#include <ossimMillerProjection.h>
| ossimMillerProjection (const ossimEllipsoid &ellipsoid=ossimEllipsoid(), const ossimGpt &origin=ossimGpt()) | |
| ossimMillerProjection (const ossimEllipsoid &ellipsoid, const ossimGpt &origin, const double falseEasting, const double falseNorthing) | |
| ~ossimMillerProjection () | |
| virtual ossimGpt | inverse (const ossimDpt &eastingNorthing) const |
| Will take a point in meters and convert it to ground. More... | |
| virtual ossimDpt | forward (const ossimGpt &latLon) const |
| All map projections will convert the world coordinate to an easting northing (Meters). More... | |
| virtual void | update () |
| void | setFalseEasting (double falseEasting) |
| void | setFalseNorthing (double falseNorthing) |
| void | setFalseEastingNorthing (double falseEasting, double falseNorthing) |
| void | setDefaults () |
| void | setCentralMeridian (double centralMeridian) |
| double | getFalseEasting () const |
| double | getFalseNorthing () const |
Public Member Functions inherited from ossimMapProjection | |
| ossimMapProjection (const ossimEllipsoid &ellipsoid=ossimEllipsoid(), const ossimGpt &origin=ossimGpt()) | |
| ossimMapProjection (const ossimMapProjection &src) | |
| virtual ossimDpt | worldToLineSample (const ossimGpt &worldPoint) const |
| virtual void | worldToLineSample (const ossimGpt &worldPoint, ossimDpt &lineSample) const |
| virtual ossimGpt | lineSampleToWorld (const ossimDpt &projectedPoint) const |
| virtual void | lineSampleToWorld (const ossimDpt &projectedPoint, ossimGpt &gpt) const |
| virtual void | lineSampleHeightToWorld (const ossimDpt &lineSampPt, const double &heightAboveEllipsoid, ossimGpt &worldPt) const |
| This is the pure virtual that projects the image point to the given elevation above ellipsoid, thereby bypassing reference to a DEM. More... | |
| virtual void | lineSampleToEastingNorthing (const ossimDpt &liineSample, ossimDpt &eastingNorthing) const |
| virtual void | eastingNorthingToLineSample (const ossimDpt &eastingNorthing, ossimDpt &lineSample) const |
| virtual void | eastingNorthingToWorld (const ossimDpt &eastingNorthing, ossimGpt &worldPt) const |
| virtual double | getStandardParallel1 () const |
| Derived classes should implement as needed. More... | |
| virtual double | getStandardParallel2 () const |
| virtual void | setPcsCode (ossim_uint32 pcsCode) |
| virtual ossim_uint32 | getPcsCode () const |
| Returns the EPSG PCS code or 32767 if the projection is a custom (non-EPSG) projection. More... | |
| virtual ossimString | getProjectionName () const |
| Returns the projection name. More... | |
| virtual double | getA () const |
| ACCESS METHODS: More... | |
| virtual double | getB () const |
| virtual double | getF () const |
| virtual const ossimDpt & | getDecimalDegreesPerPixel () const |
| Returns decimal degrees per pixel as an ossimDpt with "x" representing longitude and "y" representing latitude. More... | |
| virtual const ossimDpt & | getUlEastingNorthing () const |
| virtual const ossimGpt & | getUlGpt () const |
| virtual const ossimDatum * | getDatum () const |
| const ossimEllipsoid & | getEllipsoid () const |
| const ossimGpt & | getOrigin () const |
| virtual bool | isGeographic () const |
| virtual void | applyScale (const ossimDpt &scale, bool recenterTiePoint) |
| Applies scale to theDeltaLonPerPixel, theDeltaLatPerPixel and theMetersPerPixel data members (eg: theDeltaLonPerPixel *= scale.x). More... | |
| virtual void | setEllipsoid (const ossimEllipsoid &ellipsoid) |
| SET METHODS: More... | |
| virtual void | setAB (double a, double b) |
| virtual void | setDatum (const ossimDatum *datum) |
| Sets theDatum to datum. More... | |
| virtual void | setOrigin (const ossimGpt &origin) |
| Sets theOrigin to origin. More... | |
| virtual void | setMetersPerPixel (const ossimDpt &gsd) |
| virtual void | setDecimalDegreesPerPixel (const ossimDpt &gsd) |
| virtual void | setUlTiePoints (const ossimGpt &gpt) |
| virtual void | setUlTiePoints (const ossimDpt &eastingNorthing) |
| virtual void | setUlEastingNorthing (const ossimDpt &ulEastingNorthing) |
| virtual void | setUlGpt (const ossimGpt &ulGpt) |
| virtual void | assign (const ossimProjection &aProjection) |
| Prints data members to stream. More... | |
| virtual bool | operator== (const ossimProjection &projection) const |
| Compares this to arg projection and returns TRUE if the same. More... | |
| virtual void | computeDegreesPerPixel () |
| Computes the approximate resolution in degrees/pixel. More... | |
| virtual void | computeMetersPerPixel () |
| This will go from the ground point and give you an approximate meters per pixel. More... | |
| void | setMatrix (double rotation, const ossimDpt &scale, const ossimDpt &translation) |
| void | setMatrixScale (const ossimDpt &scale) |
| void | setMatrixRotation (double rotation) |
| void | setMatrixTranslation (const ossimDpt &translation) |
| void | snapTiePointTo (ossim_float64 multiple, ossimUnitType unitType) |
| Utility method to snap the tie point to some multiple. More... | |
| void | snapTiePointToOrigin () |
| void | setElevationLookupFlag (bool flag) |
| bool | getElevationLookupFlag () const |
| ossimUnitType | getModelTransformUnitType () const |
| void | setModelTransformUnitType (ossimUnitType unit) |
| bool | hasModelTransform () const |
| void | setProjectionUnits (ossimUnitType units) |
| ossimUnitType | getProjectionUnits () const |
| OSSIM considers all map projection coordinates (including false eastings and northings) to be in meters. More... | |
| ossimProjection () | |
| ossimObject () | |
| bool | hasError () const |
Private Member Functions | |
| long | Set_Miller_Parameters (double a, double f, double Central_Meridian, double False_Easting, double False_Northing) |
| void | Get_Miller_Parameters (double *a, double *f, double *Central_Meridian, double *False_Easting, double *False_Northing) const |
| long | Convert_Geodetic_To_Miller (double Latitude, double Longitude, double *Easting, double *Northing) const |
| long | Convert_Miller_To_Geodetic (double Easting, double Northing, double *Latitude, double *Longitude) const |
Private Attributes | |
| double | Mill_a |
| double | Mill_f |
| double | es2 |
| double | es4 |
| double | es6 |
| double | Ra |
| double | Mill_Origin_Long |
| double | Mill_False_Easting |
| double | Mill_False_Northing |
| double | Mill_Delta_Northing |
| double | Mill_Max_Easting |
| double | Mill_Min_Easting |
Protected Member Functions inherited from ossimMapProjection | |
| virtual | ~ossimMapProjection () |
| void | updateFromTransform () |
Protected Attributes inherited from ossimMapProjection | |
| ossimEllipsoid | theEllipsoid |
| This method verifies that the projection parameters match the current pcs code. More... | |
| ossimGpt | theOrigin |
| const ossimDatum * | theDatum |
| This is only set if we want to have built in datum shifting. More... | |
| ossimDpt | theMetersPerPixel |
| Holds the number of meters per pixel. More... | |
| ossimDpt | theDegreesPerPixel |
| Hold the decimal degrees per pixel. More... | |
| ossimGpt | theUlGpt |
| Hold tie point in decimal degrees. More... | |
| ossimDpt | theUlEastingNorthing |
| Hold tie point as easting northing. More... | |
| ossimDpt | theFalseEastingNorthing |
| Hold the false easting northing. More... | |
| ossim_uint32 | thePcsCode |
| Projection Coordinate System(PCS) code. More... | |
| bool | theElevationLookupFlag |
| ossimMatrix4x4 | theModelTransform |
| ossimMatrix4x4 | theInverseModelTransform |
| ossimUnitType | theModelTransformUnitType |
| ossimUnitType | theProjectionUnits |
| Linear units of the projection as indicated in the projection's specification: More... | |
Definition at line 18 of file ossimMillerProjection.h.
| ossimMillerProjection::ossimMillerProjection | ( | const ossimEllipsoid & | ellipsoid = ossimEllipsoid(), |
| const ossimGpt & | origin = ossimGpt() |
Definition at line 41 of file ossimMillerProjection.cpp.
References setDefaults(), and update().
| ossimMillerProjection::ossimMillerProjection | ( | const ossimEllipsoid & | ellipsoid, |
| const ossimGpt & | origin, | ||
| const double | falseEasting, | ||
| const double | falseNorthing | ||
Definition at line 52 of file ossimMillerProjection.cpp.
References Mill_Delta_Northing, Mill_False_Easting, Mill_False_Northing, Mill_Max_Easting, Mill_Min_Easting, and update().
inline |
Definition at line 28 of file ossimMillerProjection.h.
private |
The function Convert_Geodetic_To_Miller converts geodetic (latitude and longitude) coordinates to Miller Cylindrical projection easting, and northing coordinates, according to the current ellipsoid and Miller Cylindrical projection parameters. If any errors occur, the error code(s) are returned by the function, otherwise MILL_NO_ERROR is returned.
Latitude : Latitude (phi) in radians (input) Longitude : Longitude (lambda) in radians (input) Easting : Easting (X) in meters (output) Northing : Northing (Y) in meters (output)
Definition at line 284 of file ossimMillerProjection.cpp.
References Mill_False_Easting, Mill_False_Northing, MILL_NO_ERROR, Mill_Origin_Long, and Ra.
Referenced by forward().
private |
The function Convert_Miller_To_Geodetic converts Miller Cylindrical projection easting and northing coordinates to geodetic (latitude and longitude) coordinates, according to the current ellipsoid and Miller Cylindrical projection coordinates. If any errors occur, the error code(s) are returned by the function, otherwise MILL_NO_ERROR is returned.
Easting : Easting (X) in meters (input) Northing : Northing (Y) in meters (input) Latitude : Latitude (phi) in radians (output) Longitude : Longitude (lambda) in radians (output)
Definition at line 336 of file ossimMillerProjection.cpp.
Referenced by inverse().
inlinevirtual |
Implements ossimProjection.
Definition at line 30 of file ossimMillerProjection.h.
Definition at line 131 of file ossimMillerProjection.cpp.
References ossimGpt::changeDatum(), ossimDatum::code(), Convert_Geodetic_To_Miller(), ossimGpt::datum(), ossimGpt::latr(), ossimGpt::lonr(), and ossimMapProjection::theDatum.
private |
The function Get_Miller_Parameters returns the current ellipsoid parameters and Miller Cylindrical projection parameters.
a : Semi-major axis of ellipsoid, in meters (output) f : Flattening of ellipsoid (output) Central_Meridian : Longitude in radians at the center of (output) the projection False_Easting : A coordinate value in meters assigned to the central meridian of the projection. (output) False_Northing : A coordinate value in meters assigned to the origin latitude of the projection (output)
Definition at line 254 of file ossimMillerProjection.cpp.
References Mill_a, Mill_f, Mill_False_Easting, Mill_False_Northing, and Mill_Origin_Long.
inlinevirtual |
Definition at line 59 of file ossimMillerProjection.h.
inlinevirtual |
Definition at line 60 of file ossimMillerProjection.h.
Definition at line 118 of file ossimMillerProjection.cpp.
References Convert_Miller_To_Geodetic(), DEG_PER_RAD, ossimMapProjection::theDatum, ossimDpt::x, and ossimDpt::y.
Definition at line 158 of file ossimMillerProjection.cpp.
References ossimKeywordlist::find(), ossimMapProjection::loadState(), Mill_False_Easting, Mill_False_Northing, setDefaults(), STATIC_TYPE_NAME, ossimMapProjection::theFalseEastingNorthing, ossimKeywordNames::TYPE_KW, update(), ossimDpt::x, and ossimDpt::y.
Definition at line 153 of file ossimMillerProjection.cpp.
References ossimMapProjection::saveState().
private |
The function Set_Miller_Parameters receives the ellipsoid parameters and Miller Cylindrical projcetion parameters as inputs, and sets the corresponding state variables. If any errors occur, the error code(s) are returned by the function, otherwise MILL_NO_ERROR is returned.
a : Semi-major axis of ellipsoid, in meters (input) f : Flattening of ellipsoid (input) Central_Meridian : Longitude in radians at the center of (input) the projection False_Easting : A coordinate value in meters assigned to the central meridian of the projection. (input) False_Northing : A coordinate value in meters assigned to the origin latitude of the projection (input)
Definition at line 183 of file ossimMillerProjection.cpp.
References es2, es4, es6, Mill_a, Mill_f, Mill_False_Easting, Mill_False_Northing, Mill_Max_Easting, Mill_Min_Easting, MILL_NO_ERROR, Mill_Origin_Long, and Ra.
Referenced by update().
| void ossimMillerProjection::setCentralMeridian | ( | double | centralMeridian | ) |
Definition at line 103 of file ossimMillerProjection.cpp.
References Mill_Origin_Long, and update().
| void ossimMillerProjection::setDefaults | ( | ) |
Definition at line 94 of file ossimMillerProjection.cpp.
References Mill_Delta_Northing, Mill_False_Easting, Mill_False_Northing, Mill_Max_Easting, and Mill_Min_Easting.
Referenced by loadState(), and ossimMillerProjection().
| void ossimMillerProjection::setFalseEasting | ( | double | falseEasting | ) |
Definition at line 82 of file ossimMillerProjection.cpp.
References Mill_False_Easting, and update().
| void ossimMillerProjection::setFalseEastingNorthing | ( | double | falseEasting, |
Definition at line 109 of file ossimMillerProjection.cpp.
References Mill_False_Easting, Mill_False_Northing, and update().
| void ossimMillerProjection::setFalseNorthing | ( | double | falseNorthing | ) |
Definition at line 88 of file ossimMillerProjection.cpp.
References Mill_False_Northing, and update().
Definition at line 68 of file ossimMillerProjection.cpp.
References ossimEllipsoid::getA(), ossimEllipsoid::getFlattening(), ossimGpt::lonr(), Mill_False_Easting, Mill_False_Northing, Set_Miller_Parameters(), ossimMapProjection::theEllipsoid, ossimMapProjection::theFalseEastingNorthing, ossimMapProjection::theOrigin, ossimMapProjection::update(), ossimDpt::x, and ossimDpt::y.
Referenced by loadState(), ossimMillerProjection(), setCentralMeridian(), setFalseEasting(), setFalseEastingNorthing(), and setFalseNorthing().
mutableprivate |
Definition at line 81 of file ossimMillerProjection.h.
Referenced by Set_Miller_Parameters().
mutableprivate |
Definition at line 82 of file ossimMillerProjection.h.
mutableprivate |
Definition at line 83 of file ossimMillerProjection.h.
mutableprivate |
Definition at line 79 of file ossimMillerProjection.h.
Referenced by Get_Miller_Parameters(), and Set_Miller_Parameters().
mutableprivate |
Definition at line 90 of file ossimMillerProjection.h.
Referenced by ossimMillerProjection(), and setDefaults().
mutableprivate |
Definition at line 80 of file ossimMillerProjection.h.
mutableprivate |
Definition at line 88 of file ossimMillerProjection.h.
Referenced by Convert_Geodetic_To_Miller(), Convert_Miller_To_Geodetic(), Get_Miller_Parameters(), loadState(), ossimMillerProjection(), Set_Miller_Parameters(), setDefaults(), setFalseEasting(), setFalseEastingNorthing(), and update().
mutableprivate |
Definition at line 89 of file ossimMillerProjection.h.
Referenced by Convert_Geodetic_To_Miller(), Convert_Miller_To_Geodetic(), Get_Miller_Parameters(), loadState(), ossimMillerProjection(), Set_Miller_Parameters(), setDefaults(), setFalseEastingNorthing(), setFalseNorthing(), and update().
mutableprivate |
Definition at line 91 of file ossimMillerProjection.h.
Referenced by ossimMillerProjection(), Set_Miller_Parameters(), and setDefaults().
mutableprivate |
Definition at line 92 of file ossimMillerProjection.h.
mutableprivate |
Definition at line 87 of file ossimMillerProjection.h.
Referenced by Convert_Geodetic_To_Miller(), Convert_Miller_To_Geodetic(), Get_Miller_Parameters(), Set_Miller_Parameters(), and setCentralMeridian().
mutableprivate |
Definition at line 84 of file ossimMillerProjection.h.
Referenced by Convert_Geodetic_To_Miller(), Convert_Miller_To_Geodetic(), and Set_Miller_Parameters().
