#include <ossimKakaduCompressorInterface.h>
Public Types | |
| enum | ossimKakaduCompressionQuality { OKP_UNKNOWN = 0, OKP_USER_DEFINED = 1, OKP_NUMERICALLY_LOSSLESS = 2, OKP_VISUALLY_LOSSLESS = 3, OKP_LOSSY = 4, OKP_LOSSY2 = 5, OKP_LOSSY3 = 6, OKP_EPJE = 7 } |
| ossimKakaduCompressorInterface () | |
| GP: I had to add this or windows would not link with the latest compiler. More... | |
| virtual void | create (ossim::ostream *os, ossimScalarType scalar, ossim_uint32 bands, const ossimIrect &imageRect, const ossimIpt &tileSize, ossim_uint32 tilesToWrite, bool jp2)=0 |
| Create method. More... | |
| virtual bool | writeTile (ossimImageData &srcTile)=0 |
| Write tile method. More... | |
| virtual void | finish ()=0 |
| Finish method. More... | |
| virtual void | setAlphaChannelFlag (bool flag)=0 |
| Set the writer to add an alpha channel to the output. More... | |
| virtual void | setLevels (ossim_int32 levels)=0 |
| Sets the number of levels. More... | |
| virtual bool | setProperty (ossimRefPtr< ossimProperty > property)=0 |
| Will set the property whose name matches the argument "property->getName()". More... | |
| virtual void | setQualityType (ossimKakaduCompressionQuality type)=0 |
| Sets the quality type. More... | |
Definition at line 29 of file ossimKakaduCompressorInterface.h.
| Enumerator | |
| OKP_UNKNOWN | |
| OKP_USER_DEFINED | |
| OKP_NUMERICALLY_LOSSLESS | |
| OKP_VISUALLY_LOSSLESS | |
| OKP_LOSSY | |
| OKP_LOSSY2 | |
| OKP_LOSSY3 | |
| OKP_EPJE | |
Definition at line 34 of file ossimKakaduCompressorInterface.h.
| ossimKakaduCompressorInterface::ossimKakaduCompressorInterface | ( | ) |
Also had to put in dot.cpp for debug mode(again windows). (drb)
Definition at line 18 of file ossimKakaduCompressorInterface.cpp.
pure virtual |
Create method.
| os | Stream to write to. |
| scalar | Scalar type of source tiles to be fed to compressor. |
| bands | Number of bands in source tiles to be fed to compressor. |
| imageRect | The image rectangle. |
| tileSize | The size of a tile. |
| tilesTileWrite | The number of tiles to be written. If zero, the tlm marker segment will not be used. |
| jp2 | If true jp2 header and jp2 geotiff block will be written out. |
Implemented in ossimKakaduCompressor.
pure virtual |
Finish method.
Every call to "create" should be matched by a "finish". Note the destructor calls finish.
pure virtual |
| flag | true to create an alpha channel. |
pure virtual |
This must be positive and at least 1. Default = 5 ( r0 - r5 )
| levels | Levels to set. |
pure virtual |
| property | Object containing property to set. |
pure virtual |
Type enumerations: OKP_UNKNOWN = 0, OKP_USER_DEFINED = 1, OKP_NUMERICALLY_LOSSLESS = 2, OKP_VISUALLY_LOSSLESS = 3, OKP_EPJE = 4
| type | See enumeration for types. |
pure virtual |
Write tile method.
Writes tiles stream provided to create method. Note that tiles should be fed to compressor in left to right, top to bottom order.
| srcTile | The source tile to write. |
