#include <ossimNitfImageHeader.h>
| ossimNitfImageHeader () | |
| virtual | ~ossimNitfImageHeader () |
| virtual bool | getTagInformation (ossimNitfTagInformation &tagInfo, ossim_uint32 idx) const |
| virtual std::vector< ossimNitfTagInformation > | getAllTags () |
| virtual void | setAllTags (std::vector< ossimNitfTagInformation > tagList) |
| virtual bool | getTagInformation (ossimNitfTagInformation &tagInfo, const ossimString &tagName) const |
| ossimRefPtr< ossimNitfRegisteredTag > | getTagData (const ossimString &tagName) |
| const ossimRefPtr< ossimNitfRegisteredTag > | getTagData (const ossimString &tagName) const |
| void | getTagData (const ossimString &tagName, std::vector< const ossimNitfRegisteredTag *> &tags) const |
| Returns all tags of type tagName. More... | |
| virtual ossim_uint32 | getNumberOfTags () const |
| virtual void | addTag (const ossimNitfTagInformation &tag, bool unique=true) |
| virtual void | removeTag (const ossimString &tagName) |
| virtual void | parseStream (ossim::istream &in)=0 |
| virtual void | writeStream (ossim::ostream &out)=0 |
| virtual bool | isCompressed () const =0 |
| virtual bool | isEncrypted () const =0 |
| virtual bool | isValid () const =0 |
| isValid will test if the fields are valid and will return true or false. More... | |
| virtual ossimString | getCompressionCode () const =0 |
| virtual ossimString | getCompressionRateCode () const =0 |
| virtual ossim_uint32 | getDisplayLevel () const =0 |
| virtual ossim_uint32 | getAttachmentLevel () const =0 |
| virtual ossim_int32 | getNumberOfRows () const =0 |
| virtual ossim_int32 | getNumberOfBands () const =0 |
| virtual ossim_int32 | getNumberOfCols () const =0 |
| virtual ossim_int32 | getNumberOfBlocksPerRow () const =0 |
| virtual ossim_int32 | getNumberOfBlocksPerCol () const =0 |
| virtual ossim_int32 | getNumberOfPixelsPerBlockHoriz () const =0 |
| virtual ossim_int32 | getNumberOfPixelsPerBlockVert () const =0 |
| virtual ossimString | getImageId () const =0 |
| virtual ossimString | getTitle () const =0 |
| virtual ossim_int32 | getActualBitsPerPixelPerBand () const =0 |
| virtual ossim_int32 | getBitsPerPixelPerBand () const =0 |
| virtual ossimIrect | getImageRect () const =0 |
| virtual ossimIrect | getBlockImageRect () const =0 |
| Blocks might not be the same size as the significant rows and cols used by the getImageRect. More... | |
| virtual ossimString | getIMode () const =0 |
| virtual ossim_uint64 | getDataLocation () const =0 |
| virtual ossimString | getImageDateAndTime () const =0 |
| virtual ossimString | getAcquisitionDateMonthDayYear (ossim_uint8 separationChar='-') const =0 |
| virtual ossimString | getSecurityClassification () const =0 |
| virtual ossimString | getCategory () const =0 |
| virtual ossimString | getImageSource () const =0 |
| virtual ossimString | getRepresentation () const =0 |
| virtual ossimString | getCoordinateSystem () const =0 |
| virtual ossimString | getGeographicLocation () const =0 |
| virtual ossimString | getPixelValueType () const =0 |
| virtual ossimString | getImageMagnification () const =0 |
| virtual void | getImageLocation (ossimIpt &loc) const =0 |
| Gets the ILOC field as an ossimIpt. More... | |
| virtual void | getDecimationFactor (ossim_float64 &result) const |
| Convenience method to get the decimation factor as a double from the string returned be the getImageMagnification() method. More... | |
| virtual bool | hasBlockMaskRecords () const =0 |
| virtual bool | hasPadPixelMaskRecords () const =0 |
| virtual bool | hasTransparentCode () const =0 |
| virtual ossim_uint32 | getTransparentCode () const =0 |
| virtual ossim_uint32 | getBlockMaskRecordOffset (ossim_uint32 blockNumber, ossim_uint32 bandNumber) const =0 |
| virtual ossim_uint32 | getPadPixelMaskRecordOffset (ossim_uint32 blockNumber, ossim_uint32 bandNumber) const =0 |
| virtual const ossimRefPtr< ossimNitfCompressionHeader > | getCompressionHeader () const =0 |
| virtual const ossimRefPtr< ossimNitfImageBand > | getBandInformation (ossim_uint32 idx) const =0 |
| bool | hasLut () const |
| ossimRefPtr< ossimNBandLutDataObject > | createLut (ossim_uint32 bandIdx) const |
| virtual bool | isSameAs (const ossimNitfImageHeader *hdr) const |
| virtual ossim_uint32 | getTotalTagLength () const |
| virtual std::ostream & | printTags (std::ostream &out, const std::string &prefix=std::string()) const |
| print method that outputs a key/value type format adding prefix to keys. More... | |
| virtual void | getMetadata (ossimKeywordlist &kwl, const char *prefix=0) const |
| Populates keyword list with metadata. More... | |
| virtual std::ostream & | print (std::ostream &out, const std::string &prefix) const =0 |
| pure virtual print method that outputs a key/value type format adding prefix to keys. More... | |
| virtual bool | saveState (ossimKeywordlist &kwl, const ossimString &prefix="") const |
| ossimObject () | |
| void | checkForGeographicTiePointTruncation (const ossimDpt &tie) const |
| Method to check tie point to see if it will be truncated in field IGEOLO which has only arc second resolution. More... | |
Protected Attributes | |
| std::vector< ossimNitfTagInformation > | theTagList |
Definition at line 31 of file ossimNitfImageHeader.h.
| ossimNitfImageHeader::ossimNitfImageHeader | ( | ) |
Definition at line 32 of file ossimNitfImageHeader.cpp.
Definition at line 36 of file ossimNitfImageHeader.cpp.
Definition at line 128 of file ossimNitfImageHeader.cpp.
References ossimNitfTagInformation::getTagName(), removeTag(), and theTagList.
Referenced by ossimNitfWriterBase::addGeolobTag(), ossimNitf20Writer::addRegisteredTag(), ossimNitfWriter::addRegisteredTag(), and ossimNitfWriterBase::addRpcbTag().
protected |
Spits out warning if tie does not evenly divide by an arc second.
| tie | Tie point to check. |
Definition at line 332 of file ossimNitfImageHeader.cpp.
References ossimNotify(), ossimNotifyLevel_WARN, ossimDpt::x, x, ossimDpt::y, and y.
| ossimRefPtr< ossimNBandLutDataObject > ossimNitfImageHeader::createLut | ( | ossim_uint32 | bandIdx | ) | const |
Definition at line 290 of file ossimNitfImageHeader.cpp.
References ossimNBandLutDataObject::create(), getBandInformation(), ossimNitfImageBand::getLut(), getNumberOfBands(), ossimNitfImageBand::getNumberOfLuts(), ossimNitfImageLut::getValue(), and ossimRefPtr< T >::valid().
pure virtual |
Implemented in ossimNitfImageHeaderV2_0, and ossimNitfImageHeaderV2_1.
Referenced by getMetadata(), and ossimNitfImageHeaderV2_X::getProperty().
pure virtual |
Referenced by ossimNitfTileSource::getMaxPixelValue(), and ossimNitfTileSource::initializeScalarType().
inlinevirtual |
Definition at line 41 of file ossimNitfImageHeader.h.
pure virtual |
Implemented in ossimNitfImageHeaderV2_X.
pure virtual |
pure virtual |
Referenced by ossimJpeg12NitfReader::canUncompress(), ossimNitfTileSource::canUncompress(), ossimNitfTileSource::explodePackedBits(), ossimNitfTileSource::getMaxPixelValue(), ossimNitfTileSource::getPartialReadSize(), ossimNitfTileSource::initializeScalarType(), and isSameAs().
pure virtual |
Implemented in ossimNitfImageHeaderV2_1, and ossimNitfImageHeaderV2_X.
Referenced by ossimNitfTileSource::initializeImageRect().
pure virtual |
Implemented in ossimNitfImageHeaderV2_1, and ossimNitfImageHeaderV2_0.
Referenced by ossimNitfTileSource::getPosition().
pure virtual |
Implemented in ossimNitfImageHeaderV2_X, ossimNitfImageHeaderV2_0, and ossimNitfImageHeaderV2_1.
Referenced by ossimNitfFile::print(), and ossimNitfFile::saveState().
pure virtual |
Referenced by ossimOpjNitfReader::canUncompress(), ossimJpeg12NitfReader::canUncompress(), ossimKakaduNitfReader::canUncompress(), ossimNitfTileSource::canUncompress(), ossimNitfCodecFactory::createCodec(), ossimNitfTileSource::initializeBandCount(), ossimNitfTileSource::initializeBlockSize(), ossimNitfTileSource::initializeCompressedBuf(), ossimOpjNitfReader::initializeReadMode(), ossimKakaduNitfReader::initializeReadMode(), ossimNitfTileSource::initializeReadMode(), and ossimKakaduNitfReader::isEntryJ2k().
pure virtual |
Referenced by ossimNitfTileSource::vqUncompressC4(), and ossimNitfTileSource::vqUncompressM4().
pure virtual |
Referenced by ossimJpeg12NitfReader::loadJpeg12QuantizationTables(), and ossimNitfTileSource::loadJpegQuantizationTables().
pure virtual |
Implemented in ossimNitfImageHeaderV2_0, ossimNitfImageHeaderV2_1, and ossimNitfImageHeaderV2_X.
Referenced by ossimNitfProjectionFactory::createProjectionFromHeaders(), and isSameAs().
pure virtual |
| result | Initialized with the decimation factor as a double. Will return an ossim::nan() if something bad happens like the string is empty so callers should check result with ossim::isnan(result). |
Definition at line 357 of file ossimNitfImageHeader.cpp.
References ossimString::after(), ossimString::contains(), getImageMagnification(), ossim::nan(), ossimString::size(), ossimString::toFloat64(), and ossimString::trim().
Referenced by ossimNitfTileSource::establishDecimationFactors(), and ossimNitfFile::print().
pure virtual |
Referenced by ossimNitfFileHeaderV2_0::initializeDisplayLevels().
pure virtual |
Referenced by isSameAs(), ossimNitfProjectionFactory::makeGeographic(), and ossimNitfProjectionFactory::makeUtm().
pure virtual |
pure virtual |
pure virtual |
| loc | Initialized with the field. |
pure virtual |
pure virtual |
Referenced by ossimNitfProjectionFactory::computeScaleInDecimalDegrees(), ossimNitfProjectionFactory::computeScaleInMeters(), ossimNitfFileHeaderV2_0::initializeDisplayLevels(), ossimNitfTileSource::initializeImageRect(), isSameAs(), and ossimQuickbirdRpcModel::parseNitfFile().
pure virtual |
Implemented in ossimNitfImageHeaderV2_1, ossimNitfImageHeaderV2_0, and ossimNitfImageHeaderV2_X.
Referenced by getMetadata().
pure virtual |
expample: country_code: US
| kwl | Keywordlist to populate with metadata. |
| prefix | Optional prefix to put in front of key, like: "image1.". |
Definition at line 249 of file ossimNitfImageHeader.cpp.
References ossimKeywordlist::add(), getAcquisitionDateMonthDayYear(), getImageSource(), and getTitle().
pure virtual |
Referenced by createLut(), hasLut(), ossimNitfTileSource::initializeBandCount(), and isSameAs().
pure virtual |
Referenced by ossimKakaduNitfReader::dumpTiles(), ossimNitfImageHeaderV2_X::getBlockImageRect(), ossimNitfTileSource::getNumberOfBlocks(), isSameAs(), ossimOpjNitfReader::scanForJpegBlockOffsets(), and ossimNitfTileSource::scanForJpegBlockOffsets().
pure virtual |
Referenced by ossimKakaduNitfReader::dumpTiles(), ossimNitfImageHeaderV2_X::getBlockImageRect(), ossimNitfTileSource::getBlockNumber(), ossimNitfTileSource::getNumberOfBlocks(), isSameAs(), ossimOpjNitfReader::scanForJpegBlockOffsets(), and ossimNitfTileSource::scanForJpegBlockOffsets().
pure virtual |
Referenced by ossimNitfImageHeaderV2_X::getImageRect(), ossimNitfTileSource::getNumberOfSamples(), isSameAs(), and ossimNitfProjectionFactory::makeBilinear().
pure virtual |
pure virtual |
pure virtual |
Referenced by ossimNitfImageHeaderV2_X::getImageRect(), ossimNitfTileSource::getNumberOfLines(), isSameAs(), and ossimNitfProjectionFactory::makeBilinear().
Definition at line 123 of file ossimNitfImageHeader.cpp.
References theTagList.
pure virtual |
Referenced by ossimNitfTileSource::convertTransparentToNull().
pure virtual |
Referenced by ossimNitfTileSource::initializeScalarType().
Reimplemented from ossimPropertyInterface.
Reimplemented in ossimNitfImageHeaderV2_1, ossimNitfImageHeaderV2_X, and ossimNitfImageHeaderV2_0.
Definition at line 176 of file ossimNitfImageHeader.cpp.
Referenced by ossimNitfImageHeaderV2_X::getProperty(), and ossimNitfTileSource::getProperty().
Definition at line 217 of file ossimNitfImageHeader.cpp.
Referenced by ossimNitfImageHeaderV2_X::getPropertyNames(), and ossimNitfTileSource::getPropertyNames().
pure virtual |
pure virtual |
Referenced by ossimNitfTileSource::getSecurityClassification().
| ossimRefPtr< ossimNitfRegisteredTag > ossimNitfImageHeader::getTagData | ( | const ossimString & | tagName | ) |
Definition at line 72 of file ossimNitfImageHeader.cpp.
Referenced by ossimImageGeometryFactory::createTransformFromNitf(), ossimNitfProjectionFactory::getBlockaPoints(), ossimNitfRpcModel::getGsd(), ossimNitfRpcModel::getRpcData(), ossimNitfRpcModel::getSensorID(), and ossimQuickbirdRpcModel::parseNitfFile().
| const ossimRefPtr< ossimNitfRegisteredTag > ossimNitfImageHeader::getTagData | ( | const ossimString & | tagName | ) | const |
Definition at line 89 of file ossimNitfImageHeader.cpp.
| void ossimNitfImageHeader::getTagData | ( | const ossimString & | tagName, |
| std::vector< const ossimNitfRegisteredTag *> & | tags | ||
| ) | const |
Vector passed in "tags" is cleared, then initialized with all tags found of "tagName". Size of vector is returned.
| tagName | E.g. "RSMPCA" |
| tags | Initialized by this. |
Definition at line 58 of file ossimNitfImageHeader.cpp.
Definition at line 40 of file ossimNitfImageHeader.cpp.
pure virtual |
Definition at line 223 of file ossimNitfImageHeader.cpp.
Referenced by ossimNitfImageHeaderV2_1::writeStream(), and ossimNitfImageHeaderV2_0::writeStream().
pure virtual |
pure virtual |
| bool ossimNitfImageHeader::hasLut | ( | ) | const |
Definition at line 265 of file ossimNitfImageHeader.cpp.
References getBandInformation(), ossimNitfImageBand::getLut(), getNumberOfBands(), ossimNitfImageBand::getNumberOfLuts(), and ossimRefPtr< T >::valid().
Referenced by ossimNitfTileSource::initializeLut().
pure virtual |
pure virtual |
pure virtual |
Referenced by ossimNitfCodecFactory::createCodec(), ossimNitfTileSource::initializeScalarType(), and isSameAs().
pure virtual |
Definition at line 150 of file ossimNitfImageHeader.cpp.
References getBitsPerPixelPerBand(), getCoordinateSystem(), getGeographicLocation(), getImageRect(), getIMode(), getNumberOfBands(), getNumberOfBlocksPerCol(), getNumberOfBlocksPerRow(), getNumberOfCols(), getNumberOfPixelsPerBlockHoriz(), getNumberOfPixelsPerBlockVert(), getNumberOfRows(), and isCompressed().
pure virtual |
Implemented in ossimNitfImageHeaderV2_0, ossimNitfImageHeaderV2_X, and ossimNitfImageHeaderV2_1.
pure virtual |
Implemented in ossimNitfImageHeaderV2_0.
Referenced by ossimNitfFileHeaderV2_0::getNewImageHeader(), and ossimNitfFileHeaderV2_0::initializeDisplayLevels().
pure virtual |
Referenced by ossimNitfFile::print().
Definition at line 235 of file ossimNitfImageHeader.cpp.
References ossimNitfRegisteredTag::print(), theTagList, and ossimRefPtr< T >::valid().
Definition at line 137 of file ossimNitfImageHeader.cpp.
Referenced by addTag(), and ossimNitfImageHeaderV2_1::takeOverflowTags().
Definition at line 402 of file ossimNitfImageHeader.cpp.
References ossimObject::saveState(), ossimNitfRegisteredTag::saveState(), theTagList, and ossimRefPtr< T >::valid().
Referenced by ossimNitfCodecFactory::createCodec(), ossimNitfImageHeaderV2_X::saveState(), and ossimNitfFile::saveState().
inlinevirtual |
Definition at line 43 of file ossimNitfImageHeader.h.
Definition at line 172 of file ossimNitfImageHeader.cpp.
Referenced by ossimNitfImageHeaderV2_X::setProperty().
pure virtual |
protected |
Definition at line 199 of file ossimNitfImageHeader.h.
Referenced by addTag(), ossimNitfImageHeaderV2_0::clearFields(), getNumberOfTags(), getTagData(), getTagInformation(), getTotalTagLength(), ossimNitfImageHeaderV2_0::parseStream(), printTags(), removeTag(), saveState(), ossimNitfImageHeaderV2_1::takeOverflowTags(), ossimNitfImageHeaderV2_1::writeStream(), and ossimNitfImageHeaderV2_0::writeStream().
