#include <ossimSinusoidalProjection.h>
| ossimSinusoidalProjection (const ossimEllipsoid &ellipsoid=ossimEllipsoid(), const ossimGpt &origin=ossimGpt()) | |
| ossimSinusoidalProjection (const ossimEllipsoid &ellipsoid, const ossimGpt &origin, const double falseEasting, const double falseNorthing) | |
| ~ossimSinusoidalProjection () | |
| virtual ossimGpt | inverse (const ossimDpt &eastingNorthing) const |
| Will take a point in meters and convert it to ground. More... | |
| virtual ossimDpt | forward (const ossimGpt &latLon) const |
| All map projections will convert the world coordinate to an easting northing (Meters). More... | |
| virtual void | update () |
| void | setFalseEasting (double falseEasting) |
| void | setFalseNorthing (double falseNorthing) |
| void | setFalseEastingNorthing (double falseEasting, double falseNorthing) |
| void | setDefaults () |
| void | setCentralMeridian (double centralMeridian) |
| double | getFalseEasting () const |
| double | getFalseNorthing () const |
| virtual bool | operator== (const ossimProjection &projection) const |
| Returns TRUE if principal parameters are within epsilon tolerance. More... | |
Public Member Functions inherited from ossimMapProjection | |
| ossimMapProjection (const ossimEllipsoid &ellipsoid=ossimEllipsoid(), const ossimGpt &origin=ossimGpt()) | |
| ossimMapProjection (const ossimMapProjection &src) | |
| virtual ossimDpt | worldToLineSample (const ossimGpt &worldPoint) const |
| virtual void | worldToLineSample (const ossimGpt &worldPoint, ossimDpt &lineSample) const |
| virtual ossimGpt | lineSampleToWorld (const ossimDpt &projectedPoint) const |
| virtual void | lineSampleToWorld (const ossimDpt &projectedPoint, ossimGpt &gpt) const |
| virtual void | lineSampleHeightToWorld (const ossimDpt &lineSampPt, const double &heightAboveEllipsoid, ossimGpt &worldPt) const |
| This is the pure virtual that projects the image point to the given elevation above ellipsoid, thereby bypassing reference to a DEM. More... | |
| virtual void | lineSampleToEastingNorthing (const ossimDpt &liineSample, ossimDpt &eastingNorthing) const |
| virtual void | eastingNorthingToLineSample (const ossimDpt &eastingNorthing, ossimDpt &lineSample) const |
| virtual void | eastingNorthingToWorld (const ossimDpt &eastingNorthing, ossimGpt &worldPt) const |
| virtual double | getStandardParallel1 () const |
| Derived classes should implement as needed. More... | |
| virtual double | getStandardParallel2 () const |
| virtual void | setPcsCode (ossim_uint32 pcsCode) |
| virtual ossim_uint32 | getPcsCode () const |
| Returns the EPSG PCS code or 32767 if the projection is a custom (non-EPSG) projection. More... | |
| virtual ossimString | getProjectionName () const |
| Returns the projection name. More... | |
| virtual double | getA () const |
| ACCESS METHODS: More... | |
| virtual double | getB () const |
| virtual double | getF () const |
| virtual const ossimDpt & | getDecimalDegreesPerPixel () const |
| Returns decimal degrees per pixel as an ossimDpt with "x" representing longitude and "y" representing latitude. More... | |
| virtual const ossimDpt & | getUlEastingNorthing () const |
| virtual const ossimGpt & | getUlGpt () const |
| virtual const ossimDatum * | getDatum () const |
| const ossimEllipsoid & | getEllipsoid () const |
| const ossimGpt & | getOrigin () const |
| virtual bool | isGeographic () const |
| virtual void | applyScale (const ossimDpt &scale, bool recenterTiePoint) |
| Applies scale to theDeltaLonPerPixel, theDeltaLatPerPixel and theMetersPerPixel data members (eg: theDeltaLonPerPixel *= scale.x). More... | |
| virtual void | setEllipsoid (const ossimEllipsoid &ellipsoid) |
| SET METHODS: More... | |
| virtual void | setAB (double a, double b) |
| virtual void | setDatum (const ossimDatum *datum) |
| Sets theDatum to datum. More... | |
| virtual void | setOrigin (const ossimGpt &origin) |
| Sets theOrigin to origin. More... | |
| virtual void | setMetersPerPixel (const ossimDpt &gsd) |
| virtual void | setDecimalDegreesPerPixel (const ossimDpt &gsd) |
| virtual void | setUlTiePoints (const ossimGpt &gpt) |
| virtual void | setUlTiePoints (const ossimDpt &eastingNorthing) |
| virtual void | setUlEastingNorthing (const ossimDpt &ulEastingNorthing) |
| virtual void | setUlGpt (const ossimGpt &ulGpt) |
| virtual void | assign (const ossimProjection &aProjection) |
| Prints data members to stream. More... | |
| virtual void | computeDegreesPerPixel () |
| Computes the approximate resolution in degrees/pixel. More... | |
| virtual void | computeMetersPerPixel () |
| This will go from the ground point and give you an approximate meters per pixel. More... | |
| void | setMatrix (double rotation, const ossimDpt &scale, const ossimDpt &translation) |
| void | setMatrixScale (const ossimDpt &scale) |
| void | setMatrixRotation (double rotation) |
| void | setMatrixTranslation (const ossimDpt &translation) |
| void | snapTiePointTo (ossim_float64 multiple, ossimUnitType unitType) |
| Utility method to snap the tie point to some multiple. More... | |
| void | snapTiePointToOrigin () |
| void | setElevationLookupFlag (bool flag) |
| bool | getElevationLookupFlag () const |
| ossimUnitType | getModelTransformUnitType () const |
| void | setModelTransformUnitType (ossimUnitType unit) |
| bool | hasModelTransform () const |
| void | setProjectionUnits (ossimUnitType units) |
| ossimUnitType | getProjectionUnits () const |
| OSSIM considers all map projection coordinates (including false eastings and northings) to be in meters. More... | |
| ossimProjection () | |
| ossimObject () | |
| bool | hasError () const |
Private Member Functions | |
| long | Set_Sinusoidal_Parameters (double a, double f, double Central_Meridian, double False_Easting, double False_Northing) |
| void | Get_Sinusoidal_Parameters (double *a, double *f, double *Central_Meridian, double *False_Easting, double *False_Northing) const |
| long | Convert_Geodetic_To_Sinusoidal (double Latitude, double Longitude, double *Easting, double *Northing) const |
| long | Convert_Sinusoidal_To_Geodetic (double Easting, double Northing, double *Latitude, double *Longitude) const |
Private Attributes | |
| double | Sinu_a |
| double | Sinu_f |
| double | es2 |
| double | es4 |
| double | es6 |
| double | c0 |
| double | c1 |
| double | c2 |
| double | c3 |
| double | a0 |
| double | a1 |
| double | a2 |
| double | a3 |
| double | Sinu_Origin_Long |
| double | Sinu_False_Northing |
| double | Sinu_False_Easting |
| double | Sinu_Max_Easting |
| double | Sinu_Min_Easting |
| double | Sinu_Delta_Northing |
Protected Member Functions inherited from ossimMapProjection | |
| virtual | ~ossimMapProjection () |
| void | updateFromTransform () |
Protected Attributes inherited from ossimMapProjection | |
| ossimEllipsoid | theEllipsoid |
| This method verifies that the projection parameters match the current pcs code. More... | |
| ossimGpt | theOrigin |
| const ossimDatum * | theDatum |
| This is only set if we want to have built in datum shifting. More... | |
| ossimDpt | theMetersPerPixel |
| Holds the number of meters per pixel. More... | |
| ossimDpt | theDegreesPerPixel |
| Hold the decimal degrees per pixel. More... | |
| ossimGpt | theUlGpt |
| Hold tie point in decimal degrees. More... | |
| ossimDpt | theUlEastingNorthing |
| Hold tie point as easting northing. More... | |
| ossimDpt | theFalseEastingNorthing |
| Hold the false easting northing. More... | |
| ossim_uint32 | thePcsCode |
| Projection Coordinate System(PCS) code. More... | |
| bool | theElevationLookupFlag |
| ossimMatrix4x4 | theModelTransform |
| ossimMatrix4x4 | theInverseModelTransform |
| ossimUnitType | theModelTransformUnitType |
| ossimUnitType | theProjectionUnits |
| Linear units of the projection as indicated in the projection's specification: More... | |
Definition at line 18 of file ossimSinusoidalProjection.h.
| ossimSinusoidalProjection::ossimSinusoidalProjection | ( | const ossimEllipsoid & | ellipsoid = ossimEllipsoid(), |
| const ossimGpt & | origin = ossimGpt() |
Definition at line 49 of file ossimSinusoidalProjection.cpp.
References setDefaults(), and update().
| ossimSinusoidalProjection::ossimSinusoidalProjection | ( | const ossimEllipsoid & | ellipsoid, |
| const ossimGpt & | origin, | ||
| const double | falseEasting, | ||
| const double | falseNorthing | ||
Definition at line 57 of file ossimSinusoidalProjection.cpp.
References Sinu_Delta_Northing, Sinu_False_Easting, Sinu_False_Northing, Sinu_Max_Easting, Sinu_Min_Easting, and update().
inline |
Definition at line 29 of file ossimSinusoidalProjection.h.
private |
The function Convert_Geodetic_To_Sinusoidal converts geodetic (latitude and longitude) coordinates to Sinusoidal projection easting, and northing coordinates, according to the current ellipsoid and Sinusoidal projection parameters. If any errors occur, the error code(s) are returned by the function, otherwise SINU_NO_ERROR is returned.
Latitude : Latitude (phi) in radians (input) Longitude : Longitude (lambda) in radians (input) Easting : Easting (X) in meters (output) Northing : Northing (Y) in meters (output)
Definition at line 303 of file ossimSinusoidalProjection.cpp.
References c0, c1, c2, c3, es2, Sinu_a, SINU_COEFF_TIMES_SIN, Sinu_False_Easting, Sinu_False_Northing, SINU_NO_ERROR, and Sinu_Origin_Long.
Referenced by forward().
private |
The function Convert_Sinusoidal_To_Geodetic converts Sinusoidal projection easting and northing coordinates to geodetic (latitude and longitude) coordinates, according to the current ellipsoid and Sinusoida projection coordinates. If any errors occur, the error code(s) are returned by the function, otherwise SINU_NO_ERROR is returned.
Easting : Easting (X) in meters (input) Northing : Northing (Y) in meters (input) Latitude : Latitude (phi) in radians (output) Longitude : Longitude (lambda) in radians (output)
Definition at line 361 of file ossimSinusoidalProjection.cpp.
References a0, a1, a2, a3, c0, es2, FLOAT_EQ, PI_OVER_2, Sinu_a, SINU_COEFF_TIMES_SIN, Sinu_False_Easting, Sinu_False_Northing, SINU_NO_ERROR, and Sinu_Origin_Long.
Referenced by inverse().
inlinevirtual |
Implements ossimProjection.
Definition at line 31 of file ossimSinusoidalProjection.h.
Definition at line 136 of file ossimSinusoidalProjection.cpp.
References ossimGpt::changeDatum(), ossimDatum::code(), Convert_Geodetic_To_Sinusoidal(), ossimGpt::datum(), ossimGpt::latr(), ossimGpt::lonr(), and ossimMapProjection::theDatum.
private |
The function Get_Sinusoidal_Parameters returns the current ellipsoid parameters and Sinusoidal projection parameters.
a : Semi-major axis of ellipsoid, in meters (output) f : Flattening of ellipsoid (output) Central_Meridian : Longitude in radians at the center of (output) the projection False_Easting : A coordinate value in meters assigned to the central meridian of the projection. (output) False_Northing : A coordinate value in meters assigned to the origin latitude of the projection (output)
Definition at line 273 of file ossimSinusoidalProjection.cpp.
References Sinu_a, Sinu_f, Sinu_False_Easting, Sinu_False_Northing, and Sinu_Origin_Long.
inlinevirtual |
Definition at line 61 of file ossimSinusoidalProjection.h.
inlinevirtual |
Definition at line 62 of file ossimSinusoidalProjection.h.
Definition at line 124 of file ossimSinusoidalProjection.cpp.
References Convert_Sinusoidal_To_Geodetic(), DEG_PER_RAD, ossimMapProjection::theDatum, ossimDpt::x, and ossimDpt::y.
Definition at line 162 of file ossimSinusoidalProjection.cpp.
References ossimKeywordlist::find(), ossimMapProjection::loadState(), setDefaults(), Sinu_False_Easting, Sinu_False_Northing, STATIC_TYPE_NAME, ossimMapProjection::theFalseEastingNorthing, ossimKeywordNames::TYPE_KW, update(), ossimDpt::x, and ossimDpt::y.
Definition at line 439 of file ossimSinusoidalProjection.cpp.
References ossim::almostEqual(), and Sinu_Origin_Long.
Definition at line 157 of file ossimSinusoidalProjection.cpp.
References ossimMapProjection::saveState().
private |
The function Set_Sinusoidal_Parameters receives the ellipsoid parameters and Sinusoidal projcetion parameters as inputs, and sets the corresponding state variables. If any errors occur, the error code(s) are returned by the function, otherwise SINU_NO_ERROR is returned.
a : Semi-major axis of ellipsoid, in meters (input) f : Flattening of ellipsoid (input) Central_Meridian : Longitude in radians at the center of (input) the projection False_Easting : A coordinate value in meters assigned to the central meridian of the projection. (input) False_Northing : A coordinate value in meters assigned to the origin latitude of the projection (input)
Definition at line 187 of file ossimSinusoidalProjection.cpp.
References a0, a1, a2, a3, c0, c1, c2, c3, es2, es4, es6, Sinu_a, Sinu_f, Sinu_False_Easting, Sinu_False_Northing, Sinu_Max_Easting, Sinu_Min_Easting, SINU_NO_ERROR, and Sinu_Origin_Long.
Referenced by update().
| void ossimSinusoidalProjection::setCentralMeridian | ( | double | centralMeridian | ) |
Definition at line 109 of file ossimSinusoidalProjection.cpp.
References Sinu_Origin_Long, and update().
| void ossimSinusoidalProjection::setDefaults | ( | ) |
Definition at line 100 of file ossimSinusoidalProjection.cpp.
References Sinu_Delta_Northing, Sinu_False_Easting, Sinu_False_Northing, Sinu_Max_Easting, and Sinu_Min_Easting.
Referenced by loadState(), and ossimSinusoidalProjection().
| void ossimSinusoidalProjection::setFalseEasting | ( | double | falseEasting | ) |
Definition at line 86 of file ossimSinusoidalProjection.cpp.
References Sinu_False_Easting, and update().
| void ossimSinusoidalProjection::setFalseEastingNorthing | ( | double | falseEasting, |
Definition at line 115 of file ossimSinusoidalProjection.cpp.
References Sinu_False_Easting, Sinu_False_Northing, and update().
| void ossimSinusoidalProjection::setFalseNorthing | ( | double | falseNorthing | ) |
Definition at line 93 of file ossimSinusoidalProjection.cpp.
References Sinu_False_Northing, and update().
Definition at line 72 of file ossimSinusoidalProjection.cpp.
References ossimEllipsoid::getA(), ossimEllipsoid::getFlattening(), ossimGpt::lonr(), Set_Sinusoidal_Parameters(), Sinu_False_Easting, Sinu_False_Northing, ossimMapProjection::theEllipsoid, ossimMapProjection::theFalseEastingNorthing, ossimMapProjection::theOrigin, ossimMapProjection::update(), ossimDpt::x, and ossimDpt::y.
Referenced by loadState(), ossimSinusoidalProjection(), setCentralMeridian(), setFalseEasting(), setFalseEastingNorthing(), and setFalseNorthing().
mutableprivate |
Definition at line 93 of file ossimSinusoidalProjection.h.
Referenced by Convert_Sinusoidal_To_Geodetic(), and Set_Sinusoidal_Parameters().
mutableprivate |
Definition at line 94 of file ossimSinusoidalProjection.h.
mutableprivate |
Definition at line 95 of file ossimSinusoidalProjection.h.
mutableprivate |
Definition at line 96 of file ossimSinusoidalProjection.h.
mutableprivate |
Definition at line 89 of file ossimSinusoidalProjection.h.
Referenced by Convert_Geodetic_To_Sinusoidal(), Convert_Sinusoidal_To_Geodetic(), and Set_Sinusoidal_Parameters().
mutableprivate |
Definition at line 90 of file ossimSinusoidalProjection.h.
Referenced by Convert_Geodetic_To_Sinusoidal(), and Set_Sinusoidal_Parameters().
mutableprivate |
Definition at line 91 of file ossimSinusoidalProjection.h.
mutableprivate |
Definition at line 92 of file ossimSinusoidalProjection.h.
mutableprivate |
Definition at line 86 of file ossimSinusoidalProjection.h.
mutableprivate |
Definition at line 87 of file ossimSinusoidalProjection.h.
Referenced by Set_Sinusoidal_Parameters().
mutableprivate |
Definition at line 88 of file ossimSinusoidalProjection.h.
mutableprivate |
Definition at line 84 of file ossimSinusoidalProjection.h.
Referenced by Convert_Geodetic_To_Sinusoidal(), Convert_Sinusoidal_To_Geodetic(), Get_Sinusoidal_Parameters(), and Set_Sinusoidal_Parameters().
mutableprivate |
Definition at line 107 of file ossimSinusoidalProjection.h.
Referenced by ossimSinusoidalProjection(), and setDefaults().
mutableprivate |
Definition at line 85 of file ossimSinusoidalProjection.h.
Referenced by Get_Sinusoidal_Parameters(), and Set_Sinusoidal_Parameters().
mutableprivate |
Definition at line 101 of file ossimSinusoidalProjection.h.
Referenced by Convert_Geodetic_To_Sinusoidal(), Convert_Sinusoidal_To_Geodetic(), Get_Sinusoidal_Parameters(), loadState(), ossimSinusoidalProjection(), Set_Sinusoidal_Parameters(), setDefaults(), setFalseEasting(), setFalseEastingNorthing(), and update().
mutableprivate |
Definition at line 100 of file ossimSinusoidalProjection.h.
Referenced by Convert_Geodetic_To_Sinusoidal(), Convert_Sinusoidal_To_Geodetic(), Get_Sinusoidal_Parameters(), loadState(), ossimSinusoidalProjection(), Set_Sinusoidal_Parameters(), setDefaults(), setFalseEastingNorthing(), setFalseNorthing(), and update().
mutableprivate |
Definition at line 105 of file ossimSinusoidalProjection.h.
Referenced by ossimSinusoidalProjection(), Set_Sinusoidal_Parameters(), and setDefaults().
mutableprivate |
Definition at line 106 of file ossimSinusoidalProjection.h.
mutableprivate |
Definition at line 99 of file ossimSinusoidalProjection.h.
Referenced by Convert_Geodetic_To_Sinusoidal(), Convert_Sinusoidal_To_Geodetic(), Get_Sinusoidal_Parameters(), operator==(), Set_Sinusoidal_Parameters(), and setCentralMeridian().
