#include <ossimNitfVqCompressionHeader.h>
| ossimNitfVqCompressionHeader () | |
| virtual void | parseStream (std::istream &in) |
| virtual std::ostream & | print (std::ostream &out, const std::string &prefix) const |
| print method that outputs a key/value type format adding prefix to keys. More... | |
| virtual bool | saveState (ossimKeywordlist &kwl, const ossimString &prefix="") const |
| virtual ossim_uint32 | getBlockSizeInBytes () const |
| virtual ossim_uint32 | getNumberOfImageRows () const |
| virtual ossim_uint32 | getNumberOfImageCodesPerRow () const |
| virtual ossim_uint32 | getCompressionAlgorithmId () const |
| virtual ossim_uint32 | getImageCodeBitLength () const |
| virtual ossim_uint32 | getNumberOfTables () const |
| const std::vector< ossimNitfVqCompressionOffsetTableData > & | getTable () const |
Public Member Functions inherited from ossimNitfCompressionHeader | |
| virtual void | parseStream (ossim::istream &in)=0 |
| ossimObject () | |
| void | clearFields () |
Definition at line 37 of file ossimNitfVqCompressionHeader.h.
| ossimNitfVqCompressionHeader::ossimNitfVqCompressionHeader | ( | ) |
Definition at line 148 of file ossimNitfVqCompressionHeader.cpp.
References clearFields().
protected |
Definition at line 340 of file ossimNitfVqCompressionHeader.cpp.
References theCompressionAlgorithmId, theCompressionLookupTableOffsetRecordLength, theImageCodeBitLength, theNumberOfCompressionLookupOffsetRecords, theNumberOfImageCodesPerRow, and theNumberOfImageRows.
Referenced by ossimNitfVqCompressionHeader().
Definition at line 303 of file ossimNitfVqCompressionHeader.cpp.
References getImageCodeBitLength(), getNumberOfImageCodesPerRow(), and getNumberOfImageRows().
Definition at line 320 of file ossimNitfVqCompressionHeader.cpp.
References theCompressionAlgorithmId.
Referenced by ossimNitfImageHeaderV2_0::parseStream().
Definition at line 325 of file ossimNitfVqCompressionHeader.cpp.
References theImageCodeBitLength.
Referenced by getBlockSizeInBytes(), ossimNitfTileSource::vqUncompressC4(), and ossimNitfTileSource::vqUncompressM4().
Definition at line 315 of file ossimNitfVqCompressionHeader.cpp.
References theNumberOfImageCodesPerRow.
Definition at line 310 of file ossimNitfVqCompressionHeader.cpp.
References theNumberOfImageRows.
Definition at line 330 of file ossimNitfVqCompressionHeader.cpp.
References theTable.
| const std::vector< ossimNitfVqCompressionOffsetTableData > & ossimNitfVqCompressionHeader::getTable | ( | ) | const |
Definition at line 335 of file ossimNitfVqCompressionHeader.cpp.
Referenced by ossimNitfTileSource::vqUncompressC4(), and ossimNitfTileSource::vqUncompressM4().
Definition at line 153 of file ossimNitfVqCompressionHeader.cpp.
References ossimEndian::getSystemEndianType(), OSSIM_LITTLE_ENDIAN, ossimEndian::swap(), theCompressionAlgorithmId, theCompressionLookupOffsetTableOffset, theCompressionLookupTableOffsetRecordLength, theImageCodeBitLength, theNumberOfCompressionLookupOffsetRecords, theNumberOfCompressionParameterOffsetRecords, theNumberOfImageCodesPerRow, theNumberOfImageRows, and theTable.
Generic print method.
Derived classes should re-implement as they see fit.
Definition at line 206 of file ossimNitfVqCompressionHeader.cpp.
Implements ossimNitfCompressionHeader.
Definition at line 211 of file ossimNitfVqCompressionHeader.cpp.
References ossimString::string(), theCompressionAlgorithmId, theCompressionLookupTableOffsetRecordLength, theImageCodeBitLength, theNumberOfCompressionLookupOffsetRecords, theNumberOfImageCodesPerRow, theNumberOfImageRows, theTable, and ossimString::toString().
Reimplemented from ossimNitfCompressionHeader.
Definition at line 259 of file ossimNitfVqCompressionHeader.cpp.
References ossimKeywordlist::add(), ossimKeywordlist::parseStream(), ossimNitfCompressionHeader::saveState(), ossimString::string(), theCompressionAlgorithmId, theCompressionLookupTableOffsetRecordLength, theImageCodeBitLength, theNumberOfCompressionLookupOffsetRecords, theNumberOfImageCodesPerRow, theNumberOfImageRows, theTable, and ossimString::toString().
protected |
Definition at line 66 of file ossimNitfVqCompressionHeader.h.
Referenced by clearFields(), getCompressionAlgorithmId(), parseStream(), print(), and saveState().
protected |
Definition at line 70 of file ossimNitfVqCompressionHeader.h.
Referenced by parseStream().
protected |
Definition at line 71 of file ossimNitfVqCompressionHeader.h.
Referenced by clearFields(), parseStream(), print(), and saveState().
protected |
Definition at line 64 of file ossimNitfVqCompressionHeader.h.
Referenced by clearFields(), getImageCodeBitLength(), parseStream(), print(), and saveState().
protected |
Definition at line 67 of file ossimNitfVqCompressionHeader.h.
protected |
Definition at line 68 of file ossimNitfVqCompressionHeader.h.
protected |
Definition at line 63 of file ossimNitfVqCompressionHeader.h.
Referenced by clearFields(), getNumberOfImageCodesPerRow(), parseStream(), print(), and saveState().
protected |
Definition at line 62 of file ossimNitfVqCompressionHeader.h.
Referenced by clearFields(), getNumberOfImageRows(), parseStream(), print(), and saveState().
protected |
Definition at line 73 of file ossimNitfVqCompressionHeader.h.
Referenced by getNumberOfTables(), getTable(), parseStream(), print(), and saveState().
