#include <ossim2dTo2dShiftTransform.h>
| ossim2dTo2dShiftTransform (const ossimDpt &shift=ossimDpt(0.0, 0.0)) | |
| Constructor to initialize the shift transform. More... | |
| ossim2dTo2dShiftTransform (const ossim2dTo2dShiftTransform &src) | |
| Copy constructor. More... | |
| Duplication method that duplicates this object. More... | |
| const ossim2dTo2dShiftTransform & | operator= (const ossim2dTo2dShiftTransform &src) |
| operator = allows one to copy the contents of the class through a common = operator. More... | |
| virtual void | forward (const ossimDpt &input, ossimDpt &output) const |
| Apply the shift to the input. More... | |
| virtual void | forward (ossimDpt &modify_this) const |
| Apply the shift to the input and put the result in the same variable. More... | |
| virtual void | inverse (const ossimDpt &input, ossimDpt &output) const |
| Negate the shift to the input and put the result in output. More... | |
| virtual void | inverse (ossimDpt &modify_this) const |
| Negate the shift operation and put the result in the same variable. More... | |
| Saves the state of this object. More... | |
| loads the state of this object from a keywordlist. More... | |
| Print the contents of the class and pass to the derived class. More... | |
Public Member Functions inherited from ossim2dTo2dTransform | |
| virtual const ossim2dTo2dTransform & | operator= (const ossim2dTo2dTransform &rhs) |
| virtual ossimDpt | getOrigin () const |
| void | setConvergenceThreshold (const double &new_threshold) |
| void | setMaxIterations (int new_max_iters) |
| void | setDxDy (const ossimDpt &dxdy) |
| ossimObject () | |
| virtual | ~ossim2dTo2dShiftTransform () |
Protected Member Functions inherited from ossim2dTo2dTransform | |
| ossim2dTo2dTransform () | |
| virtual | ~ossim2dTo2dTransform () |
Protected Attributes | |
| ossimDpt | m_shift |
| TYPE_DATA | |
Protected Attributes inherited from ossim2dTo2dTransform | |
| double | theConvergenceThreshold |
| int | theMaxIterations |
| ossimDpt | theDxDy |
Definition at line 13 of file ossim2dTo2dShiftTransform.h.
inline |
Definition at line 19 of file ossim2dTo2dShiftTransform.h.
inline |
Copy constructor.
Definition at line 27 of file ossim2dTo2dShiftTransform.h.
inlineprotectedvirtual |
Definition at line 120 of file ossim2dTo2dShiftTransform.h.
inlinevirtual |
Definition at line 35 of file ossim2dTo2dShiftTransform.h.
inlinevirtual |
| input | The value to shift. |
| output | the shifted value. |
Implements ossim2dTo2dTransform.
Definition at line 57 of file ossim2dTo2dShiftTransform.h.
inlinevirtual |
| modify_this | The value to shift. The result is placed back into this value. |
Reimplemented from ossim2dTo2dTransform.
Definition at line 67 of file ossim2dTo2dShiftTransform.h.
References ossimDpt::x, and ossimDpt::y.
inlinevirtual |
| input | The value to apply the negated shift. |
Definition at line 79 of file ossim2dTo2dShiftTransform.h.
inlinevirtual |
Definition at line 90 of file ossim2dTo2dShiftTransform.h.
Definition at line 13 of file ossim2dTo2dShiftTransform.cpp.
References ossimString::empty(), ossimKeywordlist::find(), ossim2dTo2dTransform::loadState(), m_shift, and ossimDpt::toPoint().
inline |
The = is passed to the derived class.
Definition at line 41 of file ossim2dTo2dShiftTransform.h.
References m_shift, and ossim2dTo2dTransform::operator=().
inlinevirtual |
Definition at line 110 of file ossim2dTo2dShiftTransform.h.
References ossim2dTo2dTransform::print().
Definition at line 4 of file ossim2dTo2dShiftTransform.cpp.
References ossimKeywordlist::add(), m_shift, ossim2dTo2dTransform::saveState(), and ossimDpt::toString().
protected |
Definition at line 122 of file ossim2dTo2dShiftTransform.h.
Referenced by loadState(), operator=(), and saveState().
protected |
Definition at line 124 of file ossim2dTo2dShiftTransform.h.
