Projection Factory for coded projections defined in database. More...
#include <ossimEpsgProjectionFactory.h>
| virtual ossimProjection * | createProjection (const ossimFilename &filename, ossim_uint32 entryIdx) const |
| STUB. Not implemented. More... | |
| virtual ossimProjection * | createProjection (const ossimString &name) const |
| This is the principal factory method. More... | |
| virtual ossimProjection * | createProjection (const ossimKeywordlist &kwl, const char *prefix=0) const |
Looks for presence of "pcs_code" keyword with the value in the format <group>:, for example "EPSG:32615" (EPSG and AUTO–see above– are presently supported). More... | |
| virtual ossimObject * | createObject (const ossimString &typeName) const |
| virtual ossimObject * | createObject (const ossimKeywordlist &kwl, const char *prefix=0) const |
| virtual void | getTypeNameList (std::vector< ossimString > &typeList) const |
| This returns the type name of all objects in all factories. More... | |
Public Member Functions inherited from ossimProjectionFactoryBase | |
| virtual ossimProjection * | createProjection (ossimImageHandler *handler) const |
Public Member Functions inherited from ossimObjectFactory | |
| virtual | ~ossimObjectFactory () |
| ossimObject () | |
| static ossimEpsgProjectionFactory * | instance () |
| Implements singleton pattern. More... | |
| ossimEpsgProjectionFactory () | |
| Constructor loads all SRS CSV files specified in the ossim prefs. More... | |
| ossimMapProjection * | createProjFromAutoCode (const std::vector< ossimString > &spec) const |
| When the CRS is specified with the "AUTO:<spec>" code format, this method is invoked to parse the <spec> and produce a projection (or NULL if spec invalid): This really shouldn't be in this class but nobody else is parsing for it, so leave it here for now. More... | |
Protected Member Functions inherited from ossimProjectionFactoryBase | |
| ossimProjection * | createProjectionFromGeometryFile (const ossimFilename &imageFile, ossim_uint32 entryIdx) const |
| This method takes the filename and tries to find an external ".geom" file. More... | |
These are projections that are fully defined in database files and specified via a projection coordinate system (PCS) code, such as EPSG codes.
Definition at line 27 of file ossimEpsgProjectionFactory.h.
protected |
Protected as part of singleton implementation.
Definition at line 41 of file ossimEpsgProjectionFactory.cpp.
Creates an object given a type name.
Implements ossimObjectFactory.
Definition at line 176 of file ossimEpsgProjectionFactory.cpp.
References createProjection().
Creates and object given a keyword list.
Definition at line 182 of file ossimEpsgProjectionFactory.cpp.
Implements ossimProjectionFactoryBase.
Definition at line 191 of file ossimEpsgProjectionFactory.cpp.
Referenced by createObject(), createProjection(), ossimPointCloudImageHandler::getImageGeometry(), ossimGpkgTileEntry::getNewMapProjection(), ossimGpkgWriter::getNewOutputProjection(), ossimTiffInfo::getPcsCode(), ossimFgdcXmlDoc::getProjection(), ossimGeoPdfReader::getVPGeoProjection(), and ossimGeoTiff::parsePcsCode().
It accepts a string in one of three formats:
, for example "EPSG:32615", for example "32615", this is the CRS code ID for the projerection.AUTO:<comma-separated spec>, for specifying custom user-defined codes.Both projected and geographic (Platte Carre) codes are handled.
Definition at line 96 of file ossimEpsgProjectionFactory.cpp.
References ossimString::after(), createProjFromAutoCode(), ossimString::explode(), ossimEpsgProjectionDatabase::findProjection(), ossimEpsgProjectionDatabase::instance(), and ossimString::trim().
From keywordlist.
If only an integer is specified, EPSG code is assumed.
Definition at line 48 of file ossimEpsgProjectionFactory.cpp.
References ossimKeywordlist::addList(), createProjection(), ossimString::empty(), ossimKeywordlist::find(), ossimProjection::loadState(), ossimKeywordNames::PCS_CODE_KW, ossimKeywordNames::PIXEL_SCALE_UNITS_KW, ossimKeywordNames::PIXEL_SCALE_XY_KW, ossimKeywordNames::PROJECTION_KW, ossimKeywordlist::remove(), ossimProjection::saveState(), ossimKeywordNames::TIE_POINT_UNITS_KW, and ossimKeywordNames::TIE_POINT_XY_KW.
protected |
Definition at line 121 of file ossimEpsgProjectionFactory.cpp.
References ossimGpt::latd(), ossimGpt::lond(), ossimTransMercatorProjection::setFalseNorthing(), ossimUtmProjection::setHemisphere(), ossimUtmProjection::setOrigin(), ossimEquDistCylProjection::setOrigin(), ossimMapProjection::setOrigin(), ossimTransMercatorProjection::setScaleFactor(), ossimUtmProjection::setZone(), ossimUtmProjection::update(), ossimTransMercatorProjection::update(), ossimOrthoGraphicProjection::update(), and ossimEquDistCylProjection::update().
Referenced by createProjection().
This is the name used to construct the objects dynamically and this name must be unique.
Definition at line 201 of file ossimEpsgProjectionFactory.cpp.
References ossimEpsgProjectionDatabase::getProjectionsList(), and ossimEpsgProjectionDatabase::instance().
static |
METHOD: instance() Instantiates singleton instance of this class:
Definition at line 27 of file ossimEpsgProjectionFactory.cpp.
Referenced by ossimPointCloudImageHandler::getImageGeometry(), ossimGpkgTileEntry::getNewMapProjection(), ossimGpkgWriter::getNewOutputProjection(), ossimTiffInfo::getPcsCode(), ossimFgdcXmlDoc::getProjection(), ossimGeoPdfReader::getVPGeoProjection(), ossimProjectionFactoryRegistry::initializeDefaults(), and ossimGeoTiff::parsePcsCode().
