is probably inaccurate." << std::endl;
299  }
300  }
301
302  return success;
303 }
304
305 //*****************************************************************************
306 // METHOD: ossimEllipsoid::evaluate(ossimColumnVector3d)
307 //
308 // Returns neg number if inside, 0 if on, and pos number if outside of
309 // ellipsoid.
310 //
311 //*****************************************************************************
312 double ossimEllipsoid::evaluate(const ossimEcefPoint &location)const
313 {
314  //***
315  // get the axis
316  //***
317  return (((location.x() * location.x())/theA_squared) +
318  ((location.y() * location.y())/theA_squared) +
319  ((location.z() * location.z())/theB_squared) - 1.0);
320 }
321
322 //*****************************************************************************
323 // METHOD: ossimEllipsoid::gradient() version A
324 //
325 // Returns vector normal to the ellipsoid at point specified.
326 //
327 //*****************************************************************************
329  ossimEcefVector& result) const
330 {
331  result.x() = (2.0*location.x())/theA_squared;
332  result.y() = (2.0*location.y())/theA_squared;
333  result.z() = (2.0*location.z())/theB_squared;
334 }
335
336 //*****************************************************************************
337 // METHOD: ossimEllipsoid::gradient() version B
338 //
339 // Returns vector normal to the ellipsoid at point specified.
340 //
341 //*****************************************************************************
344 {
345  ossimEcefVector result;
346  gradient(location, result);
347  return result;
348 }
349
350
352  const char* prefix)
353 {
354  const char* lookup = kwl.find(prefix, ossimKeywordNames::ELLIPSE_CODE_KW);
355  bool foundCode = false;
356  if(lookup)
357  {
359
360  if(ellipse)
361  {
362  foundCode = true;
363  *this = *ellipse;
364  }
365  }
366
367  lookup = kwl.find(prefix, ossimKeywordNames::ELLIPSE_EPSG_CODE_KW);
368  if (lookup)
369  {
370  theEpsgCode = ossimString(lookup).toUInt32();
371  }
372
373  if(!foundCode)
374  {
375  const char* majorAxis = kwl.find(prefix,
377  const char* minorAxis = kwl.find(prefix,
379
380  theName = "";
381  theCode = "";
382  if(majorAxis && minorAxis)
383  {
384  theA = ossimString(majorAxis).toDouble();
385  theB = ossimString(minorAxis).toDouble();
386
390  }
391  else
392  {
394
395  *this = *ellipse;
396  }
397  }
398
399  return true;
400 }
401
403  const char* prefix)const
404 {
405  if(theCode != "")
406  {
407  kwl.add(prefix,
409  theCode.c_str(),
410  true);
411
412  kwl.add(prefix,
414  theName.c_str(),
415  true);
416  }
417  if (theEpsgCode)
418  {
420  }
421
422  kwl.add(prefix,
424  theA,
425  true);
426
427  kwl.add(prefix,
429  theB,
430  true);
431
432  return true;
433 }
434
435
436 //*****************************************************************************
437 // METHOD: ossimEllipsoid::prinRadiiOfCurv()
438 //
439 // Computes the meridional radius and prime vertical at given point.
440 //
441 //*****************************************************************************
443  double& merRadius,
444  double& primeVert) const
445 {
446  double lat, lon, hgt;
447  XYZToLatLonHeight(location.x(), location.y(), location.z(), lat, lon, hgt);
448
449  double sinPhi = sin(lat*RAD_PER_DEG);
450  double phiFac = 1.0 - theEccentricitySquared*sinPhi*sinPhi;
451  primeVert = theA / sqrt(phiFac);
452  merRadius = theA*(1.0-theEccentricitySquared) / sqrt(phiFac*phiFac*phiFac);
453 }
454
455
456 //*****************************************************************************
457 // METHOD: ossimEllipsoid::jacobianWrtEcef()
458 //
459 // Forms Jacobian of partials of geodetic WRT ECF at given point.
460 // - -
461 // | pLat/pX pLat/pY pLat/pZ |
462 // jMat = | pLon/pX pLon/pY pLon/pZ |
463 // | pHgt/pX pHgt/pY pHgt/pZ |
464 // - -
465 //
466 //*****************************************************************************
468  NEWMAT::Matrix& jMat) const
469 {
470  double primeVert;
471  double merRadius;
472  double lat, lon, hgt;
473
474  XYZToLatLonHeight(location.x(), location.y(), location.z(), lat, lon, hgt);
475  prinRadiiOfCurv(location, merRadius, primeVert);
476
477  double sinPhi = sin(lat*RAD_PER_DEG);
478  double cosPhi = cos(lat*RAD_PER_DEG);
479  double sinLam = sin(lon*RAD_PER_DEG);
480  double cosLam = cos(lon*RAD_PER_DEG);
481  double N_plus_h = primeVert + hgt;
482  double M_plus_h = merRadius + hgt;
483
484  jMat(1,1) = -sinPhi * cosLam / M_plus_h;
485  jMat(2,1) = -sinLam / (cosPhi * N_plus_h);
486  jMat(3,1) = cosPhi * cosLam;
487  jMat(1,2) = -sinPhi * sinLam / M_plus_h;
488  jMat(2,2) = cosLam / (cosPhi * N_plus_h);
489  jMat(3,2) = cosPhi * sinLam;
490  jMat(1,3) = cosPhi / M_plus_h;
491  jMat(2,3) = 0.0;
492  jMat(3,3) = sinPhi;
493 }
494
495
496 //*****************************************************************************
497 // METHOD: ossimEllipsoid::jacobianWrtGeo()
498 //
499 // Forms Jacobian of partials of ECF WRT geodetic at given point.
500 // - -
501 // | pX/pLat pX/pLon pX/pHgt |
502 // jMat = | pY/pLat pY/pLon pY/pHgt |
503 // | pZ/pLat pZ/pLon pZ/pHgt |
504 // - -
505 //
506 //*****************************************************************************
508  NEWMAT::Matrix& jMat) const
509 {
510  double primeVert;
511  double merRadius;
512  double lat, lon, hgt;
513
514  XYZToLatLonHeight(location.x(), location.y(), location.z(), lat, lon, hgt);
515  prinRadiiOfCurv(location, merRadius, primeVert);
516
517  double sinPhi = sin(lat*RAD_PER_DEG);
518  double cosPhi = cos(lat*RAD_PER_DEG);
519  double sinLam = sin(lon*RAD_PER_DEG);
520  double cosLam = cos(lon*RAD_PER_DEG);
521  double N_plus_h = primeVert + hgt;
522  double M_plus_h = merRadius + hgt;
523
524  jMat(1,1) = -M_plus_h * sinPhi * cosLam;
525  jMat(2,1) = -M_plus_h * sinPhi * sinLam;
526  jMat(3,1) = M_plus_h * cosPhi;
527  jMat(1,2) = -N_plus_h * cosPhi * sinLam;
528  jMat(2,2) = N_plus_h * cosPhi * cosLam;
529  jMat(3,2) = 0.0;
530  jMat(1,3) = cosPhi * cosLam;
531  jMat(2,3) = cosPhi * sinLam;
532  jMat(3,3) = sinPhi;
533 }
534
535
536 //*****************************************************************************
537 // METHOD: ossimEllipsoid::geodeticRadius()
538 //
539 // Computes the "geodetic" radius for a given latitude in degrees
540 //
541 //*****************************************************************************
542 double ossimEllipsoid::geodeticRadius(const double& lat) const
543 {
544  double cos_lat = ossim::cosd(lat);
545  double sin_lat = ossim::sind(lat);
546  double cos2_lat = cos_lat*cos_lat;
547  double sin2_lat = sin_lat*sin_lat;
548  double a2_cos = theA_squared*cos_lat;
549  double b2_sin = theB_squared*sin_lat;
550
551  return sqrt( ( (a2_cos*a2_cos) + (b2_sin*b2_sin) )/ (theA_squared*cos2_lat + theB_squared*sin2_lat));
552 }
553
554 //*************************************************************************************************
555 // Computes the "geodetic" radius of curvature of the ellipsoid in the east-west (x) and
556 // north-south (y) directions for a given latitude in DEGREES.
557 // Taken from http://en.wikipedia.org/wiki/Earth_radius
558 //*************************************************************************************************
559 void ossimEllipsoid::geodeticRadii(const double& lat, ossimDpt& radii) const
560 {
561  double cos_lat = ossim::cosd(lat);
562  double sin_lat = ossim::sind(lat);
563  double cos2_lat = cos_lat*cos_lat;
564  double sin2_lat = sin_lat*sin_lat;
565  double H = theA_squared*cos2_lat + theB_squared*sin2_lat;
566  double H3 = H*H*H;
567
568  radii.x = theA_squared/sqrt(H);
569  radii.y = theA_squared*theB_squared/sqrt(H3);
570 }
571
572 void ossimEllipsoid::latLonHeightToXYZ(double lat, double lon, double height,
573  double &x, double &y, double &z)const
574 {
575  double sin_latitude = ossim::sind(lat);
576  double cos_latitude = ossim::cosd(lat);
577  double N = theA / sqrt( 1.0 - theEccentricitySquared*sin_latitude*sin_latitude);
578  x = (N+height)*cos_latitude*ossim::cosd(lon);
579  y = (N+height)*cos_latitude*ossim::sind(lon);
580  z = (N*(1-theEccentricitySquared)+height)*sin_latitude;
581 }
582
583 void ossimEllipsoid::XYZToLatLonHeight(double x, double y, double z,
584  double& lat, double& lon, double& height)const
585 {
586
587 #if 1
588  // Author: Norman J. Goldstein ([email protected],
590
591  const double tol = 1e-15;
592  const double d = sqrt(x*x + y*y);
593  const int MAX_ITER = 10;
594
595  const double a2 = theA * theA;
596  const double b2 = theB * theB;
597  const double pa2 = d * d * a2;
598  const double qb2 = z * z * b2;
599  const double ae2 = a2 * eccentricitySquared();
600  const double ae4 = ae2 * ae2;
601
602  const double c3 = -( ae4/2 + pa2 + qb2 ); // s^2
603  const double c4 = ae2*( pa2 - qb2 ); // s^1
604  const double c5 = ae4/4 * ( ae4/4 - pa2 - qb2 ); // s^0
605
606  double s0 = 0.5 * (a2 + b2) * hypot( d/theA, z/theB );
607
608  for( int iterIdx = 0; iterIdx < MAX_ITER; ++iterIdx )
609  {
610  const double pol = c5 + s0 * ( c4 + s0 * ( c3 + s0 * s0 ) );
611  const double der = c4 + s0 * ( 2 * c3 + 4 * s0 * s0 );
612
613  const double ds = - pol / der;
614  s0 += ds;
615
616  if( fabs( ds ) < tol * s0 )
617  {
618  const double t = s0 - 0.5 * (a2 + b2);
619  const double x_ell = d / ( 1.0 + t/a2 );
620  const double y_ell = z / ( 1.0 + t/b2 );
621
622  height = ( d - x_ell ) * x_ell/a2 + ( z - y_ell ) * y_ell/b2;
623  height /= hypot( x_ell/a2 , y_ell/b2 );
624
625  lat = atan2( y_ell/b2, x_ell/a2 ) * DEG_PER_RAD;
626  lon = atan2( y, x ) * DEG_PER_RAD;
627
628  return;
629  }
630  }
631
632  #else
633  double d = sqrt(x*x + y*y);
634
635  double phi2 = z / ((1 - theEccentricitySquared) * d);
636  double p = 1.0;
637  double phi1 = 0.0;
638  double N1 = 0.0;
639  double height1 = 0.0;
640  int iterIdx = 0;
641  const int MAX_ITER = 10;
642  if (fabs(phi2) > 1e-16 )
643  {
644  while ( (p > 1e-17) && (iterIdx < MAX_ITER))
645  {
646  phi1 = phi2;
647  N1 = theA / sqrt(1.0 - (theEccentricitySquared * pow(sin(phi1), 2.0)));
648  height1 = (d / cos(phi1) - N1);
649  phi2 = atan((z / d) * (1.0 + (theEccentricitySquared * N1 * sin(phi1)) / z));
650  p = fabs(phi2 - phi1);
651  ++iterIdx;
652  /* printf("phi: %e phi2: %e p: %e \n", phi1, phi2, p); */
653  }
654  }
655  else
656  {
657  phi1 = phi2;
658  N1 = theA / sqrt(1.0 - (theEccentricitySquared * pow(sin(phi1), 2.0)));
659  height1 = (d / cos(phi1)) - N1;
660  }
661
662  /* *Latitude = phi2 * 180/PI; */
663  /* *Longitude = atan2(Y, X) * 180/PI; */
664  lat = phi2*DEG_PER_RAD;
665  lon = atan2(y, x)*DEG_PER_RAD;
666  height = height1;
667 #endif
668 }
669
671  ossimMatrix4x4& localToWorld)const
672 {
673  localToWorld = ossimMatrix4x4::createIdentity();
674  NEWMAT::Matrix& m = localToWorld.getData();
675
676  // put in the translation
677  m[0][3] = x;
678  m[1][3] = y;
679  m[2][3] = z;
680
681
682
683  // normalize X,Y,Z
684  double inverse_length = 1.0/sqrt(x*x + y*y + z*z);
685
686  x *= inverse_length;
687  y *= inverse_length;
688  z *= inverse_length;
689
690  double length_XY = sqrt(x*x + y*y);
691  double inverse_length_XY = 1.0/length_XY;
692
693  // Vx = |(-Y,X,0)|
694  m[0][0] = -y*inverse_length_XY;
695  m[1][0] = x*inverse_length_XY;
696  m[2][0] = 0.0;
697
698  // Vy = /(-Z*X/(sqrt(X*X+Y*Y), -Z*Y/(sqrt(X*X+Y*Y),sqrt(X*X+Y*Y))|
699  double Vy_x = -z*x*inverse_length_XY;
700  double Vy_y = -z*y*inverse_length_XY;
701  double Vy_z = length_XY;
702  inverse_length = 1.0/sqrt(Vy_x*Vy_x + Vy_y*Vy_y + Vy_z*Vy_z);
703  m[0][1] = Vy_x*inverse_length;
704  m[1][1] = Vy_y*inverse_length;
705  m[2][1] = Vy_z*inverse_length;
706
707  // Vz = (X,Y,Z)
708  m[0][2] = x;
709  m[1][2] = y;
710  m[2][2] = z;
711
712 }
713
715 {
716  if (!theCode.empty() && (theEpsgCode == 0))
718  return theEpsgCode;
719 }
720
722 {
723  if (this != &copy_me)
724  {
725  theName = copy_me.theName;
726  theCode = copy_me.theCode;
727  theEpsgCode = copy_me.theEpsgCode;
728  theA = copy_me.theA;
729  theB = copy_me.theB;
730  theFlattening = copy_me.theFlattening;
731  theA_squared = copy_me.theA_squared;
732  theB_squared = copy_me.theB_squared;
734  }
735  return *this;
736 }
ossim_uint32 x
const NEWMAT::Matrix & getData() const
static const char * MINOR_AXIS_KW
double theEccentricitySquared
static ossimEllipsoidFactory * instance()
double z() const
ossim_uint32 getEpsgCode() const
#define DEG_PER_RAD
bool loadState(const ossimKeywordlist &kwl, const char *prefix=0)
ossim_uint32 y
void jacobianWrtGeo(const ossimEcefPoint &location, NEWMAT::Matrix &jMat) const
double y
Definition: ossimDpt.h:165
const ossimEcefPoint & origin() const
Definition: ossimEcefRay.h:79
void prinRadiiOfCurv(const ossimEcefPoint &location, double &merRadius, double &primeVert) const
double x() const
ossim_uint32 toUInt32() const
double sind(double x)
Definition: ossimCommon.h:260
const double & b() const
double latd() const
Will convert the radian measure to degrees.
Definition: ossimGpt.h:87
double evaluate(const ossimEcefPoint &) const
const ossimEllipsoid * wgs84() const
ossimString theCode
static const char * ELLIPSE_CODE_KW
const double & a() const
static const char * MAJOR_AXIS_KW
unsigned int ossim_uint32
double height() const
Definition: ossimGpt.h:107
double toDouble() const
double eccentricitySquared() const
const ossimEllipsoid * create(const ossimString &code) const
void latLonHeightToXYZ(double lat, double lon, double height, double &x, double &y, double &z) const
void gradient(const ossimEcefPoint &location, ossimEcefVector &result) const
double cosd(double x)
Definition: ossimCommon.h:259
ossimEcefPoint extend(const double &t) const
Definition: ossimEcefRay.h:152
ossim_uint32 theEpsgCode
static const char * ELLIPSE_NAME_KW
void geodeticRadii(const double &latitude, ossimDpt &radii) const
double x() const
static NEWMAT::Matrix createIdentity()
const ossimEcefVector & direction() const
Definition: ossimEcefRay.h:80
double y() const
ossim_uint32 findEpsgCode(const ossimString &alpha_code) const
Given an alpha code (for example "WE" for WGS84), returns the corresponding EPSG code or 0 if not fou...
double geodeticRadius(const double &latitude) const
void jacobianWrtEcef(const ossimEcefPoint &location, NEWMAT::Matrix &jMat) const
double y() const
double x
Definition: ossimDpt.h:164
const char * c_str() const
Definition: ossimString.h:396
bool empty() const
Definition: ossimString.h:411
bool saveState(ossimKeywordlist &kwl, const char *prefix=0) const
static const char * ELLIPSE_EPSG_CODE_KW
void computeFlattening()
const ossimEllipsoid & operator=(const ossimEllipsoid &copy_me)
void computeLocalToWorldTransformFromXYZ(double x, double y, double z, ossimMatrix4x4 &localToWorld) const
bool nearestIntersection(const ossimEcefRay &ray, ossimEcefPoint &rtnPt) const
void XYZToLatLonHeight(double x, double y, double z, double &lat, double &lon, double &height) const
double z() const
ossimString theName
#define RAD_PER_DEG
