Class to handle transforming image points, rectangles, and offsets from one reduced resolution data set (rrds) level to another. More...
#include <ossimImageModel.h>
| ossimImageModel () | |
| virtual void | initialize (const ossimImageHandler &ih) |
| Method to initialize class from an image handler. More... | |
| void | rnToR0 (ossim_uint32 rrds, const ossimDpt &rnPt, ossimDpt &r0Pt) const |
| Get r0 point from rn point. More... | |
| void | rnToR0 (const ossimDpt &rnPt, ossimDpt &r0Pt) const |
| void | r0ToRn (ossim_uint32 rrds, const ossimDpt &r0Pt, ossimDpt &rnPt) const |
| Get rn point from r0 point. More... | |
| void | r0ToRn (const ossimDpt &r0Pt, ossimDpt &rnPt) const |
| void | getSubImageOffset (ossim_uint32 rrds, ossimDpt &offset) const |
| Get the sub image offset for a given resolution level. More... | |
| void | getImageRectangle (ossim_uint32 rrds, ossimDrect &rect) const |
| Gets the zero-based image rectangle for a given reduced resolution data set. More... | |
| void | getBoundingRectangle (ossim_uint32 rrds, ossimDrect &rect) const |
| Gets the model-based image rectangle for a given reduced resolution data set. More... | |
| ossim_uint32 | getNumberOfDecimationLevels () const |
| void | setTargetRrds (ossim_uint32 rrds) |
| Set theTargetRrds data member. More... | |
| ossim_uint32 | getTargetRrds () const |
| ossimObject () | |
| virtual | ~ossimImageModel () |
Protected Attributes | |
| ossimDpt | theSubImageOffset |
| Offset from the full image. More... | |
| std::vector< ossimDpt > | theDecimationFactors |
| Decimation factors for each rrds level. More... | |
| ossim_uint32 | theLines |
| ossim_uint32 | theSamples |
| ossim_uint32 | theTargetRrds |
Derived from ossimObject only so users can pass via the ossimViewInterface::setView method.
Definition at line 33 of file ossimImageModel.h.
| ossimImageModel::ossimImageModel | ( | ) |
default constructor
Definition at line 23 of file ossimImageModel.cpp.
protectedvirtual |
| void ossimImageModel::getBoundingRectangle | ( | ossim_uint32 | rrds, |
| ossimDrect & | rect | ||
| ) | const |
If this image is a sub image the offset is applied. So if the image has a sub image offset of (1024, 1024), and has 1024 lines and 1024 samples the rectangle for r0 will be: (1024, 1024) (2047, 2047)
| rrds | The reduced resolution data set. |
| rect | Initialized with image rectangle for rrds. |
Definition at line 118 of file ossimImageModel.cpp.
References theDecimationFactors, theLines, theSamples, theSubImageOffset, ossimDpt::x, and ossimDpt::y.
| void ossimImageModel::getImageRectangle | ( | ossim_uint32 | rrds, |
| ) | const |
Definition at line 101 of file ossimImageModel.cpp.
References theDecimationFactors, theLines, and theSamples.
| ossim_uint32 ossimImageModel::getNumberOfDecimationLevels | ( | ) | const |
Definition at line 138 of file ossimImageModel.cpp.
References theDecimationFactors.
| void ossimImageModel::getSubImageOffset | ( | ossim_uint32 | rrds, |
| ossimDpt & | offset | ||
| ) | const |
| offset | the Point to initialize. |
Definition at line 86 of file ossimImageModel.cpp.
References theDecimationFactors, theSubImageOffset, ossimDpt::x, and ossimDpt::y.
| ossim_uint32 ossimImageModel::getTargetRrds | ( | ) | const |
Definition at line 148 of file ossimImageModel.cpp.
References theTargetRrds.
| ih | Image handler. |
Reimplemented in ossimImageProjectionModel.
Definition at line 37 of file ossimImageModel.cpp.
References ossimImageHandler::getDecimationFactors(), ossimImageHandler::getNumberOfLines(), ossimImageHandler::getNumberOfSamples(), theDecimationFactors, theLines, theSamples, and theSubImageOffset.
Referenced by ossimImageProjectionModel::initialize().
| void ossimImageModel::r0ToRn | ( | ossim_uint32 | rrds, |
| const ossimDpt & | r0Pt, | ||
| ossimDpt & | rnPt | ||
| ) | const |
| rrds | Target (rnPt) reduced resolution data set. |
| r0Pt | The image point to tranform. |
| rnPt | the Point to initialize. |
Definition at line 65 of file ossimImageModel.cpp.
References theDecimationFactors, ossimDpt::x, and ossimDpt::y.
Referenced by r0ToRn().
This requires calling setTargetRrds(ossim_uint32 rrds) to the level for rnPt.
Definition at line 81 of file ossimImageModel.cpp.
References r0ToRn(), and theTargetRrds.
| void ossimImageModel::rnToR0 | ( | ossim_uint32 | rrds, |
| const ossimDpt & | rnPt, | ||
| ossimDpt & | r0Pt | ||
| ) | const |
| rrds | Source (rnPt) reduced resolution data set. |
| rnPt | The image point to tranform. |
| r0Pt | the Point to initialize. |
Definition at line 45 of file ossimImageModel.cpp.
Referenced by rnToR0().
Definition at line 60 of file ossimImageModel.cpp.
References rnToR0(), and theTargetRrds.
| void ossimImageModel::setTargetRrds | ( | ossim_uint32 | rrds | ) |
This is used by methods rnToR0 and r0ToRn that do not take a rrds argument.
| rrds | Target reduced resolution data set. |
Definition at line 143 of file ossimImageModel.cpp.
protected |
Definition at line 180 of file ossimImageModel.h.
Referenced by getBoundingRectangle(), getImageRectangle(), getNumberOfDecimationLevels(), getSubImageOffset(), initialize(), r0ToRn(), and rnToR0().
protected |
Definition at line 182 of file ossimImageModel.h.
Referenced by getBoundingRectangle(), getImageRectangle(), and initialize().
protected |
Definition at line 183 of file ossimImageModel.h.
protected |
Definition at line 177 of file ossimImageModel.h.
Referenced by getBoundingRectangle(), getSubImageOffset(), and initialize().
protected |
Definition at line 184 of file ossimImageModel.h.
Referenced by getTargetRrds(), r0ToRn(), rnToR0(), and setTargetRrds().
