Pure virtual base class for all video file handlers – analogous to ossimImageHandler. More...
#include <ossimVideoHandler.h>
| virtual bool | open (const ossimFilename &videoFile) |
| Returns TRUE if video file named is successfully opened. More... | |
| virtual bool | open ()=0 |
| Returns TRUE if video file at m_videoFilename is successfully opened. More... | |
| virtual void | close ()=0 |
| Closes video file. More... | |
| virtual bool | isOpen () const =0 |
| Returns TRUE if video file is open. More... | |
| const ossimFilename & | filename () const |
| Returns filename of previously opened video file. More... | |
| virtual void | rewind () |
| For rewinding all active streams to beginning. More... | |
| virtual bool | seek (ossim_float64 reference_time_sec, SeekType seekType)=0 |
| Seeks to the frame at time specified, according to the seekType (relative to active frame or absolute time from start of video). More... | |
| virtual const ossimRefPtr< ossimVideoGeometry > | getVideoGeometry () const |
| Access to video geometry object. More... | |
| ossim_float64 | currentFrameTime () const |
| Time in seconds from start of video of the current active frame, or NAN if no active frame. More... | |
| ossim_float64 | videoFrameRate () const |
| Nominal frames per second. More... | |
| ossim_float64 | duration () const |
| Total length of video in seconds. More... | |
| virtual bool | canConnectMyInputTo (ossim_int32, const ossimConnectableObject *) const |
| This object does not accept inputs. More... | |
Public Member Functions inherited from ossimVideoSource | |
| virtual bool | nextFrame () |
| Seeks to start of next frame. Returns TRUE if successful. More... | |
| virtual ossim_uint32 | getNumberOfFrames () const |
| Total number of frames in video. More... | |
| int | computeFrameNumber (double seconds_from_start) const |
| Utility method for computing frame number from frame time. More... | |
| double | computeFrameTime (ossim_uint32 frame_count) const |
| Utility method for computing frame time from frame number. More... | |
| virtual const ossimRefPtr< ossimVideoImageHandler > | getCurrentFrame () const |
| Access to current active frame. More... | |
| const ossimIpt & | frameSize () const |
| Nominal size of a frame in pixels. More... | |
| virtual bool | canConnectMyOutputTo (ossim_int32 index, const ossimConnectableObject *object) const |
| Presently can only connect into an image chain via an ossimVideoImageSource bridge, or to another video source for video chains. More... | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ossimVideoHandler () | |
| Default constructor. More... | |
Protected Member Functions inherited from ossimVideoSource | |
| ossimVideoSource () | |
Public Types inherited from ossimVideoSource | |
| enum | SeekType { SEEK_NONE = 0, SEEK_RELATIVE = 1, SEEK_ABSOLUTE = 2 } |
Definition at line 25 of file ossimVideoHandler.h.
protected |
Definition at line 20 of file ossimVideoHandler.cpp.
inlinevirtual |
Reimplemented from ossimVideoSource.
Definition at line 73 of file ossimVideoHandler.h.
pure virtual |
Closes video file.
inlinevirtual |
Definition at line 61 of file ossimVideoHandler.h.
inlinevirtual |
Definition at line 67 of file ossimVideoHandler.h.
Referenced by ossimVideoImageHandler::getNumberOfEntries().
inline |
Definition at line 45 of file ossimVideoHandler.h.
inlinevirtual |
Definition at line 58 of file ossimVideoHandler.h.
pure virtual |
Definition at line 38 of file ossimVideoHandler.cpp.
References m_videoFilename, and open().
pure virtual |
Referenced by open().
Definition at line 30 of file ossimVideoHandler.cpp.
References seek(), and ossimVideoSource::SEEK_ABSOLUTE.
pure virtual |
Referenced by rewind(), and ossimVideoImageHandler::setCurrentEntry().
inlinevirtual |
Definition at line 64 of file ossimVideoHandler.h.
protected |
Definition at line 81 of file ossimVideoHandler.h.
protected |
in frames per second
Definition at line 83 of file ossimVideoHandler.h.
mutableprotected |
in seconds
Definition at line 82 of file ossimVideoHandler.h.
protected |
Definition at line 79 of file ossimVideoHandler.h.
protected |
Definition at line 80 of file ossimVideoHandler.h.
