#include <ossimNitfTagInformation.h>
| ossimNitfTagInformation (ossimRefPtr< ossimNitfRegisteredTag > tagData=0) | |
| virtual | ~ossimNitfTagInformation () |
| virtual void | parseStream (ossim::istream &in) |
| virtual void | writeStream (ossim::ostream &out) |
| void | setTagName (const ossimString &tagName) |
| void | setTagLength (ossim_uint32 tagLength) |
| ossim_uint32 | getTotalTagLength () const |
| Length of the 5 byte tag length the 6 byte tag name and the data length. More... | |
| ossim_uint32 | getTagLength () const |
| Should return the value of theTagLength which is the length of the data in bytes. More... | |
| ossim_uint64 | getTagOffset () const |
| ossim_uint64 | getTagDataOffset () const |
| ossimString | getTagName () const |
| void | clearFields () |
| ossimRefPtr< ossimNitfRegisteredTag > | getTagData () |
| const ossimRefPtr< ossimNitfRegisteredTag > | getTagData () const |
| void | setTagData (ossimRefPtr< ossimNitfRegisteredTag > tagData) |
| ossimString | getTagType () const |
| void | setTagType (const ossimString &tagType) const |
| bool | operator< (const ossimNitfTagInformation &rhs) const |
| ossimObject () | |
Private Attributes | |
| char | theTagName [7] |
| This is a 6 byte field. More... | |
| char | theTagLength [6] |
| This is a 5 byte field. More... | |
| char | theTagType [7] |
| This is a 6 byte field which should be UDHD, UDID, XHD, IXSHD, SXSHD, or TXSHD. More... | |
| ossim_uint64 | theTagOffset |
| This will hold the offset to the start of the above information This is just a work variable. More... | |
| ossim_uint64 | theTagDataOffset |
| This will hold the start to the data. More... | |
| ossimRefPtr< ossimNitfRegisteredTag > | theTagData |
| Used to hold the tag data. More... | |
Definition at line 22 of file ossimNitfTagInformation.h.
| ossimNitfTagInformation::ossimNitfTagInformation | ( | ossimRefPtr< ossimNitfRegisteredTag > | tagData = 0 | ) |
Definition at line 21 of file ossimNitfTagInformation.cpp.
References clearFields(), and setTagData().
Definition at line 27 of file ossimNitfTagInformation.cpp.
| void ossimNitfTagInformation::clearFields | ( | ) |
Definition at line 129 of file ossimNitfTagInformation.cpp.
References theTagDataOffset, theTagLength, theTagName, theTagOffset, and theTagType.
Referenced by ossimNitfTagInformation(), parseStream(), and ossimNitfDataExtensionSegmentV2_1::parseStream().
| ossimRefPtr< ossimNitfRegisteredTag > ossimNitfTagInformation::getTagData | ( | ) |
Definition at line 172 of file ossimNitfTagInformation.cpp.
References theTagData.
| const ossimRefPtr< ossimNitfRegisteredTag > ossimNitfTagInformation::getTagData | ( | ) | const |
Definition at line 177 of file ossimNitfTagInformation.cpp.
| ossim_uint64 ossimNitfTagInformation::getTagDataOffset | ( | ) | const |
Definition at line 107 of file ossimNitfTagInformation.cpp.
References theTagDataOffset.
Referenced by ossimRpfFrameFileReader::parseFile().
| ossim_uint32 ossimNitfTagInformation::getTagLength | ( | ) | const |
Definition at line 97 of file ossimNitfTagInformation.cpp.
References theTagLength, and ossimString::toUInt32().
Referenced by getTotalTagLength(), and parseStream().
| ossimString ossimNitfTagInformation::getTagName | ( | ) | const |
Definition at line 112 of file ossimNitfTagInformation.cpp.
References theTagName, and ossimString::trim().
Referenced by ossimNitfImageHeader::addTag(), ossimNitfFileHeader::addTag(), ossimNitfFileHeaderV2_1::addTag(), ossimRpfFrameFileReader::parseFile(), parseStream(), and ossimNitfFile::print().
| ossim_uint64 ossimNitfTagInformation::getTagOffset | ( | ) | const |
Definition at line 102 of file ossimNitfTagInformation.cpp.
References theTagOffset.
| ossimString ossimNitfTagInformation::getTagType | ( | ) | const |
Definition at line 195 of file ossimNitfTagInformation.cpp.
References theTagType, and ossimString::trim().
| ossim_uint32 ossimNitfTagInformation::getTotalTagLength | ( | ) | const |
So we have Data length + 11 bytes.
Definition at line 92 of file ossimNitfTagInformation.cpp.
References getTagLength().
Referenced by operator<().
inline |
Definition at line 59 of file ossimNitfTagInformation.h.
References getTotalTagLength().
Definition at line 31 of file ossimNitfTagInformation.cpp.
References clearFields(), ossimNitfTagFactoryRegistry::create(), ossimObject::getClassName(), getTagLength(), ossimNitfRegisteredTag::getTagLength(), getTagName(), ossimNitfRegisteredTag::getTagName(), ossimNitfTagFactoryRegistry::instance(), ossimNotify(), ossimNotifyLevel_WARN, ossimNitfRegisteredTag::parseStream(), ossimNitfRegisteredTag::setTagLength(), ossimNitfRegisteredTag::setTagName(), theTagData, theTagDataOffset, theTagLength, theTagName, theTagOffset, and ossimRefPtr< T >::valid().
Referenced by ossimNitfImageHeaderV2_0::parseStream(), ossimNitfDataExtensionSegmentV2_0::parseStream(), ossimNitfDataExtensionSegmentV2_1::parseStream(), and ossimNitfFileHeaderV2_1::parseStream().
Generic print method.
Derived classes should re-implement as they see fit.
Definition at line 117 of file ossimNitfTagInformation.cpp.
| void ossimNitfTagInformation::setTagData | ( | ossimRefPtr< ossimNitfRegisteredTag > | tagData | ) |
Definition at line 182 of file ossimNitfTagInformation.cpp.
References ossimNitfRegisteredTag::getRegisterTagName(), ossimNitfRegisteredTag::getSizeInBytes(), setTagLength(), setTagName(), theTagData, theTagLength, theTagName, and ossimRefPtr< T >::valid().
Referenced by ossimNitf20Writer::addRegisteredTag(), ossimNitfWriter::addRegisteredTag(), and ossimNitfTagInformation().
| void ossimNitfTagInformation::setTagLength | ( | ossim_uint32 | tagLength | ) |
Definition at line 154 of file ossimNitfTagInformation.cpp.
References theTagLength.
Referenced by setTagData().
| void ossimNitfTagInformation::setTagName | ( | const ossimString & | tagName | ) |
Definition at line 142 of file ossimNitfTagInformation.cpp.
References theTagName.
| void ossimNitfTagInformation::setTagType | ( | const ossimString & | tagType | ) | const |
Definition at line 200 of file ossimNitfTagInformation.cpp.
References theTagType.
Referenced by ossimNitfWriter::addRegisteredTag(), and ossimNitfFileHeaderV2_1::parseStream().
Definition at line 80 of file ossimNitfTagInformation.cpp.
References theTagData, theTagDataOffset, theTagLength, theTagName, theTagOffset, ossimRefPtr< T >::valid(), and ossimNitfRegisteredTag::writeStream().
private |
Definition at line 98 of file ossimNitfTagInformation.h.
Referenced by getTagData(), parseStream(), setTagData(), and writeStream().
private |
This is just the position in the file just past the tag length field. This is just a work variable
Definition at line 93 of file ossimNitfTagInformation.h.
Referenced by clearFields(), getTagDataOffset(), parseStream(), print(), and writeStream().
private |
Definition at line 74 of file ossimNitfTagInformation.h.
Referenced by clearFields(), getTagLength(), parseStream(), print(), setTagData(), setTagLength(), and writeStream().
private |
Definition at line 69 of file ossimNitfTagInformation.h.
Referenced by clearFields(), getTagName(), parseStream(), print(), setTagData(), setTagName(), and writeStream().
private |
Definition at line 86 of file ossimNitfTagInformation.h.
Referenced by clearFields(), getTagOffset(), parseStream(), print(), and writeStream().
mutableprivate |
This is declared as mutable since changing the tag type doesn't change the contents of the tag.
Definition at line 80 of file ossimNitfTagInformation.h.
Referenced by clearFields(), getTagType(), print(), and setTagType().
