#include <ossimHttpResponse.h>
| ossimHttpResponse () | |
| ossimByteStreamBuffer & | headerBuffer () |
| const ossimByteStreamBuffer & | headerBuffer () const |
| ossimByteStreamBuffer & | bodyBuffer () |
| const ossimByteStreamBuffer & | bodyBuffer () const |
| std::iostream & | headerStream () |
| std::iostream & | bodyStream () |
| virtual std::istream * | getInputStream () |
| This might have to change in the future if we start doing other protocols such as ftp scp, ... More... | |
| virtual void | clear () |
| Clears out the Response and prepares for a new response. More... | |
| void | convertHeaderStreamToKeywordlist () |
| This will parse out the response code from the status line and initialize the header variables into a keywordlist. More... | |
| virtual void | clearLastError () |
| virtual ossimString | getLastError () const |
| ossimKeywordlist & | headerKwl () |
| const ossimKeywordlist & | headerKwl () const |
| ossim_int64 | getContentLength () const |
| ossimString | getHeaderValue (const ossimString &headerName) const |
| const ossimString & | statusLine () const |
| ossim_uint32 | getStatusCode () const |
Public Member Functions inherited from ossimWebResponse | |
| ossimWebResponse () | |
| void | copyAllDataFromInputStream (ByteBuffer &buffer) |
| ossimObject () | |
Protected Attributes | |
| ossimKeywordlist | m_headerKwl |
| ossimByteStreamBuffer | m_headerBuffer |
| ossimByteStreamBuffer | m_bodyBuffer |
| std::iostream | m_headerStream |
| std::iostream | m_bodyStream |
| ossimString | m_statusLine |
| ossim_uint32 | m_statusCode |
| TYPE_DATA | |
Public Types inherited from ossimWebResponse | |
| typedef std::vector< char > | ByteBuffer |
Public Attributes inherited from ossimWebResponse | |
| TYPE_DATA | |
Definition at line 21 of file ossimHttpResponse.h.
inline |
Definition at line 24 of file ossimHttpResponse.h.
inline |
Definition at line 33 of file ossimHttpResponse.h.
inline |
Definition at line 34 of file ossimHttpResponse.h.
inline |
Definition at line 37 of file ossimHttpResponse.h.
Referenced by ossimCurlHttpRequest::curlWriteResponseBody().
inlinevirtual |
Definition at line 45 of file ossimHttpResponse.h.
inlinevirtual |
Definition at line 59 of file ossimHttpResponse.h.
| void ossimHttpResponse::convertHeaderStreamToKeywordlist | ( | ) |
Definition at line 5 of file ossimHttpResponse.cpp.
References ossimKeywordlist::clear(), getline(), m_headerBuffer, m_headerKwl, m_statusCode, m_statusLine, ossimKeywordlist::parseStream(), ossimString::split(), and statusLine().
Referenced by ossimCurlHttpRequest::getContentLength(), ossimCurlHttpRequest::getResponse(), and ossim::CurlStreamBuffer::loadBlock().
| ossim_int64 ossimHttpResponse::getContentLength | ( | ) | const |
Definition at line 38 of file ossimHttpResponse.cpp.
References ossimString::empty(), ossimKeywordlist::find(), m_headerKwl, and ossimString::toInt64().
Referenced by ossim::CurlStreamBuffer::loadBlock().
| ossimString ossimHttpResponse::getHeaderValue | ( | const ossimString & | headerName | ) | const |
Definition at line 31 of file ossimHttpResponse.cpp.
References ossimKeywordlist::find(), and m_headerKwl.
inlinevirtual |
etc.
We currently will return the main input stream that can be used to read the bytes returned from the request. If you need access to say a header stream from an http protocol then you can dynamic_cast to an ossimHttpResponse.
Implements ossimWebResponse.
Definition at line 39 of file ossimHttpResponse.h.
inlinevirtual |
Definition at line 61 of file ossimHttpResponse.h.
inline |
Definition at line 68 of file ossimHttpResponse.h.
Referenced by ossimKakaduJpipHandler::allocateSession(), ossim::CurlStreamBuffer::loadBlock(), and ossimKakaduJpipHandler::loadClient().
inline |
Definition at line 31 of file ossimHttpResponse.h.
inline |
Definition at line 32 of file ossimHttpResponse.h.
inline |
Definition at line 63 of file ossimHttpResponse.h.
inline |
Definition at line 64 of file ossimHttpResponse.h.
inline |
Definition at line 36 of file ossimHttpResponse.h.
Referenced by ossimCurlHttpRequest::curlWriteResponseHeader().
inline |
Definition at line 67 of file ossimHttpResponse.h.
Referenced by convertHeaderStreamToKeywordlist().
protected |
Definition at line 73 of file ossimHttpResponse.h.
protected |
Definition at line 75 of file ossimHttpResponse.h.
protected |
Definition at line 72 of file ossimHttpResponse.h.
protected |
Definition at line 71 of file ossimHttpResponse.h.
Referenced by convertHeaderStreamToKeywordlist(), getContentLength(), and getHeaderValue().
protected |
Definition at line 74 of file ossimHttpResponse.h.
protected |
Definition at line 77 of file ossimHttpResponse.h.
protected |
Definition at line 76 of file ossimHttpResponse.h.
protected |
Definition at line 79 of file ossimHttpResponse.h.
