#include <ossimImageWriterFactory.h>
| virtual | ~ossimImageWriterFactory () |
| ossimImageFileWriter * | createWriterFromExtension (const ossimString &fileExtension) const |
| virtual ossimImageFileWriter * | createWriter (const ossimKeywordlist &kwl, const char *prefix=0) const |
| virtual ossimImageFileWriter * | createWriter (const ossimString &typeName) const |
| virtual ossimObject * | createObject (const ossimKeywordlist &kwl, const char *prefix=0) const |
| virtual ossimObject * | createObject (const ossimString &typeName) const |
| virtual void | getExtensions (std::vector< ossimString > &result) const |
| virtual void | getTypeNameList (std::vector< ossimString > &typeList) const |
| virtual void | getImageTypeList (std::vector< ossimString > &imageTypeList) const |
| virtual void | getImageFileWritersBySuffix (ossimImageWriterFactoryBase::ImageFileWriterList &result, const ossimString &ext) const |
| virtual void | getImageFileWritersByMimeType (ossimImageWriterFactoryBase::ImageFileWriterList &result, const ossimString &mimeType) const |
Public Member Functions inherited from ossimImageWriterFactoryBase | |
| virtual | ~ossimImageWriterFactoryBase () |
Public Member Functions inherited from ossimObjectFactory | |
| virtual | ~ossimObjectFactory () |
| ossimObject () | |
| static ossimImageWriterFactory * | instance () |
| ossimImageWriterFactory () | |
| ossimImageFileWriter * | createFromMimeType (const ossimString &mimeType) const |
| bool | isImageTypeName (const ossimString &name) const |
Static Protected Attributes | |
| static ossimImageWriterFactory * | theInstance = (ossimImageWriterFactory*)NULL |
Public Types inherited from ossimImageWriterFactoryBase | |
| typedef std::vector< ossimRefPtr< ossimImageFileWriter > > | ImageFileWriterList |
Definition at line 20 of file ossimImageWriterFactory.h.
Definition at line 39 of file ossimImageWriterFactory.cpp.
References theInstance.
inlineprotected |
protected |
Definition at line 250 of file ossimImageWriterFactory.cpp.
References ossimImageFileWriter::setOutputImageType().
Referenced by createWriter().
Creates and object given a keyword list.
Implements ossimObjectFactory.
Definition at line 292 of file ossimImageWriterFactory.cpp.
References createWriter().
Creates an object given a type name.
Definition at line 298 of file ossimImageWriterFactory.cpp.
Implements ossimImageWriterFactoryBase.
Definition at line 89 of file ossimImageWriterFactory.cpp.
References ossimKeywordlist::add(), ossimKeywordlist::find(), ossimImageFileWriter::hasImageType(), ossimKeywordNames::IMAGE_TYPE_KW, ossimImageFileWriter::loadState(), and ossimKeywordNames::TYPE_KW.
Referenced by createObject().
Definition at line 121 of file ossimImageWriterFactory.cpp.
References createFromMimeType(), ossimString::downcase(), ossimObject::getClassName(), ossimImageFileWriter::hasImageType(), ossimRefPtr< T >::release(), ossimImageFileWriter::setOutputImageType(), STATIC_TYPE_NAME, and ossimRefPtr< T >::valid().
| ossimImageFileWriter * ossimImageWriterFactory::createWriterFromExtension | ( | const ossimString & | fileExtension | ) | const |
Definition at line 44 of file ossimImageWriterFactory.cpp.
References ossimString::downcase(), OSSIM_GENERAL_RASTER_BIL, OSSIM_GENERAL_RASTER_BIP, and ossimImageFileWriter::setOutputImageType().
Definition at line 303 of file ossimImageWriterFactory.cpp.
Reimplemented from ossimImageWriterFactoryBase.
Definition at line 352 of file ossimImageWriterFactory.cpp.
References ossimString::begin(), ossimString::downcase(), ossimString::end(), and getImageFileWritersBySuffix().
Definition at line 326 of file ossimImageWriterFactory.cpp.
References ossimString::downcase(), and ossimString::push_back().
Referenced by getImageFileWritersByMimeType().
getImageTypeList. This is the actual image type name. So for example, ossimTiffWriter has several image types. Some of these include TIFF_TILED, TIFF_TILED_BAND_SEPARATE ... etc. The ossimGdalWriter may include GDAL_IMAGINE_HFA, GDAL_RGB_NITF, GDAL_JPEG20000, ... etc A writer should be able to be instantiated by this name as well as a class name
Definition at line 361 of file ossimImageWriterFactory.cpp.
References ossimImageFileWriter::getImageTypeList().
This should return the type name of all objects in all factories. This is the name used to construct the objects dynamially and this name must be unique.
Definition at line 315 of file ossimImageWriterFactory.cpp.
References STATIC_TYPE_NAME.
static |
Definition at line 28 of file ossimImageWriterFactory.cpp.
References ossimImageWriterFactoryRegistry::instance(), ossimImageWriterFactory(), ossimFactoryListInterface< T, NativeType >::registerFactory(), and theInstance.
Referenced by ossimImageWriterFactoryRegistry::instance().
protected |
staticprotected |
Definition at line 57 of file ossimImageWriterFactory.h.
Referenced by instance(), and ~ossimImageWriterFactory().
