#include <ossimEckert6Projection.h>
| ossimEckert6Projection (const ossimEllipsoid &ellipsoid=ossimEllipsoid(), const ossimGpt &origin=ossimGpt()) | |
| ossimEckert6Projection (const ossimEllipsoid &ellipsoid, const ossimGpt &origin, double falseEasting, double falseNorthing) | |
| ~ossimEckert6Projection () | |
| virtual ossimGpt | inverse (const ossimDpt &eastingNorthing) const |
| Will take a point in meters and convert it to ground. More... | |
| virtual ossimDpt | forward (const ossimGpt &latLon) const |
| All map projections will convert the world coordinate to an easting northing (Meters). More... | |
| virtual void | update () |
| void | setFalseEasting (double falseEasting) |
| void | setFalseNorthing (double falseNorthing) |
| void | setFalseEastingNorthing (double falseEasting, double falseNorthing) |
| double | getFalseEasting () const |
| double | getFalseNorthing () const |
| void | setDefaults () |
| void | setCentralMeridian (double centralMeridian) |
Public Member Functions inherited from ossimMapProjection | |
| ossimMapProjection (const ossimEllipsoid &ellipsoid=ossimEllipsoid(), const ossimGpt &origin=ossimGpt()) | |
| ossimMapProjection (const ossimMapProjection &src) | |
| virtual ossimDpt | worldToLineSample (const ossimGpt &worldPoint) const |
| virtual void | worldToLineSample (const ossimGpt &worldPoint, ossimDpt &lineSample) const |
| virtual ossimGpt | lineSampleToWorld (const ossimDpt &projectedPoint) const |
| virtual void | lineSampleToWorld (const ossimDpt &projectedPoint, ossimGpt &gpt) const |
| virtual void | lineSampleHeightToWorld (const ossimDpt &lineSampPt, const double &heightAboveEllipsoid, ossimGpt &worldPt) const |
| This is the pure virtual that projects the image point to the given elevation above ellipsoid, thereby bypassing reference to a DEM. More... | |
| virtual void | lineSampleToEastingNorthing (const ossimDpt &liineSample, ossimDpt &eastingNorthing) const |
| virtual void | eastingNorthingToLineSample (const ossimDpt &eastingNorthing, ossimDpt &lineSample) const |
| virtual void | eastingNorthingToWorld (const ossimDpt &eastingNorthing, ossimGpt &worldPt) const |
| virtual double | getStandardParallel1 () const |
| Derived classes should implement as needed. More... | |
| virtual double | getStandardParallel2 () const |
| virtual void | setPcsCode (ossim_uint32 pcsCode) |
| virtual ossim_uint32 | getPcsCode () const |
| Returns the EPSG PCS code or 32767 if the projection is a custom (non-EPSG) projection. More... | |
| virtual ossimString | getProjectionName () const |
| Returns the projection name. More... | |
| virtual double | getA () const |
| ACCESS METHODS: More... | |
| virtual double | getB () const |
| virtual double | getF () const |
| virtual const ossimDpt & | getDecimalDegreesPerPixel () const |
| Returns decimal degrees per pixel as an ossimDpt with "x" representing longitude and "y" representing latitude. More... | |
| virtual const ossimDpt & | getUlEastingNorthing () const |
| virtual const ossimGpt & | getUlGpt () const |
| virtual const ossimDatum * | getDatum () const |
| const ossimEllipsoid & | getEllipsoid () const |
| const ossimGpt & | getOrigin () const |
| virtual bool | isGeographic () const |
| virtual void | applyScale (const ossimDpt &scale, bool recenterTiePoint) |
| Applies scale to theDeltaLonPerPixel, theDeltaLatPerPixel and theMetersPerPixel data members (eg: theDeltaLonPerPixel *= scale.x). More... | |
| virtual void | setEllipsoid (const ossimEllipsoid &ellipsoid) |
| SET METHODS: More... | |
| virtual void | setAB (double a, double b) |
| virtual void | setDatum (const ossimDatum *datum) |
| Sets theDatum to datum. More... | |
| virtual void | setOrigin (const ossimGpt &origin) |
| Sets theOrigin to origin. More... | |
| virtual void | setMetersPerPixel (const ossimDpt &gsd) |
| virtual void | setDecimalDegreesPerPixel (const ossimDpt &gsd) |
| virtual void | setUlTiePoints (const ossimGpt &gpt) |
| virtual void | setUlTiePoints (const ossimDpt &eastingNorthing) |
| virtual void | setUlEastingNorthing (const ossimDpt &ulEastingNorthing) |
| virtual void | setUlGpt (const ossimGpt &ulGpt) |
| virtual void | assign (const ossimProjection &aProjection) |
| Prints data members to stream. More... | |
| virtual bool | operator== (const ossimProjection &projection) const |
| Compares this to arg projection and returns TRUE if the same. More... | |
| virtual void | computeDegreesPerPixel () |
| Computes the approximate resolution in degrees/pixel. More... | |
| virtual void | computeMetersPerPixel () |
| This will go from the ground point and give you an approximate meters per pixel. More... | |
| void | setMatrix (double rotation, const ossimDpt &scale, const ossimDpt &translation) |
| void | setMatrixScale (const ossimDpt &scale) |
| void | setMatrixRotation (double rotation) |
| void | setMatrixTranslation (const ossimDpt &translation) |
| void | snapTiePointTo (ossim_float64 multiple, ossimUnitType unitType) |
| Utility method to snap the tie point to some multiple. More... | |
| void | snapTiePointToOrigin () |
| void | setElevationLookupFlag (bool flag) |
| bool | getElevationLookupFlag () const |
| ossimUnitType | getModelTransformUnitType () const |
| void | setModelTransformUnitType (ossimUnitType unit) |
| bool | hasModelTransform () const |
| void | setProjectionUnits (ossimUnitType units) |
| ossimUnitType | getProjectionUnits () const |
| OSSIM considers all map projection coordinates (including false eastings and northings) to be in meters. More... | |
| ossimProjection () | |
| ossimObject () | |
| bool | hasError () const |
Private Member Functions | |
| long | Set_Eckert6_Parameters (double a, double f, double Central_Meridian, double False_Easting, double False_Northing) |
| void | Get_Eckert6_Parameters (double *a, double *f, double *Central_Meridian, double *False_Easting, double *False_Northing) const |
| long | Convert_Geodetic_To_Eckert6 (double Latitude, double Longitude, double *Easting, double *Northing) const |
| long | Convert_Eckert6_To_Geodetic (double Easting, double Northing, double *Latitude, double *Longitude) const |
Private Attributes | |
| double | Eck6_a |
| double | Eck6_f |
| double | es2 |
| double | es4 |
| double | es6 |
| double | Ra_Over_Sqrt_Two_Plus_PI |
| double | Inv_Ra_Over_Sqrt_Two_Plus_PI |
| double | Eck6_Origin_Long |
| double | Eck6_False_Easting |
| double | Eck6_False_Northing |
| double | Eck6_Delta_Northing |
| double | Eck6_Max_Easting |
| double | Eck6_Min_Easting |
Protected Member Functions inherited from ossimMapProjection | |
| virtual | ~ossimMapProjection () |
| void | updateFromTransform () |
Protected Attributes inherited from ossimMapProjection | |
| ossimEllipsoid | theEllipsoid |
| This method verifies that the projection parameters match the current pcs code. More... | |
| ossimGpt | theOrigin |
| const ossimDatum * | theDatum |
| This is only set if we want to have built in datum shifting. More... | |
| ossimDpt | theMetersPerPixel |
| Holds the number of meters per pixel. More... | |
| ossimDpt | theDegreesPerPixel |
| Hold the decimal degrees per pixel. More... | |
| ossimGpt | theUlGpt |
| Hold tie point in decimal degrees. More... | |
| ossimDpt | theUlEastingNorthing |
| Hold tie point as easting northing. More... | |
| ossimDpt | theFalseEastingNorthing |
| Hold the false easting northing. More... | |
| ossim_uint32 | thePcsCode |
| Projection Coordinate System(PCS) code. More... | |
| bool | theElevationLookupFlag |
| ossimMatrix4x4 | theModelTransform |
| ossimMatrix4x4 | theInverseModelTransform |
| ossimUnitType | theModelTransformUnitType |
| ossimUnitType | theProjectionUnits |
| Linear units of the projection as indicated in the projection's specification: More... | |
Definition at line 18 of file ossimEckert6Projection.h.
| ossimEckert6Projection::ossimEckert6Projection | ( | const ossimEllipsoid & | ellipsoid = ossimEllipsoid(), |
| const ossimGpt & | origin = ossimGpt() |
Definition at line 50 of file ossimEckert6Projection.cpp.
References setDefaults().
| ossimEckert6Projection::ossimEckert6Projection | ( | const ossimEllipsoid & | ellipsoid, |
| const ossimGpt & | origin, | ||
| double | falseEasting, | ||
| double | falseNorthing | ||
Definition at line 57 of file ossimEckert6Projection.cpp.
References Eck6_Delta_Northing, Eck6_False_Easting, Eck6_False_Northing, Eck6_Max_Easting, Eck6_Min_Easting, and update().
inline |
Definition at line 27 of file ossimEckert6Projection.h.
private |
The function Convert_Eckert6_To_Geodetic converts Eckert VI projection easting and northing coordinates to geodetic (latitude and longitude) coordinates, according to the current ellipsoid and Eckert VI projection coordinates. If any errors occur, the error code(s) are returned by the function, otherwise ECK6_NO_ERROR is returned.
Easting : Easting (X) in meters (input) Northing : Northing (Y) in meters (input) Latitude : Latitude (phi) in radians (output) Longitude : Longitude (lambda) in radians (output)
Definition at line 357 of file ossimEckert6Projection.cpp.
References Eck6_False_Easting, Eck6_False_Northing, ECK6_NO_ERROR, Eck6_Origin_Long, Inv_Ra_Over_Sqrt_Two_Plus_PI, MAX_LAT, and one_PLUS_PI_OVER_2.
Referenced by inverse().
private |
The function Convert_Geodetic_To_Eckert6 converts geodetic (latitude and longitude) coordinates to Eckert VI projection easting, and northing coordinates, according to the current ellipsoid and Eckert VI projection parameters. If any errors occur, the error code(s) are returned by the function, otherwise ECK6_NO_ERROR is returned.
Latitude : Latitude (phi) in radians (input) Longitude : Longitude (lambda) in radians (input) Easting : Easting (X) in meters (output) Northing : Northing (Y) in meters (output)
Definition at line 293 of file ossimEckert6Projection.cpp.
References Eck6_False_Easting, Eck6_False_Northing, ECK6_NO_ERROR, Eck6_Origin_Long, one_PLUS_PI_OVER_2, and Ra_Over_Sqrt_Two_Plus_PI.
Referenced by forward().
inlinevirtual |
Implements ossimProjection.
Definition at line 28 of file ossimEckert6Projection.h.
Definition at line 99 of file ossimEckert6Projection.cpp.
References ossimGpt::changeDatum(), ossimDatum::code(), Convert_Geodetic_To_Eckert6(), ossimGpt::datum(), ossimGpt::latr(), ossimGpt::lonr(), and ossimMapProjection::theDatum.
private |
The function Get_Eckert6_Parameters returns the current ellipsoid parameters and Eckert VI projection parameters.
a : Semi-major axis of ellipsoid, in meters (output) f : Flattening of ellipsoid (output) Central_Meridian : Longitude in radians at the center of (output) the projection False_Easting : A coordinate value in meters assigned to the central meridian of the projection. (output) False_Northing : A coordinate value in meters assigned to the origin latitude of the projection (output)
Definition at line 263 of file ossimEckert6Projection.cpp.
References Eck6_a, Eck6_f, Eck6_False_Easting, Eck6_False_Northing, and Eck6_Origin_Long.
inlinevirtual |
Definition at line 53 of file ossimEckert6Projection.h.
inlinevirtual |
Definition at line 54 of file ossimEckert6Projection.h.
Definition at line 86 of file ossimEckert6Projection.cpp.
References Convert_Eckert6_To_Geodetic(), DEG_PER_RAD, ossimMapProjection::theDatum, ossimDpt::x, and ossimDpt::y.
Definition at line 163 of file ossimEckert6Projection.cpp.
References Eck6_False_Easting, Eck6_False_Northing, ossimKeywordlist::find(), ossimMapProjection::loadState(), setDefaults(), STATIC_TYPE_NAME, ossimMapProjection::theFalseEastingNorthing, ossimKeywordNames::TYPE_KW, update(), ossimDpt::x, and ossimDpt::y.
Definition at line 158 of file ossimEckert6Projection.cpp.
References ossimMapProjection::saveState().
private |
The function Set_Eckert6_Parameters receives the ellipsoid parameters and Eckert VI projection parameters as inputs, and sets the corresponding state variables. If any errors occur, the error code(s) are returned by the function, otherwise ECK6_NO_ERROR is returned.
a : Semi-major axis of ellipsoid, in meters (input) f : Flattening of ellipsoid (input) Central_Meridian : Longitude in radians at the center of (input) the projection False_Easting : A coordinate value in meters assigned to the central meridian of the projection. (input) False_Northing : A coordinate value in meters assigned to the origin latitude of the projection (input)
Definition at line 188 of file ossimEckert6Projection.cpp.
References Eck6_a, Eck6_f, Eck6_False_Easting, Eck6_False_Northing, Eck6_Max_Easting, Eck6_Min_Easting, ECK6_NO_ERROR, Eck6_Origin_Long, es2, es4, es6, Inv_Ra_Over_Sqrt_Two_Plus_PI, M_PI, and Ra_Over_Sqrt_Two_Plus_PI.
Referenced by update().
| void ossimEckert6Projection::setCentralMeridian | ( | double | centralMeridian | ) |
Definition at line 152 of file ossimEckert6Projection.cpp.
References Eck6_Origin_Long, and update().
| void ossimEckert6Projection::setDefaults | ( | ) |
Initialize all pramters to default and calls update for pre-computations.
Definition at line 141 of file ossimEckert6Projection.cpp.
Referenced by loadState(), and ossimEckert6Projection().
| void ossimEckert6Projection::setFalseEasting | ( | double | falseEasting | ) |
Definition at line 121 of file ossimEckert6Projection.cpp.
References Eck6_False_Easting, and update().
| void ossimEckert6Projection::setFalseEastingNorthing | ( | double | falseEasting, |
Definition at line 133 of file ossimEckert6Projection.cpp.
References Eck6_False_Easting, Eck6_False_Northing, and update().
| void ossimEckert6Projection::setFalseNorthing | ( | double | falseNorthing | ) |
Definition at line 127 of file ossimEckert6Projection.cpp.
References Eck6_False_Northing, and update().
Definition at line 72 of file ossimEckert6Projection.cpp.
References Eck6_False_Easting, Eck6_False_Northing, ossimEllipsoid::getA(), ossimEllipsoid::getFlattening(), ossimGpt::lonr(), Set_Eckert6_Parameters(), ossimMapProjection::theEllipsoid, ossimMapProjection::theFalseEastingNorthing, ossimMapProjection::theOrigin, ossimMapProjection::update(), ossimDpt::x, and ossimDpt::y.
Referenced by loadState(), ossimEckert6Projection(), setCentralMeridian(), setDefaults(), setFalseEasting(), setFalseEastingNorthing(), and setFalseNorthing().
mutableprivate |
Definition at line 82 of file ossimEckert6Projection.h.
Referenced by Get_Eckert6_Parameters(), and Set_Eckert6_Parameters().
mutableprivate |
Definition at line 95 of file ossimEckert6Projection.h.
Referenced by ossimEckert6Projection(), and setDefaults().
mutableprivate |
Definition at line 83 of file ossimEckert6Projection.h.
mutableprivate |
Definition at line 93 of file ossimEckert6Projection.h.
Referenced by Convert_Eckert6_To_Geodetic(), Convert_Geodetic_To_Eckert6(), Get_Eckert6_Parameters(), loadState(), ossimEckert6Projection(), Set_Eckert6_Parameters(), setDefaults(), setFalseEasting(), setFalseEastingNorthing(), and update().
mutableprivate |
Definition at line 94 of file ossimEckert6Projection.h.
Referenced by Convert_Eckert6_To_Geodetic(), Convert_Geodetic_To_Eckert6(), Get_Eckert6_Parameters(), loadState(), ossimEckert6Projection(), Set_Eckert6_Parameters(), setDefaults(), setFalseEastingNorthing(), setFalseNorthing(), and update().
mutableprivate |
Definition at line 96 of file ossimEckert6Projection.h.
Referenced by ossimEckert6Projection(), Set_Eckert6_Parameters(), and setDefaults().
mutableprivate |
Definition at line 97 of file ossimEckert6Projection.h.
mutableprivate |
Definition at line 92 of file ossimEckert6Projection.h.
Referenced by Convert_Eckert6_To_Geodetic(), Convert_Geodetic_To_Eckert6(), Get_Eckert6_Parameters(), Set_Eckert6_Parameters(), and setCentralMeridian().
mutableprivate |
Definition at line 84 of file ossimEckert6Projection.h.
Referenced by Set_Eckert6_Parameters().
mutableprivate |
Definition at line 85 of file ossimEckert6Projection.h.
mutableprivate |
Definition at line 86 of file ossimEckert6Projection.h.
mutableprivate |
Definition at line 88 of file ossimEckert6Projection.h.
Referenced by Convert_Eckert6_To_Geodetic(), and Set_Eckert6_Parameters().
mutableprivate |
Definition at line 87 of file ossimEckert6Projection.h.
Referenced by Convert_Geodetic_To_Eckert6(), and Set_Eckert6_Parameters().
