#include <ossimMiscProjectionFactory.h>
| virtual ossimProjection * | createProjection (const ossimFilename &filename, ossim_uint32 entryIdx) const |
| virtual ossimProjection * | createProjection (const ossimString &name) const |
| Take a projection type name. More... | |
| virtual ossimProjection * | createProjection (const ossimKeywordlist &kwl, const char *prefix=0) const |
| Take a keywordlist. More... | |
| virtual ossimObject * | createObject (const ossimString &typeName) const |
| virtual ossimObject * | createObject (const ossimKeywordlist &kwl, const char *prefix=0) const |
| virtual void | getTypeNameList (std::vector< ossimString > &typeList) const |
Public Member Functions inherited from ossimProjectionFactoryBase | |
| virtual ossimProjection * | createProjection (ossimImageHandler *handler) const |
Public Member Functions inherited from ossimObjectFactory | |
| virtual | ~ossimObjectFactory () |
| ossimObject () | |
| static ossimMiscProjectionFactory * | instance () |
| ossimMiscProjectionFactory () | |
Protected Member Functions inherited from ossimProjectionFactoryBase | |
| ossimProjection * | createProjectionFromGeometryFile (const ossimFilename &imageFile, ossim_uint32 entryIdx) const |
| This method takes the filename and tries to find an external ".geom" file. More... | |
Static Protected Attributes | |
| static ossimMiscProjectionFactory * | theInstance = 0 |
Definition at line 24 of file ossimMiscProjectionFactory.h.
inlineprotected |
Creates an object given a type name.
Implements ossimObjectFactory.
Definition at line 156 of file ossimMiscProjectionFactory.cpp.
References createProjection().
Creates and object given a keyword list.
Definition at line 165 of file ossimMiscProjectionFactory.cpp.
METHOD: create() Attempts to create an instance of the projection specified by name. Returns successfully constructed projection or NULL.
Implements ossimProjectionFactoryBase.
Definition at line 59 of file ossimMiscProjectionFactory.cpp.
References ossimProjectionFactoryBase::createProjectionFromGeometryFile().
Referenced by createObject(), and createProjection().
Definition at line 115 of file ossimMiscProjectionFactory.cpp.
References STATIC_TYPE_NAME.
Take a keywordlist.
Definition at line 71 of file ossimMiscProjectionFactory.cpp.
References ossimKeywordlist::addFile(), createProjection(), ossimKeywordlist::find(), ossimProjection::loadState(), and ossimKeywordNames::TYPE_KW.
This should return the type name of all objects in all factories. This is the name used to construct the objects dynamially and this name must be unique.
Definition at line 174 of file ossimMiscProjectionFactory.cpp.
static |
METHOD: instance() Instantiates singleton instance of this class:
Definition at line 48 of file ossimMiscProjectionFactory.cpp.
References ossimMiscProjectionFactory(), and theInstance.
Referenced by ossimProjectionFactoryRegistry::initializeDefaults().
staticprotected |
Definition at line 61 of file ossimMiscProjectionFactory.h.
Referenced by instance().
