#include <ossimMercatorProjection.h>
| ossimMercatorProjection (const ossimEllipsoid &ellipsoid=ossimEllipsoid(), const ossimGpt &origin=ossimGpt()) | |
| ossimMercatorProjection (const ossimEllipsoid &ellipsoid, const ossimGpt &origin, double falseEasting, double falseNorthing, double scaleFactor) | |
| ~ossimMercatorProjection () | |
| virtual ossimGpt | inverse (const ossimDpt &eastingNorthing) const |
| Will take a point in meters and convert it to ground. More... | |
| virtual ossimDpt | forward (const ossimGpt &latLon) const |
| All map projections will convert the world coordinate to an easting northing (Meters). More... | |
| virtual void | update () |
| void | setFalseEasting (double falseEasting) |
| void | setFalseNorthing (double falseNorthing) |
| void | setFalseEastingNorthing (double falseEasting, double falseNorthing) |
| void | setScaleFactor (double scaleFactor) |
| void | setParameters (double falseEasting, double falseNorthing, double scaleFactor) |
| void | setDefaults () |
| double | getFalseEasting () const |
| double | getFalseNorthing () const |
| double | getScaleFactor () const |
| virtual bool | operator== (const ossimProjection &projection) const |
| Returns TRUE if principal parameters are within epsilon tolerance. More... | |
Public Member Functions inherited from ossimMapProjection | |
| ossimMapProjection (const ossimEllipsoid &ellipsoid=ossimEllipsoid(), const ossimGpt &origin=ossimGpt()) | |
| ossimMapProjection (const ossimMapProjection &src) | |
| virtual ossimDpt | worldToLineSample (const ossimGpt &worldPoint) const |
| virtual void | worldToLineSample (const ossimGpt &worldPoint, ossimDpt &lineSample) const |
| virtual ossimGpt | lineSampleToWorld (const ossimDpt &projectedPoint) const |
| virtual void | lineSampleToWorld (const ossimDpt &projectedPoint, ossimGpt &gpt) const |
| virtual void | lineSampleHeightToWorld (const ossimDpt &lineSampPt, const double &heightAboveEllipsoid, ossimGpt &worldPt) const |
| This is the pure virtual that projects the image point to the given elevation above ellipsoid, thereby bypassing reference to a DEM. More... | |
| virtual void | lineSampleToEastingNorthing (const ossimDpt &liineSample, ossimDpt &eastingNorthing) const |
| virtual void | eastingNorthingToLineSample (const ossimDpt &eastingNorthing, ossimDpt &lineSample) const |
| virtual void | eastingNorthingToWorld (const ossimDpt &eastingNorthing, ossimGpt &worldPt) const |
| virtual double | getStandardParallel1 () const |
| Derived classes should implement as needed. More... | |
| virtual double | getStandardParallel2 () const |
| virtual void | setPcsCode (ossim_uint32 pcsCode) |
| virtual ossim_uint32 | getPcsCode () const |
| Returns the EPSG PCS code or 32767 if the projection is a custom (non-EPSG) projection. More... | |
| virtual ossimString | getProjectionName () const |
| Returns the projection name. More... | |
| virtual double | getA () const |
| ACCESS METHODS: More... | |
| virtual double | getB () const |
| virtual double | getF () const |
| virtual const ossimDpt & | getDecimalDegreesPerPixel () const |
| Returns decimal degrees per pixel as an ossimDpt with "x" representing longitude and "y" representing latitude. More... | |
| virtual const ossimDpt & | getUlEastingNorthing () const |
| virtual const ossimGpt & | getUlGpt () const |
| virtual const ossimDatum * | getDatum () const |
| const ossimEllipsoid & | getEllipsoid () const |
| const ossimGpt & | getOrigin () const |
| virtual bool | isGeographic () const |
| virtual void | applyScale (const ossimDpt &scale, bool recenterTiePoint) |
| Applies scale to theDeltaLonPerPixel, theDeltaLatPerPixel and theMetersPerPixel data members (eg: theDeltaLonPerPixel *= scale.x). More... | |
| virtual void | setEllipsoid (const ossimEllipsoid &ellipsoid) |
| SET METHODS: More... | |
| virtual void | setAB (double a, double b) |
| virtual void | setDatum (const ossimDatum *datum) |
| Sets theDatum to datum. More... | |
| virtual void | setOrigin (const ossimGpt &origin) |
| Sets theOrigin to origin. More... | |
| virtual void | setMetersPerPixel (const ossimDpt &gsd) |
| virtual void | setDecimalDegreesPerPixel (const ossimDpt &gsd) |
| virtual void | setUlTiePoints (const ossimGpt &gpt) |
| virtual void | setUlTiePoints (const ossimDpt &eastingNorthing) |
| virtual void | setUlEastingNorthing (const ossimDpt &ulEastingNorthing) |
| virtual void | setUlGpt (const ossimGpt &ulGpt) |
| virtual void | assign (const ossimProjection &aProjection) |
| Prints data members to stream. More... | |
| virtual void | computeDegreesPerPixel () |
| Computes the approximate resolution in degrees/pixel. More... | |
| virtual void | computeMetersPerPixel () |
| This will go from the ground point and give you an approximate meters per pixel. More... | |
| void | setMatrix (double rotation, const ossimDpt &scale, const ossimDpt &translation) |
| void | setMatrixScale (const ossimDpt &scale) |
| void | setMatrixRotation (double rotation) |
| void | setMatrixTranslation (const ossimDpt &translation) |
| void | snapTiePointTo (ossim_float64 multiple, ossimUnitType unitType) |
| Utility method to snap the tie point to some multiple. More... | |
| void | snapTiePointToOrigin () |
| void | setElevationLookupFlag (bool flag) |
| bool | getElevationLookupFlag () const |
| ossimUnitType | getModelTransformUnitType () const |
| void | setModelTransformUnitType (ossimUnitType unit) |
| bool | hasModelTransform () const |
| void | setProjectionUnits (ossimUnitType units) |
| ossimUnitType | getProjectionUnits () const |
| OSSIM considers all map projection coordinates (including false eastings and northings) to be in meters. More... | |
| ossimProjection () | |
| ossimObject () | |
| bool | hasError () const |
Private Member Functions | |
| long | Set_Mercator_Parameters (double a, double f, double Origin_Latitude, double Central_Meridian, double False_Easting, double False_Northing, double *Scale_Factor) |
| void | Get_Mercator_Parameters (double *a, double *f, double *Origin_Latitude, double *Central_Meridian, double *False_Easting, double *False_Northing, double *Scale_Factor) const |
| long | Convert_Geodetic_To_Mercator (double Latitude, double Longitude, double *Easting, double *Northing) const |
| long | Convert_Mercator_To_Geodetic (double Easting, double Northing, double *Latitude, double *Longitude) const |
Private Attributes | |
| double | Merc_a |
| double | Merc_f |
| double | Merc_e |
| double | Merc_es |
| double | Merc_Origin_Lat |
| double | Merc_Origin_Long |
| double | Merc_False_Northing |
| double | Merc_False_Easting |
| double | Merc_Scale_Factor |
| double | Merc_ab |
| double | Merc_bb |
| double | Merc_cb |
| double | Merc_db |
| double | Merc_Delta_Easting |
| double | Merc_Delta_Northing |
| bool | theSphericalFlag |
Protected Member Functions inherited from ossimMapProjection | |
| virtual | ~ossimMapProjection () |
| void | updateFromTransform () |
Protected Attributes inherited from ossimMapProjection | |
| ossimEllipsoid | theEllipsoid |
| This method verifies that the projection parameters match the current pcs code. More... | |
| ossimGpt | theOrigin |
| const ossimDatum * | theDatum |
| This is only set if we want to have built in datum shifting. More... | |
| ossimDpt | theMetersPerPixel |
| Holds the number of meters per pixel. More... | |
| ossimDpt | theDegreesPerPixel |
| Hold the decimal degrees per pixel. More... | |
| ossimGpt | theUlGpt |
| Hold tie point in decimal degrees. More... | |
| ossimDpt | theUlEastingNorthing |
| Hold tie point as easting northing. More... | |
| ossimDpt | theFalseEastingNorthing |
| Hold the false easting northing. More... | |
| ossim_uint32 | thePcsCode |
| Projection Coordinate System(PCS) code. More... | |
| bool | theElevationLookupFlag |
| ossimMatrix4x4 | theModelTransform |
| ossimMatrix4x4 | theInverseModelTransform |
| ossimUnitType | theModelTransformUnitType |
| ossimUnitType | theProjectionUnits |
| Linear units of the projection as indicated in the projection's specification: More... | |
Definition at line 18 of file ossimMercatorProjection.h.
| ossimMercatorProjection::ossimMercatorProjection | ( | const ossimEllipsoid & | ellipsoid = ossimEllipsoid(), |
| const ossimGpt & | origin = ossimGpt() |
Definition at line 40 of file ossimMercatorProjection.cpp.
References setDefaults(), and update().
| ossimMercatorProjection::ossimMercatorProjection | ( | const ossimEllipsoid & | ellipsoid, |
| const ossimGpt & | origin, | ||
| double | falseEasting, | ||
| double | falseNorthing, | ||
| double | scaleFactor | ||
Definition at line 48 of file ossimMercatorProjection.cpp.
References Merc_False_Easting, Merc_False_Northing, Merc_Scale_Factor, setDefaults(), and update().
inline |
Definition at line 30 of file ossimMercatorProjection.h.
private |
The function Convert_Geodetic_To_Mercator converts geodetic (latitude and longitude) coordinates to Mercator projection easting, and northing coordinates, according to the current ellipsoid and Mercator projection parameters. If any errors occur, the error code(s) are returned by the function, otherwise MERC_NO_ERROR is returned.
Latitude : Latitude (phi) in radians (input) Longitude : Longitude (lambda) in radians (input) Easting : Easting (X) in meters (output) Northing : Northing (Y) in meters (output)
Definition at line 373 of file ossimMercatorProjection.cpp.
References MAX_LAT, Merc_a, Merc_e, Merc_False_Easting, Merc_False_Northing, MERC_LAT_ERROR, MERC_NO_ERROR, Merc_Origin_Long, Merc_Scale_Factor, and PI.
Referenced by forward(), and Set_Mercator_Parameters().
private |
The function Convert_Mercator_To_Geodetic converts Mercator projection easting and northing coordinates to geodetic (latitude and longitude) coordinates, according to the current ellipsoid and Mercator projection coordinates. If any errors occur, the error code(s) are returned by the function, otherwise MERC_NO_ERROR is returned.
Easting : Easting (X) in meters (input) Northing : Northing (Y) in meters (input) Latitude : Latitude (phi) in radians (output) Longitude : Longitude (lambda) in radians (output)
Definition at line 430 of file ossimMercatorProjection.cpp.
References M_PI, Merc_a, Merc_ab, Merc_bb, Merc_cb, Merc_db, Merc_False_Easting, Merc_False_Northing, MERC_NO_ERROR, Merc_Origin_Long, Merc_Scale_Factor, PI, and theSphericalFlag.
Referenced by inverse().
inlinevirtual |
Implements ossimProjection.
Definition at line 31 of file ossimMercatorProjection.h.
Definition at line 154 of file ossimMercatorProjection.cpp.
References ossimGpt::changeDatum(), ossimDatum::code(), Convert_Geodetic_To_Mercator(), ossimGpt::datum(), ossimGpt::latd(), ossimGpt::latr(), ossimGpt::lond(), ossimGpt::lonr(), M_PI, ossimDpt::makeNan(), Merc_a, MERC_NO_ERROR, ossimMapProjection::theDatum, and theSphericalFlag.
private |
The function Get_Mercator_Parameters returns the current ellipsoid parameters, Mercator projection parameters, and scale factor.
a : Semi-major axis of ellipsoid, in meters (output) f : Flattening of ellipsoid (output) Origin_Latitude : Latitude in radians at which the (output) point scale factor is 1.0 Central_Meridian : Longitude in radians at the center of (output) the projection False_Easting : A coordinate value in meters assigned to the central meridian of the projection. (output) False_Northing : A coordinate value in meters assigned to the origin latitude of the projection (output) Scale_Factor : Multiplier which reduces distances in the projection to the actual distance on the ellipsoid (output)
Definition at line 334 of file ossimMercatorProjection.cpp.
References Merc_a, Merc_f, Merc_False_Easting, Merc_False_Northing, Merc_Origin_Lat, Merc_Origin_Long, and Merc_Scale_Factor.
inlinevirtual |
Definition at line 70 of file ossimMercatorProjection.h.
inlinevirtual |
Definition at line 71 of file ossimMercatorProjection.h.
inline |
Definition at line 72 of file ossimMercatorProjection.h.
Definition at line 126 of file ossimMercatorProjection.cpp.
References Convert_Mercator_To_Geodetic(), M_PI, ossim::radiansToDegrees(), ossimMapProjection::theDatum, theSphericalFlag, ossimDpt::x, and ossimDpt::y.
Definition at line 209 of file ossimMercatorProjection.cpp.
References ossimKeywordlist::find(), ossimMapProjection::loadState(), Merc_False_Easting, Merc_False_Northing, Merc_Scale_Factor, ossimKeywordNames::SCALE_FACTOR_KW, setDefaults(), STATIC_TYPE_NAME, ossimMapProjection::theFalseEastingNorthing, ossimString::toDouble(), ossimKeywordNames::TYPE_KW, update(), ossimDpt::x, and ossimDpt::y.
Definition at line 492 of file ossimMercatorProjection.cpp.
References ossim::almostEqual(), and Merc_Scale_Factor.
Definition at line 199 of file ossimMercatorProjection.cpp.
References ossimKeywordlist::add(), Merc_Scale_Factor, ossimMapProjection::saveState(), and ossimKeywordNames::SCALE_FACTOR_KW.
private |
The function Set_Mercator_Parameters receives the ellipsoid parameters and Mercator projcetion parameters as inputs, and sets the corresponding state variables. It calculates and returns the scale factor. If any errors occur, the error code(s) are returned by the function, otherwise MERC_NO_ERROR is returned.
a : Semi-major axis of ellipsoid, in meters (input) f : Flattening of ellipsoid (input) Origin_Latitude : Latitude in radians at which the (input) point scale factor is 1.0 Central_Meridian : Longitude in radians at the center of (input) the projection False_Easting : A coordinate value in meters assigned to the central meridian of the projection. (input) False_Northing : A coordinate value in meters assigned to the origin latitude of the projection (input) Scale_Factor : Multiplier which reduces distances in the projection to the actual distance on the ellipsoid (output)
Definition at line 241 of file ossimMercatorProjection.cpp.
References ossim::almostEqual(), Convert_Geodetic_To_Mercator(), MAX_LAT, Merc_a, Merc_ab, Merc_bb, Merc_cb, Merc_db, Merc_Delta_Easting, Merc_Delta_Northing, Merc_e, Merc_es, Merc_f, Merc_False_Easting, Merc_False_Northing, MERC_NO_ERROR, Merc_Origin_Lat, Merc_Origin_Long, Merc_Scale_Factor, PI, and theSphericalFlag.
Referenced by update().
| void ossimMercatorProjection::setDefaults | ( | ) |
Definition at line 117 of file ossimMercatorProjection.cpp.
References Merc_Delta_Easting, Merc_Delta_Northing, Merc_False_Easting, Merc_False_Northing, and Merc_Scale_Factor.
Referenced by loadState(), and ossimMercatorProjection().
| void ossimMercatorProjection::setFalseEasting | ( | double | falseEasting | ) |
Definition at line 80 of file ossimMercatorProjection.cpp.
References Merc_False_Easting, and update().
| void ossimMercatorProjection::setFalseEastingNorthing | ( | double | falseEasting, |
| double | falseNorthing | ||
Definition at line 98 of file ossimMercatorProjection.cpp.
References Merc_False_Easting, Merc_False_Northing, and update().
| void ossimMercatorProjection::setFalseNorthing | ( | double | falseNorthing | ) |
Definition at line 86 of file ossimMercatorProjection.cpp.
References Merc_False_Northing, and update().
| void ossimMercatorProjection::setParameters | ( | double | falseEasting, |
Allows one to set all parameters for this projections. parallels are in degrees and easting northings are in meters. Update is then called so we can pre-compute paramters.
Definition at line 106 of file ossimMercatorProjection.cpp.
References Merc_False_Easting, Merc_False_Northing, Merc_Scale_Factor, and update().
| void ossimMercatorProjection::setScaleFactor | ( | double | scaleFactor | ) |
sets the scale.
Definition at line 92 of file ossimMercatorProjection.cpp.
References Merc_Scale_Factor, and update().
Referenced by ossimWktProjectionFactory::doMercator().
Definition at line 63 of file ossimMercatorProjection.cpp.
References ossimEllipsoid::getA(), ossimEllipsoid::getFlattening(), ossimGpt::latr(), ossimGpt::lonr(), Merc_False_Easting, Merc_False_Northing, Merc_Scale_Factor, Set_Mercator_Parameters(), ossimMapProjection::theEllipsoid, ossimMapProjection::theFalseEastingNorthing, ossimMapProjection::theOrigin, ossimMapProjection::update(), ossimDpt::x, and ossimDpt::y.
Referenced by loadState(), ossimMercatorProjection(), setFalseEasting(), setFalseEastingNorthing(), setFalseNorthing(), setParameters(), and setScaleFactor().
mutableprivate |
Definition at line 94 of file ossimMercatorProjection.h.
Referenced by Convert_Geodetic_To_Mercator(), Convert_Mercator_To_Geodetic(), forward(), Get_Mercator_Parameters(), and Set_Mercator_Parameters().
mutableprivate |
Definition at line 107 of file ossimMercatorProjection.h.
Referenced by Convert_Mercator_To_Geodetic(), and Set_Mercator_Parameters().
mutableprivate |
Definition at line 108 of file ossimMercatorProjection.h.
mutableprivate |
Definition at line 109 of file ossimMercatorProjection.h.
mutableprivate |
Definition at line 110 of file ossimMercatorProjection.h.
mutableprivate |
Definition at line 114 of file ossimMercatorProjection.h.
Referenced by Set_Mercator_Parameters(), and setDefaults().
mutableprivate |
Definition at line 115 of file ossimMercatorProjection.h.
mutableprivate |
Definition at line 96 of file ossimMercatorProjection.h.
Referenced by Convert_Geodetic_To_Mercator(), and Set_Mercator_Parameters().
mutableprivate |
Definition at line 97 of file ossimMercatorProjection.h.
Referenced by Set_Mercator_Parameters().
mutableprivate |
Definition at line 95 of file ossimMercatorProjection.h.
Referenced by Get_Mercator_Parameters(), and Set_Mercator_Parameters().
mutableprivate |
Definition at line 103 of file ossimMercatorProjection.h.
Referenced by Convert_Geodetic_To_Mercator(), Convert_Mercator_To_Geodetic(), Get_Mercator_Parameters(), loadState(), ossimMercatorProjection(), Set_Mercator_Parameters(), setDefaults(), setFalseEasting(), setFalseEastingNorthing(), setParameters(), and update().
mutableprivate |
Definition at line 102 of file ossimMercatorProjection.h.
Referenced by Convert_Geodetic_To_Mercator(), Convert_Mercator_To_Geodetic(), Get_Mercator_Parameters(), loadState(), ossimMercatorProjection(), Set_Mercator_Parameters(), setDefaults(), setFalseEastingNorthing(), setFalseNorthing(), setParameters(), and update().
mutableprivate |
Definition at line 100 of file ossimMercatorProjection.h.
mutableprivate |
Definition at line 101 of file ossimMercatorProjection.h.
Referenced by Convert_Geodetic_To_Mercator(), Convert_Mercator_To_Geodetic(), Get_Mercator_Parameters(), and Set_Mercator_Parameters().
mutableprivate |
Definition at line 104 of file ossimMercatorProjection.h.
Referenced by Convert_Geodetic_To_Mercator(), Convert_Mercator_To_Geodetic(), Get_Mercator_Parameters(), loadState(), operator==(), ossimMercatorProjection(), saveState(), Set_Mercator_Parameters(), setDefaults(), setParameters(), setScaleFactor(), and update().
private |
Definition at line 118 of file ossimMercatorProjection.h.
Referenced by Convert_Mercator_To_Geodetic(), forward(), inverse(), and Set_Mercator_Parameters().
