Private class representing a getTile job. More...
#include <ossimMultiThreadSequencer.h>
| ossimGetTileJob (ossim_uint32 tile_id, ossim_uint32 chain_id, ossimMultiThreadSequencer &sequencer) | |
Public Member Functions inherited from ossimJob | |
| ossimJob () | |
| virtual void | start () |
| Main entry point to the job. More... | |
| std::shared_ptr< ossimJob > | getSharedFromThis () |
| This is a convenience method to get the shared representation of this pointer. More... | |
| std::shared_ptr< const ossimJob > | getSharedFromThis () const |
| void | setPercentComplete (double value) |
| When the pernet complete is set for the job it will call any callbacks and nofity percentCompleteChanged. More... | |
| void | setPriority (double value) |
| sets the priority of the job More... | |
| double | priority () const |
| virtual void | release () |
| If derived interfaces implement a block this will allow one to release. More... | |
| State | state () const |
| virtual void | resetState (int value) |
| Will clear out the state and the call setState. More... | |
| virtual void | setState (int value, bool on=true) |
| Will allow you to set the state of the job. More... | |
| bool | isCanceled () const |
| virtual void | cancel () |
| Sets the state if the object as cancelled. More... | |
| virtual void | ready () |
| Sets the state if the object as ready. More... | |
| virtual void | running () |
| Sets the state if the object as running. More... | |
| virtual void | finished () |
| Sets the state if the object as finished. More... | |
| bool | isReady () const |
| bool | isStopped () const |
| bool | isFinished () const |
| bool | isRunning () const |
| void | setCallback (std::shared_ptr< ossimJobCallback > callback) |
| void | setName (const ossimString &value) |
| Sets the name of a job. More... | |
| const ossimString & | name () const |
| void | setId (const ossimString &value) |
| const ossimString & | id () const |
| void | setDescription (const ossimString &value) |
| const ossimString & | description () const |
| std::shared_ptr< ossimJobCallback > | callback () |
| virtual void | run () |
| Abstract method and must be overriden by the base class. More... | |
Private Attributes | |
| ossim_uint32 | m_tileID |
| ossim_uint32 | m_chainID |
| ossimMultiThreadSequencer & | m_sequencer |
| bool | t_launchNewJob |
Friends | |
| class | ossimMultiThreadSequencer |
Public Types inherited from ossimJob | |
| enum | State { ossimJob_NONE = 0, ossimJob_READY = 1, ossimJob_RUNNING = 2, ossimJob_CANCEL = 4, ossimJob_FINISHED = 8, ossimJob_ALL = (ossimJob_READY|ossimJob_RUNNING|ossimJob_CANCEL|ossimJob_FINISHED) } |
This is a Bit vector. More... | |
| typedef std::list< std::shared_ptr< ossimJob > > | List |
Protected Attributes inherited from ossimJob | |
| std::mutex | m_jobMutex |
| ossimString | m_name |
| ossimString | m_description |
| ossimString | m_id |
| State | m_state |
| double | m_priority |
| std::shared_ptr< ossimJobCallback > | m_callback |
Definition at line 78 of file ossimMultiThreadSequencer.h.
inline |
Definition at line 81 of file ossimMultiThreadSequencer.h.
protectedvirtual |
The base ossimJob will call run from the start method after setting some variables.
Implements ossimJob.
Definition at line 27 of file ossimMultiThreadSequencer.cpp.
References ossimMultiThreadSequencer::d_debugEnabled, ossimImageData::dup(), ossimJob::finished(), ossimImageChainMtAdaptor::getClone(), ossimImageSource::getTile(), ossimImageSourceSequencer::getTileRect(), ossimTimer::instance(), m_chainID, ossimMultiThreadSequencer::m_getTileBlock, ossimMultiThreadSequencer::m_inputChain, m_sequencer, m_tileID, ossimMultiThreadSequencer::nextJob(), ossimMultiThreadSequencer::print(), ossim::Block::release(), ossimJob::running(), ossimImageData::setImageRectangle(), ossimMultiThreadSequencer::setTileInCache(), t_launchNewJob, ossimImageSourceSequencer::theBlankTile, ossimTimer::time_s(), and ossimRefPtr< T >::valid().
friend |
Definition at line 95 of file ossimMultiThreadSequencer.h.
private |
Definition at line 91 of file ossimMultiThreadSequencer.h.
Referenced by run().
private |
Definition at line 92 of file ossimMultiThreadSequencer.h.
private |
Definition at line 90 of file ossimMultiThreadSequencer.h.
private |
Definition at line 94 of file ossimMultiThreadSequencer.h.
