ossimKakaduNitfOverviewBuilder Class to build overviews from the Kakadu library. More...
#include <ossimKakaduNitfOverviewBuilder.h>
| ossimKakaduNitfOverviewBuilder () | |
| virtual | ~ossimKakaduNitfOverviewBuilder () |
| virtual bool | execute () |
| Builds the overviews. More... | |
| virtual void | setOutputFile (const ossimFilename &file) |
| Sets the output filename. More... | |
| virtual ossimFilename | getOutputFile () const |
| Returns the output. More... | |
| virtual bool | setOverviewType (const ossimString &type) |
| Sets the overview output type. More... | |
| virtual ossimString | getOverviewType () const |
| Gets the overview type. More... | |
| virtual void | getTypeNameList (std::vector< ossimString > &typeList) const |
| Method to populate class supported types. More... | |
| virtual bool | canConnectMyInputTo (ossim_int32 index, const ossimConnectableObject *obj) const |
| Method to set properties. More... | |
| Method to populate the list of property names. More... | |
| print method. More... | |
Public Member Functions inherited from ossimOverviewBuilderBase | |
| ossimOverviewBuilderBase () | |
| virtual bool | setOutputWriter (ossimImageFileWriter *outputWriter) |
| Sets an optional file writer to the builder. More... | |
| virtual bool | setInputSource (ossimImageHandler *imageSource) |
| Sets the input to the builder. More... | |
| virtual bool | hasOverviewType (const ossimString &type) const |
| Method to check if builder can handle type. More... | |
| virtual ossim_uint32 | getOverviewStopDimension () const |
| Get the overview stop dimension. More... | |
| virtual void | setOverviewStopDimension (ossim_uint32 dim) |
| Sets the overview stop dimension. More... | |
| ossimHistogramMode | getHistogramMode () const |
| Gets the histogram accumulation mode. More... | |
| void | setHistogramMode (ossimHistogramMode mode) |
| Sets the histogram accumulation mode. More... | |
| virtual void | finalize () |
| Finalize method. More... | |
| void | setBitMaskSpec (const ossimKeywordlist &bit_mask_spec) |
| Specifies parameters (in KWL) for generation of an alpha (bit) mask such that any full or partial null pixels will be masked out. More... | |
| void | setScanForMinMax (bool flag) |
| Turn on/off scan for min max flag. More... | |
| bool | getScanForMinMax () const |
| void | setScanForMinMaxNull (bool flag) |
| Turn on/off scan for min, max, null flag. More... | |
| bool | getScanForMinMaxNull () const |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
Public Member Functions inherited from ossimProcessInterface | |
| ossimProcessInterface () | |
| virtual | ~ossimProcessInterface () |
| virtual void | abort () |
| bool | needsAborting () const |
| bool | isAbortRequested () const |
| bool | isAborted () const |
| bool | isExecuting () const |
| ossimProcessStatus | getProcessStatus () const |
| virtual void | setProcessStatus (ossimProcessStatus processStatus) |
| virtual double | getPercentComplete () const |
| virtual void | setPercentComplete (double percentComplete) |
| virtual ossimListenerManager * | getManager () |
| void | enableEvents () |
| void | disableEvents () |
| void | setCurrentMessage (const ossimString &message) |
| ProcessEvent. More... | |
| virtual void | disconnectInputEvent (ossimConnectionEvent &) |
| virtual void | connectInputEvent (ossimConnectionEvent &) |
| virtual void | propertyEvent (ossimPropertyEvent &) |
| virtual void | refreshEvent (ossimRefreshEvent &) |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
Private Member Functions | |
| void | setImagField (ossimNitfImageHeaderV2_1 *hdr, ossim_uint32 startingResLevel) const |
| Set the Image Magnification (IMAG) field in the form of "/2 ". More... | |
Private Attributes | |
| ossimFilename | m_outputFile |
| ossimFilename | m_outputFileTmp |
| ossimKakaduCompressor * | m_compressor |
Definition at line 32 of file ossimKakaduNitfOverviewBuilder.h.
| ossimKakaduNitfOverviewBuilder::ossimKakaduNitfOverviewBuilder | ( | ) |
default constructor
Definition at line 66 of file ossimKakaduNitfOverviewBuilder.cpp.
virtual destructor
Definition at line 90 of file ossimKakaduNitfOverviewBuilder.cpp.
References m_compressor, and ossimOverviewBuilderBase::m_imageHandler.
Implements ossimConnectableObject.
Definition at line 748 of file ossimKakaduNitfOverviewBuilder.cpp.
References PTR_CAST.
Implements ossimOverviewBuilderBase.
Definition at line 149 of file ossimKakaduNitfOverviewBuilder.cpp.
Implements ossimProcessInterface.
Definition at line 738 of file ossimKakaduNitfOverviewBuilder.cpp.
Definition at line 743 of file ossimKakaduNitfOverviewBuilder.cpp.
Returns the output.
This will be derived from the input file if not explicitly set.
Definition at line 106 of file ossimKakaduNitfOverviewBuilder.cpp.
References ossimImageHandler::getNumberOfEntries(), ossimOverviewBuilderBase::m_imageHandler, m_outputFile, ossimFilename::NIL, and ossimRefPtr< T >::valid().
Satisfies pure virtual from ossimOverviewBuilderInterface.
Definition at line 137 of file ossimKakaduNitfOverviewBuilder.cpp.
| propertyNames | List to populate. This does not clear the list just adds to it. |
Definition at line 725 of file ossimKakaduNitfOverviewBuilder.cpp.
References ossimKakaduCompressor::getPropertyNames(), and m_compressor.
| typeList | List of ossimStrings to add to. |
Definition at line 142 of file ossimKakaduNitfOverviewBuilder.cpp.
print method.
Reimplemented from ossimProcessInterface.
Definition at line 731 of file ossimKakaduNitfOverviewBuilder.cpp.
private |
| hdr | The nitf image header. |
| starting | resolution level. |
Definition at line 761 of file ossimKakaduNitfOverviewBuilder.cpp.
References ossimNitfImageHeaderV2_1::setImageMagnification(), ossimString::size(), and ossimString::toString().
| file | The output file name. |
Definition at line 101 of file ossimKakaduNitfOverviewBuilder.cpp.
References m_outputFile.
Currently handled types are: "ossim_tiff_nearest" and "ossim_tiff_box"
| type | This should be the string representing the type. This method will do nothing if type is not handled and return false. |
Definition at line 121 of file ossimKakaduNitfOverviewBuilder.cpp.
| property | Property to set. |
Definition at line 716 of file ossimKakaduNitfOverviewBuilder.cpp.
References m_compressor, ossimKakaduCompressor::setProperty(), and ossimRefPtr< T >::valid().
private |
Definition at line 150 of file ossimKakaduNitfOverviewBuilder.h.
Referenced by getPropertyNames(), setProperty(), and ~ossimKakaduNitfOverviewBuilder().
private |
Definition at line 148 of file ossimKakaduNitfOverviewBuilder.h.
Referenced by getOutputFile(), and setOutputFile().
private |
Definition at line 149 of file ossimKakaduNitfOverviewBuilder.h.
