#include <ossimNitfProjectionFactory.h>
| virtual | ~ossimNitfProjectionFactory () |
| destructor More... | |
| virtual ossimProjection * | createProjection (const ossimFilename &filename, ossim_uint32 entryIdx) const |
| virtual ossimProjection * | createProjection (const ossimString &name) const |
| virtual ossimProjection * | createProjection (const ossimKeywordlist &kwl, const char *prefix=0) const |
| virtual ossimProjection * | createProjection (ossimImageHandler *handler) const |
| virtual ossimObject * | createObject (const ossimString &typeName) const |
| Creates an object given a type name. More... | |
| virtual ossimObject * | createObject (const ossimKeywordlist &kwl, const char *prefix=0) const |
| Creates and object given a keyword list. More... | |
| virtual void | getTypeNameList (std::vector< ossimString > &typeList) const |
| This should return the type name of all objects in all factories. More... | |
Public Member Functions inherited from ossimObjectFactory | |
| virtual | ~ossimObjectFactory () |
| ossimObject () | |
| static ossimNitfProjectionFactory * | instance () |
| METHOD: instance() More... | |
Private Member Functions | |
| ossimProjection * | createProjectionFromHeaders (ossimNitfFileHeader *fileHeader, ossimNitfImageHeader *imageHeader) const |
| ossimProjection * | makeGeographic (const ossimNitfImageHeader *hdr, const ossimString &coordinateSysetm) const |
| ossimProjection * | makeUtm (const ossimNitfImageHeader *hdr, const ossimString &coordinateSysetm) const |
| ossimProjection * | makeEuiDistant (const ossimNitfImageHeader *hdr, const std::vector< ossimGpt > &gpts) const |
| ossimProjection * | makeBilinear (const ossimNitfImageHeader *hdr, const std::vector< ossimGpt > &gpts) const |
| void | parseGeographicString (const ossimString &geographicLocation, std::vector< ossimGpt > &gpts) const |
| Parses geographic stream. More... | |
| void | parseDecimalDegreesString (const ossimString &geographicLocation, std::vector< ossimGpt > &gpts) const |
| Parses Decimal degree stream. More... | |
| void | parseUtmString (const ossimString &utmLocation, ossim_uint32 &zone, std::vector< ossimDpt > &utmPoints) const |
| bool | parseMgrsString (const ossimString &mgrsLocationString, ossim_uint32 &zone, char &hemisphere, std::vector< ossimDpt > &utmPoints) const |
| Gets UTM points, zone and hemisphere from IGEOLO field when ICORDS files = U which is UTM expressed in MGRS. More... | |
| void | computeScaleInDecimalDegrees (const ossimNitfImageHeader *hdr, const std::vector< ossimGpt > &gpts, ossimDpt &scale) const |
| Computes the scale in decimal degrees with scale.x being longitude, y being latitude. More... | |
| void | computeScaleInMeters (const ossimNitfImageHeader *hdr, const std::vector< ossimDpt > &dpts, ossimDpt &scale) const |
| Computes the scale in meters with scale.x being easting, y being northing. More... | |
| bool | isSkewed (const std::vector< ossimGpt > &gpts) const |
| bool | isSkewed (const std::vector< ossimDpt > &gpts) const |
| bool | getBlockaPoints (const ossimNitfImageHeader *hdr, std::vector< ossimGpt > &gpts) const |
| bool | getGeolobPoints (const ossimNitfImageHeader *hdr, std::vector< ossimGpt > &gpts) const |
| ossimNitfProjectionFactory () | |
| Private constructor, users must go through instance() method. More... | |
| ossimNitfProjectionFactory (const ossimNitfProjectionFactory &obj) | |
| Private copy constructor to hide from use. More... | |
| ossimNitfProjectionFactory & | operator= (const ossimNitfProjectionFactory &rhs) |
| Private operator = to hide from use. More... | |
| bool | isNitf (const ossimFilename &filename) const |
Static Private Attributes | |
| static ossimNitfProjectionFactory * | theInstance = 0 |
Protected Member Functions inherited from ossimProjectionFactoryBase | |
| ossimProjection * | createProjectionFromGeometryFile (const ossimFilename &imageFile, ossim_uint32 entryIdx) const |
| This method takes the filename and tries to find an external ".geom" file. More... | |
Definition at line 27 of file ossimNitfProjectionFactory.h.
private |
Definition at line 37 of file ossimNitfProjectionFactory.cpp.
Referenced by instance().
private |
Definition at line 1113 of file ossimNitfProjectionFactory.cpp.
private |
| hdr | The nitf image header from the currently opened nitf file. |
| gpts | Four geographic corner points. |
| scale | Scale to initialize. |
Definition at line 828 of file ossimNitfProjectionFactory.cpp.
References ossimNitfImageHeader::getImageRect(), ossimIrect::height(), isSkewed(), ossimDpt::makeNan(), ossimIrect::width(), ossimDpt::x, and ossimDpt::y.
Referenced by makeEuiDistant().
private |
| dpts | Four utm corner points. |
Definition at line 875 of file ossimNitfProjectionFactory.cpp.
References ossimNitfImageHeader::getImageRect(), ossimIrect::height(), isSkewed(), ossimDpt::makeNan(), ossimIrect::width(), ossimDpt::x, x, ossimDpt::y, and y.
Implements ossimObjectFactory.
Definition at line 130 of file ossimNitfProjectionFactory.cpp.
References createProjection().
Definition at line 136 of file ossimNitfProjectionFactory.cpp.
| filename | This filename can be an image file or it can also be a ossim .geom file. It could be other forms of geom files as well. The factories job will be to determine what parser to use and return a projection if successful. |
Implements ossimProjectionFactoryBase.
Definition at line 56 of file ossimNitfProjectionFactory.cpp.
Referenced by createObject(), and createProjection().
| name | This would be a projection name. |
Definition at line 124 of file ossimNitfProjectionFactory.cpp.
| kwl | Keyword list to instantiate projection from. |
Definition at line 117 of file ossimNitfProjectionFactory.cpp.
Reimplemented from ossimProjectionFactoryBase.
Definition at line 147 of file ossimNitfProjectionFactory.cpp.
References createProjection(), createProjectionFromHeaders(), ossimImageHandler::getCurrentEntry(), ossimNitfTileSource::getCurrentImageHeader(), ossimNitfTileSource::getFileHeader(), ossimImageHandler::getFilename(), and isNitf().
private |
Definition at line 187 of file ossimNitfProjectionFactory.cpp.
References ossimNitfImageHeader::getCoordinateSystem(), ossimNitfFileHeader::getVersion(), makeGeographic(), and makeUtm().
Referenced by createProjection().
private |
| gpts | Ground points to initialize from BLOCKA tag. This should be an empty vector. |
Definition at line 670 of file ossimNitfProjectionFactory.cpp.
References ossimNitfImageHeader::getTagData().
Referenced by makeGeographic().
private |
| gpts | Ground points to initialize from GEOLOB tag. This should be an empty vector. |
Definition at line 747 of file ossimNitfProjectionFactory.cpp.
This is the name used to construct the objects dynamially and this name must be unique.
| typeList | List to append names to. |
Definition at line 142 of file ossimNitfProjectionFactory.cpp.
static |
METHOD: instance()
Definition at line 45 of file ossimNitfProjectionFactory.cpp.
References ossimNitfProjectionFactory(), and theInstance.
Referenced by ossimProjectionFactoryRegistry::initializeDefaults().
private |
Definition at line 169 of file ossimNitfProjectionFactory.cpp.
References ossimString::c_str().
private |
Definition at line 649 of file ossimNitfProjectionFactory.cpp.
Referenced by computeScaleInDecimalDegrees(), and computeScaleInMeters().
private |
Definition at line 660 of file ossimNitfProjectionFactory.cpp.
private |
Definition at line 617 of file ossimNitfProjectionFactory.cpp.
References ossimNitfImageHeader::getNumberOfCols(), ossimNitfImageHeader::getNumberOfRows(), and ossimRefPtr< T >::release().
private |
| hdr | The nitf image header. |
Definition at line 570 of file ossimNitfProjectionFactory.cpp.
References ossim::acosd(), computeScaleInDecimalDegrees(), ossimMapProjection::getOrigin(), ossimDpt::hasNans(), ossimGpt::lat, ossimGpt::latd(), ossimGpt::lond(), ossimMapProjection::setDecimalDegreesPerPixel(), ossimEquDistCylProjection::setOrigin(), ossimMapProjection::setUlTiePoints(), ossimDpt::x, x, and ossimDpt::y.
private |
| coordianteSystem | The coordinate system as a string. |
| geographicLocation | This should contain the four corner strings. |
Definition at line 207 of file ossimNitfProjectionFactory.cpp.
References getBlockaPoints(), ossimNitfImageHeader::getGeographicLocation(), getGeolobPoints(), and ossimString::size().
Referenced by createProjectionFromHeaders().
private |
Definition at line 344 of file ossimNitfProjectionFactory.cpp.
References ossimNitfImageHeader::getGeographicLocation(), parseMgrsString(), parseUtmString(), ossimString::size(), and status.
private |
Definition at line 1117 of file ossimNitfProjectionFactory.cpp.
private |
This will initialize the vector of ossimGpt's with the four corners. If the string geographicLocation is not the correct size the vector will be cleared.
| geographicLocation | String containing corners. |
| gpts | Vector to initialize. |
Definition at line 1066 of file ossimNitfProjectionFactory.cpp.
References ossimString::c_str(), and ossimString::toDouble().
private |
Definition at line 972 of file ossimNitfProjectionFactory.cpp.
References ossimString::c_str(), ossimDms::getDegrees(), ossimGpt::latd(), ossimGpt::lond(), ossimDms::setDegrees(), ossimDms::setLatFlag(), ossimString::size(), and SPACE.
private |
| mgrsLocationString | String from IGEOLO field. |
| zone | Initialized in method. |
| hemisphere | Initialized in method. |
| utmPoints | Initialized in method. |
Definition at line 518 of file ossimNitfProjectionFactory.cpp.
References Convert_OSSIM_MGRS_To_UTM(), n, ossimString::size(), and ossimString::substr().
Referenced by makeUtm().
private |
Definition at line 909 of file ossimNitfProjectionFactory.cpp.
References ossimString::begin(), ossimString::push_back(), ossimString::toDouble(), and ossimString::toUInt32().
staticprivate |
Definition at line 266 of file ossimNitfProjectionFactory.h.
