#include <ossimNitfFileHeader.h>
| ossimNitfFileHeader () | |
| virtual | ~ossimNitfFileHeader () |
| virtual void | parseStream (ossim::istream &in)=0 |
| virtual void | writeStream (ossim::ostream &out)=0 |
| virtual bool | isEncrypted () const =0 |
| virtual ossim_int32 | getNumberOfImages () const =0 |
| virtual ossim_int32 | getNumberOfLabels () const =0 |
| virtual ossim_int32 | getNumberOfSymbols () const =0 |
| virtual ossim_int32 | getNumberOfGraphics () const =0 |
| virtual ossim_int32 | getNumberOfTextSegments () const =0 |
| virtual ossim_int32 | getNumberOfDataExtSegments () const =0 |
| virtual ossim_int32 | getNumberOfReservedExtSegments () const =0 |
| virtual ossim_int32 | getHeaderSize () const =0 |
| void | addTag (const ossimNitfTagInformation &tag, bool unique=true) |
| virtual void | removeTag (const ossimString &tagName) |
| virtual bool | getTagInformation (ossimNitfTagInformation &tag, int idx) const |
| virtual std::vector< ossimNitfTagInformation > | getAllTags () |
| virtual void | setAllTags (std::vector< ossimNitfTagInformation > tagList) |
| virtual int | getNumberOfTags () const |
| virtual bool | getTag (ossimNitfTagInformation &tagInfo, const ossimString &tagName) const |
| virtual ossim_int64 | getFileSize () const =0 |
| virtual const char * | getVersion () const =0 |
| virtual const char * | getDateTime () const =0 |
| virtual ossimDrect | getImageRect () const =0 |
| virtual ossimString | getSecurityClassification () const =0 |
| virtual bool | isValid () const =0 |
| isValid will test if the fields are valid and will return true or false. More... | |
| bool | hasImages () const |
| bool | hasSymbols () const |
| bool | hasGraphics () const |
| bool | hasText () const |
| bool | hasLabels () const |
| bool | hasDataExtSegments () const |
| virtual ossimNitfImageHeader * | getNewImageHeader (ossim_uint32 imageNumber, ossim::istream &in) const =0 |
| virtual ossimNitfSymbolHeader * | getNewSymbolHeader (ossim_uint32 symbolNumber, ossim::istream &in) const =0 |
| virtual ossimNitfLabelHeader * | getNewLabelHeader (ossim_uint32 labelNumber, ossim::istream &in) const =0 |
| virtual ossimNitfTextHeader * | getNewTextHeader (ossim_uint32 textNumber, ossim::istream &in) const =0 |
| virtual ossimNitfDataExtensionSegment * | getNewDataExtensionSegment (ossim_int32 dataExtNumber, ossim::istream &in) const =0 |
| virtual ossimNitfImageHeader * | allocateImageHeader () const =0 |
| virtual ossimNitfSymbolHeader * | allocateSymbolHeader () const =0 |
| virtual ossimNitfLabelHeader * | allocateLabelHeader () const =0 |
| virtual ossimNitfTextHeader * | allocateTextHeader () const =0 |
| virtual ossimNitfDataExtensionSegment * | allocateDataExtSegment () const =0 |
| virtual ossim_uint32 | getTotalTagLength () const |
| virtual void | setFileLength (ossim_uint64 fileLength)=0 |
| Sets file length (FL) field. More... | |
| virtual void | setHeaderLength (ossim_uint64 headerLength)=0 |
| Sets header length (HL) field. More... | |
| virtual std::ostream & | print (std::ostream &out, const std::string &prefix=std::string()) const |
| Print method that outputs a key/value type format adding prefix to keys. More... | |
| virtual std::ostream & | printTags (std::ostream &out, const std::string &prefix=std::string()) const |
| print tags method that outputs a key/value type format adding prefix to keys. More... | |
| virtual bool | saveState (ossimKeywordlist &kwl, const ossimString &prefix="") const |
| ossimObject () | |
Protected Attributes | |
| std::vector< ossimNitfTagInformation > | theTagList |
| std::vector< ossimNitfDesInformation > | theDesList |
Friends | |
| class | ossimNitfFile |
Definition at line 124 of file ossimNitfFileHeader.h.
| ossimNitfFileHeader::ossimNitfFileHeader | ( | ) |
Definition at line 30 of file ossimNitfFileHeader.cpp.
Definition at line 34 of file ossimNitfFileHeader.cpp.
| void ossimNitfFileHeader::addTag | ( | const ossimNitfTagInformation & | tag, |
| bool | unique = true |
Definition at line 98 of file ossimNitfFileHeader.cpp.
References ossimNitfTagInformation::getTagName(), removeTag(), and theTagList.
Referenced by ossimNitf20Writer::addTags().
pure virtual |
Implemented in ossimNitfFileHeaderV2_0, and ossimNitfFileHeaderV2_1.
pure virtual |
pure virtual |
pure virtual |
pure virtual |
inlinevirtual |
Definition at line 151 of file ossimNitfFileHeader.h.
pure virtual |
pure virtual |
pure virtual |
pure virtual |
Referenced by ossimNitfFile::getImageRect().
pure virtual |
Referenced by ossimNitfFile::getNewDataExtensionSegment().
pure virtual |
Referenced by ossimNitfFile::getNewImageHeader().
pure virtual |
Referenced by ossimNitfFile::getNewLabelHeader().
pure virtual |
Referenced by ossimNitfFile::getNewSymbolHeader().
pure virtual |
Referenced by ossimNitfFile::getNewTextHeader().
pure virtual |
Referenced by hasDataExtSegments().
pure virtual |
Referenced by hasGraphics().
pure virtual |
Referenced by hasImages(), ossimNitfFile::print(), and ossimNitfFile::saveState().
pure virtual |
Referenced by hasLabels().
pure virtual |
pure virtual |
Referenced by hasSymbols().
Definition at line 121 of file ossimNitfFileHeader.cpp.
References theTagList.
pure virtual |
Referenced by hasText().
Reimplemented from ossimPropertyInterface.
Reimplemented in ossimNitfFileHeaderV2_0, ossimNitfFileHeaderV2_1, and ossimNitfFileHeaderV2_X.
Definition at line 143 of file ossimNitfFileHeader.cpp.
Referenced by ossimNitfFileHeaderV2_X::getProperty(), and ossimNitfTileSource::getProperty().
Definition at line 184 of file ossimNitfFileHeader.cpp.
Referenced by ossimNitfFileHeaderV2_X::getPropertyNames(), and ossimNitfTileSource::getPropertyNames().
pure virtual |
Implemented in ossimNitfFileHeaderV2_0, and ossimNitfFileHeaderV2_X.
Definition at line 39 of file ossimNitfFileHeader.cpp.
Referenced by ossimRpfFrameFileReader::parseFile(), and ossimNitfFile::print().
Definition at line 107 of file ossimNitfFileHeader.cpp.
Definition at line 126 of file ossimNitfFileHeader.cpp.
Referenced by ossimNitfFileHeaderV2_0::writeStream().
pure virtual |
| bool ossimNitfFileHeader::hasDataExtSegments | ( | ) | const |
Definition at line 81 of file ossimNitfFileHeader.cpp.
References getNumberOfDataExtSegments().
| bool ossimNitfFileHeader::hasGraphics | ( | ) | const |
Definition at line 67 of file ossimNitfFileHeader.cpp.
References getNumberOfGraphics().
| bool ossimNitfFileHeader::hasImages | ( | ) | const |
Definition at line 57 of file ossimNitfFileHeader.cpp.
References getNumberOfImages().
| bool ossimNitfFileHeader::hasLabels | ( | ) | const |
Definition at line 77 of file ossimNitfFileHeader.cpp.
References getNumberOfLabels().
| bool ossimNitfFileHeader::hasSymbols | ( | ) | const |
Definition at line 62 of file ossimNitfFileHeader.cpp.
References getNumberOfSymbols().
| bool ossimNitfFileHeader::hasText | ( | ) | const |
Definition at line 72 of file ossimNitfFileHeader.cpp.
References getNumberOfTextSegments().
pure virtual |
pure virtual |
Implemented in ossimNitfFileHeaderV2_1, ossimNitfFileHeaderV2_0, and ossimNitfFileHeaderV2_X.
pure virtual |
Reimplemented in ossimNitfFileHeaderV2_1, and ossimNitfFileHeaderV2_0.
Definition at line 210 of file ossimNitfFileHeader.cpp.
References printTags().
Referenced by ossimNitfFile::print(), ossimNitfFileHeaderV2_0::print(), and ossimNitfFileHeaderV2_1::print().
Definition at line 216 of file ossimNitfFileHeader.cpp.
References ossimNitfRegisteredTag::print(), theTagList, and ossimRefPtr< T >::valid().
Referenced by print().
Reimplemented in ossimNitfFileHeaderV2_1.
Definition at line 86 of file ossimNitfFileHeader.cpp.
Referenced by addTag().
Definition at line 189 of file ossimNitfFileHeader.cpp.
References ossimObject::saveState(), ossimNitfRegisteredTag::saveState(), theTagList, and ossimRefPtr< T >::valid().
Referenced by ossimNitfFileHeaderV2_X::saveState(), and ossimNitfFile::saveState().
inlinevirtual |
Definition at line 152 of file ossimNitfFileHeader.h.
pure virtual |
pure virtual |
Definition at line 139 of file ossimNitfFileHeader.cpp.
Referenced by ossimNitfFileHeaderV2_X::setProperty().
pure virtual |
friend |
Definition at line 128 of file ossimNitfFileHeader.h.
protected |
Definition at line 225 of file ossimNitfFileHeader.h.
Referenced by ossimNitfFileHeaderV2_1::print(), and ossimNitfFileHeaderV2_1::readDes().
protected |
Definition at line 224 of file ossimNitfFileHeader.h.
Referenced by addTag(), ossimNitfFileHeaderV2_1::addTag(), getNumberOfTags(), getTag(), getTagInformation(), getTotalTagLength(), ossimNitfFileHeaderV2_1::parseStream(), printTags(), ossimNitfFileHeaderV2_1::readOverflowTags(), ossimNitfFileHeaderV2_0::readOverflowTags(), removeTag(), ossimNitfFileHeaderV2_1::removeTag(), saveState(), ossimNitfFileHeaderV2_1::takeOverflowTags(), ossimNitfFileHeaderV2_1::writeStream(), and ossimNitfFileHeaderV2_0::writeStream().
