#include <ossimGeoidManager.h>
| virtual | ~ossimGeoidManager () |
| virtual bool | open (const ossimFilename &dir, ossimByteOrder byteOrder) |
| Permits initialization of geoids from directory name. More... | |
| virtual double | offsetFromEllipsoid (const ossimGpt &gpt) |
| Method to save the state of the object to a keyword list. More... | |
| Method to the load (recreate) the state of the object from a keyword list. More... | |
| virtual void | addGeoid (ossimRefPtr< ossimGeoid > geoid, bool toFrontFlag=false) |
| Permits adding additional geoids to the list: More... | |
| ossimGeoid * | findGeoidByShortName (const ossimString &shortName, bool caseSensitive=true) |
| virtual void | clear () |
| Permits to clear the GeoidList. More... | |
Public Member Functions inherited from ossimGeoid | |
| ossimGeoid () | |
| ossimObject () | |
| bool | hasError () const |
| static ossimGeoidManager * | instance () |
| Implements singelton pattern: More... | |
Private Member Functions | |
| ossimGeoidManager () | |
| Private constructor. More... | |
Private Attributes | |
| std::vector< ossimRefPtr< ossimGeoid > > | theGeoidList |
| ossimRefPtr< ossimGeoid > | theIdentityGeoid |
Protected Member Functions inherited from ossimGeoid | |
| virtual | ~ossimGeoid () |
Definition at line 26 of file ossimGeoidManager.h.
Definition at line 54 of file ossimGeoidManager.cpp.
References clear().
private |
Use "instance" method.
Definition at line 44 of file ossimGeoidManager.cpp.
References theIdentityGeoid.
Definition at line 94 of file ossimGeoidManager.cpp.
References theGeoidList.
Definition at line 69 of file ossimGeoidManager.cpp.
Referenced by ~ossimGeoidManager().
| ossimGeoid * ossimGeoidManager::findGeoidByShortName | ( | const ossimString & | shortName, |
| bool | caseSensitive = true |
Definition at line 328 of file ossimGeoidManager.cpp.
References ossimString::downcase(), ossimRefPtr< T >::get(), ossimObject::getShortName(), theGeoidList, and theIdentityGeoid.
Referenced by ossimElevationDatabase::loadState().
static |
Definition at line 78 of file ossimGeoidManager.cpp.
Referenced by ossimElevRemapper::elevRemap(), ossimElevManager::getHeightAboveEllipsoid(), ossimElevManager::getHeightAboveMSL(), ossimElevationDatabase::getOffsetFromEllipsoid(), ossimGpt::heightMSL(), ossimElevationDatabase::loadState(), ossimIpodSensor::loadState(), ossimSkyBoxLearSensor::loadState(), ossimSonomaSensor::loadState(), and ossimInfo::outputHeight().
Definition at line 116 of file ossimGeoidManager.cpp.
Implements ossimGeoid.
Definition at line 313 of file ossimGeoidManager.cpp.
References ossim::isnan(), ossim::nan(), and theGeoidList.
Referenced by ossimElevRemapper::elevRemap(), ossimElevManager::getHeightAboveEllipsoid(), ossimElevManager::getHeightAboveMSL(), ossimElevationDatabase::getOffsetFromEllipsoid(), ossimGpt::heightMSL(), ossimIpodSensor::loadState(), ossimSkyBoxLearSensor::loadState(), ossimSonomaSensor::loadState(), and ossimInfo::outputHeight().
Should never be called since called on specific geoid types:
Definition at line 296 of file ossimGeoidManager.cpp.
References ossim::byteOrder(), status, and theGeoidList.
Return true if ok or false on error. DO NOTHING
Definition at line 106 of file ossimGeoidManager.cpp.
mutableprivate |
Definition at line 84 of file ossimGeoidManager.h.
Referenced by addGeoid(), clear(), findGeoidByShortName(), offsetFromEllipsoid(), and open().
private |
Definition at line 88 of file ossimGeoidManager.h.
Referenced by findGeoidByShortName(), and ossimGeoidManager().
