Class derived from ossimImageModel, this adds an image projection for lineSampleToWorld and worldToLineSample. More...
#include <ossimImageProjectionModel.h>
| ossimImageProjectionModel () | |
| virtual void | initialize (const ossimImageHandler &ih) |
| Method to initialize class from an image handler. More... | |
| const ossimProjection * | getProjection () const |
| Method to get projection. More... | |
Public Member Functions inherited from ossimImageModel | |
| ossimImageModel () | |
| void | rnToR0 (ossim_uint32 rrds, const ossimDpt &rnPt, ossimDpt &r0Pt) const |
| Get r0 point from rn point. More... | |
| void | rnToR0 (const ossimDpt &rnPt, ossimDpt &r0Pt) const |
| void | r0ToRn (ossim_uint32 rrds, const ossimDpt &r0Pt, ossimDpt &rnPt) const |
| Get rn point from r0 point. More... | |
| void | r0ToRn (const ossimDpt &r0Pt, ossimDpt &rnPt) const |
| void | getSubImageOffset (ossim_uint32 rrds, ossimDpt &offset) const |
| Get the sub image offset for a given resolution level. More... | |
| void | getImageRectangle (ossim_uint32 rrds, ossimDrect &rect) const |
| Gets the zero-based image rectangle for a given reduced resolution data set. More... | |
| void | getBoundingRectangle (ossim_uint32 rrds, ossimDrect &rect) const |
| Gets the model-based image rectangle for a given reduced resolution data set. More... | |
| ossim_uint32 | getNumberOfDecimationLevels () const |
| void | setTargetRrds (ossim_uint32 rrds) |
| Set theTargetRrds data member. More... | |
| ossim_uint32 | getTargetRrds () const |
| ossimObject () | |
| virtual | ~ossimImageProjectionModel () |
Protected Member Functions inherited from ossimImageModel | |
| virtual | ~ossimImageModel () |
Protected Attributes | |
| ossimProjection * | theProjection |
Protected Attributes inherited from ossimImageModel | |
| ossimDpt | theSubImageOffset |
| Offset from the full image. More... | |
| std::vector< ossimDpt > | theDecimationFactors |
| Decimation factors for each rrds level. More... | |
| ossim_uint32 | theLines |
| ossim_uint32 | theSamples |
| ossim_uint32 | theTargetRrds |
Note that image points fed to projection methods should be full resolution with any sub image offset applied.
Definition at line 30 of file ossimImageProjectionModel.h.
| ossimImageProjectionModel::ossimImageProjectionModel | ( | ) |
default constructor
protectedvirtual |
virtual destructor
Definition at line 30 of file ossimImageProjectionModel.cpp.
References theProjection.
| const ossimProjection * ossimImageProjectionModel::getProjection | ( | ) | const |
Definition at line 51 of file ossimImageProjectionModel.cpp.
| ih | Image handler. |
Reimplemented from ossimImageModel.
Definition at line 35 of file ossimImageProjectionModel.cpp.
References ossimImageHandler::getImageGeometry(), ossimImageGeometry::getProjection(), ossimImageModel::initialize(), theProjection, and ossimRefPtr< T >::valid().
protected |
Definition at line 56 of file ossimImageProjectionModel.h.
Referenced by getProjection(), initialize(), and ~ossimImageProjectionModel().
