#include <ossimWebResponse.h>
Public Types | |
| typedef std::vector< char > | ByteBuffer |
| ossimWebResponse () | |
| virtual std::istream * | getInputStream ()=0 |
| This might have to change in the future if we start doing other protocols such as ftp scp, ... More... | |
| void | copyAllDataFromInputStream (ByteBuffer &buffer) |
| ossimObject () | |
Public Attributes | |
| TYPE_DATA | |
Definition at line 7 of file ossimWebResponse.h.
| typedef std::vector<char> ossimWebResponse::ByteBuffer |
Definition at line 10 of file ossimWebResponse.h.
inline |
Definition at line 11 of file ossimWebResponse.h.
| void ossimWebResponse::copyAllDataFromInputStream | ( | ByteBuffer & | buffer | ) |
Definition at line 6 of file ossimWebResponse.cpp.
References getInputStream().
Referenced by ossim::CurlStreamBuffer::loadBlock().
pure virtual |
etc.
We currently will return the main input stream that can be used to read the bytes returned from the request. If you need access to say a header stream from an http protocol then you can dynamic_cast to an ossimHttpResponse.
Implemented in ossimHttpResponse.
Referenced by copyAllDataFromInputStream().
| ossimWebResponse::TYPE_DATA |
Definition at line 25 of file ossimWebResponse.h.
