Pure virtual base class for all video data.
More...
#include <ossimVideoGeometry.h>
| virtual bool | sensorPosition (const double &t, ossimGpt &gpt) const =0 |
| | Provides platform position in lat, lon, hgt given frame time in seconds since start of sequence. More...
| virtual bool | sensorAttitude (const double &t, double &X_deg, double &Y_deg, double &Z_deg) const =0 |
| | Provides platform attitude in degrees given frame time in seconds since start of sequence sequence. More...
| virtual bool | sensorFocalLength (const double &t, double &focal_len_meters) const =0 |
| | Provides focal length in meters given frame time in seconds since start of sequence. More...
| virtual bool | frameCenter (const double &t, ossimGpt ¢erGpt) const =0 |
| | Provides scene center position in lat, lon, hgt given frame time in seconds since start of sequence. More...
| virtual bool | frameBoundingPoly (const double &t, ossimPolygon &geo_poly) const =0 |
| | Provides scene corner points in lat, lon given frame time in seconds since start of sequence. More...
| virtual bool | videoBoundingRect (ossimDrect &geo_rect) const =0 |
| | Provides the bounding rect that covers all frames in the full video. More...
| virtual const ossimIpt & | frameSize () const =0 |
| | Access method returns number of pixels in a frame. More...
| virtual ossimRefPtr< ossimImageGeometry > | getImageGeometry (const double &t)=0 |
| | Provides an image geometry object for frame at specified time in seconds since start of sequence. More...
| | ossimReferenced () |
| | ossimReferenced (const ossimReferenced &) |
| | increment the reference count by one, indicating that this object has another pointer which is referencing it. More...
| | decrement the reference count by one, indicating that a pointer to this object is referencing it. More...
Definition at line 28 of file ossimVideoGeometry.h.
◆ ossimVideoGeometry() [1/2]
◆ ossimVideoGeometry() [2/2]
| ossimVideoGeometry::ossimVideoGeometry |
inlineprotected |
◆ frameBoundingPoly()
| virtual bool ossimVideoGeometry::frameBoundingPoly |
const double & |
t, |
ossimPolygon & |
geo_poly |
| const |
pure virtual |
Returns TRUE if polygon valid.
◆ frameCenter()
| virtual bool ossimVideoGeometry::frameCenter |
const double & |
t, |
ossimGpt & |
centerGpt |
| const |
pure virtual |
Returns TRUE if point valid.
◆ frameSize()
| virtual const ossimIpt& ossimVideoGeometry::frameSize |
const |
pure virtual |
◆ getImageGeometry()
◆ sensorAttitude()
| virtual bool ossimVideoGeometry::sensorAttitude |
const double & |
t, |
double & |
X_deg, |
double & |
Y_deg, |
double & |
Z_deg |
| const |
pure virtual |
Returns TRUE if parameters valid. The coordinate system is defined by the derived class (can represent for example Euler rotations about an ECF, ENU or roll, pitch, heading)
◆ sensorFocalLength()
| virtual bool ossimVideoGeometry::sensorFocalLength |
const double & |
t, |
double & |
focal_len_meters |
| const |
pure virtual |
◆ sensorPosition()
| virtual bool ossimVideoGeometry::sensorPosition |
const double & |
t, |
ossimGpt & |
gpt |
| const |
pure virtual |
◆ videoBoundingRect()
| virtual bool ossimVideoGeometry::videoBoundingRect |
ossimDrect & |
geo_rect | ) |
const |
pure virtual |
Returns TRUE if rect valid.
◆ m_video
The documentation for this class was generated from the following file:
