#include <ossimSensorModelFactory.h>
| virtual ossimProjection * | createProjection (const ossimFilename &filename, ossim_uint32 entryIdx) const |
| takes a filename. More... | |
| virtual ossimProjection * | createProjection (const ossimString &spec) const |
| virtual ossimProjection * | createProjection (const ossimKeywordlist &kwl, const char *prefix=0) const |
| Take a keywordlist. More... | |
| virtual ossimObject * | createObject (const ossimString &typeName) const |
| virtual ossimObject * | createObject (const ossimKeywordlist &kwl, const char *prefix=0) const |
| virtual void | getTypeNameList (std::vector< ossimString > &typeList) const |
Public Member Functions inherited from ossimProjectionFactoryBase | |
| virtual ossimProjection * | createProjection (ossimImageHandler *handler) const |
Public Member Functions inherited from ossimObjectFactory | |
| virtual | ~ossimObjectFactory () |
| ossimObject () | |
| static ossimSensorModelFactory * | instance () |
| ossimSensorModelFactory () | |
| bool | isNitf (const ossimFilename &filename) const |
| bool | isLandsat (const ossimFilename &filename) const |
| void | findCoarseGrid (ossimFilename &result, const ossimFilename &geomFile) const |
Protected Member Functions inherited from ossimProjectionFactoryBase | |
| ossimProjection * | createProjectionFromGeometryFile (const ossimFilename &imageFile, ossim_uint32 entryIdx) const |
| This method takes the filename and tries to find an external ".geom" file. More... | |
Definition at line 19 of file ossimSensorModelFactory.h.
inlineprotected |
Definition at line 57 of file ossimSensorModelFactory.h.
Creates an object given a type name.
Implements ossimObjectFactory.
Definition at line 243 of file ossimSensorModelFactory.cpp.
References createProjection().
Creates and object given a keyword list.
Definition at line 252 of file ossimSensorModelFactory.cpp.
takes a filename.
This filename can be an image file or it can also be a ossim .geom file. It could be other forms of geom files as well. The factories job will be to determine what parser to use and return a projection if successful.
Implements ossimProjectionFactoryBase.
Definition at line 293 of file ossimSensorModelFactory.cpp.
References ossimKeywordlist::add(), ossimKeywordlist::addFile(), ossimString::c_str(), ossimKeywordlist::clear(), ossimProjectionFactoryBase::createProjectionFromGeometryFile(), ossimString::empty(), ossimFilename::exists(), ossimKeywordlist::find(), findCoarseGrid(), ossimErrorStatusInterface::getErrorStatus(), ossimRefPtr< T >::release(), ossimFilename::setExtension(), STATIC_TYPE_NAME, ossimKeywordNames::TYPE_KW, and ossimRefPtr< T >::valid().
Referenced by createObject(), and createProjection().
METHOD: create() Attempts to create an instance of the Product given a Specifier or keywordlist. Returns successfully constructed product or NULL.
Definition at line 133 of file ossimSensorModelFactory.cpp.
References STATIC_TYPE_NAME.
Take a keywordlist.
Definition at line 93 of file ossimSensorModelFactory.cpp.
References createProjection(), ossimKeywordlist::find(), ossimKeywordNames::GEOM_FILE_KW, ossimProjection::loadState(), ossimRefPtr< T >::release(), ossimKeywordNames::TYPE_KW, and ossimRefPtr< T >::valid().
protected |
Definition at line 688 of file ossimSensorModelFactory.cpp.
References ossimFilename::exists(), ossimFilename::fileNoExtension(), ossimDirectory::OSSIM_DIR_FILES, ossimFilename::path(), ossimFilename::setExtension(), and ossimFilename::setFile().
Referenced by createProjection().
This should return the type name of all objects in all factories. This is the name used to construct the objects dynamially and this name must be unique.
Definition at line 262 of file ossimSensorModelFactory.cpp.
static |
METHOD: instance() For accessing static instance of concrete factory.
Definition at line 84 of file ossimSensorModelFactory.cpp.
Referenced by ossimProjectionFactoryRegistry::initializeDefaults().
protected |
Definition at line 670 of file ossimSensorModelFactory.cpp.
References ossimString::contains(), ossimString::downcase(), and ossimErrorStatusInterface::getErrorStatus().
protected |
Definition at line 654 of file ossimSensorModelFactory.cpp.
References ossim::StreamFactoryRegistry::instance().
