#include <ossimQuickbirdMetaData.h>
| ossimQuickbirdMetaData () | |
| virtual | ~ossimQuickbirdMetaData () |
| bool | open (const ossimFilename &imageFile) |
| Open method that takes the image file, derives the metadata, header and rpc files, then calls parse methods parseMetaData, parseHdrData, and parseRpcData. More... | |
| void | clearFields () |
| Method to save the state of the object to a keyword list. More... | |
| Method to the load (recreate) the state of the object from a keyword list. More... | |
| bool | parseMetaData (const ossimFilename &metadata) |
| Method to parse Quickbird metadata file. More... | |
| bool | parseGEOData (const ossimFilename &data_file) |
| Method to parse Quickbird rpc file. More... | |
| bool | parseATTData (const ossimFilename &data_file) |
| bool | parseEPHData (const ossimFilename &data_file) |
| ossimString | getSatID () const |
| bool | getEndOfLine (char *fileBuf, ossimString lineBeginning, const char *format, ossimString &name) |
| const ossimIpt & | getImageSize () const |
| bool | getMapProjectionKwl (const ossimFilename &imd_file, ossimKeywordlist &kwl) |
| ossimObject () | |
Private Attributes | |
| ossimString | theGenerationDate |
| ossimString | theBandId |
| int | theBitsPerPixel |
| ossimString | theSatID |
| ossimString | theTLCDate |
| ossim_float64 | theSunAzimuth |
| ossim_float64 | theSunElevation |
| ossim_float64 | theSatAzimuth |
| ossim_float64 | theSatElevation |
| int | theTDILevel |
| std::vector< double > | theAbsCalFactors |
| ossimString | theBandNameList |
| ossimIpt | theImageSize |
Definition at line 27 of file ossimQuickbirdMetaData.h.
| ossimQuickbirdMetaData::ossimQuickbirdMetaData | ( | ) |
default constructor
Definition at line 32 of file ossimQuickbirdMetaData.cpp.
References ossimIpt::makeNan(), theAbsCalFactors, and theImageSize.
| void ossimQuickbirdMetaData::clearFields | ( | ) |
Definition at line 82 of file ossimQuickbirdMetaData.cpp.
References ossimIpt::makeNan(), theAbsCalFactors, theBandId, theBandNameList, theBitsPerPixel, theGenerationDate, theImageSize, theSatAzimuth, theSatElevation, theSatID, theSunAzimuth, theSunElevation, theTDILevel, and theTLCDate.
Referenced by loadState(), and open().
| bool ossimQuickbirdMetaData::getEndOfLine | ( | char * | fileBuf, |
| ossimString | lineBeginning, | ||
| const char * | format, | ||
| ossimString & | name | ||
Definition at line 1047 of file ossimQuickbirdMetaData.cpp.
References ossimString::c_str().
| const ossimIpt & ossimQuickbirdMetaData::getImageSize | ( | ) | const |
Definition at line 1077 of file ossimQuickbirdMetaData.cpp.
References theImageSize.
Referenced by ossimQbTileFilesHandler::computeImageRects().
| bool ossimQuickbirdMetaData::getMapProjectionKwl | ( | const ossimFilename & | imd_file, |
| ossimKeywordlist & | kwl | ||
Definition at line 781 of file ossimQuickbirdMetaData.cpp.
Referenced by ossimQbTileFilesHandler::getImageGeometry().
| ossimString ossimQuickbirdMetaData::getSatID | ( | ) | const |
Definition at line 776 of file ossimQuickbirdMetaData.cpp.
References theSatID.
Referenced by ossimQuickbirdRpcModel::parseMetaData().
Definition at line 213 of file ossimQuickbirdMetaData.cpp.
References ossimKeywordNames::AZIMUTH_ANGLE_KW, clearFields(), ossimKeywordNames::ELEVATION_ANGLE_KW, ossimKeywordlist::find(), ossimString::split(), theAbsCalFactors, theBandId, theBandNameList, theBitsPerPixel, theGenerationDate, theSatAzimuth, theSatElevation, theSatID, theSunAzimuth, theSunElevation, theTDILevel, theTLCDate, ossimString::toDouble(), ossimString::toFloat64(), ossimString::toInt(), and ossimKeywordNames::TYPE_KW.
Referenced by ossimQuickbirdRpcModel::loadState().
| bool ossimQuickbirdMetaData::open | ( | const ossimFilename & | imageFile | ) |
| imageFile | Usually in the form of "po_2619900_pan_0000000.tif". |
Definition at line 56 of file ossimQuickbirdMetaData.cpp.
References clearFields(), parseMetaData(), and ossimFilename::setExtension().
Referenced by ossimQbTileFilesHandler::computeImageRects(), and ossimQuickbirdRpcModel::parseMetaData().
| bool ossimQuickbirdMetaData::parseATTData | ( | const ossimFilename & | data_file | ) |
Definition at line 771 of file ossimQuickbirdMetaData.cpp.
| bool ossimQuickbirdMetaData::parseEPHData | ( | const ossimFilename & | data_file | ) |
Definition at line 760 of file ossimQuickbirdMetaData.cpp.
| bool ossimQuickbirdMetaData::parseGEOData | ( | const ossimFilename & | data_file | ) |
| metadata | File name usually in the form of ".GEO.txt" |
Definition at line 749 of file ossimQuickbirdMetaData.cpp.
| bool ossimQuickbirdMetaData::parseMetaData | ( | const ossimFilename & | metadata | ) |
| metadata | File name usually in the form of ".IMD." |
Definition at line 336 of file ossimQuickbirdMetaData.cpp.
Referenced by open().
Generic print method.
Derived classes should re-implement as they see fit.
Definition at line 99 of file ossimQuickbirdMetaData.cpp.
References theAbsCalFactors, theBandId, theBandNameList, theBitsPerPixel, theGenerationDate, theImageSize, theSatAzimuth, theSatElevation, theSatID, theSunAzimuth, theSunElevation, theTDILevel, and theTLCDate.
Definition at line 128 of file ossimQuickbirdMetaData.cpp.
References ossimKeywordlist::add(), ossimKeywordNames::AZIMUTH_ANGLE_KW, ossimKeywordNames::ELEVATION_ANGLE_KW, ossimString::split(), theAbsCalFactors, theBandId, theBandNameList, theBitsPerPixel, theGenerationDate, theSatAzimuth, theSatElevation, theSatID, theSunAzimuth, theSunElevation, theTDILevel, theTLCDate, and ossimKeywordNames::TYPE_KW.
Referenced by ossimQuickbirdRpcModel::saveState().
private |
Definition at line 125 of file ossimQuickbirdMetaData.h.
Referenced by clearFields(), loadState(), ossimQuickbirdMetaData(), print(), and saveState().
private |
Definition at line 116 of file ossimQuickbirdMetaData.h.
Referenced by clearFields(), loadState(), print(), and saveState().
private |
Definition at line 126 of file ossimQuickbirdMetaData.h.
private |
Definition at line 117 of file ossimQuickbirdMetaData.h.
private |
Definition at line 115 of file ossimQuickbirdMetaData.h.
private |
Definition at line 127 of file ossimQuickbirdMetaData.h.
Referenced by clearFields(), getImageSize(), ossimQuickbirdMetaData(), and print().
private |
Definition at line 122 of file ossimQuickbirdMetaData.h.
private |
Definition at line 123 of file ossimQuickbirdMetaData.h.
private |
Definition at line 118 of file ossimQuickbirdMetaData.h.
Referenced by clearFields(), getSatID(), loadState(), print(), and saveState().
private |
Definition at line 120 of file ossimQuickbirdMetaData.h.
private |
Definition at line 121 of file ossimQuickbirdMetaData.h.
private |
Definition at line 124 of file ossimQuickbirdMetaData.h.
private |
Definition at line 119 of file ossimQuickbirdMetaData.h.
