#include <ossimJpipMessageDecoder.h>
| ossimJpipMessageDecoder () | |
| ossimByteStreamBuffer & | inputStreamBuffer () |
| std::istream & | inputStream () const |
| virtual ossimJpipMessage * | readMessage () |
| ossim_int64 | readVBAS () |
| Reads a Variable-length Byte-Aligned Segment. More... | |
| ossimJpipMessage * | readEORMessage () |
Protected Attributes | |
| ossim_int32 | m_lastClass |
| ossim_int32 | m_lastCSn |
| Contains the last CSn value. More... | |
| ossim_int64 | m_headerLength |
| Indicates the length of the JPIP message header. More... | |
| ossimByteStreamBuffer | m_streamBuffer |
| std::istream | m_inputStream |
Definition at line 9 of file ossimJpipMessageDecoder.h.
| ossimJpipMessageDecoder::ossimJpipMessageDecoder | ( | ) |
Definition at line 3 of file ossimJpipMessageDecoder.cpp.
inline |
Definition at line 14 of file ossimJpipMessageDecoder.h.
inline |
Definition at line 13 of file ossimJpipMessageDecoder.h.
protected |
Definition at line 148 of file ossimJpipMessageDecoder.cpp.
References ossimJpipMessage::header(), ossimJpipMessageHeader::m_EORCode, m_headerLength, m_inputStream, ossimJpipMessageHeader::m_isEOR, ossimJpipMessageHeader::m_msgLength, ossimJpipMessage::messageBody(), readVBAS(), and ossimRefPtr< T >::release().
Referenced by readMessage().
Definition at line 12 of file ossimJpipMessageDecoder.cpp.
References ossimJpipMessage::header(), ossimJpipMessageHeader::m_aux, ossimJpipMessageHeader::m_classIdentifier, ossimJpipMessageHeader::m_CSn, m_headerLength, ossimJpipMessageHeader::m_inClassIdentifier, m_inputStream, ossimJpipMessageHeader::m_isLastByte, m_lastClass, m_lastCSn, ossimJpipMessageHeader::m_msgLength, ossimJpipMessageHeader::m_msgOffset, ossimJpipMessage::messageBody(), readEORMessage(), readVBAS(), ossimRefPtr< T >::release(), and ossimJpipMessage::setHeaderLength().
protected |
| ossimException | if an I/O error occurs. |
Definition at line 117 of file ossimJpipMessageDecoder.cpp.
References m_headerLength, and m_inputStream.
Referenced by readEORMessage(), and readMessage().
protected |
This attribute is useful for statistics.
Definition at line 45 of file ossimJpipMessageDecoder.h.
Referenced by readEORMessage(), readMessage(), and readVBAS().
mutableprotected |
Definition at line 48 of file ossimJpipMessageDecoder.h.
protected |
Definition at line 33 of file ossimJpipMessageDecoder.h.
protected |
It is a state variables used when dependent form is used.
Definition at line 39 of file ossimJpipMessageDecoder.h.
mutableprotected |
Definition at line 47 of file ossimJpipMessageDecoder.h.
