#include <ossimImageMetaDataWriterRegistry.h>
| ~ossimImageMetaDataWriterRegistry () | |
| void | registerFactory (ossimImageMetaDataWriterFactoryBase *factory) |
| void | unregisterFactory (ossimImageMetaDataWriterFactoryBase *factory) |
| bool | findFactory (ossimImageMetaDataWriterFactoryBase *factory) const |
| virtual ossimObject * | createObject (const ossimString &typeName) const |
| Creates an object given a type name. More... | |
| virtual ossimObject * | createObject (const ossimKeywordlist &kwl, const char *prefix=0) const |
| Creates and object given a keyword list. More... | |
| virtual ossimRefPtr< ossimMetadataFileWriter > | createWriter (const ossimString &type) const |
| Creates a writer from either a class name or a string representing the meta data type like "tiff_world_file". More... | |
| virtual void | getTypeNameList (std::vector< ossimString > &typeList) const |
| This should return the type name of all objects in all factories. More... | |
| virtual void | getMetadatatypeList (std::vector< ossimString > &metadatatypeList) const |
| Initializes list with meta data types from all registered metadata factories. More... | |
Public Member Functions inherited from ossimObjectFactory | |
| virtual | ~ossimObjectFactory () |
| ossimObject () | |
| static ossimImageMetaDataWriterRegistry * | instance () |
| ossimImageMetaDataWriterRegistry (const ossimImageMetaDataWriterRegistry &rhs) | |
| const ossimImageMetaDataWriterRegistry & | operator= (const ossimImageMetaDataWriterRegistry &rhs) |
Protected Member Functions inherited from ossimImageMetaDataWriterFactoryBase | |
| ossimImageMetaDataWriterFactoryBase () | |
| ossimImageMetaDataWriterFactoryBase (const ossimImageMetaDataWriterFactoryBase &) | |
| const ossimImageMetaDataWriterFactoryBase & | operator= (const ossimImageMetaDataWriterFactoryBase &) |
Protected Attributes | |
| std::vector< ossimImageMetaDataWriterFactoryBase * > | theFactoryList |
Definition at line 15 of file ossimImageMetaDataWriterRegistry.h.
| ossimImageMetaDataWriterRegistry::~ossimImageMetaDataWriterRegistry | ( | ) |
Definition at line 24 of file ossimImageMetaDataWriterRegistry.cpp.
References ossimObjectFactoryRegistry::instance(), and ossimFactoryListInterface< T, NativeType >::unregisterFactory().
protected |
Definition at line 18 of file ossimImageMetaDataWriterRegistry.cpp.
References ossimObjectFactoryRegistry::instance(), ossimImageMetaDataWriterFactory::instance(), registerFactory(), and ossimFactoryListInterface< T, NativeType >::registerFactory().
protected |
Definition at line 153 of file ossimImageMetaDataWriterRegistry.cpp.
Implements ossimObjectFactory.
Definition at line 67 of file ossimImageMetaDataWriterRegistry.cpp.
References theFactoryList.
Definition at line 83 of file ossimImageMetaDataWriterRegistry.cpp.
Implements ossimImageMetaDataWriterFactoryBase.
Definition at line 100 of file ossimImageMetaDataWriterRegistry.cpp.
| bool ossimImageMetaDataWriterRegistry::findFactory | ( | ossimImageMetaDataWriterFactoryBase * | factory | ) | const |
Definition at line 58 of file ossimImageMetaDataWriterRegistry.cpp.
Referenced by registerFactory().
This is the actual image type name like: ossim_geometry envi_header tiff_world_file jpeg_world_file
| metadatatypeList | stl::vector<ossimString> list to append to. |
Definition at line 134 of file ossimImageMetaDataWriterRegistry.cpp.
This is the name used to construct the objects dynamially and this name must be unique.
Definition at line 114 of file ossimImageMetaDataWriterRegistry.cpp.
static |
Definition at line 29 of file ossimImageMetaDataWriterRegistry.cpp.
Referenced by ossimInit::initializeDefaultFactories(), and ossimImageMetaDataWriterRegistryGetInstance().
protected |
Definition at line 159 of file ossimImageMetaDataWriterRegistry.cpp.
| void ossimImageMetaDataWriterRegistry::registerFactory | ( | ossimImageMetaDataWriterFactoryBase * | factory | ) |
Definition at line 36 of file ossimImageMetaDataWriterRegistry.cpp.
References findFactory(), and theFactoryList.
Referenced by ossimImageMetaDataWriterRegistry().
| void ossimImageMetaDataWriterRegistry::unregisterFactory | ( | ossimImageMetaDataWriterFactoryBase * | factory | ) |
Definition at line 45 of file ossimImageMetaDataWriterRegistry.cpp.
protected |
Definition at line 90 of file ossimImageMetaDataWriterRegistry.h.
Referenced by createObject(), createWriter(), findFactory(), getMetadatatypeList(), getTypeNameList(), registerFactory(), and unregisterFactory().
