Utility class for generating point-cloud-derived image products. More...
#include <ossimPointCloudTool.h>
| ossimPointCloudTool () | |
| ~ossimPointCloudTool () | |
| bool | initialize (ossimArgumentParser &ap) override |
| Initializes from command line arguments. More... | |
| void | loadJSON (const Json::Value &json_request) override |
| Reads processing params from JSON object provided. More... | |
| void | saveJSON (Json::Value &json) const override |
| Fetch product as JSON object when applicable Always returns true since using exception on error. More... | |
| virtual bool | execute () override |
| Writes product to output file if applicable. More... | |
Public Member Functions inherited from ossimTool | |
| ossimTool () | |
| virtual | ~ossimTool () |
| virtual void | initialize (const ossimKeywordlist &kwl) |
| Reads processing params from KWL and prepares for execute. More... | |
| virtual const std::string & | getResponse () const |
| Fetch product as string (typically JSON) when applicable, otherwise passes back empty string. More... | |
| virtual void | clear () |
| Disconnects and clears the DEM and image layers. More... | |
| virtual void | abort () |
| Kills current (asynchronous) process. More... | |
| virtual void | getKwlTemplate (ossimKeywordlist &kwl) |
| Assigns a template keywordlist to string for initializing derived classes. More... | |
| void | getAPI (std::string &out) const |
| Outputs a JSON representation of the Utility's API. More... | |
| std::string | getAPI () const |
| void | getBuildDate (std::string &s) const |
| Gets build date. More... | |
| void | getRevision (std::string &s) const |
| Gets revision. More... | |
| void | getVersion (std::string &s) const |
| Gets version. More... | |
| virtual bool | isChipProcessor () const |
| Overrides base class implementation to indicate this class supports getChip() calls. More... | |
| void | setOutputStream (std::ostream *os) |
| Redirects any console output to the supplied stream for logging or JNI application. More... | |
| bool | helpRequested () const |
| Returns true when the initialization detects a "--help" option, so caller can avoid subsequent execute() call. More... | |
| ossimObject () | |
Public Member Functions inherited from ossim::JsonInterface | |
| JsonInterface () | |
| virtual | ~JsonInterface () |
Protected Types | |
| enum | Operation { HIGHEST_DEM, LOWEST_DEM, HIGHEST_LOWEST } |
| bool | initialize () |
| void | setGSD (const double &meters_per_pixel) |
| void | usage (ossimArgumentParser &ap) |
| void | addArguments (ossimArgumentParser &ap) |
| bool | loadPC () |
| bool | loadDem () |
Protected Member Functions inherited from ossimTool | |
| virtual void | setUsage (ossimArgumentParser &ap) |
| Initializes the aurgument parser with expected parameters and options. More... | |
Protected Attributes | |
| enum ossimPointCloudTool::Operation | m_operation |
| ossimRefPtr< ossimImageGeometry > | m_prodGeom |
| ossimRefPtr< ossimPointCloudHandler > | m_pcHandler |
| ossimRefPtr< ossimPointCloudImageHandler > | m_pciHandler |
| ossimRefPtr< ossimPointCloudUtilityFilter > | m_pcuFilter |
| double | m_gsd |
| ossimFilename | m_lutFile |
| ossimFilename | m_prodFile |
| ossimFilename | m_demFile |
| ossimFilename | m_pcFile |
Protected Attributes inherited from ossimTool | |
| ossimKeywordlist | m_kwl |
| std::ostream * | m_consoleStream |
| bool | m_helpRequested |
| std::string | m_response |
Friends | |
| class | ossimPointCloudUtilityFilter |
Definition at line 26 of file ossimPointCloudTool.h.
protected |
| Enumerator | |
| HIGHEST_DEM | |
| LOWEST_DEM | |
| HIGHEST_LOWEST | |
Definition at line 47 of file ossimPointCloudTool.h.
| ossimPointCloudTool::ossimPointCloudTool | ( | ) |
Definition at line 27 of file ossimPointCloudTool.cpp.
| ossimPointCloudTool::~ossimPointCloudTool | ( | ) |
Definition at line 33 of file ossimPointCloudTool.cpp.
References m_pcHandler, m_pcuFilter, and m_prodGeom.
protected |
Definition at line 40 of file ossimPointCloudTool.cpp.
References ossimApplicationUsage::addCommandLineOption(), ossimArgumentParser::getApplicationName(), ossimArgumentParser::getApplicationUsage(), and ossimApplicationUsage::setCommandLineUsage().
Referenced by usage().
overridevirtual |
The product may also beAlways returns true since using exception on error.
Implements ossimTool.
Definition at line 234 of file ossimPointCloudTool.cpp.
References ossimKeywordlist::addFile(), ossimConnectableObject::connectMyInputTo(), ossimImageWriterFactoryRegistry::createWriter(), ossimString::empty(), ossimImageFileWriter::execute(), ossimRefPtr< T >::get(), ossimIndexToRgbLutFilter::initialize(), ossimImageWriterFactoryRegistry::instance(), ossimIndexToRgbLutFilter::loadState(), m_lutFile, m_pcuFilter, m_prodFile, ossimNotify(), ossimNotifyLevel_WARN, and ossimRefPtr< T >::valid().
overridevirtual |
This base class has some common arguments to read. The derived class should call this implementation in addition to setting its own arguments.
| ap | Represents command line. |
Reimplemented from ossimTool.
Definition at line 95 of file ossimPointCloudTool.cpp.
References ossimArgumentParser::argc(), ossimString::contains(), HIGHEST_DEM, HIGHEST_LOWEST, initialize(), m_demFile, m_gsd, m_lutFile, m_operation, m_pcFile, m_prodFile, ossimArgumentParser::read(), ossimString::toDouble(), and usage().
protected |
Definition at line 159 of file ossimPointCloudTool.cpp.
References ossimString::empty(), loadDem(), loadPC(), m_demFile, m_pcFile, m_pcuFilter, ossimNotify(), ossimNotifyLevel_WARN, and ossimPointCloudUtilityFilter.
Referenced by initialize().
protected |
Definition at line 201 of file ossimPointCloudTool.cpp.
References ossimElevManager::addDatabase(), ossimElevManager::clear(), ossimRefPtr< T >::get(), ossimElevManager::instance(), m_demFile, ossim::nan(), ossimImageElevationDatabase::open(), ossimNotify(), ossimNotifyLevel_WARN, ossimElevManager::setDefaultHeightAboveEllipsoid(), and ossimElevManager::setUseGeoidIfNullFlag().
overridevirtual |
If all good, the object is ready for subsequent call to execute().
Definition at line 154 of file ossimPointCloudTool.cpp.
protected |
Definition at line 176 of file ossimPointCloudTool.cpp.
References ossimRefPtr< T >::get(), ossimImageGeometry::getAsMapProjection(), ossimPointCloudImageHandler::getImageGeometry(), ossimPointCloudHandlerRegistry::instance(), m_gsd, m_pcFile, m_pcHandler, m_pciHandler, m_prodGeom, ossimPointCloudHandlerRegistry::open(), ossimNotify(), ossimNotifyLevel_WARN, ossimMapProjection::setMetersPerPixel(), ossimPointCloudImageHandler::setPointCloudHandler(), and ossimRefPtr< T >::valid().
overridevirtual |
| json | Returns non-empty object if valid response available. |
Definition at line 272 of file ossimPointCloudTool.cpp.
protected |
Definition at line 225 of file ossimPointCloudTool.cpp.
References ossimImageGeometry::getAsMapProjection(), m_gsd, m_prodGeom, and ossimMapProjection::setMetersPerPixel().
protected |
Definition at line 79 of file ossimPointCloudTool.cpp.
References addArguments(), ossimInit::addOptions(), ossimArgumentParser::getApplicationUsage(), ossimInit::instance(), ossimNotify(), ossimNotifyLevel_INFO, and ossimApplicationUsage::write().
friend |
Definition at line 28 of file ossimPointCloudTool.h.
protected |
Definition at line 55 of file ossimPointCloudTool.h.
Referenced by initialize(), and loadDem().
protected |
Definition at line 52 of file ossimPointCloudTool.h.
Referenced by initialize(), loadPC(), and setGSD().
protected |
Definition at line 53 of file ossimPointCloudTool.h.
Referenced by execute(), and initialize().
protected |
Referenced by ossimPointCloudUtilityFilter::getTile(), and initialize().
protected |
Definition at line 56 of file ossimPointCloudTool.h.
Referenced by initialize(), and loadPC().
protected |
Definition at line 49 of file ossimPointCloudTool.h.
Referenced by loadPC(), and ~ossimPointCloudTool().
protected |
Definition at line 50 of file ossimPointCloudTool.h.
Referenced by ossimPointCloudUtilityFilter::getTile(), and loadPC().
protected |
Definition at line 51 of file ossimPointCloudTool.h.
Referenced by execute(), initialize(), and ~ossimPointCloudTool().
protected |
Definition at line 54 of file ossimPointCloudTool.h.
protected |
Definition at line 48 of file ossimPointCloudTool.h.
Referenced by ossimPointCloudUtilityFilter::getImageGeometry(), ossimPointCloudUtilityFilter::getTile(), loadPC(), setGSD(), and ~ossimPointCloudTool().
