Go to the source code of this file.
| void * | vpfmalloc (unsigned long size) |
| void | vpffree (void *ptr) |
| void | displaymessage (char *,...) |
| void | displayinfo (char *text[], int nlines) |
| void | no_study_area (void) |
| void | no_map_displayed (void) |
| void | display_message (char *str) |
| dms_type | float_to_dms (double coord) |
| double | dms_to_float (dms_type coord) |
| char * | dms_string (dms_type coord, int seconds) |
| void | out_dms (dms_type coord, int x, int y, int dir, int seconds) |
| int | strpos (char *str, char ch) |
| VPF_BOOLEAN | fwithin (float x, float y, extent_type extent) |
| VPF_BOOLEAN | contained (extent_type extent1, extent_type extent2) |
| void | memleft (void) |
| char * | strupr (char *str) |
| float | distance (double lat1, double lon1, double lat2, double lon2, int units) |
| char * | rightjust (char *str) |
| char * | leftjust (char *str) |
| VPF_BOOLEAN | displayerror (char *text[], int nlines) |
| int | printer_ready (void) |
| int | printer_ok (void) |
| int | is_primitive (char *name) |
| int | is_simple_feature (char *name) |
| int | is_complex_feature (char *name) |
| int | is_feature (char *name) |
| int | feature_type (char *name) |
| int | is_join (char *name) |
| int | primitive_class (char *name) |
| int | ossim_strcasecmp (const char *s1, const char *s2) |
| | Written to replace non-portable "strcasecmp". More...
| int | ossim_strncasecmp (const char *s1, const char *s2, unsigned int n) |
| | Written to replace non-portable "strncasecmp". More...
◆ graphic_mode
| #define graphic_mode |
( (getgraphmode() < 0) ? 0 : 1) |
◆ contained()
◆ display_message()
| void display_message |
char * |
str | ) |
◆ displayerror()
◆ displayinfo()
| void displayinfo |
char * |
text[], |
int |
nlines |
◆ displaymessage()
| void displaymessage |
char * |
◆ distance()
| float distance |
double |
lat1, |
double |
lon1, |
double |
lat2, |
double |
lon2, |
int |
units |
◆ dms_string()
| char* dms_string |
dms_type |
coord, |
int |
seconds |
◆ dms_to_float()
◆ feature_type()
| int feature_type |
char * |
name | ) |
◆ float_to_dms()
◆ fwithin()
◆ is_complex_feature()
| int is_complex_feature |
char * |
name | ) |
◆ is_feature()
| int is_feature |
char * |
name | ) |
◆ is_join()
| int is_join |
char * |
name | ) |
◆ is_primitive()
| int is_primitive |
char * |
name | ) |
◆ is_simple_feature()
| int is_simple_feature |
char * |
name | ) |
◆ leftjust()
| char* leftjust |
char * |
str | ) |
◆ memleft()
◆ no_map_displayed()
| void no_map_displayed |
void |
◆ no_study_area()
| void no_study_area |
void |
◆ ossim_strcasecmp()
| int ossim_strcasecmp |
const char * |
s1, |
const char * |
s2 |
- Returns
- An integer -1, 0, or 1 if s1 is found, respectively, to be less than, to match, or be greater than s2.
◆ ossim_strncasecmp()
| int ossim_strncasecmp |
const char * |
s1, |
const char * |
s2, |
unsigned int |
n |
Similar to ossim_strcasecmp, except it only compares the first n characters.
- Returns
◆ out_dms()
| void out_dms |
dms_type |
coord, |
int |
x, |
int |
y, |
int |
dir, |
int |
seconds |
◆ primitive_class()
| int primitive_class |
char * |
name | ) |
◆ printer_ok()
◆ printer_ready()
| int printer_ready |
void |
◆ rightjust()
| char* rightjust |
char * |
str | ) |
◆ strpos()
| int strpos |
char * |
str, |
char |
ch |
◆ strupr()
| char* strupr |
char * |
str | ) |
◆ vpffree()
| void vpffree |
void * |
ptr | ) |
◆ vpfmalloc()
| void* vpfmalloc |
unsigned long |
size | ) |
