#include <ossimXmlDocument.h>
| ossimXmlDocument (const ossimFilename &xmlFileName="") | |
| ossimXmlDocument (const ossimXmlDocument &src) | |
| virtual | ~ossimXmlDocument () |
| bool | write (const ossimFilename &file) |
| bool | openFile (const ossimFilename &filename) |
| bool | read (std::istream &in) |
| void | findNodes (const ossimString &xpath, std::vector< ossimRefPtr< ossimXmlNode > > &nodelist) const |
| Appends any matching nodes to the list supplied (should be empty): More... | |
| void | initRoot (ossimRefPtr< ossimXmlNode > node) |
| ossimRefPtr< ossimXmlNode > | getRoot () |
| const ossimRefPtr< ossimXmlNode > | getRoot () const |
| ossimRefPtr< ossimXmlNode > | removeRoot () |
| void | fromKwl (const ossimKeywordlist &kwl) |
| void | toKwl (ossimKeywordlist &kwl, const ossimString &prefix="") const |
| ossimObject () | |
| bool | hasError () const |
Private Member Functions | |
| bool | readHeader (std::istream &in) |
Private Attributes | |
| ossimRefPtr< ossimXmlNode > | theRootNode |
| ossimString | theXmlHeader |
| ossimFilename | theFilename |
| bool | theStrictCheckFlag |
Friends | |
| OSSIMDLLEXPORT friend std::ostream & | operator<< (std::ostream &os, const ossimXmlDocument &xml_doc) |
Definition at line 24 of file ossimXmlDocument.h.
| ossimXmlDocument::ossimXmlDocument | ( | const ossimFilename & | xmlFileName = "" | ) |
Definition at line 49 of file ossimXmlDocument.cpp.
| ossimXmlDocument::ossimXmlDocument | ( | const ossimXmlDocument & | src | ) |
Definition at line 61 of file ossimXmlDocument.cpp.
Definition at line 71 of file ossimXmlDocument.cpp.
inlinevirtual |
Definition at line 30 of file ossimXmlDocument.h.
| void ossimXmlDocument::findNodes | ( | const ossimString & | xpath, |
| std::vector< ossimRefPtr< ossimXmlNode > > & | nodelist | ||
| ) | const |
Definition at line 172 of file ossimXmlDocument.cpp.
References theRootNode, and ossimRefPtr< T >::valid().
Referenced by ossimGmlSupportData::addLineSamps(), ossimGmlSupportData::addScale(), ossimGmlSupportData::addTie(), ossimFgdcFileWriter::find(), ossimplugins::ossimTerraSarProductDoc::getCommonPrf(), ossimplugins::ossimTerraSarProductDoc::getCommonRsf(), ossimplugins::ossimTerraSarProductDoc::getImageDataStrartWith(), ossimGmlSupportData::getImageGeometryFromRectifiedGrid(), ossimGmlSupportData::getImageGeometryFromSeonsorModel(), ossimFgdcXmlDoc::getImageSize(), ossimplugins::ossimTerraSarProductDoc::getNumberOfAzimuthLooks(), ossimplugins::ossimTerraSarProductDoc::getNumberOfRangeLooks(), ossimplugins::ossim::getPath(), ossimAuxXmlSupportData::getPath(), ossimXmpInfo::getPath(), ossimFgdcXmlDoc::getPath(), ossimplugins::ossimTerraSarModel::getPolLayerFromImageFile(), ossimplugins::ossimTerraSarModel::initCalibration(), ossimSpotDimapSupportData::initFramePoints(), ossimFormosatDimapSupportData::initFramePoints(), ossimAuxXmlSupportData::initializeProjection(), ossimSpotDimapSupportData::initImageId(), ossimFormosatDimapSupportData::initImageId(), ossimplugins::ossimRadarSat2Model::InitLut(), ossimSpotDimapSupportData::initMetadataVersion(), ossimFormosatDimapSupportData::initMetadataVersion(), ossimplugins::ossimTerraSarModel::initNoise(), ossimplugins::ossimTerraSarProductDoc::initNoise(), ossimplugins::ossimTerraSarProductDoc::initPlatformPosition(), ossimplugins::ossimRadarSat2Model::InitRefNoiseLevel(), ossimplugins::ossimTerraSarProductDoc::initSceneCoord(), ossimSpotDimapSupportData::initSceneSource(), ossimFormosatDimapSupportData::initSceneSource(), ossimplugins::ossimTerraSarModel::initSRGR(), ossimplugins::ossimRadarSat2Model::initSRGR(), ossimplugins::ossimTerraSarProductDoc::initTiePoints(), ossimNitfXmlDataContentDes::loadValueFromXml(), ossimplugins::ossimSpot6DimapSupportData::parseDatasetContent(), ossimplugins::ossimPleiadesDimapSupportData::parseDatasetContent(), ossimplugins::ossimSpot6DimapSupportData::parseGeometricData(), ossimplugins::ossimPleiadesDimapSupportData::parseGeometricData(), ossimplugins::ossimSpot6DimapSupportData::parseMetadataIdentificationDIMAPv2(), ossimplugins::ossimPleiadesDimapSupportData::parseMetadataIdentificationDIMAPv2(), ossimSpotDimapSupportData::parsePart1(), ossimFormosatDimapSupportData::parsePart1(), ossimFormosatDimapSupportData::parsePart2(), ossimSpotDimapSupportData::parsePart2(), ossimFormosatDimapSupportData::parsePart3(), ossimSpotDimapSupportData::parsePart3(), ossimFormosatDimapSupportData::parsePart4(), ossimSpotDimapSupportData::parsePart4(), ossimplugins::ossimSpot6DimapSupportData::parseRadiometricData(), ossimplugins::ossimPleiadesDimapSupportData::parseRadiometricData(), ossimplugins::ossimSpot6DimapSupportData::parseRasterData(), ossimplugins::ossimPleiadesDimapSupportData::parseRasterData(), ossimplugins::ossimSpot6DimapSupportData::parseRPCMetadata(), ossimplugins::ossimPleiadesDimapSupportData::parseRPCMetadata(), and ossimTiffInfo::printXmpMetadata().
| void ossimXmlDocument::fromKwl | ( | const ossimKeywordlist & | kwl | ) |
Definition at line 288 of file ossimXmlDocument.cpp.
References ossimXmlNode::addAttribute(), ossimXmlNode::addNode(), ossimString::contains(), ossimXmlNode::getChildNodes(), ossimKeywordlist::getMap(), ossimXmlNode::getParentNode(), ossimXmlNode::getTag(), ossimXmlNode::getText(), ossimXmlNode::removeChild(), ossimXmlNode::setTag(), ossimXmlNode::setText(), ossimString::substitute(), and theRootNode.
Referenced by ossimSubImageTool::execute(), and ossimInfo::outputXml().
| ossimRefPtr< ossimXmlNode > ossimXmlDocument::getRoot | ( | ) |
Definition at line 268 of file ossimXmlDocument.cpp.
References theRootNode.
Referenced by ossimKmlSuperOverlayReader::open(), ossimKakaduJpipInfo::print(), ossimWmsCapabilitiesDocument::read(), and ossimPpjFrameSensorFile::readStream().
| const ossimRefPtr< ossimXmlNode > ossimXmlDocument::getRoot | ( | ) | const |
Definition at line 273 of file ossimXmlDocument.cpp.
| void ossimXmlDocument::initRoot | ( | ossimRefPtr< ossimXmlNode > | node | ) |
Definition at line 263 of file ossimXmlDocument.cpp.
Referenced by ossimGmlSupportData::initialize(), and ossimKakaduJpipInfo::print().
| bool ossimXmlDocument::openFile | ( | const ossimFilename & | filename | ) |
Definition at line 91 of file ossimXmlDocument.cpp.
References ossimString::c_str(), and theFilename.
Referenced by ossimplugins::ossimRadarSat2TiffReader::getInternalImageGeometry(), ossimplugins::ossimTerraSarTiffReader::getInternalImageGeometry(), ossimplugins::ossimRadarSat2Model::InitLut(), ossimplugins::ossimRadarSat2TiffReader::isRadarSat2ProductFile(), ossimplugins::ossimTerraSarTiffReader::isTerraSarProductFile(), ossimplugins::ossimRadarSat2TiffReader::open(), ossimplugins::ossimTerraSarTiffReader::open(), ossimplugins::ossimRadarSat2RPCModel::open(), ossimplugins::ossimTerraSarModel::open(), ossimplugins::ossimRadarSat2Model::open(), and ossimFgdcFileWriter::setTemplate().
| bool ossimXmlDocument::read | ( | std::istream & | in | ) |
Definition at line 121 of file ossimXmlDocument.cpp.
References ossimString::contains(), readHeader(), ossimErrorStatusInterface::setErrorStatus(), theStrictCheckFlag, and theXmlHeader.
Referenced by ossimXmpInfo::getDate(), ossimAuxXmlSupportData::getProjection(), ossimXmpInfo::getProjection(), ossimKmlSuperOverlayReader::getTopLevelKmlFileInfo(), ossimGmlSupportData::initialize(), ossimNitfXmlDataContentDes::parseStream(), ossimplugins::ossimSpot6DimapSupportData::parseXmlFile(), ossimplugins::ossimPleiadesDimapSupportData::parseXmlFile(), ossimKakaduJpipInfo::print(), ossimTiffInfo::printXmpMetadata(), ossimWmsCapabilitiesDocument::read(), and ossimPpjFrameSensorFile::readStream().
private |
Definition at line 376 of file ossimXmlDocument.cpp.
References ossimString::clear(), and theXmlHeader.
Referenced by read().
| ossimRefPtr< ossimXmlNode > ossimXmlDocument::removeRoot | ( | ) |
Definition at line 278 of file ossimXmlDocument.cpp.
| void ossimXmlDocument::toKwl | ( | ossimKeywordlist & | kwl, |
| const ossimString & | prefix = "" |
| ) | const |
Definition at line 359 of file ossimXmlDocument.cpp.
References theRootNode, ossimXmlNode::toKwl(), and ossimRefPtr< T >::valid().
Referenced by ossimKakaduJpipInfo::print().
| bool ossimXmlDocument::write | ( | const ossimFilename & | file | ) |
Definition at line 75 of file ossimXmlDocument.cpp.
References ossimString::c_str().
friend |
private |
Definition at line 58 of file ossimXmlDocument.h.
Referenced by openFile().
private |
Definition at line 56 of file ossimXmlDocument.h.
Referenced by findNodes(), fromKwl(), getRoot(), initRoot(), operator<<(), removeRoot(), and toKwl().
private |
Definition at line 59 of file ossimXmlDocument.h.
private |
Definition at line 57 of file ossimXmlDocument.h.
Referenced by operator<<(), read(), and readHeader().
