#include <ossimTransCylEquAreaProjection.h>
| ossimTransCylEquAreaProjection (const ossimEllipsoid &ellipsoid=ossimEllipsoid(6378137, 6356752.3142), const ossimGpt &origin=ossimGpt()) | |
| ossimTransCylEquAreaProjection (const ossimEllipsoid &ellipsoid, const ossimGpt &origin, double falseEasting, double falseNorthing, double scaleFactor) | |
| ~ossimTransCylEquAreaProjection () | |
| virtual ossimGpt | inverse (const ossimDpt &eastingNorthing) const |
| Will take a point in meters and convert it to ground. More... | |
| virtual ossimDpt | forward (const ossimGpt &latLon) const |
| All map projections will convert the world coordinate to an easting northing (Meters). More... | |
| virtual void | update () |
| void | setFalseEasting (double falseEasting) |
| void | setFalseNorthing (double falseNorthing) |
| void | setScaleFactor (double scaleFactor) |
| void | setFalseEastingNorthing (double falseEasting, double falseNorthing) |
| void | setParameters (double falseEasting, double falseNorthing, double scaleFactor) |
| void | setDefaults () |
| double | getFalseEasting () const |
| double | getFalseNorthing () const |
| double | getScaleFactor () const |
| virtual bool | operator== (const ossimProjection &projection) const |
| Returns TRUE if principal parameters are within epsilon tolerance. More... | |
Public Member Functions inherited from ossimMapProjection | |
| ossimMapProjection (const ossimEllipsoid &ellipsoid=ossimEllipsoid(), const ossimGpt &origin=ossimGpt()) | |
| ossimMapProjection (const ossimMapProjection &src) | |
| virtual ossimDpt | worldToLineSample (const ossimGpt &worldPoint) const |
| virtual void | worldToLineSample (const ossimGpt &worldPoint, ossimDpt &lineSample) const |
| virtual ossimGpt | lineSampleToWorld (const ossimDpt &projectedPoint) const |
| virtual void | lineSampleToWorld (const ossimDpt &projectedPoint, ossimGpt &gpt) const |
| virtual void | lineSampleHeightToWorld (const ossimDpt &lineSampPt, const double &heightAboveEllipsoid, ossimGpt &worldPt) const |
| This is the pure virtual that projects the image point to the given elevation above ellipsoid, thereby bypassing reference to a DEM. More... | |
| virtual void | lineSampleToEastingNorthing (const ossimDpt &liineSample, ossimDpt &eastingNorthing) const |
| virtual void | eastingNorthingToLineSample (const ossimDpt &eastingNorthing, ossimDpt &lineSample) const |
| virtual void | eastingNorthingToWorld (const ossimDpt &eastingNorthing, ossimGpt &worldPt) const |
| virtual double | getStandardParallel1 () const |
| Derived classes should implement as needed. More... | |
| virtual double | getStandardParallel2 () const |
| virtual void | setPcsCode (ossim_uint32 pcsCode) |
| virtual ossim_uint32 | getPcsCode () const |
| Returns the EPSG PCS code or 32767 if the projection is a custom (non-EPSG) projection. More... | |
| virtual ossimString | getProjectionName () const |
| Returns the projection name. More... | |
| virtual double | getA () const |
| ACCESS METHODS: More... | |
| virtual double | getB () const |
| virtual double | getF () const |
| virtual const ossimDpt & | getDecimalDegreesPerPixel () const |
| Returns decimal degrees per pixel as an ossimDpt with "x" representing longitude and "y" representing latitude. More... | |
| virtual const ossimDpt & | getUlEastingNorthing () const |
| virtual const ossimGpt & | getUlGpt () const |
| virtual const ossimDatum * | getDatum () const |
| const ossimEllipsoid & | getEllipsoid () const |
| const ossimGpt & | getOrigin () const |
| virtual bool | isGeographic () const |
| virtual void | applyScale (const ossimDpt &scale, bool recenterTiePoint) |
| Applies scale to theDeltaLonPerPixel, theDeltaLatPerPixel and theMetersPerPixel data members (eg: theDeltaLonPerPixel *= scale.x). More... | |
| virtual void | setEllipsoid (const ossimEllipsoid &ellipsoid) |
| SET METHODS: More... | |
| virtual void | setAB (double a, double b) |
| virtual void | setDatum (const ossimDatum *datum) |
| Sets theDatum to datum. More... | |
| virtual void | setOrigin (const ossimGpt &origin) |
| Sets theOrigin to origin. More... | |
| virtual void | setMetersPerPixel (const ossimDpt &gsd) |
| virtual void | setDecimalDegreesPerPixel (const ossimDpt &gsd) |
| virtual void | setUlTiePoints (const ossimGpt &gpt) |
| virtual void | setUlTiePoints (const ossimDpt &eastingNorthing) |
| virtual void | setUlEastingNorthing (const ossimDpt &ulEastingNorthing) |
| virtual void | setUlGpt (const ossimGpt &ulGpt) |
| virtual void | assign (const ossimProjection &aProjection) |
| Prints data members to stream. More... | |
| virtual void | computeDegreesPerPixel () |
| Computes the approximate resolution in degrees/pixel. More... | |
| virtual void | computeMetersPerPixel () |
| This will go from the ground point and give you an approximate meters per pixel. More... | |
| void | setMatrix (double rotation, const ossimDpt &scale, const ossimDpt &translation) |
| void | setMatrixScale (const ossimDpt &scale) |
| void | setMatrixRotation (double rotation) |
| void | setMatrixTranslation (const ossimDpt &translation) |
| void | snapTiePointTo (ossim_float64 multiple, ossimUnitType unitType) |
| Utility method to snap the tie point to some multiple. More... | |
| void | snapTiePointToOrigin () |
| void | setElevationLookupFlag (bool flag) |
| bool | getElevationLookupFlag () const |
| ossimUnitType | getModelTransformUnitType () const |
| void | setModelTransformUnitType (ossimUnitType unit) |
| bool | hasModelTransform () const |
| void | setProjectionUnits (ossimUnitType units) |
| ossimUnitType | getProjectionUnits () const |
| OSSIM considers all map projection coordinates (including false eastings and northings) to be in meters. More... | |
| ossimProjection () | |
| ossimObject () | |
| bool | hasError () const |
Private Member Functions | |
| long | Set_Trans_Cyl_Eq_Area_Parameters (double a, double f, double Origin_Latitude, double Central_Meridian, double False_Easting, double False_Northing, double Scale_Factor) |
| void | Get_Trans_Cyl_Eq_Area_Parameters (double *a, double *f, double *Origin_Latitude, double *Central_Meridian, double *False_Easting, double *False_Northing, double *Scale_Factor) const |
| long | Convert_Geodetic_To_Trans_Cyl_Eq_Area (double Latitude, double Longitude, double *Easting, double *Northing) const |
| long | Convert_Trans_Cyl_Eq_Area_To_Geodetic (double Easting, double Northing, double *Latitude, double *Longitude) const |
Private Attributes | |
| double | Tcea_a |
| double | Tcea_f |
| double | es2 |
| double | es4 |
| double | es6 |
| double | es |
| double | M0 |
| double | qp |
| double | One_MINUS_es2 |
| double | One_OVER_2es |
| double | a0 |
| double | a1 |
| double | a2 |
| double | b0 |
| double | b1 |
| double | b2 |
| double | b3 |
| double | c0 |
| double | c1 |
| double | c2 |
| double | c3 |
| double | Tcea_Origin_Lat |
| double | Tcea_Origin_Long |
| double | Tcea_False_Northing |
| double | Tcea_False_Easting |
| double | Tcea_Scale_Factor |
| double | Tcea_Min_Easting |
| double | Tcea_Max_Easting |
| double | Tcea_Min_Northing |
| double | Tcea_Max_Northing |
Protected Member Functions inherited from ossimMapProjection | |
| virtual | ~ossimMapProjection () |
| void | updateFromTransform () |
Protected Attributes inherited from ossimMapProjection | |
| ossimEllipsoid | theEllipsoid |
| This method verifies that the projection parameters match the current pcs code. More... | |
| ossimGpt | theOrigin |
| const ossimDatum * | theDatum |
| This is only set if we want to have built in datum shifting. More... | |
| ossimDpt | theMetersPerPixel |
| Holds the number of meters per pixel. More... | |
| ossimDpt | theDegreesPerPixel |
| Hold the decimal degrees per pixel. More... | |
| ossimGpt | theUlGpt |
| Hold tie point in decimal degrees. More... | |
| ossimDpt | theUlEastingNorthing |
| Hold tie point as easting northing. More... | |
| ossimDpt | theFalseEastingNorthing |
| Hold the false easting northing. More... | |
| ossim_uint32 | thePcsCode |
| Projection Coordinate System(PCS) code. More... | |
| bool | theElevationLookupFlag |
| ossimMatrix4x4 | theModelTransform |
| ossimMatrix4x4 | theInverseModelTransform |
| ossimUnitType | theModelTransformUnitType |
| ossimUnitType | theProjectionUnits |
| Linear units of the projection as indicated in the projection's specification: More... | |
Definition at line 18 of file ossimTransCylEquAreaProjection.h.
| ossimTransCylEquAreaProjection::ossimTransCylEquAreaProjection | ( | const ossimEllipsoid & | ellipsoid = ossimEllipsoid(6378137, 6356752.3142), |
| const ossimGpt & | origin = ossimGpt() |
Definition at line 51 of file ossimTransCylEquAreaProjection.cpp.
References setDefaults(), and update().
| ossimTransCylEquAreaProjection::ossimTransCylEquAreaProjection | ( | const ossimEllipsoid & | ellipsoid, |
| const ossimGpt & | origin, | ||
| double | falseEasting, | ||
| double | falseNorthing, | ||
| double | scaleFactor | ||
Definition at line 59 of file ossimTransCylEquAreaProjection.cpp.
References Tcea_False_Easting, Tcea_False_Northing, Tcea_Max_Easting, Tcea_Max_Northing, Tcea_Min_Easting, Tcea_Min_Northing, Tcea_Scale_Factor, and update().
inline |
Definition at line 29 of file ossimTransCylEquAreaProjection.h.
private |
The function Convert_Geodetic_To_Trans_Cyl_Eq_Area converts geodetic (latitude and longitude) coordinates to Transverse Cylindrical Equal Area projection easting, and northing coordinates, according to the current ellipsoid and Transverse Cylindrical Equal Area projection parameters. If any errors occur, the error code(s) are returned by the function, otherwise TCEA_NO_ERROR is returned.
Latitude : Latitude (phi) in radians (input) Longitude : Longitude (lambda) in radians (input) Easting : Easting (X) in meters (output) Northing : Northing (Y) in meters (output)
Definition at line 376 of file ossimTransCylEquAreaProjection.cpp.
References a0, a1, a2, c0, c1, c2, c3, es, es2, M0, M_PI, PI_OVER_2, qp, Tcea_a, TCEA_COEFF_TIMES_SIN, Tcea_False_Easting, Tcea_False_Northing, TCEA_L, TCEA_LON_WARNING, TCEA_M, TCEA_NO_ERROR, Tcea_Origin_Long, TCEA_Q, Tcea_Scale_Factor, TWO_PI, and x.
Referenced by forward(), and Set_Trans_Cyl_Eq_Area_Parameters().
private |
The function Convert_Trans_Cyl_Eq_Area_To_Geodetic converts Transverse Cylindrical Equal Area projection easting and northing coordinates to geodetic (latitude and longitude) coordinates. coordinates, according to the current ellipsoid and Transverse Cylindrical Equal Area projection If any errors occur, the error code(s) are returned by the function, otherwise TCEA_NO_ERROR is returned.
Easting : Easting (X) in meters (input) Northing : Northing (Y) in meters (input) Latitude : Latitude (phi) in radians (output) Longitude : Longitude (lambda) in radians (output)
Definition at line 478 of file ossimTransCylEquAreaProjection.cpp.
References a0, a1, a2, b0, b1, b2, b3, c0, es, es2, M0, qp, Tcea_a, TCEA_COEFF_TIMES_SIN, Tcea_False_Easting, Tcea_False_Northing, TCEA_L, TCEA_NO_ERROR, Tcea_Origin_Long, TCEA_Q, Tcea_Scale_Factor, and x.
Referenced by inverse().
inlinevirtual |
Implements ossimProjection.
Definition at line 31 of file ossimTransCylEquAreaProjection.h.
Definition at line 160 of file ossimTransCylEquAreaProjection.cpp.
References ossimGpt::changeDatum(), ossimDatum::code(), Convert_Geodetic_To_Trans_Cyl_Eq_Area(), ossimGpt::datum(), ossimGpt::latr(), ossimGpt::lonr(), and ossimMapProjection::theDatum.
private |
The function Get_Trans_Cyl_Eq_Area_Parameters returns the current ellipsoid parameters, Transverse Cylindrical Equal Area projection parameters, and scale factor.
a : Semi-major axis of ellipsoid, in meters (output) f : Flattening of ellipsoid (output) Origin_Latitude : Latitude in radians at which the (output) point scale factor is 1.0 Central_Meridian : Longitude in radians at the center of (output) the projection False_Easting : A coordinate value in meters assigned to the central meridian of the projection. (output) False_Northing : A coordinate value in meters assigned to the origin latitude of the projection (output) Scale_Factor : Multiplier which reduces distances in the projection to the actual distance on the ellipsoid (output)
Definition at line 337 of file ossimTransCylEquAreaProjection.cpp.
References Tcea_a, Tcea_f, Tcea_False_Easting, Tcea_False_Northing, Tcea_Origin_Lat, Tcea_Origin_Long, and Tcea_Scale_Factor.
inlinevirtual |
Definition at line 66 of file ossimTransCylEquAreaProjection.h.
inlinevirtual |
Definition at line 67 of file ossimTransCylEquAreaProjection.h.
inline |
Definition at line 68 of file ossimTransCylEquAreaProjection.h.
Definition at line 147 of file ossimTransCylEquAreaProjection.cpp.
References Convert_Trans_Cyl_Eq_Area_To_Geodetic(), DEG_PER_RAD, ossimMapProjection::theDatum, ossimDpt::x, and ossimDpt::y.
Definition at line 192 of file ossimTransCylEquAreaProjection.cpp.
References ossimKeywordlist::find(), ossimMapProjection::loadState(), ossimKeywordNames::SCALE_FACTOR_KW, setDefaults(), STATIC_TYPE_NAME, Tcea_False_Easting, Tcea_False_Northing, Tcea_Scale_Factor, ossimMapProjection::theFalseEastingNorthing, ossimString::toDouble(), ossimKeywordNames::TYPE_KW, update(), ossimDpt::x, and ossimDpt::y.
Definition at line 586 of file ossimTransCylEquAreaProjection.cpp.
References ossim::almostEqual(), and Tcea_Scale_Factor.
Definition at line 182 of file ossimTransCylEquAreaProjection.cpp.
References ossimKeywordlist::add(), ossimMapProjection::saveState(), ossimKeywordNames::SCALE_FACTOR_KW, and Tcea_Scale_Factor.
private |
Definition at line 217 of file ossimTransCylEquAreaProjection.cpp.
References a0, a1, a2, b0, b1, b2, b3, c0, c1, c2, c3, Convert_Geodetic_To_Trans_Cyl_Eq_Area(), es, es2, es4, es6, M0, M_PI, One_MINUS_es2, One_OVER_2es, PI_OVER_2, qp, Tcea_a, TCEA_COEFF_TIMES_SIN, Tcea_f, Tcea_False_Easting, Tcea_False_Northing, TCEA_M, Tcea_Max_Northing, Tcea_Min_Northing, TCEA_NO_ERROR, Tcea_Origin_Lat, Tcea_Origin_Long, TCEA_Q, Tcea_Scale_Factor, TWO_PI, and x.
Referenced by update().
| void ossimTransCylEquAreaProjection::setDefaults | ( | ) |
Definition at line 119 of file ossimTransCylEquAreaProjection.cpp.
References Tcea_False_Easting, Tcea_False_Northing, Tcea_Max_Easting, Tcea_Max_Northing, Tcea_Min_Easting, Tcea_Min_Northing, and Tcea_Scale_Factor.
Referenced by loadState(), and ossimTransCylEquAreaProjection().
| void ossimTransCylEquAreaProjection::setFalseEasting | ( | double | falseEasting | ) |
Definition at line 77 of file ossimTransCylEquAreaProjection.cpp.
References Tcea_False_Easting, and update().
| void ossimTransCylEquAreaProjection::setFalseEastingNorthing | ( | double | falseEasting, |
| double | falseNorthing | ||
Definition at line 92 of file ossimTransCylEquAreaProjection.cpp.
References Tcea_False_Easting, Tcea_False_Northing, and update().
| void ossimTransCylEquAreaProjection::setFalseNorthing | ( | double | falseNorthing | ) |
Definition at line 85 of file ossimTransCylEquAreaProjection.cpp.
References Tcea_False_Northing, and update().
| void ossimTransCylEquAreaProjection::setParameters | ( | double | falseEasting, |
Definition at line 108 of file ossimTransCylEquAreaProjection.cpp.
References Tcea_False_Easting, Tcea_False_Northing, Tcea_Scale_Factor, and update().
| void ossimTransCylEquAreaProjection::setScaleFactor | ( | double | scaleFactor | ) |
Definition at line 101 of file ossimTransCylEquAreaProjection.cpp.
References Tcea_Scale_Factor, and update().
Definition at line 130 of file ossimTransCylEquAreaProjection.cpp.
References ossimEllipsoid::getA(), ossimEllipsoid::getFlattening(), ossimGpt::latr(), ossimGpt::lonr(), Set_Trans_Cyl_Eq_Area_Parameters(), Tcea_False_Easting, Tcea_False_Northing, Tcea_Scale_Factor, ossimMapProjection::theEllipsoid, ossimMapProjection::theFalseEastingNorthing, ossimMapProjection::theOrigin, ossimMapProjection::update(), ossimDpt::x, and ossimDpt::y.
Referenced by loadState(), ossimTransCylEquAreaProjection(), setFalseEasting(), setFalseEastingNorthing(), setFalseNorthing(), setParameters(), and setScaleFactor().
mutableprivate |
Definition at line 99 of file ossimTransCylEquAreaProjection.h.
Referenced by Convert_Geodetic_To_Trans_Cyl_Eq_Area(), Convert_Trans_Cyl_Eq_Area_To_Geodetic(), and Set_Trans_Cyl_Eq_Area_Parameters().
mutableprivate |
Definition at line 100 of file ossimTransCylEquAreaProjection.h.
mutableprivate |
Definition at line 101 of file ossimTransCylEquAreaProjection.h.
mutableprivate |
Definition at line 102 of file ossimTransCylEquAreaProjection.h.
Referenced by Convert_Trans_Cyl_Eq_Area_To_Geodetic(), and Set_Trans_Cyl_Eq_Area_Parameters().
mutableprivate |
Definition at line 103 of file ossimTransCylEquAreaProjection.h.
mutableprivate |
Definition at line 104 of file ossimTransCylEquAreaProjection.h.
mutableprivate |
Definition at line 105 of file ossimTransCylEquAreaProjection.h.
mutableprivate |
Definition at line 106 of file ossimTransCylEquAreaProjection.h.
mutableprivate |
Definition at line 107 of file ossimTransCylEquAreaProjection.h.
Referenced by Convert_Geodetic_To_Trans_Cyl_Eq_Area(), and Set_Trans_Cyl_Eq_Area_Parameters().
mutableprivate |
Definition at line 108 of file ossimTransCylEquAreaProjection.h.
mutableprivate |
Definition at line 109 of file ossimTransCylEquAreaProjection.h.
mutableprivate |
Definition at line 94 of file ossimTransCylEquAreaProjection.h.
mutableprivate |
Definition at line 91 of file ossimTransCylEquAreaProjection.h.
mutableprivate |
Definition at line 92 of file ossimTransCylEquAreaProjection.h.
Referenced by Set_Trans_Cyl_Eq_Area_Parameters().
mutableprivate |
Definition at line 93 of file ossimTransCylEquAreaProjection.h.
mutableprivate |
Definition at line 95 of file ossimTransCylEquAreaProjection.h.
mutableprivate |
Definition at line 97 of file ossimTransCylEquAreaProjection.h.
mutableprivate |
Definition at line 98 of file ossimTransCylEquAreaProjection.h.
mutableprivate |
Definition at line 96 of file ossimTransCylEquAreaProjection.h.
mutableprivate |
Definition at line 89 of file ossimTransCylEquAreaProjection.h.
Referenced by Convert_Geodetic_To_Trans_Cyl_Eq_Area(), Convert_Trans_Cyl_Eq_Area_To_Geodetic(), Get_Trans_Cyl_Eq_Area_Parameters(), and Set_Trans_Cyl_Eq_Area_Parameters().
mutableprivate |
Definition at line 90 of file ossimTransCylEquAreaProjection.h.
Referenced by Get_Trans_Cyl_Eq_Area_Parameters(), and Set_Trans_Cyl_Eq_Area_Parameters().
mutableprivate |
Definition at line 115 of file ossimTransCylEquAreaProjection.h.
Referenced by Convert_Geodetic_To_Trans_Cyl_Eq_Area(), Convert_Trans_Cyl_Eq_Area_To_Geodetic(), Get_Trans_Cyl_Eq_Area_Parameters(), loadState(), ossimTransCylEquAreaProjection(), Set_Trans_Cyl_Eq_Area_Parameters(), setDefaults(), setFalseEasting(), setFalseEastingNorthing(), setParameters(), and update().
mutableprivate |
Definition at line 114 of file ossimTransCylEquAreaProjection.h.
Referenced by Convert_Geodetic_To_Trans_Cyl_Eq_Area(), Convert_Trans_Cyl_Eq_Area_To_Geodetic(), Get_Trans_Cyl_Eq_Area_Parameters(), loadState(), ossimTransCylEquAreaProjection(), Set_Trans_Cyl_Eq_Area_Parameters(), setDefaults(), setFalseEastingNorthing(), setFalseNorthing(), setParameters(), and update().
mutableprivate |
Definition at line 121 of file ossimTransCylEquAreaProjection.h.
Referenced by ossimTransCylEquAreaProjection(), and setDefaults().
mutableprivate |
Definition at line 123 of file ossimTransCylEquAreaProjection.h.
Referenced by ossimTransCylEquAreaProjection(), Set_Trans_Cyl_Eq_Area_Parameters(), and setDefaults().
mutableprivate |
Definition at line 120 of file ossimTransCylEquAreaProjection.h.
mutableprivate |
Definition at line 122 of file ossimTransCylEquAreaProjection.h.
mutableprivate |
Definition at line 112 of file ossimTransCylEquAreaProjection.h.
mutableprivate |
Definition at line 113 of file ossimTransCylEquAreaProjection.h.
mutableprivate |
Definition at line 116 of file ossimTransCylEquAreaProjection.h.
Referenced by Convert_Geodetic_To_Trans_Cyl_Eq_Area(), Convert_Trans_Cyl_Eq_Area_To_Geodetic(), Get_Trans_Cyl_Eq_Area_Parameters(), loadState(), operator==(), ossimTransCylEquAreaProjection(), saveState(), Set_Trans_Cyl_Eq_Area_Parameters(), setDefaults(), setParameters(), setScaleFactor(), and update().
