| virtual | ~ossimPointCloudHandlerRegistry () |
| virtual ossimPointCloudHandler * | open (const ossimFilename &fileName) const |
| virtual ossimPointCloudHandler * | open (const ossimKeywordlist &kwl, const char *prefix=0) const |
| virtual ossimRefPtr< ossimPointCloudHandler > | open (std::istream *str, std::streamoff restartPosition, bool youOwnIt) const |
| virtual ossimObject * | createObject (const ossimString &typeName) const |
| virtual ossimObject * | createObject (const ossimKeywordlist &kwl, const char *prefix=0) const |
| virtual void | getTypeNameList (std::vector< ossimString > &typeList) const |
| virtual | ~ossimObjectFactory () |
| | ossimObject () |
| | Generic print method. More...
| | ossimReferenced () |
| | ossimReferenced (const ossimReferenced &) |
| | increment the reference count by one, indicating that this object has another pointer which is referencing it. More...
| | decrement the reference count by one, indicating that a pointer to this object is referencing it. More...
| | ossimFactoryListInterface () |
| void | addFactory (ossimPointCloudHandlerFactory *factory) |
| | This is for backward compatability and calls registerFactory for simple adds. More...
| bool | isFactoryRegistered (ossimPointCloudHandlerFactory *factory) const |
| | Public access method to determine if a factory is already registered to this list. More...
| void | registerFactory (ossimPointCloudHandlerFactory *factory, bool pushToFrontFlag=false) |
| | Will register a factory to the factory list. More...
| void | unregisterFactory (ossimPointCloudHandlerFactory *factory) |
| | Will remove the factory from the registry. More...
| void | unregisterFactory (const ossimString &factoryTypeName) |
| | Will remove the factory from the registry by name. More...
| void | unregisterAllFactories () |
| | Will remove all factories from the registry. More...
| void | registerFactoryToFront (ossimPointCloudHandlerFactory *factory) |
| | Inserts the factory to the front of the list. More...
| void | registerFactoryBefore (ossimPointCloudHandlerFactory *factory, ossimPointCloudHandlerFactory *beforeThisFactory) |
| | Will insert the factory before the beforeThisFactory. More...
| void | getAllTypeNamesFromRegistry (std::vector< ossimString > &typeList) const |
| | Will add all object types the factories can allocate. More...
| ossimObject * | createObjectFromRegistry (const ossimString &typeName) const |
| | This is the base object return for all objects in the system. More...
| ossimObject * | createObjectFromRegistry (const ossimKeywordlist &kwl, const char *prefix=0) const |
| ossimPointCloudHandler * | createNativeObjectFromRegistry (const ossimString &typeName) const |
| | This is a helper method that calls the createObject and makes sure that the returned object is of the NativeType base type this registry supports. More...
| ossimPointCloudHandler * | createNativeObjectFromRegistry (const ossimKeywordlist &kwl, const char *prefix=0) const |
