#include <ossimCylEquAreaProjection.h>
| ossimCylEquAreaProjection (const ossimEllipsoid &ellipsoid=ossimEllipsoid(), const ossimGpt &origin=ossimGpt()) | |
| ossimCylEquAreaProjection (const ossimEllipsoid &ellipsoid, const ossimGpt &origin, double falseEasting, double falseNorthing) | |
| ~ossimCylEquAreaProjection () | |
| virtual ossimDpt | forward (const ossimGpt &worldPoint) const |
| All map projections will convert the world coordinate to an easting northing (Meters). More... | |
| virtual ossimGpt | inverse (const ossimDpt &projectedPoint) const |
| Will take a point in meters and convert it to ground. More... | |
| virtual void | update () |
| void | setFalseEasting (double falseEasting) |
| void | setFalseNorthing (double falseNorthing) |
| void | setFalseEastingNorthing (double falseEasting, double falseNorthing) |
| double | getFalseEasting () const |
| double | getFalseNorthing () const |
| void | setDefaults () |
Public Member Functions inherited from ossimMapProjection | |
| ossimMapProjection (const ossimEllipsoid &ellipsoid=ossimEllipsoid(), const ossimGpt &origin=ossimGpt()) | |
| ossimMapProjection (const ossimMapProjection &src) | |
| virtual ossimDpt | worldToLineSample (const ossimGpt &worldPoint) const |
| virtual void | worldToLineSample (const ossimGpt &worldPoint, ossimDpt &lineSample) const |
| virtual ossimGpt | lineSampleToWorld (const ossimDpt &projectedPoint) const |
| virtual void | lineSampleToWorld (const ossimDpt &projectedPoint, ossimGpt &gpt) const |
| virtual void | lineSampleHeightToWorld (const ossimDpt &lineSampPt, const double &heightAboveEllipsoid, ossimGpt &worldPt) const |
| This is the pure virtual that projects the image point to the given elevation above ellipsoid, thereby bypassing reference to a DEM. More... | |
| virtual void | lineSampleToEastingNorthing (const ossimDpt &liineSample, ossimDpt &eastingNorthing) const |
| virtual void | eastingNorthingToLineSample (const ossimDpt &eastingNorthing, ossimDpt &lineSample) const |
| virtual void | eastingNorthingToWorld (const ossimDpt &eastingNorthing, ossimGpt &worldPt) const |
| virtual double | getStandardParallel1 () const |
| Derived classes should implement as needed. More... | |
| virtual double | getStandardParallel2 () const |
| virtual void | setPcsCode (ossim_uint32 pcsCode) |
| virtual ossim_uint32 | getPcsCode () const |
| Returns the EPSG PCS code or 32767 if the projection is a custom (non-EPSG) projection. More... | |
| virtual ossimString | getProjectionName () const |
| Returns the projection name. More... | |
| virtual double | getA () const |
| ACCESS METHODS: More... | |
| virtual double | getB () const |
| virtual double | getF () const |
| virtual const ossimDpt & | getDecimalDegreesPerPixel () const |
| Returns decimal degrees per pixel as an ossimDpt with "x" representing longitude and "y" representing latitude. More... | |
| virtual const ossimDpt & | getUlEastingNorthing () const |
| virtual const ossimGpt & | getUlGpt () const |
| virtual const ossimDatum * | getDatum () const |
| const ossimEllipsoid & | getEllipsoid () const |
| const ossimGpt & | getOrigin () const |
| virtual bool | isGeographic () const |
| virtual void | applyScale (const ossimDpt &scale, bool recenterTiePoint) |
| Applies scale to theDeltaLonPerPixel, theDeltaLatPerPixel and theMetersPerPixel data members (eg: theDeltaLonPerPixel *= scale.x). More... | |
| virtual void | setEllipsoid (const ossimEllipsoid &ellipsoid) |
| SET METHODS: More... | |
| virtual void | setAB (double a, double b) |
| virtual void | setDatum (const ossimDatum *datum) |
| Sets theDatum to datum. More... | |
| virtual void | setOrigin (const ossimGpt &origin) |
| Sets theOrigin to origin. More... | |
| virtual void | setMetersPerPixel (const ossimDpt &gsd) |
| virtual void | setDecimalDegreesPerPixel (const ossimDpt &gsd) |
| virtual void | setUlTiePoints (const ossimGpt &gpt) |
| virtual void | setUlTiePoints (const ossimDpt &eastingNorthing) |
| virtual void | setUlEastingNorthing (const ossimDpt &ulEastingNorthing) |
| virtual void | setUlGpt (const ossimGpt &ulGpt) |
| virtual void | assign (const ossimProjection &aProjection) |
| Prints data members to stream. More... | |
| virtual bool | operator== (const ossimProjection &projection) const |
| Compares this to arg projection and returns TRUE if the same. More... | |
| virtual void | computeDegreesPerPixel () |
| Computes the approximate resolution in degrees/pixel. More... | |
| virtual void | computeMetersPerPixel () |
| This will go from the ground point and give you an approximate meters per pixel. More... | |
| void | setMatrix (double rotation, const ossimDpt &scale, const ossimDpt &translation) |
| void | setMatrixScale (const ossimDpt &scale) |
| void | setMatrixRotation (double rotation) |
| void | setMatrixTranslation (const ossimDpt &translation) |
| void | snapTiePointTo (ossim_float64 multiple, ossimUnitType unitType) |
| Utility method to snap the tie point to some multiple. More... | |
| void | snapTiePointToOrigin () |
| void | setElevationLookupFlag (bool flag) |
| bool | getElevationLookupFlag () const |
| ossimUnitType | getModelTransformUnitType () const |
| void | setModelTransformUnitType (ossimUnitType unit) |
| bool | hasModelTransform () const |
| void | setProjectionUnits (ossimUnitType units) |
| ossimUnitType | getProjectionUnits () const |
| OSSIM considers all map projection coordinates (including false eastings and northings) to be in meters. More... | |
| ossimProjection () | |
| ossimObject () | |
| bool | hasError () const |
Private Member Functions | |
| long | Set_Cyl_Eq_Area_Parameters (double a, double f, double Origin_Latitude, double Central_Meridian, double False_Easting, double False_Northing) |
| void | Get_Cyl_Eq_Area_Parameters (double *a, double *f, double *Origin_Latitude, double *Central_Meridian, double *False_Easting, double *False_Northing) const |
| long | Convert_Geodetic_To_Cyl_Eq_Area (double Latitude, double Longitude, double *Easting, double *Northing) const |
| long | Convert_Cyl_Eq_Area_To_Geodetic (double Easting, double Northing, double *Latitude, double *Longitude) const |
Private Attributes | |
| double | Cyeq_a |
| double | Cyeq_f |
| double | es2 |
| double | es |
| double | es4 |
| double | es6 |
| double | k0 |
| double | Cyeq_a_k0 |
| double | two_k0 |
| double | c0 |
| double | c1 |
| double | c2 |
| double | Cyeq_Origin_Lat |
| double | Cyeq_Origin_Long |
| double | Cyeq_False_Northing |
| double | Cyeq_False_Easting |
| double | Cyeq_Max_Easting |
| double | Cyeq_Min_Easting |
| double | Cyeq_Delta_Northing |
Protected Member Functions inherited from ossimMapProjection | |
| virtual | ~ossimMapProjection () |
| void | updateFromTransform () |
Protected Attributes inherited from ossimMapProjection | |
| ossimEllipsoid | theEllipsoid |
| This method verifies that the projection parameters match the current pcs code. More... | |
| ossimGpt | theOrigin |
| const ossimDatum * | theDatum |
| This is only set if we want to have built in datum shifting. More... | |
| ossimDpt | theMetersPerPixel |
| Holds the number of meters per pixel. More... | |
| ossimDpt | theDegreesPerPixel |
| Hold the decimal degrees per pixel. More... | |
| ossimGpt | theUlGpt |
| Hold tie point in decimal degrees. More... | |
| ossimDpt | theUlEastingNorthing |
| Hold tie point as easting northing. More... | |
| ossimDpt | theFalseEastingNorthing |
| Hold the false easting northing. More... | |
| ossim_uint32 | thePcsCode |
| Projection Coordinate System(PCS) code. More... | |
| bool | theElevationLookupFlag |
| ossimMatrix4x4 | theModelTransform |
| ossimMatrix4x4 | theInverseModelTransform |
| ossimUnitType | theModelTransformUnitType |
| ossimUnitType | theProjectionUnits |
| Linear units of the projection as indicated in the projection's specification: More... | |
Definition at line 18 of file ossimCylEquAreaProjection.h.
| ossimCylEquAreaProjection::ossimCylEquAreaProjection | ( | const ossimEllipsoid & | ellipsoid = ossimEllipsoid(), |
| const ossimGpt & | origin = ossimGpt() |
Definition at line 51 of file ossimCylEquAreaProjection.cpp.
References setDefaults(), and update().
| ossimCylEquAreaProjection::ossimCylEquAreaProjection | ( | const ossimEllipsoid & | ellipsoid, |
| const ossimGpt & | origin, | ||
| double | falseEasting, | ||
| double | falseNorthing | ||
Definition at line 59 of file ossimCylEquAreaProjection.cpp.
References Cyeq_Delta_Northing, Cyeq_False_Easting, Cyeq_False_Northing, Cyeq_Max_Easting, Cyeq_Min_Easting, and update().
inline |
Definition at line 27 of file ossimCylEquAreaProjection.h.
private |
The function Convert_Cyl_Eq_Area_To_Geodetic converts Cylindrical Equal Area projection easting and northing coordinates to geodetic (latitude and longitude) coordinates, according to the current ellipsoid and Cylindrical Equal Area projection coordinates. If any errors occur, the error code(s) are returned by the function, otherwise CYEQ_NO_ERROR is returned.
Easting : Easting (X) in meters (input) Northing : Northing (Y) in meters (input) Latitude : Latitude (phi) in radians (output) Longitude : Longitude (lambda) in radians (output)
Definition at line 364 of file ossimCylEquAreaProjection.cpp.
References c0, c1, c2, Cyeq_a, Cyeq_a_k0, CYEQ_COEFF_TIMES_SIN, Cyeq_False_Easting, Cyeq_False_Northing, CYEQ_NO_ERROR, Cyeq_Origin_Long, CYLEQAR_Q, es, PI_OVER_2, two_k0, and x.
Referenced by inverse().
private |
The function Convert_Geodetic_To_Cyl_Eq_Area converts geodetic (latitude and longitude) coordinates to Cylindrical Equal Area projection easting, and northing coordinates, according to the current ellipsoid and Cylindrical Equal Area projection parameters. If any errors occur, the error code(s) are returned by the function, otherwise CYEQ_NO_ERROR is returned.
Latitude : Latitude (phi) in radians (input) Longitude : Longitude (lambda) in radians (input) Easting : Easting (X) in meters (output) Northing : Northing (Y) in meters (output)
Definition at line 312 of file ossimCylEquAreaProjection.cpp.
References Cyeq_a, Cyeq_a_k0, Cyeq_False_Easting, Cyeq_False_Northing, CYEQ_NO_ERROR, Cyeq_Origin_Long, CYLEQAR_Q, es, two_k0, and x.
Referenced by forward(), and Set_Cyl_Eq_Area_Parameters().
inlinevirtual |
Implements ossimProjection.
Definition at line 28 of file ossimCylEquAreaProjection.h.
Definition at line 135 of file ossimCylEquAreaProjection.cpp.
References ossimGpt::changeDatum(), ossimDatum::code(), Convert_Geodetic_To_Cyl_Eq_Area(), ossimGpt::datum(), ossimGpt::latr(), ossimGpt::lonr(), and ossimMapProjection::theDatum.
private |
The function Get_Cyl_Eq_Area_Parameters returns the current ellipsoid parameters and Cylindrical Equal Area projection parameters.
a : Semi-major axis of ellipsoid, in meters (output) f : Flattening of ellipsoid (output) Origin_Latitude : Latitude in radians at which the (output) point scale factor is 1.0 Central_Meridian : Longitude in radians at the center of (output) the projection False_Easting : A coordinate value in meters assigned to the central meridian of the projection. (output) False_Northing : A coordinate value in meters assigned to the origin latitude of the projection (output)
Definition at line 279 of file ossimCylEquAreaProjection.cpp.
References Cyeq_a, Cyeq_f, Cyeq_False_Easting, Cyeq_False_Northing, Cyeq_Origin_Lat, and Cyeq_Origin_Long.
inlinevirtual |
Definition at line 56 of file ossimCylEquAreaProjection.h.
inlinevirtual |
Definition at line 57 of file ossimCylEquAreaProjection.h.
Definition at line 123 of file ossimCylEquAreaProjection.cpp.
References Convert_Cyl_Eq_Area_To_Geodetic(), DEG_PER_RAD, ossimMapProjection::theDatum, ossimDpt::x, and ossimDpt::y.
Definition at line 163 of file ossimCylEquAreaProjection.cpp.
References Cyeq_False_Easting, Cyeq_False_Northing, ossimKeywordlist::find(), ossimMapProjection::loadState(), setDefaults(), STATIC_TYPE_NAME, ossimMapProjection::theFalseEastingNorthing, ossimKeywordNames::TYPE_KW, update(), ossimDpt::x, and ossimDpt::y.
Definition at line 158 of file ossimCylEquAreaProjection.cpp.
References ossimMapProjection::saveState().
private |
The function Set_Cyl_Eq_Area_Parameters receives the ellipsoid parameters and Cylindrical Equal Area projcetion parameters as inputs, and sets the corresponding state variables. If any errors occur, the error code(s) are returned by the function, otherwise CYEQ_NO_ERROR is returned.
a : Semi-major axis of ellipsoid, in meters (input) f : Flattening of ellipsoid (input) Origin_Latitude : Latitude in radians at which the (input) point scale factor is 1.0 Central_Meridian : Longitude in radians at the center of (input) the projection False_Easting : A coordinate value in meters assigned to the central meridian of the projection. (input) False_Northing : A coordinate value in meters assigned to the origin latitude of the projection (input)
Definition at line 188 of file ossimCylEquAreaProjection.cpp.
References c0, c1, c2, Convert_Geodetic_To_Cyl_Eq_Area(), Cyeq_a, Cyeq_a_k0, Cyeq_Delta_Northing, Cyeq_f, Cyeq_False_Easting, Cyeq_False_Northing, Cyeq_Max_Easting, Cyeq_Min_Easting, CYEQ_NO_ERROR, Cyeq_Origin_Lat, Cyeq_Origin_Long, es, es2, es4, es6, k0, M_PI, ONE, PI_OVER_2, two_k0, and TWO_PI.
Referenced by update().
| void ossimCylEquAreaProjection::setDefaults | ( | ) |
Initialize all pramters to default and calls update for pre-computations.
Definition at line 94 of file ossimCylEquAreaProjection.cpp.
References Cyeq_Delta_Northing, Cyeq_False_Easting, Cyeq_False_Northing, Cyeq_Max_Easting, and Cyeq_Min_Easting.
Referenced by loadState(), and ossimCylEquAreaProjection().
| void ossimCylEquAreaProjection::setFalseEasting | ( | double | falseEasting | ) |
Definition at line 74 of file ossimCylEquAreaProjection.cpp.
References Cyeq_False_Easting, and update().
| void ossimCylEquAreaProjection::setFalseEastingNorthing | ( | double | falseEasting, |
Definition at line 86 of file ossimCylEquAreaProjection.cpp.
References Cyeq_False_Easting, Cyeq_False_Northing, and update().
| void ossimCylEquAreaProjection::setFalseNorthing | ( | double | falseNorthing | ) |
Definition at line 80 of file ossimCylEquAreaProjection.cpp.
References Cyeq_False_Northing, and update().
Definition at line 103 of file ossimCylEquAreaProjection.cpp.
References Cyeq_Delta_Northing, Cyeq_False_Easting, Cyeq_False_Northing, Cyeq_Max_Easting, Cyeq_Min_Easting, ossimEllipsoid::getA(), ossimEllipsoid::getFlattening(), ossimGpt::latr(), ossimGpt::lonr(), Set_Cyl_Eq_Area_Parameters(), ossimMapProjection::theEllipsoid, ossimMapProjection::theFalseEastingNorthing, ossimMapProjection::theOrigin, ossimMapProjection::update(), ossimDpt::x, and ossimDpt::y.
Referenced by loadState(), ossimCylEquAreaProjection(), setFalseEasting(), setFalseEastingNorthing(), and setFalseNorthing().
mutableprivate |
Definition at line 92 of file ossimCylEquAreaProjection.h.
Referenced by Convert_Cyl_Eq_Area_To_Geodetic(), and Set_Cyl_Eq_Area_Parameters().
mutableprivate |
Definition at line 93 of file ossimCylEquAreaProjection.h.
mutableprivate |
Definition at line 94 of file ossimCylEquAreaProjection.h.
mutableprivate |
Definition at line 83 of file ossimCylEquAreaProjection.h.
Referenced by Convert_Cyl_Eq_Area_To_Geodetic(), Convert_Geodetic_To_Cyl_Eq_Area(), Get_Cyl_Eq_Area_Parameters(), and Set_Cyl_Eq_Area_Parameters().
mutableprivate |
Definition at line 90 of file ossimCylEquAreaProjection.h.
Referenced by Convert_Cyl_Eq_Area_To_Geodetic(), Convert_Geodetic_To_Cyl_Eq_Area(), and Set_Cyl_Eq_Area_Parameters().
mutableprivate |
Definition at line 106 of file ossimCylEquAreaProjection.h.
Referenced by ossimCylEquAreaProjection(), Set_Cyl_Eq_Area_Parameters(), setDefaults(), and update().
mutableprivate |
Definition at line 84 of file ossimCylEquAreaProjection.h.
Referenced by Get_Cyl_Eq_Area_Parameters(), and Set_Cyl_Eq_Area_Parameters().
mutableprivate |
Definition at line 100 of file ossimCylEquAreaProjection.h.
Referenced by Convert_Cyl_Eq_Area_To_Geodetic(), Convert_Geodetic_To_Cyl_Eq_Area(), Get_Cyl_Eq_Area_Parameters(), loadState(), ossimCylEquAreaProjection(), Set_Cyl_Eq_Area_Parameters(), setDefaults(), setFalseEasting(), setFalseEastingNorthing(), and update().
mutableprivate |
Definition at line 99 of file ossimCylEquAreaProjection.h.
Referenced by Convert_Cyl_Eq_Area_To_Geodetic(), Convert_Geodetic_To_Cyl_Eq_Area(), Get_Cyl_Eq_Area_Parameters(), loadState(), ossimCylEquAreaProjection(), Set_Cyl_Eq_Area_Parameters(), setDefaults(), setFalseEastingNorthing(), setFalseNorthing(), and update().
mutableprivate |
Definition at line 104 of file ossimCylEquAreaProjection.h.
mutableprivate |
Definition at line 105 of file ossimCylEquAreaProjection.h.
mutableprivate |
Definition at line 97 of file ossimCylEquAreaProjection.h.
mutableprivate |
Definition at line 98 of file ossimCylEquAreaProjection.h.
mutableprivate |
Definition at line 86 of file ossimCylEquAreaProjection.h.
mutableprivate |
Definition at line 85 of file ossimCylEquAreaProjection.h.
Referenced by Set_Cyl_Eq_Area_Parameters().
mutableprivate |
Definition at line 87 of file ossimCylEquAreaProjection.h.
mutableprivate |
Definition at line 88 of file ossimCylEquAreaProjection.h.
mutableprivate |
Definition at line 89 of file ossimCylEquAreaProjection.h.
mutableprivate |
Definition at line 91 of file ossimCylEquAreaProjection.h.
