#include <ossimEckert4Projection.h>
| ossimEckert4Projection (const ossimEllipsoid &ellipsoid=ossimEllipsoid(), const ossimGpt &origin=ossimGpt()) | |
| ossimEckert4Projection (const ossimEllipsoid &ellipsoid, const ossimGpt &origin, double falseEasting, double falseNorthing) | |
| ~ossimEckert4Projection () | |
| virtual ossimDpt | forward (const ossimGpt &worldPoint) const |
| All map projections will convert the world coordinate to an easting northing (Meters). More... | |
| virtual ossimGpt | inverse (const ossimDpt &projectedPoint) const |
| Will take a point in meters and convert it to ground. More... | |
| virtual void | update () |
| void | setFalseEasting (double falseEasting) |
| void | setFalseNorthing (double falseNorthing) |
| void | setFalseEastingNorthing (double falseEasting, double falseNorthing) |
| double | getFalseEasting () const |
| double | getFalseNorthing () const |
| void | setDefaults () |
Public Member Functions inherited from ossimMapProjection | |
| ossimMapProjection (const ossimEllipsoid &ellipsoid=ossimEllipsoid(), const ossimGpt &origin=ossimGpt()) | |
| ossimMapProjection (const ossimMapProjection &src) | |
| virtual ossimDpt | worldToLineSample (const ossimGpt &worldPoint) const |
| virtual void | worldToLineSample (const ossimGpt &worldPoint, ossimDpt &lineSample) const |
| virtual ossimGpt | lineSampleToWorld (const ossimDpt &projectedPoint) const |
| virtual void | lineSampleToWorld (const ossimDpt &projectedPoint, ossimGpt &gpt) const |
| virtual void | lineSampleHeightToWorld (const ossimDpt &lineSampPt, const double &heightAboveEllipsoid, ossimGpt &worldPt) const |
| This is the pure virtual that projects the image point to the given elevation above ellipsoid, thereby bypassing reference to a DEM. More... | |
| virtual void | lineSampleToEastingNorthing (const ossimDpt &liineSample, ossimDpt &eastingNorthing) const |
| virtual void | eastingNorthingToLineSample (const ossimDpt &eastingNorthing, ossimDpt &lineSample) const |
| virtual void | eastingNorthingToWorld (const ossimDpt &eastingNorthing, ossimGpt &worldPt) const |
| virtual double | getStandardParallel1 () const |
| Derived classes should implement as needed. More... | |
| virtual double | getStandardParallel2 () const |
| virtual void | setPcsCode (ossim_uint32 pcsCode) |
| virtual ossim_uint32 | getPcsCode () const |
| Returns the EPSG PCS code or 32767 if the projection is a custom (non-EPSG) projection. More... | |
| virtual ossimString | getProjectionName () const |
| Returns the projection name. More... | |
| virtual double | getA () const |
| ACCESS METHODS: More... | |
| virtual double | getB () const |
| virtual double | getF () const |
| virtual const ossimDpt & | getDecimalDegreesPerPixel () const |
| Returns decimal degrees per pixel as an ossimDpt with "x" representing longitude and "y" representing latitude. More... | |
| virtual const ossimDpt & | getUlEastingNorthing () const |
| virtual const ossimGpt & | getUlGpt () const |
| virtual const ossimDatum * | getDatum () const |
| const ossimEllipsoid & | getEllipsoid () const |
| const ossimGpt & | getOrigin () const |
| virtual bool | isGeographic () const |
| virtual void | applyScale (const ossimDpt &scale, bool recenterTiePoint) |
| Applies scale to theDeltaLonPerPixel, theDeltaLatPerPixel and theMetersPerPixel data members (eg: theDeltaLonPerPixel *= scale.x). More... | |
| virtual void | setEllipsoid (const ossimEllipsoid &ellipsoid) |
| SET METHODS: More... | |
| virtual void | setAB (double a, double b) |
| virtual void | setDatum (const ossimDatum *datum) |
| Sets theDatum to datum. More... | |
| virtual void | setOrigin (const ossimGpt &origin) |
| Sets theOrigin to origin. More... | |
| virtual void | setMetersPerPixel (const ossimDpt &gsd) |
| virtual void | setDecimalDegreesPerPixel (const ossimDpt &gsd) |
| virtual void | setUlTiePoints (const ossimGpt &gpt) |
| virtual void | setUlTiePoints (const ossimDpt &eastingNorthing) |
| virtual void | setUlEastingNorthing (const ossimDpt &ulEastingNorthing) |
| virtual void | setUlGpt (const ossimGpt &ulGpt) |
| virtual void | assign (const ossimProjection &aProjection) |
| Prints data members to stream. More... | |
| virtual bool | operator== (const ossimProjection &projection) const |
| Compares this to arg projection and returns TRUE if the same. More... | |
| virtual void | computeDegreesPerPixel () |
| Computes the approximate resolution in degrees/pixel. More... | |
| virtual void | computeMetersPerPixel () |
| This will go from the ground point and give you an approximate meters per pixel. More... | |
| void | setMatrix (double rotation, const ossimDpt &scale, const ossimDpt &translation) |
| void | setMatrixScale (const ossimDpt &scale) |
| void | setMatrixRotation (double rotation) |
| void | setMatrixTranslation (const ossimDpt &translation) |
| void | snapTiePointTo (ossim_float64 multiple, ossimUnitType unitType) |
| Utility method to snap the tie point to some multiple. More... | |
| void | snapTiePointToOrigin () |
| void | setElevationLookupFlag (bool flag) |
| bool | getElevationLookupFlag () const |
| ossimUnitType | getModelTransformUnitType () const |
| void | setModelTransformUnitType (ossimUnitType unit) |
| bool | hasModelTransform () const |
| void | setProjectionUnits (ossimUnitType units) |
| ossimUnitType | getProjectionUnits () const |
| OSSIM considers all map projection coordinates (including false eastings and northings) to be in meters. More... | |
| ossimProjection () | |
| ossimObject () | |
| bool | hasError () const |
Private Member Functions | |
| long | Set_Eckert4_Parameters (double a, double f, double Central_Meridian, double False_Easting, double False_Northing) |
| void | Get_Eckert4_Parameters (double *a, double *f, double *Central_Meridian, double *False_Easting, double *False_Northing) const |
| long | Convert_Geodetic_To_Eckert4 (double Latitude, double Longitude, double *Easting, double *Northing) const |
| long | Convert_Eckert4_To_Geodetic (double Easting, double Northing, double *Latitude, double *Longitude) const |
Private Attributes | |
| double | Eck4_a |
| double | Eck4_f |
| double | es2 |
| double | es4 |
| double | es6 |
| double | Ra0 |
| double | Ra1 |
| double | Eck4_Origin_Long |
| double | Eck4_False_Easting |
| double | Eck4_False_Northing |
| double | Eck4_Delta_Northing |
| double | Eck4_Max_Easting |
| double | Eck4_Min_Easting |
Protected Member Functions inherited from ossimMapProjection | |
| virtual | ~ossimMapProjection () |
| void | updateFromTransform () |
Protected Attributes inherited from ossimMapProjection | |
| ossimEllipsoid | theEllipsoid |
| This method verifies that the projection parameters match the current pcs code. More... | |
| ossimGpt | theOrigin |
| const ossimDatum * | theDatum |
| This is only set if we want to have built in datum shifting. More... | |
| ossimDpt | theMetersPerPixel |
| Holds the number of meters per pixel. More... | |
| ossimDpt | theDegreesPerPixel |
| Hold the decimal degrees per pixel. More... | |
| ossimGpt | theUlGpt |
| Hold tie point in decimal degrees. More... | |
| ossimDpt | theUlEastingNorthing |
| Hold tie point as easting northing. More... | |
| ossimDpt | theFalseEastingNorthing |
| Hold the false easting northing. More... | |
| ossim_uint32 | thePcsCode |
| Projection Coordinate System(PCS) code. More... | |
| bool | theElevationLookupFlag |
| ossimMatrix4x4 | theModelTransform |
| ossimMatrix4x4 | theInverseModelTransform |
| ossimUnitType | theModelTransformUnitType |
| ossimUnitType | theProjectionUnits |
| Linear units of the projection as indicated in the projection's specification: More... | |
Definition at line 16 of file ossimEckert4Projection.h.
| ossimEckert4Projection::ossimEckert4Projection | ( | const ossimEllipsoid & | ellipsoid = ossimEllipsoid(), |
| const ossimGpt & | origin = ossimGpt() |
Definition at line 51 of file ossimEckert4Projection.cpp.
References setDefaults(), and update().
| ossimEckert4Projection::ossimEckert4Projection | ( | const ossimEllipsoid & | ellipsoid, |
| const ossimGpt & | origin, | ||
| double | falseEasting, | ||
| double | falseNorthing | ||
Definition at line 59 of file ossimEckert4Projection.cpp.
References Eck4_Delta_Northing, Eck4_False_Easting, Eck4_False_Northing, Eck4_Max_Easting, Eck4_Min_Easting, and update().
inline |
Definition at line 26 of file ossimEckert4Projection.h.
private |
The function Convert_Eckert4_To_Geodetic converts Eckert IV projection easting and northing coordinates to geodetic (latitude and longitude) coordinates, according to the current ellipsoid and Eckert IV projection coordinates. If any errors occur, the error code(s) are returned by the function, otherwise ECK4_NO_ERROR is returned.
Easting : Easting (X) in meters (input) Northing : Northing (Y) in meters (input) Latitude : Latitude (phi) in radians (output) Longitude : Longitude (lambda) in radians (output)
Definition at line 359 of file ossimEckert4Projection.cpp.
References Eck4_False_Easting, Eck4_False_Northing, ECK4_NO_ERROR, Eck4_Origin_Long, NUM, Ra0, Ra1, and two_PLUS_PI_OVER_2.
Referenced by inverse().
private |
The function Convert_Geodetic_To_Eckert4 converts geodetic (latitude and longitude) coordinates to Eckert IV projection easting, and northing coordinates, according to the current ellipsoid and Eckert IV projection parameters. If any errors occur, the error code(s) are returned by the function, otherwise ECK4_NO_ERROR is returned.
Latitude : Latitude (phi) in radians (input) Longitude : Longitude (lambda) in radians (input) Easting : Easting (X) in meters (output) Northing : Northing (Y) in meters (output)
Definition at line 290 of file ossimEckert4Projection.cpp.
Referenced by forward().
inlinevirtual |
Implements ossimProjection.
Definition at line 27 of file ossimEckert4Projection.h.
Definition at line 104 of file ossimEckert4Projection.cpp.
References ossimGpt::changeDatum(), ossimDatum::code(), Convert_Geodetic_To_Eckert4(), ossimGpt::datum(), ossimGpt::latr(), ossimGpt::lonr(), and ossimMapProjection::theDatum.
private |
The function Get_Eckert4_Parameters returns the current ellipsoid parameters and EckertIV projection parameters.
a : Semi-major axis of ellipsoid, in meters (output) f : Flattening of ellipsoid (output) Central_Meridian : Longitude in radians at the center of (output) the projection False_Easting : A coordinate value in meters assigned to the central meridian of the projection. (output) False_Northing : A coordinate value in meters assigned to the origin latitude of the projection (output)
Definition at line 261 of file ossimEckert4Projection.cpp.
References Eck4_a, Eck4_f, Eck4_False_Easting, Eck4_False_Northing, and Eck4_Origin_Long.
inlinevirtual |
Definition at line 54 of file ossimEckert4Projection.h.
inlinevirtual |
Definition at line 55 of file ossimEckert4Projection.h.
Definition at line 91 of file ossimEckert4Projection.cpp.
References Convert_Eckert4_To_Geodetic(), DEG_PER_RAD, ossimMapProjection::theDatum, ossimDpt::x, and ossimDpt::y.
Definition at line 160 of file ossimEckert4Projection.cpp.
References Eck4_False_Easting, Eck4_False_Northing, ossimKeywordlist::find(), ossimMapProjection::loadState(), setDefaults(), STATIC_TYPE_NAME, ossimMapProjection::theFalseEastingNorthing, ossimKeywordNames::TYPE_KW, update(), ossimDpt::x, and ossimDpt::y.
Definition at line 155 of file ossimEckert4Projection.cpp.
References ossimMapProjection::saveState().
private |
The function Set_Eckert4_Parameters receives the ellipsoid parameters and Eckert IV projection parameters as inputs, and sets the corresponding state variables. If any errors occur, the error code(s) are returned by the function, otherwise ECK4_NO_ERROR is returned.
a : Semi-major axis of ellipsoid, in meters (input) f : Flattening of ellipsoid (input) Central_Meridian : Longitude in radians at the center of (input) the projection False_Easting : A coordinate value in meters assigned to the central meridian of the projection. (input) False_Northing : A coordinate value in meters assigned to the origin latitude of the projection (input)
Definition at line 185 of file ossimEckert4Projection.cpp.
References Eck4_a, Eck4_f, Eck4_False_Easting, Eck4_False_Northing, Eck4_Max_Easting, Eck4_Min_Easting, ECK4_NO_ERROR, Eck4_Origin_Long, es2, es4, es6, Ra0, and Ra1.
Referenced by update().
| void ossimEckert4Projection::setDefaults | ( | ) |
Initialize all pramters to default and calls update for pre-computations.
Definition at line 146 of file ossimEckert4Projection.cpp.
References Eck4_Delta_Northing, Eck4_False_Easting, Eck4_False_Northing, Eck4_Max_Easting, and Eck4_Min_Easting.
Referenced by loadState(), and ossimEckert4Projection().
| void ossimEckert4Projection::setFalseEasting | ( | double | falseEasting | ) |
Definition at line 126 of file ossimEckert4Projection.cpp.
References Eck4_False_Easting, and update().
| void ossimEckert4Projection::setFalseEastingNorthing | ( | double | falseEasting, |
Definition at line 138 of file ossimEckert4Projection.cpp.
References Eck4_False_Easting, Eck4_False_Northing, and update().
| void ossimEckert4Projection::setFalseNorthing | ( | double | falseNorthing | ) |
Definition at line 132 of file ossimEckert4Projection.cpp.
References Eck4_False_Northing, and update().
Definition at line 76 of file ossimEckert4Projection.cpp.
References Eck4_False_Easting, Eck4_False_Northing, ossimEllipsoid::getA(), ossimEllipsoid::getFlattening(), ossimGpt::lonr(), Set_Eckert4_Parameters(), ossimMapProjection::theEllipsoid, ossimMapProjection::theFalseEastingNorthing, ossimMapProjection::theOrigin, ossimMapProjection::update(), ossimDpt::x, and ossimDpt::y.
Referenced by loadState(), ossimEckert4Projection(), setFalseEasting(), setFalseEastingNorthing(), and setFalseNorthing().
mutableprivate |
Definition at line 79 of file ossimEckert4Projection.h.
Referenced by Get_Eckert4_Parameters(), and Set_Eckert4_Parameters().
mutableprivate |
Definition at line 92 of file ossimEckert4Projection.h.
Referenced by ossimEckert4Projection(), and setDefaults().
mutableprivate |
Definition at line 80 of file ossimEckert4Projection.h.
mutableprivate |
Definition at line 90 of file ossimEckert4Projection.h.
Referenced by Convert_Eckert4_To_Geodetic(), Convert_Geodetic_To_Eckert4(), Get_Eckert4_Parameters(), loadState(), ossimEckert4Projection(), Set_Eckert4_Parameters(), setDefaults(), setFalseEasting(), setFalseEastingNorthing(), and update().
mutableprivate |
Definition at line 91 of file ossimEckert4Projection.h.
Referenced by Convert_Eckert4_To_Geodetic(), Convert_Geodetic_To_Eckert4(), Get_Eckert4_Parameters(), loadState(), ossimEckert4Projection(), Set_Eckert4_Parameters(), setDefaults(), setFalseEastingNorthing(), setFalseNorthing(), and update().
mutableprivate |
Definition at line 93 of file ossimEckert4Projection.h.
Referenced by ossimEckert4Projection(), Set_Eckert4_Parameters(), and setDefaults().
mutableprivate |
Definition at line 94 of file ossimEckert4Projection.h.
mutableprivate |
Definition at line 89 of file ossimEckert4Projection.h.
Referenced by Convert_Eckert4_To_Geodetic(), Convert_Geodetic_To_Eckert4(), Get_Eckert4_Parameters(), and Set_Eckert4_Parameters().
mutableprivate |
Definition at line 81 of file ossimEckert4Projection.h.
Referenced by Set_Eckert4_Parameters().
mutableprivate |
Definition at line 82 of file ossimEckert4Projection.h.
mutableprivate |
Definition at line 83 of file ossimEckert4Projection.h.
mutableprivate |
Definition at line 85 of file ossimEckert4Projection.h.
Referenced by Convert_Eckert4_To_Geodetic(), Convert_Geodetic_To_Eckert4(), and Set_Eckert4_Parameters().
mutableprivate |
Definition at line 86 of file ossimEckert4Projection.h.
