For engineering use in ATP. More...
#include <AtpAnnotatedImage.h>
| AtpAnnotatedImage (ossimRefPtr< ossimImageChain > &sourceChain, ossimRefPtr< ossimImageViewProjectionTransform > &ivt, const ossimDrect &aoi) | |
| ~AtpAnnotatedImage () | |
| void | setImageName (const std::string &name) |
| void | setAOI (const ossimDrect &aoi) |
| void | annotateFeatureSearchTiles (std::vector< ossimIrect > &tileRects) |
| void | annotateFeatures (std::vector< ossimDpt > &atpList, int r, int g, int b) |
| void | annotateCorrelations (AtpList &atpList, int r, int g, int b) |
| void | annotateCorrelationSearchTile (const ossimIrect &tileRect) |
| void | annotateOverlap (ossimPolygon &poly) |
| void | annotateResiduals (AtpList &atps, int r, int g, int b) |
| void | annotateTPIDs (AtpList &atps, int r, int g, int b) |
| void | annotateCorrBoxes (AtpList &atpList, int r) |
| bool | write () |
Public Member Functions inherited from ossimImageChain | |
| ossimImageChain () | |
| virtual | ~ossimImageChain () |
| ossimConnectableObject::ConnectableObjectList & | getChainList () |
| const ossimConnectableObject::ConnectableObjectList & | getChainList () const |
| ossimConnectableObject * | operator[] (ossim_uint32 index) |
| virtual ossimConnectableObject * | getConnectableObject (ossim_uint32 index) |
| Same as operator[](ossim_uint32 i) More... | |
| virtual ossim_int32 | indexOf (ossimConnectableObject *obj) const |
| virtual ossimImageSource * | getFirstSource () |
| Return the first source which is the one that first receives the getTile request. More... | |
| virtual const ossimImageSource * | getFirstSource () const |
| virtual ossimObject * | getFirstObject () |
| virtual ossimImageSource * | getLastSource () |
| Return the last source which is the one that last receives the getTile request. More... | |
| virtual const ossimImageSource * | getLastSource () const |
| virtual ossimObject * | getLastObject () |
| bool | addFirst (ossimConnectableObject *obj) |
| Adds it to the start of the chain. More... | |
| bool | addLast (ossimConnectableObject *obj) |
| Adds it to the end. More... | |
| bool | deleteFirst () |
| Deletes the first object. More... | |
| bool | deleteLast () |
| Deletes the last object. More... | |
| bool | insertRight (ossimConnectableObject *newObj, ossimConnectableObject *rightOfThisObj) |
| bool | insertRight (ossimConnectableObject *newObj, const ossimId &id) |
| bool | insertLeft (ossimConnectableObject *newObj, const ossimId &id) |
| bool | insertLeft (ossimConnectableObject *newObj, ossimConnectableObject *leftOfThisObj) |
| bool | replace (ossimConnectableObject *newObj, ossimConnectableObject *oldObj) |
| virtual bool | add (ossimConnectableObject *source) |
| Will return true or false if an image source was added to the chain. More... | |
| Within the image chain will pass the head of the list. More... | |
| this call is passed to the head of the list. More... | |
| This call is passed to the head of the list. More... | |
| Will pass this call to the head of the list. More... | |
| virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=NULL) const |
| Will save the state of the chain. More... | |
| virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=NULL) |
| Will load the state. More... | |
| bool | canConnectMyInputTo (ossim_int32 myInputIndex, const ossimConnectableObject *object) const |
| OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject::ConnectableObjectList findAllObjectsOfType(const RTTItypeid &typeInfo, bool recurse=true)) | |
| OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject::ConnectableObjectList findAllObjectsOfType(const ossimString &className, bool recurse=true)) | |
| OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findFirstObjectOfType(const RTTItypeid &typeInfo, bool recurse=true)) | |
| OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findFirstObjectOfType(const ossimString &className, bool recurse=true)) | |
| OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObject(const ossimId &id, bool recurse=true)) | |
| OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObject(const ossimConnectableObject *obj, bool recurse=true)) | |
| virtual void | makeUniqueIds () |
| Will cycle through all sources setting their ids. More... | |
| virtual ossim_uint32 | getNumberOfObjects (bool recurse=true) const |
| Returns the number of objects within this container and all child containers. More... | |
| virtual ossim_uint32 | getNumberOfSources () const |
| Deprecated! Please use getNumberOfObjects(false). More... | |
| virtual bool | addChild (ossimConnectableObject *attachableObject) |
| Will add an object to the container and then set the added objects owner to this. More... | |
| virtual bool | removeChild (ossimConnectableObject *object) |
| Will remove the child from the container. More... | |
| virtual ossimConnectableObject * | removeChild (const ossimId &id) |
| virtual void | getChildren (vector< ossimConnectableObject *> &children, bool immediateChildrenOnlyFlag) |
| virtual void | disconnectOutputEvent (ossimConnectionEvent &event) |
| virtual void | connectOutputEvent (ossimConnectionEvent &event) |
| virtual void | objectDestructingEvent (ossimObjectDestructingEvent &event) |
| ProcessEvent. More... | |
| void | deleteList () |
| virtual ossimConnectableObject::ConnectableObjectList & | imageChainList () |
| These access methods greatly facilitate the implementation of an image chain adaptor class. More... | |
| virtual const ossimConnectableObject::ConnectableObjectList & | imageChainList () const |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| virtual void | propertyEvent (ossimPropertyEvent &) |
| virtual void | refreshEvent (ossimRefreshEvent &) |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
Public Member Functions inherited from ossimConnectableContainerInterface | |
| ossimConnectableContainerInterface (ossimObject *obj) | |
| virtual | ~ossimConnectableContainerInterface () |
| virtual ossimConnectableObject::ConnectableObjectList | findAllObjectsOfType (const RTTItypeid &typeInfo, bool recurse=true)=0 |
| virtual ossimConnectableObject::ConnectableObjectList | findAllObjectsOfType (const ossimString &className, bool recurse=true)=0 |
| virtual ossimConnectableObject * | findFirstObjectOfType (const RTTItypeid &typeInfo, bool recurse=true)=0 |
| virtual ossimConnectableObject * | findFirstObjectOfType (const ossimString &className, bool recurse=true)=0 |
| virtual ossimConnectableObject * | findObject (const ossimId &id, bool recurse=true)=0 |
| virtual ossimConnectableObject * | findObject (const ossimConnectableObject *obj, bool recurse=true)=0 |
| ossimObject * | getObject () |
| const ossimObject * | getObject () const |
| void | deleteAllChildren () |
| virtual void | getChildren (std::vector< ossimConnectableObject *> &children, bool immediateChildrenOnlyFlag)=0 |
| void | drawBox (const ossimIrect &rect, int r, int g, int b) |
Protected Member Functions inherited from ossimImageChain | |
| void | prepareForRemoval (ossimConnectableObject *connectableObject) |
| Inserts all of this object's children and inputs into the container provided. More... | |
| bool | addAllSources (map< ossimId, vector< ossimId > > &idMapping, const ossimKeywordlist &kwl, const char *prefix=NULL) |
| For dynamic loading to take place we must allocate all objects first and then assign id's later. More... | |
| void | findInputConnectionIds (vector< ossimId > &result, const ossimKeywordlist &kwl, const char *prefix=NULL) |
| bool | connectAllSources (const map< ossimId, vector< ossimId > > &idMapping) |
Definition at line 27 of file AtpAnnotatedImage.h.
| ATP::AtpAnnotatedImage::AtpAnnotatedImage | ( | ossimRefPtr< ossimImageChain > & | sourceChain, |
| ossimRefPtr< ossimImageViewProjectionTransform > & | ivt, | ||
| const ossimDrect & | aoi | ||
Definition at line 29 of file AtpAnnotatedImage.cpp.
References ossimImageChain::accept(), ossimImageChain::add(), ossim::JsonParam::asInt(), ossimRefPtr< T >::get(), ossim::JsonConfig::getParameter(), ossimDrect::height(), ossimImageChain::initialize(), ATP::AtpConfig::instance(), m_annScale, m_annScaleInverse, m_annSource, setAOI(), ossimBandSelector::setOutputBandList(), ossimDrect::width(), ossimDpt::x, and ossimDpt::y.
| ATP::AtpAnnotatedImage::~AtpAnnotatedImage | ( | ) |
Definition at line 91 of file AtpAnnotatedImage.cpp.
| void ATP::AtpAnnotatedImage::annotateCorrBoxes | ( | AtpList & | atpList, |
| int | r | ||
| void ATP::AtpAnnotatedImage::annotateCorrelations | ( | AtpList & | atpList, |
| int | r, | ||
| int | g, | ||
| int | b | ||
Definition at line 175 of file AtpAnnotatedImage.cpp.
References ossimAnnotationSource::addObject(), ossim::JsonParam::asFloat(), ossim::JsonParam::asUint(), drawBox(), ossimRefPtr< T >::get(), ossim::JsonConfig::getParameter(), ATP::AtpConfig::instance(), m_annScaleInverse, m_annSource, ossimIrect::set_ll(), ossimIrect::set_lr(), ossimIrect::set_ul(), ossimIrect::set_ur(), ossimDpt::x, and ossimDpt::y.
| void ATP::AtpAnnotatedImage::annotateCorrelationSearchTile | ( | const ossimIrect & | tileRect | ) |
Definition at line 273 of file AtpAnnotatedImage.cpp.
References drawBox(), m_annScaleInverse, m_annSource, and ossimDpt::x.
| void ATP::AtpAnnotatedImage::annotateFeatures | ( | std::vector< ossimDpt > & | atpList, |
| int | r, | ||
| int | g, | ||
| int | b | ||
Definition at line 150 of file AtpAnnotatedImage.cpp.
References ossimAnnotationSource::addObject(), ATP::AtpConfig::instance(), m_annScaleInverse, m_annSource, and ossimDpt::x.
| void ATP::AtpAnnotatedImage::annotateFeatureSearchTiles | ( | std::vector< ossimIrect > & | tileRects | ) |
Definition at line 233 of file AtpAnnotatedImage.cpp.
References CINFO, drawBox(), m_annScaleInverse, m_annSource, ossimIrect::set_ll(), ossimIrect::set_lr(), ossimIrect::set_ul(), ossimIrect::set_ur(), ossimDpt::x, and ossimDpt::y.
| void ATP::AtpAnnotatedImage::annotateOverlap | ( | ossimPolygon & | poly | ) |
Definition at line 212 of file AtpAnnotatedImage.cpp.
References ossimAnnotationSource::addObject(), ossimPolygon::getVertexList(), m_annScaleInverse, m_annSource, and ossimDpt::x.
| void ATP::AtpAnnotatedImage::annotateResiduals | ( | AtpList & | atps, |
| int | r, | ||
| int | g, | ||
| int | b | ||
Definition at line 101 of file AtpAnnotatedImage.cpp.
| void ATP::AtpAnnotatedImage::annotateTPIDs | ( | AtpList & | atps, |
| int | r, | ||
| int | g, | ||
| int | b | ||
Definition at line 135 of file AtpAnnotatedImage.cpp.
References ossimAnnotationSource::addObject(), ossimRefPtr< T >::get(), and m_annSource.
protected |
Definition at line 298 of file AtpAnnotatedImage.cpp.
References ossimAnnotationSource::addObject(), ossimIrect::ll(), ossimIrect::lr(), m_annSource, ossimIrect::ul(), and ossimIrect::ur().
Referenced by annotateCorrelations(), annotateCorrelationSearchTile(), annotateFeatureSearchTiles(), and annotateResiduals().
| void ATP::AtpAnnotatedImage::setAOI | ( | const ossimDrect & | aoi | ) |
Definition at line 95 of file AtpAnnotatedImage.cpp.
References m_annScaledAoi, m_annScaleInverse, and ossimDpt::x.
Referenced by AtpAnnotatedImage().
inline |
| bool ATP::AtpAnnotatedImage::write | ( | ) |
Definition at line 282 of file AtpAnnotatedImage.cpp.
References CINFO, ossimTiffWriter::close(), ossimConnectableObject::connectMyInputTo(), ossimImageFileWriter::execute(), ossimImageFileWriter::initialize(), m_annFilename, m_annScaledAoi, ossimImageFileWriter::setAreaOfInterest(), ossimImageFileWriter::setFilename(), and status.
protected |
Definition at line 56 of file AtpAnnotatedImage.h.
Referenced by setImageName(), and write().
protected |
Definition at line 53 of file AtpAnnotatedImage.h.
protected |
Definition at line 55 of file AtpAnnotatedImage.h.
protected |
Definition at line 54 of file AtpAnnotatedImage.h.
Referenced by annotateCorrelations(), annotateCorrelationSearchTile(), annotateFeatures(), annotateFeatureSearchTiles(), annotateOverlap(), annotateResiduals(), AtpAnnotatedImage(), and setAOI().
protected |
Definition at line 52 of file AtpAnnotatedImage.h.
Referenced by annotateCorrelations(), annotateCorrelationSearchTile(), annotateFeatures(), annotateFeatureSearchTiles(), annotateOverlap(), annotateResiduals(), annotateTPIDs(), AtpAnnotatedImage(), and drawBox().
