Projection Factory for coded projections defined in database. More...
#include <ossimWktProjectionFactory.h>
| virtual ossimProjection * | createProjection (const ossimFilename &filename, ossim_uint32 entryIdx) const |
| STUB. Not implemented. More... | |
| virtual ossimProjection * | createProjection (const ossimString &name) const |
| This is the principal factory method. More... | |
| virtual ossim_uint32 | getCode (const ossimString &name) |
| virtual ossimProjection * | createProjection (const ossimKeywordlist &kwl, const char *prefix=0) const |
| Looks for presence of "projection" keyword with the value in WKT format, for example "Anguilla_1957_British_West_Indies_Grid". More... | |
| virtual ossimObject * | createObject (const ossimString &typeName) const |
| virtual ossimObject * | createObject (const ossimKeywordlist &kwl, const char *prefix=0) const |
| virtual void | getTypeNameList (std::vector< ossimString > &typeList) const |
| This returns the type name of all objects in all factories. More... | |
Public Member Functions inherited from ossimProjectionFactoryBase | |
| virtual ossimProjection * | createProjection (ossimImageHandler *handler) const |
Public Member Functions inherited from ossimObjectFactory | |
| virtual | ~ossimObjectFactory () |
| ossimObject () | |
| static ossimWktProjectionFactory * | instance () |
| Implements singleton pattern. More... | |
| ossimWktProjectionFactory () | |
| Constructor loads the WKT CSV file specified in the ossim prefs with "wkt_database_file" keyword. More... | |
| ossimProjection * | doTransverseMercator (const ossimKeywordlist &kwl) const |
| ossimProjection * | doMercator (const ossimKeywordlist &kwl) const |
| ossimProjection * | doLambertConformalConic (const ossimKeywordlist &kwl) const |
| ossimProjection * | doEquiDistCylindrical (const ossimKeywordlist &kwl) const |
| ossimProjection * | doEquiAreaCylindrical (const ossimKeywordlist &kwl) const |
| void | loadRecords () const |
| Loads all SRS CSV files specified in the ossim prefs. More... | |
| template<class T > | |
| void | doMapCommon (const ossimKeywordlist &kwl, T proj) const |
Protected Member Functions inherited from ossimProjectionFactoryBase | |
| ossimProjection * | createProjectionFromGeometryFile (const ossimFilename &imageFile, ossim_uint32 entryIdx) const |
| This method takes the filename and tries to find an external ".geom" file. More... | |
Protected Attributes | |
| std::map< std::string, ossim_uint32 > | m_wktProjRecords |
Static Protected Attributes | |
| static ossimWktProjectionFactory * | m_instance = 0 |
| Singleton implementation. More... | |
These are projections that are fully defined in database files and specified via a projection coordinate system (PCS) code, such as EPSG codes.
Definition at line 27 of file ossimWktProjectionFactory.h.
inlineprotected |
Definition at line 61 of file ossimWktProjectionFactory.h.
Referenced by instance().
Creates an object given a type name.
Implements ossimObjectFactory.
Definition at line 298 of file ossimWktProjectionFactory.cpp.
References createProjection().
Creates and object given a keyword list.
Definition at line 304 of file ossimWktProjectionFactory.cpp.
Implements ossimProjectionFactoryBase.
Definition at line 313 of file ossimWktProjectionFactory.cpp.
Referenced by createObject(), createProjection(), and ossimPointCloudGeometry::ossimPointCloudGeometry().
It accepts a WKT string, for example "Anguilla_1957_British_West_Indies_Grid"
Definition at line 286 of file ossimWktProjectionFactory.cpp.
References createProjection(), ossimWkt::getKwl(), and ossimWkt::parse().
From keywordlist (as generated typically by ossimWkt class)
Definition at line 206 of file ossimWktProjectionFactory.cpp.
References ossimString::contains(), doEquiAreaCylindrical(), doEquiDistCylindrical(), doLambertConformalConic(), doMercator(), doTransverseMercator(), ossimString::downcase(), ossimString::empty(), ossimKeywordlist::find(), ossimEpsgProjectionDatabase::findProjection(), ossimString::gsub(), ossimEpsgProjectionDatabase::instance(), loadRecords(), m_wktProjRecords, ossimString::string(), ossimKeywordlist::stripPrefixFromAll(), ossimString::toString(), ossimString::toUInt32(), and ossimString::trim().
protected |
protected |
protected |
Definition at line 395 of file ossimWktProjectionFactory.cpp.
References ossimString::find(), ossimLambertConformalConicProjection::setStandardParallel1(), ossimLambertConformalConicProjection::setStandardParallel2(), ossimString::toDouble(), and ossimString::toString().
Referenced by createProjection().
protected |
Definition at line 441 of file ossimWktProjectionFactory.cpp.
References ossimString::contains(), ossimEpsgDatumFactory::create(), ossimString::empty(), ossimKeywordlist::find(), ossimEpsgDatumFactory::instance(), ossimGpt::lat, ossimGpt::lon, MTRS_PER_FT, OSSIM_FEET, ossimString::toDouble(), ossimString::toString(), and ossimString::toUInt32().
protected |
Definition at line 366 of file ossimWktProjectionFactory.cpp.
References ossimString::find(), ossimMercatorProjection::setScaleFactor(), ossimString::toDouble(), and ossimString::toString().
protected |
Definition at line 337 of file ossimWktProjectionFactory.cpp.
References ossimString::find(), ossimTransMercatorProjection::setScaleFactor(), ossimString::toDouble(), and ossimString::toString().
Definition at line 187 of file ossimWktProjectionFactory.cpp.
References loadRecords(), m_wktProjRecords, and ossimString::string().
This is the name used to construct the objects dynamically and this name must be unique.
Definition at line 323 of file ossimWktProjectionFactory.cpp.
References loadRecords(), and m_wktProjRecords.
static |
METHOD: instance() Instantiates singleton instance of this class:
Definition at line 75 of file ossimWktProjectionFactory.cpp.
References m_instance, and ossimWktProjectionFactory().
Referenced by ossimProjectionFactoryRegistry::initializeDefaults(), and ossimPointCloudGeometry::ossimPointCloudGeometry().
protected |
Definition at line 85 of file ossimWktProjectionFactory.cpp.
References ossimString::chars(), ossimFilename::dirCat(), getline(), ossimPreferences::instance(), ossimFilename::isReadable(), ossimFilename::isRelative(), ossimPreferences::preferencesKWL(), ossimString::size(), ossimString::string(), and ossimString::trim().
Referenced by createProjection(), getCode(), and getTypeNameList().
staticprotected |
Definition at line 73 of file ossimWktProjectionFactory.h.
mutableprotected |
Definition at line 74 of file ossimWktProjectionFactory.h.
