#include <ossimNgaProjectionFactory.h>
| virtual ossimProjection * | createProjection (const ossimFilename &filename, ossim_uint32 entryIdx) const |
| takes a filename. More... | |
| virtual ossimProjection * | createProjection (const ossimString &name) const |
| Take a projection type name. More... | |
| virtual ossimProjection * | createProjection (const ossimKeywordlist &kwl, const char *prefix) const |
| Take a keywordlist. More... | |
| virtual ossimObject * | createObject (const ossimString &typeName) const |
| virtual ossimObject * | createObject (const ossimKeywordlist &kwl, const char *prefix=0) const |
| virtual void | getTypeNameList (std::vector< ossimString > &typeList) const |
Public Member Functions inherited from ossimProjectionFactoryBase | |
| virtual ossimProjection * | createProjection (ossimImageHandler *handler) const |
Public Member Functions inherited from ossimObjectFactory | |
| virtual | ~ossimObjectFactory () |
| ossimObject () | |
| static ossimNgaProjectionFactory * | instance () |
| Implements singleton pattern. More... | |
| ossimNgaProjectionFactory () | |
| Constructor loads all SRS CSV files specified in the ossim prefs. More... | |
Protected Member Functions inherited from ossimProjectionFactoryBase | |
| ossimProjection * | createProjectionFromGeometryFile (const ossimFilename &imageFile, ossim_uint32 entryIdx) const |
| This method takes the filename and tries to find an external ".geom" file. More... | |
Definition at line 15 of file ossimNgaProjectionFactory.h.
inlineprotected |
Protected as part of singleton implementation.
Definition at line 60 of file ossimNgaProjectionFactory.h.
Creates an object given a type name.
Implements ossimObjectFactory.
Definition at line 71 of file ossimNgaProjectionFactory.cpp.
References createProjection().
Creates and object given a keyword list.
Definition at line 77 of file ossimNgaProjectionFactory.cpp.
takes a filename.
This filename can be an image file or it can also be a ossim .geom file. It could be other forms of geom files as well. The factories job will be to determine what parser to use and return a projection if successful.
Implements ossimProjectionFactoryBase.
Definition at line 34 of file ossimNgaProjectionFactory.cpp.
References ossimProjectionFactoryBase::createProjectionFromGeometryFile().
Referenced by createObject().
Definition at line 49 of file ossimNgaProjectionFactory.cpp.
References ossimString::after(), ossimEllipsoidFactory::create(), ossimEllipsoidFactory::instance(), and ossimString::toInt().
Take a keywordlist.
Definition at line 65 of file ossimNgaProjectionFactory.cpp.
This should return the type name of all objects in all factories. This is the name used to construct the objects dynamially and this name must be unique.
Definition at line 83 of file ossimNgaProjectionFactory.cpp.
static |
Definition at line 27 of file ossimNgaProjectionFactory.cpp.
Referenced by ossimProjectionFactoryRegistry::initializeDefaults().
