#include <ossimTiffProjectionFactory.h>
| virtual ossimProjection * | createProjection (const ossimFilename &filename, ossim_uint32 entryIdx) const |
| takes a filename. More... | |
| virtual ossimProjection * | createProjection (const ossimString &name) const |
| virtual ossimProjection * | createProjection (const ossimKeywordlist &kwl, const char *prefix=0) const |
| Take a keywordlist. More... | |
| ossimProjection * | createProjection (ossimImageHandler *handler) const |
| virtual ossimObject * | createObject (const ossimString &typeName) const |
| virtual ossimObject * | createObject (const ossimKeywordlist &kwl, const char *prefix=0) const |
| virtual void | getTypeNameList (std::vector< ossimString > &typeList) const |
Public Member Functions inherited from ossimObjectFactory | |
| virtual | ~ossimObjectFactory () |
| ossimObject () | |
| static ossimTiffProjectionFactory * | instance () |
| ossimTiffProjectionFactory () | |
| bool | isTiff (const ossimFilename &filename) const |
Protected Member Functions inherited from ossimProjectionFactoryBase | |
| ossimProjection * | createProjectionFromGeometryFile (const ossimFilename &imageFile, ossim_uint32 entryIdx) const |
| This method takes the filename and tries to find an external ".geom" file. More... | |
Static Protected Attributes | |
| static ossimTiffProjectionFactory * | theInstance = 0 |
Definition at line 25 of file ossimTiffProjectionFactory.h.
inlineprotected |
Creates an object given a type name.
Implements ossimObjectFactory.
Definition at line 108 of file ossimTiffProjectionFactory.cpp.
References createProjection().
Creates and object given a keyword list.
Definition at line 113 of file ossimTiffProjectionFactory.cpp.
takes a filename.
This filename can be an image file or it can also be a ossim .geom file. It could be other forms of geom files as well. The factories job will be to determine what parser to use and return a projection if successful.
Implements ossimProjectionFactoryBase.
Definition at line 40 of file ossimTiffProjectionFactory.cpp.
References ossimGeoTiff::addImageGeometry(), ossimProjectionFactoryRegistry::createProjection(), ossimProjectionFactoryRegistry::instance(), and ossimGeoTiff::readTags().
Referenced by createObject().
METHOD: create() Attempts to create an instance of the projection specified by name. Returns successfully constructed projection or NULL.
Definition at line 74 of file ossimTiffProjectionFactory.cpp.
Take a keywordlist.
Definition at line 64 of file ossimTiffProjectionFactory.cpp.
Reimplemented from ossimProjectionFactoryBase.
Definition at line 79 of file ossimTiffProjectionFactory.cpp.
References ossimGeoTiff::addImageGeometry(), ossimProjectionFactoryRegistry::createProjection(), ossimImageHandler::getCurrentEntry(), ossimImageHandler::getState(), ossimProjectionFactoryRegistry::instance(), ossimGeoTiff::readTags(), and ossimTiffTileSource::tiffPtr().
This should return the type name of all objects in all factories. This is the name used to construct the objects dynamially and this name must be unique.
Definition at line 119 of file ossimTiffProjectionFactory.cpp.
static |
METHOD: instance() Instantiates singleton instance of this class:
Definition at line 29 of file ossimTiffProjectionFactory.cpp.
References ossimTiffProjectionFactory(), and theInstance.
Referenced by ossimProjectionFactoryRegistry::initializeDefaults().
protected |
Definition at line 123 of file ossimTiffProjectionFactory.cpp.
References ossimString::c_str().
staticprotected |
Definition at line 63 of file ossimTiffProjectionFactory.h.
Referenced by instance().
