#include <ossimProjectionFactoryBase.h>
| virtual ossimProjection * | createProjection (const ossimFilename &filename, ossim_uint32 entryIdx) const =0 |
| takes a filename. More... | |
| virtual ossimProjection * | createProjection (const ossimString &name) const =0 |
| Take a projection type name. More... | |
| virtual ossimProjection * | createProjection (const ossimKeywordlist &kwl, const char *prefix) const =0 |
| Take a keywordlist. More... | |
| virtual ossimProjection * | createProjection (ossimImageHandler *handler) const |
Public Member Functions inherited from ossimObjectFactory | |
| virtual | ~ossimObjectFactory () |
| virtual ossimObject * | createObject (const ossimString &typeName) const =0 |
| virtual ossimObject * | createObject (const ossimKeywordlist &kwl, const char *prefix=0) const =0 |
| virtual void | getTypeNameList (std::vector< ossimString > &typeList) const =0 |
| ossimObject () | |
| ossimProjection * | createProjectionFromGeometryFile (const ossimFilename &imageFile, ossim_uint32 entryIdx) const |
| This method takes the filename and tries to find an external ".geom" file. More... | |
Definition at line 17 of file ossimProjectionFactoryBase.h.
pure virtual |
takes a filename.
This filename can be an image file or it can also be a ossim .geom file. It could be other forms of geom files as well. The factories job will be to determine what parser to use and return a projection if successful.
Implemented in ossimNitfProjectionFactory, ossimMiscProjectionFactory, ossimEpsgProjectionFactory, ossimWktProjectionFactory, ossimMapProjectionFactory, ossimTiffProjectionFactory, ossimplugins::ossimPluginProjectionFactory, ossimGdalProjectionFactory, ossimNgaProjectionFactory, ossimSensorModelFactory, ossimHdf5ProjectionFactory, ossimHdf5ProjectionFactory, and ossimJpipProjectionFactory.
Referenced by createProjection().
pure virtual |
Implemented in ossimNitfProjectionFactory, ossimEpsgProjectionFactory, ossimMapProjectionFactory, ossimTiffProjectionFactory, ossimWktProjectionFactory, ossimMiscProjectionFactory, ossimplugins::ossimPluginProjectionFactory, ossimGdalProjectionFactory, ossimSensorModelFactory, ossimNgaProjectionFactory, ossimHdf5ProjectionFactory, ossimHdf5ProjectionFactory, and ossimJpipProjectionFactory.
pure virtual |
Take a keywordlist.
Implemented in ossimNitfProjectionFactory, ossimEpsgProjectionFactory, ossimWktProjectionFactory, ossimMapProjectionFactory, ossimTiffProjectionFactory, ossimplugins::ossimPluginProjectionFactory, ossimMiscProjectionFactory, ossimNgaProjectionFactory, ossimGdalProjectionFactory, ossimSensorModelFactory, ossimHdf5ProjectionFactory, ossimHdf5ProjectionFactory, and ossimJpipProjectionFactory.
Reimplemented in ossimNitfProjectionFactory, and ossimTiffProjectionFactory.
Definition at line 105 of file ossimProjectionFactoryBase.cpp.
References createProjection(), ossimImageHandler::getCurrentEntry(), and ossimImageHandler::getFilename().
protected |
If the "entryIndx" is 0 and the "imageFile" is foo.ntf this will look for "foo.geom". If that fails it will look for foo_e0.geom.
If the "entryIndx" is 5 and the "imageFile" is foo.ntf this will look for foo_e5.geom.
| imageFile | Image file that needs a projection. |
| entryIdx | For image files that support multiple images this is the zero base index to that image. Images that don't support multiple indexes should just pass 0. |
Definition at line 25 of file ossimProjectionFactoryBase.cpp.
Referenced by ossimHdf5ProjectionFactory::createProjection(), ossimSensorModelFactory::createProjection(), ossimNgaProjectionFactory::createProjection(), ossimMapProjectionFactory::createProjection(), and ossimMiscProjectionFactory::createProjection().
