Pure virtual base class for all video sources – analogous to ossimImageSource. More...
#include <ossimVideoSource.h>
Public Types | |
| enum | SeekType { SEEK_NONE = 0, SEEK_RELATIVE = 1, SEEK_ABSOLUTE = 2 } |
| virtual void | rewind () |
| For rewinding all active streams to beginning. More... | |
| virtual bool | seek (ossim_float64 reference_time_sec, SeekType seekType) |
| Seeks to the frame at time specified, according to the seekType (relative to active frame or absolute time from start of video). More... | |
| virtual bool | nextFrame () |
| Seeks to start of next frame. Returns TRUE if successful. More... | |
| virtual ossim_float64 | duration () const |
| Total length of video in seconds. More... | |
| virtual ossim_uint32 | getNumberOfFrames () const |
| Total number of frames in video. More... | |
| virtual ossim_float64 | currentFrameTime () const |
| Time in seconds from start of video of the current active frame, or NAN if no active frame. More... | |
| virtual ossim_float64 | videoFrameRate () const |
| Nominal frames per second. More... | |
| int | computeFrameNumber (double seconds_from_start) const |
| Utility method for computing frame number from frame time. More... | |
| double | computeFrameTime (ossim_uint32 frame_count) const |
| Utility method for computing frame time from frame number. More... | |
| virtual const ossimRefPtr< ossimVideoGeometry > | getVideoGeometry () const |
| Access to video geometry object. More... | |
| virtual const ossimRefPtr< ossimVideoImageHandler > | getCurrentFrame () const |
| Access to current active frame. More... | |
| const ossimIpt & | frameSize () const |
| Nominal size of a frame in pixels. More... | |
| virtual bool | canConnectMyInputTo (ossim_int32 index, const ossimConnectableObject *object) const |
| Connections only to other video sources are allowed. More... | |
| virtual bool | canConnectMyOutputTo (ossim_int32 index, const ossimConnectableObject *object) const |
| Presently can only connect into an image chain via an ossimVideoImageSource bridge, or to another video source for video chains. More... | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ossimVideoSource () | |
| Default constructor. More... | |
Protected Attributes | |
| ossimIpt | m_frameSize |
| in pixels More... | |
Protected Attributes inherited from ossimSource | |
| bool | theEnableFlag |
| bool | theInitializedFlag |
Protected Attributes inherited from ossimConnectableObject | |
| ossimId | theId |
| ossimString | theDescription |
| ossimObject * | theOwner |
| bool | theInputListIsFixedFlag |
| Indicates whether the theInputObjectList is fixed. More... | |
| bool | theOutputListIsFixedFlag |
| Indicates whether the theOutputObjectList is fixed. More... | |
| ConnectableObjectList | theInputObjectList |
| Holds a list of input objects. More... | |
| ConnectableObjectList | theOutputObjectList |
| Holds a list of output objects. More... | |
Protected Attributes inherited from ossimListenerManager | |
| std::list< ossimListener * > | theListenerList |
| bool | theEnabledFlag |
| std::list< ossimListener * > | theDelayedAdd |
| std::list< ossimListener * > | theDelayedRemove |
| bool | theFireEventFlag |
Definition at line 27 of file ossimVideoSource.h.
| Enumerator | |
| SEEK_NONE | |
| SEEK_RELATIVE | |
| SEEK_ABSOLUTE | |
Definition at line 31 of file ossimVideoSource.h.
protected |
Implements ossimConnectableObject.
Reimplemented in ossimVideoHandler.
Definition at line 155 of file ossimVideoSource.cpp.
References PTR_CAST.
Returns TRUE if connection possible.
Reimplemented from ossimConnectableObject.
Definition at line 168 of file ossimVideoSource.cpp.
| int ossimVideoSource::computeFrameNumber | ( | double | seconds_from_start | ) | const |
Definition at line 131 of file ossimVideoSource.cpp.
References videoFrameRate().
Referenced by ossimVideoImageHandler::getNumberOfEntries(), and getNumberOfFrames().
| double ossimVideoSource::computeFrameTime | ( | ossim_uint32 | frame_count | ) | const |
Definition at line 143 of file ossimVideoSource.cpp.
References ossim::nan(), and videoFrameRate().
Referenced by ossimVideoImageHandler::getImageGeometry(), and ossimVideoImageHandler::setCurrentEntry().
Definition at line 76 of file ossimVideoSource.cpp.
References currentFrameTime(), ossimConnectableObject::getInput(), and PTR_CAST.
Referenced by currentFrameTime().
Definition at line 64 of file ossimVideoSource.cpp.
References duration(), ossimConnectableObject::getInput(), and PTR_CAST.
Referenced by duration(), getNumberOfFrames(), and ossimVideoImageSource::setFrameTime().
inline |
Definition at line 81 of file ossimVideoSource.h.
Referenced by ossimVideoImageHandler::getNumberOfLines(), ossimVideoImageHandler::getNumberOfSamples(), and ossimVideoImageSource::initialize().
Definition at line 112 of file ossimVideoSource.cpp.
Definition at line 121 of file ossimVideoSource.cpp.
References computeFrameNumber(), and duration().
Definition at line 100 of file ossimVideoSource.cpp.
References ossimConnectableObject::getInput(), getVideoGeometry(), and PTR_CAST.
Referenced by ossimVideoImageSource::getImageGeometry(), and getVideoGeometry().
Definition at line 52 of file ossimVideoSource.cpp.
References ossimConnectableObject::getInput(), nextFrame(), and PTR_CAST.
Referenced by nextFrame().
Definition at line 29 of file ossimVideoSource.cpp.
References ossimConnectableObject::getInput(), PTR_CAST, and rewind().
Referenced by rewind().
Definition at line 40 of file ossimVideoSource.cpp.
References ossimConnectableObject::getInput(), PTR_CAST, and seek().
Referenced by seek(), and ossimVideoImageSource::setFrameTime().
Definition at line 88 of file ossimVideoSource.cpp.
References ossimConnectableObject::getInput(), PTR_CAST, and videoFrameRate().
Referenced by computeFrameNumber(), computeFrameTime(), and videoFrameRate().
protected |
in pixels
Definition at line 97 of file ossimVideoSource.h.
