#include <ossimAzimEquDistProjection.h>
| ossimAzimEquDistProjection (const ossimEllipsoid &ellipsoid=ossimEllipsoid(), const ossimGpt &origin=ossimGpt()) | |
| ossimAzimEquDistProjection (const ossimEllipsoid &ellipsoid, const ossimGpt &origin, double falseEasting, double falseNorthing) | |
| ossimAzimEquDistProjection (const ossimAzimEquDistProjection &rhs) | |
| virtual ossimGpt | inverse (const ossimDpt &eastingNorthing) const |
| Will take a point in meters and convert it to ground. More... | |
| virtual ossimDpt | forward (const ossimGpt &latLon) const |
| All map projections will convert the world coordinate to an easting northing (Meters). More... | |
| virtual void | update () |
| double | getFalseEasting () const |
| double | getFalseNorthing () const |
| void | setFalseEasting (double falseEasting) |
| void | setFalseNorthing (double falseNorthing) |
| void | setFalseEastingNorthing (double falseEasting, double falseNorthing) |
| void | setDefaults () |
Public Member Functions inherited from ossimMapProjection | |
| ossimMapProjection (const ossimEllipsoid &ellipsoid=ossimEllipsoid(), const ossimGpt &origin=ossimGpt()) | |
| ossimMapProjection (const ossimMapProjection &src) | |
| virtual ossimDpt | worldToLineSample (const ossimGpt &worldPoint) const |
| virtual void | worldToLineSample (const ossimGpt &worldPoint, ossimDpt &lineSample) const |
| virtual ossimGpt | lineSampleToWorld (const ossimDpt &projectedPoint) const |
| virtual void | lineSampleToWorld (const ossimDpt &projectedPoint, ossimGpt &gpt) const |
| virtual void | lineSampleHeightToWorld (const ossimDpt &lineSampPt, const double &heightAboveEllipsoid, ossimGpt &worldPt) const |
| This is the pure virtual that projects the image point to the given elevation above ellipsoid, thereby bypassing reference to a DEM. More... | |
| virtual void | lineSampleToEastingNorthing (const ossimDpt &liineSample, ossimDpt &eastingNorthing) const |
| virtual void | eastingNorthingToLineSample (const ossimDpt &eastingNorthing, ossimDpt &lineSample) const |
| virtual void | eastingNorthingToWorld (const ossimDpt &eastingNorthing, ossimGpt &worldPt) const |
| virtual double | getStandardParallel1 () const |
| Derived classes should implement as needed. More... | |
| virtual double | getStandardParallel2 () const |
| virtual void | setPcsCode (ossim_uint32 pcsCode) |
| virtual ossim_uint32 | getPcsCode () const |
| Returns the EPSG PCS code or 32767 if the projection is a custom (non-EPSG) projection. More... | |
| virtual ossimString | getProjectionName () const |
| Returns the projection name. More... | |
| virtual double | getA () const |
| ACCESS METHODS: More... | |
| virtual double | getB () const |
| virtual double | getF () const |
| virtual const ossimDpt & | getDecimalDegreesPerPixel () const |
| Returns decimal degrees per pixel as an ossimDpt with "x" representing longitude and "y" representing latitude. More... | |
| virtual const ossimDpt & | getUlEastingNorthing () const |
| virtual const ossimGpt & | getUlGpt () const |
| virtual const ossimDatum * | getDatum () const |
| const ossimEllipsoid & | getEllipsoid () const |
| const ossimGpt & | getOrigin () const |
| virtual bool | isGeographic () const |
| virtual void | applyScale (const ossimDpt &scale, bool recenterTiePoint) |
| Applies scale to theDeltaLonPerPixel, theDeltaLatPerPixel and theMetersPerPixel data members (eg: theDeltaLonPerPixel *= scale.x). More... | |
| virtual void | setEllipsoid (const ossimEllipsoid &ellipsoid) |
| SET METHODS: More... | |
| virtual void | setAB (double a, double b) |
| virtual void | setDatum (const ossimDatum *datum) |
| Sets theDatum to datum. More... | |
| virtual void | setOrigin (const ossimGpt &origin) |
| Sets theOrigin to origin. More... | |
| virtual void | setMetersPerPixel (const ossimDpt &gsd) |
| virtual void | setDecimalDegreesPerPixel (const ossimDpt &gsd) |
| virtual void | setUlTiePoints (const ossimGpt &gpt) |
| virtual void | setUlTiePoints (const ossimDpt &eastingNorthing) |
| virtual void | setUlEastingNorthing (const ossimDpt &ulEastingNorthing) |
| virtual void | setUlGpt (const ossimGpt &ulGpt) |
| virtual void | assign (const ossimProjection &aProjection) |
| Prints data members to stream. More... | |
| virtual bool | operator== (const ossimProjection &projection) const |
| Compares this to arg projection and returns TRUE if the same. More... | |
| virtual void | computeDegreesPerPixel () |
| Computes the approximate resolution in degrees/pixel. More... | |
| virtual void | computeMetersPerPixel () |
| This will go from the ground point and give you an approximate meters per pixel. More... | |
| void | setMatrix (double rotation, const ossimDpt &scale, const ossimDpt &translation) |
| void | setMatrixScale (const ossimDpt &scale) |
| void | setMatrixRotation (double rotation) |
| void | setMatrixTranslation (const ossimDpt &translation) |
| void | snapTiePointTo (ossim_float64 multiple, ossimUnitType unitType) |
| Utility method to snap the tie point to some multiple. More... | |
| void | snapTiePointToOrigin () |
| void | setElevationLookupFlag (bool flag) |
| bool | getElevationLookupFlag () const |
| ossimUnitType | getModelTransformUnitType () const |
| void | setModelTransformUnitType (ossimUnitType unit) |
| bool | hasModelTransform () const |
| void | setProjectionUnits (ossimUnitType units) |
| ossimUnitType | getProjectionUnits () const |
| OSSIM considers all map projection coordinates (including false eastings and northings) to be in meters. More... | |
| ossimProjection () | |
| ossimObject () | |
| bool | hasError () const |
| virtual | ~ossimAzimEquDistProjection () |
| long | Set_Azimuthal_Equidistant_Parameters (double a, double f, double Origin_Latitude, double Central_Meridian, double False_Easting, double False_Northing) |
| void | Get_Azimuthal_Equidistant_Parameters (double *a, double *f, double *Origin_Latitude, double *Central_Meridian, double *False_Easting, double *False_Northing) const |
| long | Convert_Geodetic_To_Azimuthal_Equidistant (double Latitude, double Longitude, double *Easting, double *Northing) const |
| long | Convert_Azimuthal_Equidistant_To_Geodetic (double Easting, double Northing, double *Latitude, double *Longitude) const |
Protected Member Functions inherited from ossimMapProjection | |
| virtual | ~ossimMapProjection () |
| void | updateFromTransform () |
Protected Attributes | |
| double | abs_Azeq_Origin_Lat |
| double | Azeq_a |
| double | Azeq_f |
| double | Ra |
| double | Sin_Azeq_Origin_Lat |
| double | Cos_Azeq_Origin_Lat |
| double | Azeq_Origin_Lat |
| double | Azeq_Origin_Long |
| double | Azeq_False_Northing |
| double | Azeq_False_Easting |
| double | Azeq_Delta_Northing |
| double | Azeq_Delta_Easting |
Protected Attributes inherited from ossimMapProjection | |
| ossimEllipsoid | theEllipsoid |
| This method verifies that the projection parameters match the current pcs code. More... | |
| ossimGpt | theOrigin |
| const ossimDatum * | theDatum |
| This is only set if we want to have built in datum shifting. More... | |
| ossimDpt | theMetersPerPixel |
| Holds the number of meters per pixel. More... | |
| ossimDpt | theDegreesPerPixel |
| Hold the decimal degrees per pixel. More... | |
| ossimGpt | theUlGpt |
| Hold tie point in decimal degrees. More... | |
| ossimDpt | theUlEastingNorthing |
| Hold tie point as easting northing. More... | |
| ossimDpt | theFalseEastingNorthing |
| Hold the false easting northing. More... | |
| ossim_uint32 | thePcsCode |
| Projection Coordinate System(PCS) code. More... | |
| bool | theElevationLookupFlag |
| ossimMatrix4x4 | theModelTransform |
| ossimMatrix4x4 | theInverseModelTransform |
| ossimUnitType | theModelTransformUnitType |
| ossimUnitType | theProjectionUnits |
| Linear units of the projection as indicated in the projection's specification: More... | |
Definition at line 18 of file ossimAzimEquDistProjection.h.
| ossimAzimEquDistProjection::ossimAzimEquDistProjection | ( | const ossimEllipsoid & | ellipsoid = ossimEllipsoid(), |
| const ossimGpt & | origin = ossimGpt() |
Definition at line 34 of file ossimAzimEquDistProjection.cpp.
| ossimAzimEquDistProjection::ossimAzimEquDistProjection | ( | const ossimEllipsoid & | ellipsoid, |
| const ossimGpt & | origin, | ||
| double | falseEasting, | ||
| double | falseNorthing | ||
Definition at line 42 of file ossimAzimEquDistProjection.cpp.
References setFalseEastingNorthing().
inline |
Definition at line 29 of file ossimAzimEquDistProjection.h.
inlineprotectedvirtual |
Definition at line 85 of file ossimAzimEquDistProjection.h.
protected |
The function Convert_Azimuthal_Equidistant_To_Geodetic converts Azimuthal Equidistant projection (easting and northing) coordinates to geodetic (latitude and longitude) coordinates, according to the current ellipsoid and Azimuthal Equidistant projection coordinates. If any errors occur, the error code(s) are returned by the function, otherwise AZEQ_NO_ERROR is returned.
Easting : Easting (X) in meters (input) Northing : Northing (Y) in meters (input) Latitude : Latitude (phi) in radians (output) Longitude : Longitude (lambda) in radians (output)
Definition at line 404 of file ossimAzimEquDistProjection.cpp.
References abs_Azeq_Origin_Lat, Azeq_False_Easting, Azeq_False_Northing, AZEQ_NO_ERROR, Azeq_Origin_Lat, Azeq_Origin_Long, Cos_Azeq_Origin_Lat, M_PI, PI_OVER_2, Ra, and Sin_Azeq_Origin_Lat.
Referenced by inverse().
protected |
The function Convert_Geodetic_To_Azimuthal_Equidistant converts geodetic (latitude and longitude) coordinates to Azimuthal Equidistant projection (easting and northing) coordinates, according to the current ellipsoid and Azimuthal Equidistant projection parameters. If any errors occur, the error code(s) are returned by the function, otherwise AZEQ_NO_ERROR is returned.
Latitude : Latitude (phi) in radians (input) Longitude : Longitude (lambda) in radians (input) Easting : Easting (X) in meters (output) Northing : Northing (Y) in meters (output)
Definition at line 282 of file ossimAzimEquDistProjection.cpp.
References abs_Azeq_Origin_Lat, Azeq_False_Easting, Azeq_False_Northing, AZEQ_NO_ERROR, Azeq_Origin_Lat, Azeq_Origin_Long, AZEQ_PROJECTION_ERROR, Cos_Azeq_Origin_Lat, M_PI, PI_OVER_2, Ra, Sin_Azeq_Origin_Lat, and TWO_PI.
Referenced by forward(), and Set_Azimuthal_Equidistant_Parameters().
inlinevirtual |
Implements ossimProjection.
Definition at line 33 of file ossimAzimEquDistProjection.h.
Definition at line 79 of file ossimAzimEquDistProjection.cpp.
References ossimGpt::changeDatum(), ossimDatum::code(), Convert_Geodetic_To_Azimuthal_Equidistant(), ossimGpt::datum(), ossimGpt::latr(), ossimGpt::lonr(), and ossimMapProjection::theDatum.
protected |
The function Get_Azimuthal_Equidistant_Parameters returns the current ellipsoid parameters and Azimuthal Equidistant projection parameters.
a : Semi-major axis of ellipsoid, in meters (output) f : Flattening of ellipsoid (output) Origin_Latitude : Latitude in radians at which the (output) point scale factor is 1.0 Central_Meridian : Longitude in radians at the center of (output) the projection False_Easting : A coordinate value in meters assigned to the central meridian of the projection. (output) False_Northing : A coordinate value in meters assigned to the origin latitude of the projection (output)
Definition at line 248 of file ossimAzimEquDistProjection.cpp.
References Azeq_a, Azeq_f, Azeq_False_Easting, Azeq_False_Northing, Azeq_Origin_Lat, and Azeq_Origin_Long.
inlinevirtual |
Definition at line 42 of file ossimAzimEquDistProjection.h.
inlinevirtual |
Definition at line 43 of file ossimAzimEquDistProjection.h.
Definition at line 67 of file ossimAzimEquDistProjection.cpp.
References Convert_Azimuthal_Equidistant_To_Geodetic(), DEG_PER_RAD, ossimMapProjection::theDatum, ossimDpt::x, and ossimDpt::y.
Definition at line 135 of file ossimAzimEquDistProjection.cpp.
References Azeq_False_Easting, Azeq_False_Northing, ossimKeywordlist::find(), ossimMapProjection::loadState(), setDefaults(), STATIC_TYPE_NAME, ossimMapProjection::theFalseEastingNorthing, ossimKeywordNames::TYPE_KW, update(), ossimDpt::x, and ossimDpt::y.
Definition at line 130 of file ossimAzimEquDistProjection.cpp.
References ossimMapProjection::saveState().
protected |
The function Set_Azimuthal_Equidistant_Parameters receives the ellipsoid parameters and projection parameters as inputs, and sets the corresponding state variables. If any errors occur, the error code(s) are returned by the function, otherwise AZEQ_NO_ERROR is returned.
a : Semi-major axis of ellipsoid, in meters (input) f : Flattening of ellipsoid (input) Origin_Latitude : Latitude in radians at which the (input) point scale factor is 1.0 Central_Meridian : Longitude in radians at the center of (input) the projection False_Easting : A coordinate value in meters assigned to the central meridian of the projection. (input) False_Northing : A coordinate value in meters assigned to the origin latitude of the projection (input)
Definition at line 153 of file ossimAzimEquDistProjection.cpp.
References abs_Azeq_Origin_Lat, Azeq_a, Azeq_Delta_Easting, Azeq_Delta_Northing, Azeq_f, Azeq_False_Easting, Azeq_False_Northing, AZEQ_NO_ERROR, Azeq_Origin_Lat, Azeq_Origin_Long, Convert_Geodetic_To_Azimuthal_Equidistant(), Cos_Azeq_Origin_Lat, M_PI, ONE, PI_OVER_2, Ra, and Sin_Azeq_Origin_Lat.
Referenced by update().
| void ossimAzimEquDistProjection::setDefaults | ( | ) |
Will initialize all parameters to a default values and then call update for pre-computations.
Definition at line 123 of file ossimAzimEquDistProjection.cpp.
References Azeq_False_Easting, Azeq_False_Northing, and update().
Referenced by loadState().
| void ossimAzimEquDistProjection::setFalseEasting | ( | double | falseEasting | ) |
Definition at line 100 of file ossimAzimEquDistProjection.cpp.
References Azeq_False_Easting, and update().
| void ossimAzimEquDistProjection::setFalseEastingNorthing | ( | double | falseEasting, |
Definition at line 114 of file ossimAzimEquDistProjection.cpp.
Referenced by ossimAzimEquDistProjection().
| void ossimAzimEquDistProjection::setFalseNorthing | ( | double | falseNorthing | ) |
Definition at line 107 of file ossimAzimEquDistProjection.cpp.
References Azeq_False_Northing, and update().
Definition at line 52 of file ossimAzimEquDistProjection.cpp.
References Azeq_False_Easting, Azeq_False_Northing, ossimEllipsoid::getA(), ossimEllipsoid::getFlattening(), ossimGpt::latr(), ossimGpt::lonr(), Set_Azimuthal_Equidistant_Parameters(), ossimMapProjection::theEllipsoid, ossimMapProjection::theFalseEastingNorthing, ossimMapProjection::theOrigin, ossimMapProjection::update(), ossimDpt::x, and ossimDpt::y.
Referenced by loadState(), setDefaults(), setFalseEasting(), setFalseEastingNorthing(), and setFalseNorthing().
mutableprotected |
Definition at line 87 of file ossimAzimEquDistProjection.h.
Referenced by Convert_Azimuthal_Equidistant_To_Geodetic(), Convert_Geodetic_To_Azimuthal_Equidistant(), and Set_Azimuthal_Equidistant_Parameters().
mutableprotected |
Definition at line 88 of file ossimAzimEquDistProjection.h.
Referenced by Get_Azimuthal_Equidistant_Parameters(), and Set_Azimuthal_Equidistant_Parameters().
mutableprotected |
Definition at line 99 of file ossimAzimEquDistProjection.h.
Referenced by Set_Azimuthal_Equidistant_Parameters().
mutableprotected |
Definition at line 98 of file ossimAzimEquDistProjection.h.
mutableprotected |
Definition at line 89 of file ossimAzimEquDistProjection.h.
mutableprotected |
Definition at line 96 of file ossimAzimEquDistProjection.h.
Referenced by Convert_Azimuthal_Equidistant_To_Geodetic(), Convert_Geodetic_To_Azimuthal_Equidistant(), Get_Azimuthal_Equidistant_Parameters(), loadState(), Set_Azimuthal_Equidistant_Parameters(), setDefaults(), setFalseEasting(), setFalseEastingNorthing(), and update().
mutableprotected |
Definition at line 95 of file ossimAzimEquDistProjection.h.
Referenced by Convert_Azimuthal_Equidistant_To_Geodetic(), Convert_Geodetic_To_Azimuthal_Equidistant(), Get_Azimuthal_Equidistant_Parameters(), loadState(), Set_Azimuthal_Equidistant_Parameters(), setDefaults(), setFalseEastingNorthing(), setFalseNorthing(), and update().
mutableprotected |
Definition at line 93 of file ossimAzimEquDistProjection.h.
Referenced by Convert_Azimuthal_Equidistant_To_Geodetic(), Convert_Geodetic_To_Azimuthal_Equidistant(), Get_Azimuthal_Equidistant_Parameters(), and Set_Azimuthal_Equidistant_Parameters().
mutableprotected |
Definition at line 94 of file ossimAzimEquDistProjection.h.
mutableprotected |
Definition at line 92 of file ossimAzimEquDistProjection.h.
mutableprotected |
Definition at line 90 of file ossimAzimEquDistProjection.h.
mutableprotected |
Definition at line 91 of file ossimAzimEquDistProjection.h.
