#include <ossimAnnotationLineObject.h>
| ossimAnnotationLineObject () | |
| ossimAnnotationLineObject (const ossimIpt &start, const ossimIpt &end, unsigned char r=255, unsigned char g=255, unsigned char b=255, long thickness=1) | |
| ossimAnnotationLineObject (long x1, long y1, long x2, long y2, unsigned char r=255, unsigned char g=255, unsigned char b=255, long thickness=1) | |
| ossimAnnotationLineObject (const ossimAnnotationLineObject &rhs) | |
| virtual void | applyScale (double x, double y) |
| virtual ossimAnnotationObject * | getNewClippedObject (const ossimDrect &rect) const |
| virtual bool | intersects (const ossimDrect &rect) const |
| virtual void | draw (ossimRgbImage &anImage) const |
| virtual void | getBoundingRect (ossimDrect &rect) const |
| virtual bool | isPointWithin (const ossimDpt &imagePoint) const |
| virtual void | computeBoundingRect () |
| void | setLine (const ossimDpt &start, const ossimDpt &end) |
| void | getLine (ossimDpt &start, ossimDpt &end) |
Public Member Functions inherited from ossimAnnotationObject | |
| virtual | ~ossimAnnotationObject () |
| ossimAnnotationObject (ossim_uint8 r=255, ossim_uint8 g=255, ossim_uint8 b=255, ossim_uint8 thickness=1) | |
| virtual void | applyScale (const ossimDpt &scale) |
| virtual ossimDrect | getBoundingRect () const |
| virtual void | setColor (ossim_uint8 r, ossim_uint8 g, ossim_uint8 b) |
| void | getColor (ossim_uint8 &r, ossim_uint8 &g, ossim_uint8 &b) const |
| ossim_uint8 | getThickness () const |
| virtual void | setThickness (ossim_uint8 thickness) |
| Saves the current state of this object. More... | |
| virtual ossimString | getName () const |
| virtual void | setName (const ossimString &name) |
| ossim_uint32 | getId () const |
| virtual ossim_uint32 | setId () |
| ossimObject () | |
Protected Attributes | |
| ossimIpt | theStart |
| ossimIpt | theEnd |
| ossimDrect | theBoundingRect |
Protected Attributes inherited from ossimAnnotationObject | |
| ossim_uint8 | theRed |
| ossim_uint8 | theGreen |
| ossim_uint8 | theBlue |
| ossim_uint8 | theThickness |
| ossimString | theName |
| ossim_uint32 | theId |
Static Public Member Functions inherited from ossimAnnotationObject | |
| static ossim_uint32 | getNextId () |
| static void | restIdCounter () |
Static Protected Attributes inherited from ossimAnnotationObject | |
| static ossim_uint32 | theIdCounter = 0 |
Definition at line 15 of file ossimAnnotationLineObject.h.
| ossimAnnotationLineObject::ossimAnnotationLineObject | ( | ) |
Referenced by dup().
| ossimAnnotationLineObject::ossimAnnotationLineObject | ( | const ossimIpt & | start, |
| const ossimIpt & | end, | ||
| unsigned char | r = 255, |
| unsigned char | g = 255, |
| unsigned char | b = 255, |
| long | thickness = 1 |
Definition at line 28 of file ossimAnnotationLineObject.cpp.
References computeBoundingRect().
| ossimAnnotationLineObject::ossimAnnotationLineObject | ( | long | x1, |
| long | y1, | ||
| long | x2, | ||
| long | y2, | ||
Definition at line 41 of file ossimAnnotationLineObject.cpp.
| ossimAnnotationLineObject::ossimAnnotationLineObject | ( | const ossimAnnotationLineObject & | rhs | ) |
Definition at line 56 of file ossimAnnotationLineObject.cpp.
Implements ossimAnnotationObject.
Definition at line 69 of file ossimAnnotationLineObject.cpp.
References computeBoundingRect(), theEnd, theStart, ossimIpt::x, x, ossimIpt::y, and y.
Referenced by ossimGeoAnnotationLineObject::applyScale().
Definition at line 150 of file ossimAnnotationLineObject.cpp.
References theBoundingRect, theEnd, and theStart.
Referenced by applyScale(), ossimGeoAnnotationLineObject::computeBoundingRect(), ossimAnnotationLineObject(), and setLine().
Definition at line 101 of file ossimAnnotationLineObject.cpp.
References ossimRgbImage::drawLine(), ossimRgbImage::getImageData(), ossimImageData::getImageRectangle(), ossimDrect::lr(), ossimRgbImage::setDrawColor(), ossimRgbImage::setThickness(), ossimAnnotationObject::theBlue, theEnd, ossimAnnotationObject::theGreen, ossimAnnotationObject::theRed, theStart, ossimAnnotationObject::theThickness, ossimDrect::ul(), ossimRefPtr< T >::valid(), ossimDpt::x, and ossimDpt::y.
Referenced by ossimGeographicAnnotationGrid::draw(), and ossimGeoAnnotationLineObject::draw().
Definition at line 64 of file ossimAnnotationLineObject.cpp.
References ossimAnnotationLineObject().
Referenced by getNewClippedObject().
Definition at line 145 of file ossimAnnotationLineObject.cpp.
References theBoundingRect.
Referenced by ossimGeoAnnotationLineObject::getBoundingRect().
Will allocate a new object that is clipped to the passed. in rect. Look at derived classes to see if the object is actually clipped or not. A new object is returned if it clips to the rect else NULL should be returned it doesn't clip.
Definition at line 78 of file ossimAnnotationLineObject.cpp.
References ossimDrect::clip(), dup(), setLine(), theEnd, and theStart.
Referenced by ossimGeoAnnotationLineObject::getNewClippedObject().
Definition at line 93 of file ossimAnnotationLineObject.cpp.
References ossimDrect::clip(), theEnd, and theStart.
Referenced by ossimGeoAnnotationLineObject::intersects().
This method allows you to pick an object. It will return true or false if the point falls somewhere on an object. Look at derived classes for further information.
Reimplemented from ossimAnnotationObject.
Definition at line 173 of file ossimAnnotationLineObject.cpp.
References ossimDrect::pointWithin(), and theBoundingRect.
Generic print method.
Derived classes should re-implement as they see fit.
Definition at line 137 of file ossimAnnotationLineObject.cpp.
Definition at line 160 of file ossimAnnotationLineObject.cpp.
References computeBoundingRect(), theEnd, and theStart.
Referenced by ossimChipperUtil::addCrossHairAnnotation(), ossimGeographicAnnotationGrid::draw(), getNewClippedObject(), and ossimGeoAnnotationLineObject::transform().
protected |
Definition at line 57 of file ossimAnnotationLineObject.h.
Referenced by computeBoundingRect(), getBoundingRect(), isPointWithin(), and print().
protected |
Definition at line 56 of file ossimAnnotationLineObject.h.
Referenced by applyScale(), computeBoundingRect(), draw(), getLine(), getNewClippedObject(), intersects(), print(), and setLine().
protected |
Definition at line 55 of file ossimAnnotationLineObject.h.
