#include <ossimImageWriterFactoryRegistry.h>
| ossimImageFileWriter * | createWriter (const ossimFilename &filename) const |
| ossimImageFileWriter * | createWriterFromExtension (const ossimString &fileExtension) const |
| ossimImageFileWriter * | createWriter (const ossimKeywordlist &kwl, const char *prefix=0) const |
| ossimImageFileWriter * | createWriter (const ossimString &typeName) const |
| ossimObject * | createObject (const ossimKeywordlist &kwl, const char *prefix=0) const |
| ossimObject * | createObject (const ossimString &typeName) const |
| virtual void | getTypeNameList (std::vector< ossimString > &typeList) const |
| getTypeNameList. More... | |
| virtual void | getImageTypeList (std::vector< ossimString > &imageTypeList) const |
| getImageTypeList. More... | |
| virtual void | getImageFileWritersBySuffix (ossimImageWriterFactoryBase::ImageFileWriterList &result, const ossimString &ext) const |
| virtual void | getImageFileWritersByMimeType (ossimImageWriterFactoryBase::ImageFileWriterList &result, const ossimString &mimeType) const |
| std::ostream & | printImageTypeList (std::ostream &out) const |
| Prints list of writers from getImageTypeList. More... | |
| std::ostream & | printWriterProps (std::ostream &out) const |
Public Member Functions inherited from ossimObjectFactory | |
| virtual | ~ossimObjectFactory () |
| ossimObject () | |
Public Member Functions inherited from ossimFactoryListInterface< ossimImageWriterFactoryBase, ossimImageFileWriter > | |
| ossimFactoryListInterface () | |
| void | addFactory (ossimImageWriterFactoryBase *factory) |
| This is for backward compatability and calls registerFactory for simple adds. More... | |
| bool | isFactoryRegistered (ossimImageWriterFactoryBase *factory) const |
| Public access method to determine if a factory is already registered to this list. More... | |
| void | registerFactory (ossimImageWriterFactoryBase *factory, bool pushToFrontFlag=false) |
| Will register a factory to the factory list. More... | |
| void | unregisterFactory (ossimImageWriterFactoryBase *factory) |
| Will remove the factory from the registry. More... | |
| void | unregisterFactory (const ossimString &factoryTypeName) |
| Will remove the factory from the registry by name. More... | |
| void | unregisterAllFactories () |
| Will remove all factories from the registry. More... | |
| void | registerFactoryToFront (ossimImageWriterFactoryBase *factory) |
| Inserts the factory to the front of the list. More... | |
| void | registerFactoryBefore (ossimImageWriterFactoryBase *factory, ossimImageWriterFactoryBase *beforeThisFactory) |
| Will insert the factory before the beforeThisFactory. More... | |
| void | getAllTypeNamesFromRegistry (std::vector< ossimString > &typeList) const |
| Will add all object types the factories can allocate. More... | |
| ossimObject * | createObjectFromRegistry (const ossimString &typeName) const |
| This is the base object return for all objects in the system. More... | |
| ossimObject * | createObjectFromRegistry (const ossimKeywordlist &kwl, const char *prefix=0) const |
| ossimImageFileWriter * | createNativeObjectFromRegistry (const ossimString &typeName) const |
| This is a helper method that calls the createObject and makes sure that the returned object is of the NativeType base type this registry supports. More... | |
| ossimImageFileWriter * | createNativeObjectFromRegistry (const ossimKeywordlist &kwl, const char *prefix=0) const |
| static ossimImageWriterFactoryRegistry * | instance () |
| ossimImageWriterFactoryRegistry () | |
| ossimImageWriterFactoryRegistry (const ossimImageWriterFactoryRegistry &) | |
| void | operator= (const ossimImageWriterFactoryRegistry &) |
Protected Member Functions inherited from ossimFactoryListInterface< ossimImageWriterFactoryBase, ossimImageFileWriter > | |
| bool | findFactory (ossimImageWriterFactoryBase *factory) const |
| Utility to find a factory in the list. More... | |
Public Types inherited from ossimFactoryListInterface< ossimImageWriterFactoryBase, ossimImageFileWriter > | |
| typedef std::vector< ossimImageWriterFactoryBase *> | FactoryListType |
| typedef ossimImageWriterFactoryBase | FactoryType |
| typedef ossimImageFileWriter | NativeReturnType |
Protected Attributes inherited from ossimFactoryListInterface< ossimImageWriterFactoryBase, ossimImageFileWriter > | |
| std::mutex | m_factoryListMutex |
| FactoryListType | m_factoryList |
Definition at line 24 of file ossimImageWriterFactoryRegistry.h.
protected |
Definition at line 28 of file ossimImageWriterFactoryRegistry.cpp.
protected |
Definition at line 309 of file ossimImageWriterFactoryRegistry.cpp.
Creates and object given a keyword list.
Implements ossimObjectFactory.
Definition at line 64 of file ossimImageWriterFactoryRegistry.cpp.
References ossimFactoryListInterface< ossimImageWriterFactoryBase, ossimImageFileWriter >::createObjectFromRegistry().
Creates an object given a type name.
Definition at line 70 of file ossimImageWriterFactoryRegistry.cpp.
| ossimImageFileWriter * ossimImageWriterFactoryRegistry::createWriter | ( | const ossimFilename & | filename | ) | const |
Definition at line 53 of file ossimImageWriterFactoryRegistry.cpp.
References createWriterFromExtension(), ossimString::downcase(), ossimFilename::ext(), and ossimImageFileWriter::setFilename().
Referenced by ossimDemTool::doOMG(), ossimPointCloudTool::execute(), and main().
| ossimImageFileWriter * ossimImageWriterFactoryRegistry::createWriter | ( | const ossimKeywordlist & | kwl, |
| const char * | prefix = 0 |
| ) | const |
Definition at line 93 of file ossimImageWriterFactoryRegistry.cpp.
References createWriterFromExtension(), ossimFilename::ext(), ossimKeywordNames::FILENAME_KW, ossimKeywordlist::find(), ossimFactoryListInterface< ossimImageWriterFactoryBase, ossimImageFileWriter >::m_factoryList, ossimImageFileWriter::setFilename(), and ossimKeywordNames::TYPE_KW.
| ossimImageFileWriter * ossimImageWriterFactoryRegistry::createWriter | ( | const ossimString & | typeName | ) | const |
Definition at line 136 of file ossimImageWriterFactoryRegistry.cpp.
References ossimFactoryListInterface< ossimImageWriterFactoryBase, ossimImageFileWriter >::m_factoryList.
| ossimImageFileWriter * ossimImageWriterFactoryRegistry::createWriterFromExtension | ( | const ossimString & | fileExtension | ) | const |
Definition at line 80 of file ossimImageWriterFactoryRegistry.cpp.
References getImageFileWritersBySuffix().
Referenced by createWriter().
Definition at line 194 of file ossimImageWriterFactoryRegistry.cpp.
Definition at line 174 of file ossimImageWriterFactoryRegistry.cpp.
Referenced by createWriterFromExtension().
getImageTypeList.
This is the actual image type name. So for example, ossimTiffWriter has several image types. Some of these include TIFF_TILED, TIFF_TILED_BAND_SEPARATE ... etc. The ossimGdalWriter may include GDAL_IMAGINE_HFA, GDAL_RGB_NITF, GDAL_JPEG20000, ... etc A writer should be able to be instantiated by this name as well as a class name
Definition at line 156 of file ossimImageWriterFactoryRegistry.cpp.
Referenced by printImageTypeList(), and printOutputTypes().
getTypeNameList.
This should return the class type of the object being used to perform the writting.
Definition at line 75 of file ossimImageWriterFactoryRegistry.cpp.
static |
Definition at line 32 of file ossimImageWriterFactoryRegistry.cpp.
References ossimImageWriterFactory::instance(), ossimObjectFactoryRegistry::instance(), and ossimFactoryListInterface< T, NativeType >::registerFactory().
Referenced by ossimDemTool::doOMG(), ossimPointCloudTool::execute(), ossimInit::initializeDefaultFactories(), ossimImageWriterFactory::instance(), main(), ossimImageWriterFactoryRegistryGetInstance(), ossimSharedLibraryFinalize(), ossimSharedLibraryInitialize(), printOutputTypes(), ossimInfo::printWriterProps(), and ossimInfo::printWriters().
protected |
Definition at line 315 of file ossimImageWriterFactoryRegistry.cpp.
| std::ostream & ossimImageWriterFactoryRegistry::printImageTypeList | ( | std::ostream & | out | ) | const |
| out | Stream to print to. |
Definition at line 213 of file ossimImageWriterFactoryRegistry.cpp.
References getImageTypeList().
Referenced by ossimInfo::printWriters().
| std::ostream & ossimImageWriterFactoryRegistry::printWriterProps | ( | std::ostream & | out | ) | const |
Definition at line 226 of file ossimImageWriterFactoryRegistry.cpp.
References ossimRefPtr< T >::get(), ossimObject::getClassName(), ossimStringProperty::getConstraints(), ossimImageFileWriter::getImageTypeList(), ossimImageFileWriter::getProperty(), ossimImageFileWriter::getPropertyNames(), ossimFactoryListInterface< ossimImageWriterFactoryBase, ossimImageFileWriter >::m_factoryList, and ossimRefPtr< T >::valid().
Referenced by ossimInfo::printWriterProps().
