Go to the source code of this file.
Classes | |
| struct | linked_list_cell |
Macros | |
| #define | TRUE 1 |
| #define | FALSE 0 |
| #define | LL_FIRST(list) (position_type)list |
| #define | LL_NEXT(position) position->next |
Typedefs | |
| typedef struct linked_list_cell | cell_type |
| typedef struct linked_list_cell * | linked_list_type |
| typedef struct linked_list_cell * | position_type |
Functions | |
| linked_list_type | ll_init () |
| int | ll_empty (linked_list_type list) |
| position_type | ll_first (linked_list_type list) |
| position_type | ll_last (linked_list_type list) |
| position_type | ll_next (position_type position) |
| position_type | ll_previous (position_type position, linked_list_type list) |
| int | ll_end (position_type position) |
| void | ll_element (position_type position, void *element) |
| void | ll_insert (void *element, unsigned size, position_type position) |
| void | ll_delete (position_type position) |
| void | ll_reset (linked_list_type list) |
| position_type | ll_locate (void *element, linked_list_type list) |
| void | ll_replace (void *element, position_type position) |
| #define FALSE 0 |
Definition at line 23 of file linklist.h.
Referenced by ossimJpegStdIOSrc_fill_input_buffer().
| #define LL_FIRST | ( | list | ) | (position_type)list |
Definition at line 34 of file linklist.h.
| #define LL_NEXT | ( | position | ) | position->next |
Definition at line 40 of file linklist.h.
| #define TRUE 1 |
Definition at line 20 of file linklist.h.
Referenced by ossimJpegCodec::decodeJpeg(), DllMain(), empty_output_buffer(), ossimJpegCodec::encode(), fill_input_buffer(), fill_input_buffer12(), ossimJpegCodec::getColorSpace(), ossimJpegStdIOSrc_fill_input_buffer(), ossimJpegStdIOSrc_init_source(), ossimJpegTileSource::restart(), and ossimPdfWriter::writeJpegTile().
| typedef struct linked_list_cell cell_type |
| typedef struct linked_list_cell * linked_list_type |
| typedef struct linked_list_cell * position_type |
| void ll_delete | ( | position_type | position | ) |
| void ll_element | ( | position_type | position, |
| void * | element | ||
| int ll_empty | ( | linked_list_type | list | ) |
| int ll_end | ( | position_type | position | ) |
| position_type ll_first | ( | linked_list_type | list | ) |
| linked_list_type ll_init | ( | ) |
| void ll_insert | ( | void * | element, |
| unsigned | size, | ||
| position_type | position | ||
| position_type ll_last | ( | linked_list_type | list | ) |
| position_type ll_locate | ( | void * | element, |
| linked_list_type | list | ||
| position_type ll_next | ( | position_type | position | ) |
| position_type ll_previous | ( | position_type | position, |
| void ll_replace | ( | void * | element, |
| void ll_reset | ( | linked_list_type | list | ) |
